Two-in-One Video Doorbell Solutions for Front Yard Security and Doorstep Monitoring
When it comes to securing your front yard and monitoring your doorstep, having a versatile, reliable video doorbell system is essential. Wyze offers some of the most advanced and user-friendly video doorbell solutions designed to keep your home safe and connected. Whether you want a battery-powered dual-camera system or a wired doorbell with crystal-clear 2K video, Wyze has you covered.
Wyze Duo Cam Battery Doorbell: Dual Camera, Dual Protection
Experience comprehensive front yard security with Wyze Duo Cam Doorbell.
The
Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered video doorbell, perfect for those seeking a two-in-one solution for front yard security and doorstep monitoring. It features dual cameras that provide two distinct views:
- Front Camera: 2K resolution (2048 x 1536) with a wide 132° horizontal and 100° vertical field of view, capturing clear images of visitors.
- Bottom Camera: 1080p resolution with a 121° horizontal and 60° vertical field of view, ideal for monitoring packages left at your doorstep.
Key Features:
- Battery-powered with USB-C charging and optional hardwired power for continuous operation.
- Two-way audio with a built-in siren (90 dB) and motion-activated voice deterrence.
- Real-time AI detections for people, packages, and motion alerts.
- Local storage support up to 256GB microSD card and cloud storage options.
- Weather-resistant IP65 rating ensures durability in all seasons.
- Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
This doorbell is perfect for homeowners who want to monitor both visitors and deliveries with a single device, providing peace of mind and convenience.
Wyze Video Doorbell v2: Wired 2K Clarity with Essential Features
Answer your door from anywhere with Wyze Video Doorbell v2.
The
Wyze Video Doorbell v2 is a wired video doorbell that delivers sharp 2K video resolution and essential smart features for doorstep monitoring:
- 2K (2048 x 1536) video resolution with a wide 135° horizontal and 103° vertical field of view.
- Two-way audio with ECM microphone and 8Ω 1W speaker for clear communication.
- Motion-activated voice deterrence to warn unwanted visitors.
- Local microSD storage up to 256GB for continuous recording.
- IP65 weather resistance for reliable outdoor use.
- Compatible with Alexa, Google Assistant, and IFTTT.
This wired doorbell is ideal for users who prefer a hardwired installation with high-resolution video and smart alerts, ensuring you never miss a visitor or package.
The Front Porch Security Bundle: Complete Smart Home Solution
The
Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Chime to create a comprehensive front porch security system:
- Wyze Video Doorbell: View your front porch in 1080p HD with two-way audio and motion detection.
- Wyze Lock: Remotely lock/unlock your door and monitor lock history via the Wyze app.
- Wyze Chime: Hear doorbell alerts anywhere in your home with multiple sound options.
Bundle Highlights:
- Seamless integration with Alexa and Google Assistant.
- Remote access to video and lock controls from your smartphone.
- Weather-resistant doorbell with 120° vertical and 88° horizontal field of view.
- Two-way audio with noise and echo cancellation for clear conversations.
- Multiple mounting options and included accessories for easy installation.
This bundle is perfect for homeowners looking for an all-in-one front porch security system that combines video monitoring with smart lock control.
Why Choose Wyze for Your Front Yard Security?
Wyze video doorbells stand out for their combination of advanced technology, affordability, and ease of use. Whether you want the dual-camera versatility of the Wyze Duo Cam Battery Doorbell or the wired reliability of the Wyze Video Doorbell v2, Wyze offers solutions that fit various needs and budgets.
"Wyze’s two-in-one video doorbell solutions provide comprehensive coverage, smart alerts, and seamless integration with your smart home ecosystem, ensuring your front yard and doorstep are always secure."
Additional Accessories for Enhanced Coverage
For users of the Wyze Video Doorbell v2, the
Wyze Video Doorbell v2 Wedge Kit is a perfect accessory to optimize your doorbell’s viewing angle. It helps eliminate blind spots on angled door frames or porches with stairs, ensuring maximum coverage and security.
Summary of Wyze Video Doorbell Solutions
Product | Power Source | Video Resolution | Special Features | Weather Resistance | Price Range |
Wyze Duo Cam Battery Doorbell | Battery / Hardwired | Front 2K / Bottom 1080p | Dual cameras, AI detection, siren, USB-C charging | IP65 | $89.98 - $109.99 |
Wyze Video Doorbell v2 | Wired | 2K | Two-way audio, local storage, voice deterrence | IP65 | $44.98 |
Front Porch Security Bundle | Wired + Lock (Battery) | 1080p | Video doorbell + smart lock + chime | IP65 | $123.99+ |
Enhance your home security with Wyze’s innovative two-in-one video doorbell solutions designed for front yard safety and doorstep monitoring. Choose the model that fits your lifestyle and enjoy peace of mind with smart, reliable technology.
What are the main features of the Wyze Duo Cam Battery Doorbell?
The Wyze Duo Cam Battery Doorbell features dual cameras for comprehensive front yard and doorstep monitoring. The front camera offers 2K resolution with a wide 132° horizontal and 100° vertical field of view, while the bottom camera provides 1080p resolution for package monitoring. It supports battery power with USB-C charging, optional hardwired installation, two-way audio, a built-in 90 dB siren, real-time AI detections for people and packages, local microSD storage up to 256GB, cloud storage options, and is weather-resistant with an IP65 rating. It also integrates with Alexa, Google Assistant, and IFTTT.How does the Wyze Video Doorbell v2 differ from the Duo Cam Battery Doorbell?
The Wyze Video Doorbell v2 is a wired doorbell that delivers sharp 2K video resolution with a 135° horizontal and 103° vertical field of view. Unlike the Duo Cam, it has a single camera but offers essential features like two-way audio, motion-activated voice deterrence, local microSD storage up to 256GB, and IP65 weather resistance. It is ideal for users who prefer a hardwired installation and high-resolution video for doorstep monitoring.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes the Wyze Video Doorbell, Wyze Lock, and Wyze Chime. This bundle provides 1080p HD video monitoring, two-way audio, motion detection, remote lock/unlock capabilities, lock history monitoring via the Wyze app, and customizable chime alerts. It offers seamless integration with Alexa and Google Assistant, remote access from your smartphone, and multiple mounting options for easy installation.Is the Wyze Duo Cam Battery Doorbell weather-resistant?
Yes, the Wyze Duo Cam Battery Doorbell is IP65 weather-resistant, making it suitable for outdoor use in all seasons and ensuring durability against rain, dust, and other environmental factors.Can I use local storage with Wyze video doorbells?
Yes, both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 support local storage with microSD cards up to 256GB, allowing for continuous recording and easy access to your video footage.Do Wyze video doorbells support smart home integration?
Yes, Wyze video doorbells are compatible with Alexa, Google Assistant, and IFTTT, enabling seamless integration with your smart home ecosystem for enhanced convenience and control.What is the Wyze Video Doorbell v2 Wedge Kit and how does it help?
The Wyze Video Doorbell v2 Wedge Kit is an accessory designed to optimize your doorbell’s viewing angle. It helps eliminate blind spots on angled door frames or porches with stairs, ensuring maximum coverage and improved security.What are the power options for Wyze video doorbells?
The Wyze Duo Cam Battery Doorbell can be powered by a rechargeable battery with USB-C charging or hardwired for continuous operation. The Wyze Video Doorbell v2 is a wired-only device, requiring a hardwired installation for power.How does Wyze ensure package and visitor detection?
Wyze video doorbells use real-time AI detections to identify people, packages, and motion. This ensures you receive instant alerts for visitors and deliveries, enhancing your front yard and doorstep security.Why should I choose Wyze for front yard security and doorstep monitoring?
Wyze offers advanced, affordable, and user-friendly video doorbell solutions with features like dual cameras, high-resolution video, AI-powered alerts, local and cloud storage, and smart home integration. Whether you need a battery-powered or wired system, Wyze provides reliable options to keep your home safe and connected.
