20ft Wyze Cam USB Extension Cable for High Mounting & Flexibility
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you're looking to mount your Wyze Cam at a higher vantage point or simply need more flexibility in camera placement, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This cable extends your camera's reach by 20 feet, allowing you to position your Wyze Cam exactly where you need it without worrying about power outlet proximity.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Length: A generous 20-foot length provides ample extension for indoor or outdoor mounting.
  • Ease of Use: Simply plug in to extend your existing USB power cable without any complicated setup.
  • Affordable: Priced at just $7.99, it’s a cost-effective solution to enhance your camera setup.
Say goodbye to short cables and enjoy the freedom to mount your Wyze Cam in the ideal location for optimal surveillance.
Why Use a USB Extension Cable for Your Wyze Cam?
Mounting your Wyze Cam higher or in hard-to-reach places can significantly improve your home security coverage. However, the standard 6-foot USB cable that comes with most Wyze Cams can limit your options. The 20ft USB extension cable solves this by:
  • Allowing placement on ceilings, high walls, or outdoor eaves.
  • Enabling discreet installation away from power outlets.
  • Providing flexibility for creative mounting solutions, such as using lamp sockets or other power sources.
Compatible Wyze Cameras for Extended Mounting
The Wyze Cam USB Extension Cable supports a wide range of Wyze cameras, making it a versatile accessory for your smart home security system.
Wyze Cam v4
  • Resolution: 2.5K QHD (2560x1440) for crystal-clear video.
  • Features: Color night vision, 115.8° field of view, built-in siren, and two-way audio.
  • Mounting: Supports stand, wall, ceiling, and magnetic mounts.
  • Power: Comes with a 6-foot USB cable, extendable with the 20ft extension for higher or distant mounting.
  • Zoom: 3x telephoto lens with 8x digital zoom.
  • Video: 1080p HD with quick live streaming and 3x faster notifications.
  • Weather Resistance: IP65 rating for indoor/outdoor use.
  • Mounting: Stand, wall, or ceiling mount options.
  • Power: Includes a 6-foot power cable, extendable with the USB extension cable.
Wyze Cam Pan v3
  • Coverage: 360° horizontal and 180° vertical pan and tilt.
  • Features: Motion tracking, color night vision, and two-way audio.
  • Power: Compatible with the USB extension cable for flexible placement.
Enhance Your Setup with the Cam v4 + Lamp Socket v2 Bundle
For those wanting to power their Wyze Cam v4 without relying on nearby outlets, the Cam v4 + Lamp Socket v2 Bundle offers a smart solution. This bundle allows you to power your camera through a standard lamp socket, perfect for outdoor lighting fixtures or hard-to-reach indoor locations.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Features: Motion-activated lights, dusk-to-dawn scheduling, and linkability without limits.
  • Installation: Easy screw-in E26 socket adapter.
  • Power: Supports 120V, 60Hz input with a max lamp power of 20W.
Using the USB extension cable in combination with this lamp socket bundle can give you ultimate flexibility in mounting and powering your Wyze Cam.
Summary: Why Choose the Wyze Cam USB Extension Cable?
  • Extended Reach: 20 feet of extra cable length for versatile mounting.
  • Wide Compatibility: Supports almost all Wyze Cam models.
  • Affordable and Easy: Simple plug-and-play extension at a budget-friendly price.
  • Improved Security: Position your camera for the best possible coverage.
Elevate your home security by mounting your Wyze Cam exactly where it’s needed most — high, out of reach, and with a clear view.
Home Security Camera Mounted High Mount your Wyze Cam at the perfect height with the 20ft USB extension cable. Smart Home Security Setup Combine Wyze Cam with smart accessories for comprehensive home protection. Outdoor Lighting with Wyze Cam Use the Cam v4 + Lamp Socket v2 Bundle for flexible outdoor camera placement.
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam by 20 feet, allowing you to mount your camera at higher vantage points or in locations farther from power outlets for optimal surveillance coverage.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
How long is the Wyze Cam USB extension cable?The Wyze Cam USB extension cable is 20 feet long, providing ample length for flexible camera placement indoors or outdoors.
Is the Wyze Cam USB extension cable easy to install?Yes, the Wyze Cam USB extension cable is easy to use. Simply plug it into your existing USB power cable—no complicated setup required.
How much does the Wyze Cam USB extension cable cost?The Wyze Cam USB extension cable is affordably priced at just $7.99, making it a cost-effective solution for extending your camera’s reach.
Why should I use a USB extension cable with my Wyze Cam?Using a USB extension cable allows you to mount your Wyze Cam on ceilings, high walls, or outdoor eaves, enabling discreet installation away from power outlets and providing flexibility for creative mounting solutions.
Can I use the Wyze Cam USB extension cable outdoors?Yes, the 20ft USB extension cable can be used for both indoor and outdoor camera mounting, especially when paired with weather-resistant Wyze Cam models like the Wyze Cam OG Telephoto.
Does the Wyze Cam v4 support the 20ft USB extension cable?Yes, the Wyze Cam v4 is compatible with the 20ft USB extension cable, allowing you to extend its standard 6-foot power cable for higher or more distant mounting.
What are the benefits of using the Cam v4 + Lamp Socket v2 Bundle?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 through a standard lamp socket, making it ideal for outdoor lighting fixtures or hard-to-reach indoor locations. It features motion-activated lights, dusk-to-dawn scheduling, and easy installation.
Can I use the USB extension cable with the Cam v4 + Lamp Socket v2 Bundle?Yes, you can use the 20ft USB extension cable in combination with the Cam v4 + Lamp Socket v2 Bundle for ultimate flexibility in mounting and powering your Wyze Cam.
How does the 20ft USB extension cable improve home security?By allowing you to position your Wyze Cam at the ideal height and location, the 20ft USB extension cable helps you achieve better coverage and improved security for your home.
What are the key features of the Wyze Cam USB Extension Cable?How does the USB extension cable improve the placement of my Wyze Cam?Do you have any ongoing sales or discounts for the USB extension cable?
