20ft USB Extension Cable for Wyze Cam – Continuous Power Support
USB Extension Cable for Wyze Cam – 20ft of Continuous Power
If you’re looking for a reliable USB extension cable that supports continuous power for your Wyze Cam during updates and everyday use, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This cable extends your camera’s reach without compromising power delivery, ensuring your Wyze Cam stays powered on even during firmware updates or long recording sessions.
Why Choose the Wyze Cam USB Extension Cable?
  • Length & Flexibility: At 20 feet, this USB extension cable gives you the freedom to position your Wyze Cam exactly where you need it, whether indoors or outdoors.
  • Compatibility: Works seamlessly with a wide range of Wyze Cam models including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam OG Standard and Telephoto.
  • Continuous Power Support: Designed to maintain stable power delivery, this cable ensures your camera won’t lose power during updates or extended use.
  • Durability: Built to last with quality materials that support consistent data transfer and power flow.
Say goodbye to short cables and power interruptions. Extend your Wyze Cam’s USB connection with confidence and enjoy uninterrupted security monitoring.
Enhance Your Wyze Cam Setup with the Latest Cameras
Pairing your Wyze Cam USB extension cable with the latest Wyze Cam models can maximize your home security experience. Here are some top Wyze Cam options compatible with the extension cable:
Wyze Cam v4
  • High-Resolution Video: 2.5K QHD (2560x1440) resolution for crystal-clear footage.
  • Advanced Night Vision: Features 4 IR LEDs and 2 white spotlight LEDs for color night vision.
  • Wide Field of View: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
  • Multiple Mounting Options: Stand, wall mount, ceiling mount, and magnetic adhesive mount.
  • Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for faster, more reliable connections.
  • Power: Comes with a 6-foot flat micro USB to USB-A cable, but can be extended with the 20ft USB extension cable for more flexible placement.
  • Durability: Weather-resistant with IP65 rating, suitable for indoor and outdoor use.
  • Smart Features: Alexa, Google Assistant, and IFTTT integration for voice control and automation.
Wyze Cam v4 Outdoor Bundle
  • Complete Outdoor Security: Includes Wyze Cam v4, outdoor power adapter, and 128GB microSD card.
  • Enhanced Color Night Vision: See vivid colors even in low light.
  • 24/7 Local Recording: Continuous recording with local storage.
  • Wi-Fi 6 Support: Ensures stable outdoor connectivity.
  • Motion and Sound Detection: Customizable detection zones and alerts.
  • Weatherproof: Designed specifically for outdoor use.
Power Your Wyze Cam with Convenience: Cam v4 + Lamp Socket v2 Bundle
For those who want to power their Wyze Cam without relying on traditional outlets, the Cam v4 + Lamp Socket v2 Bundle offers a smart solution:
  • Power Without an Outlet: Use your existing lamp socket (E26) to power your Wyze Cam v4 or compatible models.
  • Motion-Activated Lighting: The lamp socket supports dusk-to-dawn scheduling and motion-activated lights.
  • Compact and Easy to Install: Small form factor fits standard lamp sockets.
  • Compatibility: Works with Wyze Cam v3, v
What is the Wyze Cam USB Extension Cable and how long is it?The Wyze Cam USB Extension Cable is a 20-foot long cable designed to extend the reach of your Wyze Cam, allowing for flexible camera placement while ensuring continuous power delivery.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam OG Standard and Telephoto models.
Does the Wyze Cam USB Extension Cable support continuous power during firmware updates?Yes, the Wyze Cam USB Extension Cable is designed to provide stable, continuous power to your camera, even during firmware updates and long recording sessions.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the 20ft USB extension cable is built with durable materials, making it suitable for both indoor and outdoor Wyze Cam installations.
Can I use the Wyze Cam USB Extension Cable with the latest Wyze Cam v4?Absolutely. The Wyze Cam v4 comes with a 6-foot cable, but you can use the 20ft USB extension cable for more flexible placement and extended reach.
What are the benefits of using a USB extension cable with my Wyze Cam?Using a USB extension cable allows you to position your Wyze Cam exactly where you need it, eliminates the limitations of short cables, and ensures uninterrupted power for continuous security monitoring.
What features does the Wyze Cam v4 offer when paired with the USB extension cable?When paired with the USB extension cable, the Wyze Cam v4 offers high-resolution 2.5K QHD video, advanced night vision, a wide field of view, multiple mounting options, weather resistance (IP65), and smart home integration with Alexa, Google Assistant, and IFTTT.
Is there a solution to power my Wyze Cam without a traditional outlet?Yes, the Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam using a standard E26 lamp socket, providing a convenient alternative to traditional power outlets.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for 24/7 local recording, making it ideal for complete outdoor security.
