Unlimited Wyze Camera Licenses for Complete Home Surveillance
When it comes to securing your home with unlimited Wyze camera licenses, Wyze offers a comprehensive ecosystem of smart cameras, sensors, and professional monitoring services designed to provide complete home surveillance. Whether you want crystal-clear video, smart lighting integration, or 24/7 professional monitoring, Wyze has you covered with scalable solutions that grow with your needs.
Wyze Cam v4: The Ultimate Wired Security Camera
Experience unmatched home security with the
Wyze Cam v4, a wired camera that delivers stunning 2.5K QHD resolution for crystal-clear video day and night. Its enhanced color night vision and motion-activated spotlight ensure you never miss a detail, even in low light.
- Video Quality: 2.5K QHD (2560x1440) with 8x digital zoom
- Night Vision: 4 IR LEDs plus 2 white spotlight LEDs (72 lumens) for color night vision
- Field of View: Wide 115.8° diagonal, 98.5° horizontal, 53.1° vertical
- Connectivity: Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for fast, reliable streaming
- Audio: 99dB waterproof speaker with two-way talk and built-in siren
- Storage: Local microSD card support up to 512 GB plus optional cloud storage
- Weather Resistance: IP65 rated for outdoor use
- Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT
- Mounting Options: Stand, wall, ceiling, or magnetic adhesive mounts for versatile placement
This camera is perfect for both indoor and outdoor use, providing robust surveillance with easy installation and smart features.
Wyze Cam v4 mounted outdoors for comprehensive home security
Wyze Bulb Cam: 2-in-1 Smart Lighting and Security
Protect your home with the innovative
Wyze Bulb Cam, a smart LED light bulb combined with a 2K HD security camera. This unique device fits into standard light fixtures, making it an unobtrusive yet powerful surveillance tool.
- Video Resolution: 2K HD (2304 x 1296) with 160° field of view
- Night Vision: Color night vision plus IR night vision for clear footage in darkness
- Lighting: Up to 800 lumens brightness with 3000K warm color temperature
- Audio: Built-in microphone and two-way audio for real-time communication
- Alerts: Instant motion alerts and push notifications
- Storage: Supports local microSD cards up to 256 GB; cloud storage available
- Weatherproof: IP65 rated for outdoor use
- Installation: Easy screw-in installation into any standard E26 socket
- Smart Controls: Motion-activated light, ambient light sensing, scheduling, and Wyze Automations
Ideal for porches, garages, or any outdoor lighting fixture, the Wyze Bulb Cam blends security with smart lighting convenience.
Wyze Bulb Cam providing security and lighting in outdoor settings
Wyze Cam Pan v3: 360° Pan and 180° Tilt Coverage
For full-room coverage, the
Wyze Cam Pan v3 offers a dynamic 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your home with a single camera.
- Video Quality: 1080p Full HD with 8x digital zoom
- Field of View: 120° fixed lens with pan and tilt capabilities
- Night Vision: 4 IR LEDs for clear black-and-white night vision
- Audio: Two-way audio with noise and echo cancellation
- Weather Resistance: IP65 rated for indoor/outdoor use (requires outdoor power adapter for outside)
- Connectivity: 2.4 GHz Wi-Fi support
- Storage: Supports microSD cards up to 256 GB
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT
- Dimensions: Compact and lightweight for flexible placement
This camera is perfect for monitoring large spaces or areas where you want to remotely control the viewing angle.
Wyze Cam Pan v3 providing weather-resistant surveillance in snowy conditions
Wyze Home Monitoring Service: 24/7 Professional Surveillance
To complement your Wyze cameras, the
Wyze Home Monitoring Service offers professional 24/7 monitoring powered by Noonlight, ensuring your home is protected even when you’re away.
- Professional Monitoring: Around-the-clock monitoring with emergency response
- Deep Integration: Works seamlessly with Wyze cameras and sensors
- Remote Control: Arm and disarm your system remotely via the Wyze app
- Customizable: Set personalized monitoring rules and share access with family
- Sensors Supported: Includes Wyze Sense Hub, motion, entry, climate, and leak sensors
- Easy Installation: Peel-and-stick sensors with no tools required
- Plans: Flexible monthly or annual subscription options
This service enhances your home security by providing peace of mind with professional backup and smart automation.
Wyze Sense Keypad and Motion Sensor: Smart Home Monitoring Accessories
Enhance your home security system with Wyze’s smart accessories designed for seamless integration:
Wyze Sense Keypad
- Arm and disarm your security system remotely
- Emergency button for quick alerts
- Requires Wyze Home Monitoring service and Sense Hub
- Indoor use with permanent adhesive mounting
Wyze Sense Motion Sensor
- Detects motion up to 25 feet with adjustable sensitivity
- Supports up to 100 sensors per hub for large homes
- Easy installation with adhesive or screws
- Compatible with Wyze Sense v2 and Home Monitoring
These accessories provide additional layers of security and control, making your home surveillance system more responsive and customizable.
Why Choose Wyze for Unlimited Home Surveillance?
Wyze offers a scalable, affordable, and feature-rich home security ecosystem that supports unlimited camera licenses, allowing you to monitor every corner of your property with ease. From high-resolution wired cameras to smart lighting solutions and professional monitoring services, Wyze ensures your home is safe, connected, and smart.
With Wyze, you get:
- High-quality video and audio surveillance
- Smart home integration with Alexa and Google Assistant
- Flexible storage options including local and cloud
- Weather-resistant devices for indoor and outdoor use
- Professional 24/7 monitoring with emergency response
- Easy installation and management via the Wyze app
Secure your home completely with Wyze’s unlimited camera licenses and comprehensive monitoring solutions.
What are unlimited Wyze camera licenses and how do they benefit home surveillance?
Unlimited Wyze camera licenses allow you to add and monitor as many Wyze cameras as you need within your home, providing comprehensive surveillance coverage. This scalable solution ensures you can secure every corner of your property without restrictions, making it ideal for both small and large homes.What features does the Wyze Cam v4 offer for home security?
The Wyze Cam v4 is a wired security camera that delivers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and a wide 115.8° field of view. It supports Wi-Fi 6, two-way audio, local microSD storage up to 512 GB, optional cloud storage, and is IP65 weather-resistant for both indoor and outdoor use. It also integrates with Alexa, Google Assistant, and IFTTT.How does the Wyze Bulb Cam combine lighting and security?
The Wyze Bulb Cam is a 2-in-1 device that functions as both a smart LED light bulb and a 2K HD security camera. It fits into standard E26 light sockets, offers up to 800 lumens of brightness, color and IR night vision, two-way audio, instant motion alerts, and supports both local and cloud storage. Its IP65 rating makes it suitable for outdoor use.What makes the Wyze Cam Pan v3 suitable for full-room surveillance?
The Wyze Cam Pan v3 features 360° horizontal pan and 180° vertical tilt, allowing you to remotely control the camera's view and monitor every corner of a room. It offers 1080p Full HD video, 8x digital zoom, two-way audio, night vision, and is IP65 rated for indoor and outdoor use with the appropriate power adapter.What is included in the Wyze Home Monitoring Service?
The Wyze Home Monitoring Service provides 24/7 professional monitoring powered by Noonlight, deep integration with Wyze cameras and sensors, remote system control via the Wyze app, customizable monitoring rules, and flexible subscription plans. It supports a range of sensors including motion, entry, climate, and leak sensors, and offers easy installation.How do Wyze Sense Keypad and Motion Sensor enhance home security?
The Wyze Sense Keypad allows you to arm and disarm your security system remotely and features an emergency button for quick alerts. The Wyze Sense Motion Sensor detects motion up to 25 feet, supports up to 100 sensors per hub, and is easy to install. Both accessories integrate seamlessly with the Wyze Home Monitoring system for enhanced security and control.Are Wyze cameras and accessories weather-resistant for outdoor use?
Yes, many Wyze cameras and accessories, such as the Wyze Cam v4, Wyze Bulb Cam, and Wyze Cam Pan v3 (with outdoor power adapter), are IP65 rated for weather resistance, making them suitable for both indoor and outdoor surveillance.What smart home integrations are available with Wyze security products?
Wyze security products are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, allowing you to control and automate your home surveillance system with voice commands and smart routines.What storage options are available for Wyze cameras?
Wyze cameras support flexible storage options, including local microSD card storage (up to 512 GB for Wyze Cam v4 and up to 256 GB for other models) and optional cloud storage for video recordings and event clips.Why should I choose Wyze for my home surveillance needs?
Wyze offers a scalable, affordable, and feature-rich home security ecosystem with unlimited camera licenses, high-quality video and audio, smart home integration, flexible storage, weather-resistant devices, professional 24/7 monitoring, and easy installation and management through the Wyze app.
