How to Add Unlimited Licenses with Cam Plus Unlimited Plan for Wyze Cams
Wyze offers a flexible and affordable way to secure your home with its Cam Plus Unlimited plan, allowing you to add unlimited licenses for multiple Wyze cameras under one subscription. This plan is perfect for users who want comprehensive coverage without the hassle of managing individual camera licenses.
Understanding the Cam Plus Unlimited Plan
The
Cam Plus Unlimited plan is designed to unlock the full potential of your Wyze cameras by providing:
- Unlimited camera coverage under a single subscription.
- Smart event video recording with person, vehicle, package, and pet detection.
- Multi-camera timeline for quick review of live views and recorded events.
- Smart Arm/Disarm modes for easier home monitoring.
- Facial recognition features with Friendly Faces and unknown face alerts.
- Access to Wyze Web Portal for desktop or laptop viewing.
- No contracts, no hidden fees, and cancel anytime.
"Transforms your Wyze Cams into a powerful multi-camera security system with simultaneous timeline viewing, smart modes, and AI detections."
This plan is ideal for users with multiple Wyze cameras who want seamless, centralized management and enhanced AI-powered security features.
Compatible Wyze Cameras for Cam Plus Unlimited Plan
To maximize your Cam Plus Unlimited subscription, you can add unlimited licenses for the following Wyze cameras, each offering unique features to fit your home security needs:
Wyze Cam Pan v3
- 360° horizontal pan and 180° vertical tilt for full room coverage.
- Automatic motion tracking to follow movement.
- Color night vision and two-way audio for clear communication.
- IP65 weather resistance for indoor/outdoor use (requires outdoor power adapter for outdoor use).
- Supports up to 256 GB microSD local storage.
- Compatible with Alexa, Google Assistant, and IFTTT.
Stay connected with panoramic coverage and weather resistance.
Wyze Cam v4
- Crystal-clear 2.5K QHD resolution with enhanced color night vision.
- Motion-activated spotlight and built-in siren for deterrence.
- 24/7 local recording with microSD card support up to 512 GB.
- Wi-Fi 6 support for faster, more reliable connectivity.
- Multiple mounting options including magnetic and ceiling mounts.
- IP65 weather resistance for outdoor durability.
- Integrates with Alexa, Google Assistant, and IFTTT.
Wyze Battery Cam Pro
- Wire-free design with removable, rechargeable 6200mAh battery lasting up to 6 months.
- 2.5K HDR video resolution with CMOS-Starlight sensor for clear images day and night.
- Integrated spotlight, siren, and radar + PIR motion detection.
- Supports 2.4 GHz and 5 GHz Wi-Fi bands.
- IP65 weatherproof for all-season outdoor use.
- Two-way audio with noise and echo cancellation.
How to Add Unlimited Licenses to Your Wyze Cams
1.
Choose the Cam Plus Unlimited Plan: Select the $9.99/month plan (or save 20% with an annual subscription) to cover unlimited cameras.
2.
Add Compatible Wyze Cameras: Purchase or use your existing Wyze Cam Pan v3, Wyze Cam v4, Wyze Battery Cam Pro, or other supported models.
3.
Activate Your Subscription: Link your Wyze account to the Cam Plus Unlimited plan via the Wyze app.
4.
Add Cameras to Your Account: Connect all your Wyze cameras to your Wyze app account.
5.
Enjoy Unlimited Coverage: All connected cameras will be covered under the single subscription, enabling smart detections, event recording, and multi-camera timeline viewing.
With this setup, you can monitor your entire home with no limits on the number of cameras, all managed easily from one app.
Why Choose Wyze Cam Plus Unlimited?
- Cost-Effective: Protect multiple cameras for less than $0.08 a day.
- Smart AI Features: Get alerts that matter with person, vehicle, and pet detection.
- Flexible & No Contracts: Cancel anytime without penalties.
- Access Anywhere: View your cameras on mobile or desktop via Wyze Web Portal.
- Wide Camera Compatibility: Works with a broad range of Wyze cameras, indoor and outdoor.
Essential Security Bundle: Complete Home Protection
For those looking to start or upgrade their home security system, the
Essential Security Bundle offers a comprehensive package:
- Wyze Video Doorbell v2: 1080p HD video, two-way audio, and person detection.
- Wyze Lock Bolt: Smart lock with fingerprint sensor and backlit keypad.
- Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage.
- Two Wyze Cam OGs: Versatile plug-in cameras with motion-activated spotlights and color night vision.
This bundle pairs perfectly with the Cam Plus Unlimited plan to provide all-around security coverage.
Summary
Adding unlimited licenses with the Cam Plus Unlimited plan is straightforward and ideal for users with multiple Wyze cameras. Whether you have the versatile Wyze Cam Pan v3, the high-resolution Wyze Cam v4, or the wire-free Wyze Battery Cam Pro, this plan unlocks advanced AI features and unlimited cloud recording for all your devices.
Secure your home smarter and easier with Wyze’s flexible plans and powerful cameras.
Communicate clearly with two-way audio on Wyze cameras.
What is the Wyze Cam Plus Unlimited plan?
The Wyze Cam Plus Unlimited plan is a subscription service that allows you to add unlimited licenses for multiple Wyze cameras under a single plan. It provides advanced features like smart event video recording, person, vehicle, package, and pet detection, multi-camera timeline viewing, facial recognition, and access to the Wyze Web Portal. There are no contracts or hidden fees, and you can cancel anytime.How do I add unlimited licenses to my Wyze cameras with Cam Plus Unlimited?
To add unlimited licenses, select the Cam Plus Unlimited plan ($9.99/month or save 20% with an annual subscription), activate your subscription via the Wyze app, and connect all your compatible Wyze cameras to your account. All connected cameras will be covered under the single subscription, enabling smart detections, event recording, and multi-camera timeline viewing.Which Wyze cameras are compatible with the Cam Plus Unlimited plan?
The Cam Plus Unlimited plan is compatible with a wide range of Wyze cameras, including Wyze Cam Pan v3, Wyze Cam v4, Wyze Battery Cam Pro, and other supported models. These cameras offer features like 360° pan, 2.5K QHD resolution, wire-free installation, color night vision, and weather resistance.What features are included with the Cam Plus Unlimited plan?
The Cam Plus Unlimited plan includes unlimited camera coverage, smart event video recording with person, vehicle, package, and pet detection, multi-camera timeline for quick review, smart Arm/Disarm modes, facial recognition with Friendly Faces, access to the Wyze Web Portal, and the ability to cancel anytime with no hidden fees.How much does the Cam Plus Unlimited plan cost?
The Cam Plus Unlimited plan costs $9.99 per month, with an option to save 20% by choosing the annual subscription. This covers unlimited Wyze cameras under one subscription.Can I use the Cam Plus Unlimited plan for both indoor and outdoor Wyze cameras?
Yes, the Cam Plus Unlimited plan works with both indoor and outdoor Wyze cameras, including models like Wyze Cam Pan v3, Wyze Cam v4, and Wyze Battery Cam Pro, all of which offer weather resistance for outdoor use.What are the benefits of choosing the Cam Plus Unlimited plan over individual camera licenses?
The Cam Plus Unlimited plan is cost-effective, allowing you to protect multiple cameras for less than $0.08 a day. It simplifies management by covering all your cameras under one subscription and unlocks advanced AI features, unlimited cloud recording, and centralized control via the Wyze app or web portal.Is there a contract or cancellation fee with the Cam Plus Unlimited plan?
No, there are no contracts or cancellation fees with the Cam Plus Unlimited plan. You can cancel your subscription at any time without penalties.What is included in the Wyze Essential Security Bundle?
The Wyze Essential Security Bundle includes a Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OGs. This bundle is designed to provide comprehensive home security and pairs perfectly with the Cam Plus Unlimited plan for all-around protection.Can I access my Wyze cameras from a desktop or laptop?
Yes, with the Cam Plus Unlimited plan, you can access your Wyze cameras via the Wyze Web Portal on your desktop or laptop, in addition to the Wyze mobile app.
