Top Weatherproof Accessories for Wyze Cam V4 & Standard Models
Best Third-Party Accessories to Weatherproof Your Wyze Cam V4 and Standard Wyze Cam
When it comes to protecting your Wyze Cam V4 or standard Wyze Cam from the elements, choosing the right third-party accessories can make all the difference. Whether you want to enhance weather resistance, improve lighting, or secure your camera in place, these accessories are designed to keep your camera safe and functional outdoors.
Wyze Cam V4: Built for the Outdoors with Added Protection
The Wyze Cam V4 is already engineered with an IP65 weather-resistant rating, making it suitable for outdoor use in rain, snow, or dust. However, to maximize its durability and performance, consider these accessories:
Wyze Cam V4 Skins by dBrand
Give your Wyze Cam V4 an extra layer of protection and style with the Wyze Cam v4 Skins by dBrand. These skins are precision-cut and made from quality materials that shield your camera from scratches, minor impacts, and UV exposure. Features:
  • Quality materials for durable protection
  • Precision cut for a perfect fit
  • Easy application and removal
  • Adds a stylish look with options like Triple Black or Green Camo
This accessory is perfect for users who want to maintain their camera’s sleek look while adding a protective barrier against outdoor wear and tear.
Wyze Cam v4 Outdoor Bundle
For those seeking a comprehensive weatherproof solution, the Wyze Cam v4 Outdoor Bundle is an excellent choice. It includes:
  • Wyze Cam v4 with IP65 weather resistance
  • Wyze Outdoor Power Adapter for reliable outdoor power supply
  • 128GB Wyze MicroSD Card for 24/7 local recording without subscription fees
This bundle ensures your camera stays powered and records continuously, even in harsh weather conditions, while providing crystal-clear 2.5K QHD video and enhanced color night vision.
"Get unmatched security with Wyze Cam v4’s outdoor-ready features and accessories designed to keep your home safe day and night."
Outdoor security camera mounted on a house exterior at dusk Alt text: Wyze Cam v4 mounted outdoors on a home wall at dusk
Accessories to Weatherproof and Enhance Standard Wyze Cam Models
If you own a standard Wyze Cam such as the Wyze Cam v3, which is not inherently weatherproof, third-party accessories can help you adapt it for outdoor use.
Wyze Cam v3 Spotlight Kit
This motion-activated, IP65-rated spotlight kit is designed specifically for the Wyze Cam v3. It adds a powerful spotlight that activates on motion detection, improving visibility and security during nighttime or low-light conditions. Key Benefits:
  • IP65 weather resistance to withstand rain and dust
  • Motion-activated lighting to deter intruders
  • Easy installation and integration with Wyze Cam v3
This kit is ideal for users who want to upgrade their standard Wyze Cam v3 for outdoor use without replacing the camera itself.
Wyze Cam Mounting Kit
Proper mounting is essential for weatherproofing your camera setup. The Wyze Cam Mounting Kit includes:
  • Wall plate for secure installation
  • Adhesive tape for flexible mounting options
  • 5-foot USB extension cable for convenient power placement
  • Screws for durable mounting
Compatible with Wyze Cam v2, v3, and v3 Pro, this kit helps you position your camera optimally to avoid exposure to direct rain or harsh elements, enhancing its longevity outdoors.
Why Weatherproofing Your Wyze Cam Matters
Outdoor environments expose your security cameras to moisture, dust, temperature fluctuations, and physical impacts. Using third-party weatherproof accessories:
  • Extends the lifespan of your camera
  • Maintains video quality by protecting lenses and sensors
  • Ensures continuous operation in all weather conditions
  • Enhances security with added lighting and mounting stability
Investing in these accessories is a smart way to safeguard your Wyze Cam investment and keep your home protected year-round.
Summary of Recommended Accessories for Weatherproofing Wyze Cams
AccessoryCompatible ModelsKey FeaturesPrice Range
Wyze Cam v4 Skins by dBrandWyze Cam v4Protective skins, stylish designs$11.98
Wyze Cam v4 Outdoor BundleWyze Cam v4Outdoor power adapter, SD card, IP65$69.99
Wyze Cam v3 Spotlight KitWyze Cam v3Motion-activated spotlight, IP65$16.98
Wyze Cam Mounting KitWyze Cam v2, v3, v3 ProMounting bracket, adhesive, cable$5.99
Enhance your Wyze Cam’s outdoor durability and performance with these trusted third-party accessories. Whether upgrading your Wyze Cam v3 or maximizing the outdoor readiness of your Wyze Cam v4, these products provide the weatherproofing and convenience you need for reliable home security. Home security camera mounted near front door with spotlight Alt text: Wyze Cam with spotlight mounted near a front door at night
Protect your Wyze Cam investment with accessories designed to weatherproof and enhance your camera’s outdoor capabilities.
Person installing a Wyze Cam outdoors on a sunny day Alt text: Person installing a Wyze Cam outdoors on a sunny day
By choosing the right accessories, you ensure your Wyze Cam stays safe, functional, and ready to protect your home no matter the weather.
Feature / ProductWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v3 Spotlight KitWyze Cam Mounting Kit
TypeCameraCamera BundleAccessoryAccessory
Price$100.00 (Default Title)$69.99$16.98$5.99
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)N/A (Accessory)N/A (Accessory)
Night VisionEnhanced Color Night Vision + IR LEDsEnhanced Color Night Vision + IR LEDsN/AN/A
SpotlightMotion-activated spotlight (72 lumens)Included (part of camera)Motion-activated headlamp (70 lumens)N/A
SirenBuilt-in 99 dB sirenIncluded (part of camera)N/AN/A
Weather ResistanceIP65IP65IP65Not specified
AudioEnhanced Two-Way Talk, 99 dB speakerEnhanced Two-Way Talk, 99 dB speakerN/AN/A
StoragemicroSD card support up to 512GBIncludes 128GB microSD cardN/AN/A
PowerWired (6-foot micro USB cable included)Includes Wyze Outdoor Power AdapterPowered via Micro USBN/A
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 6N/AN/A
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic mountSame as Wyze Cam v4N/AMounting bracket, adhesive, longer USB cable
Bluetooth Version5.25.2N/AN/A
Dimensions2in x 2in x 2 3/8inSame as Wyze Cam v421.5 x 55.8 x 34.4 mmN/A
Weight0.49 lb (222 g)Same as Wyze Cam v4N/AN/A
CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+N/ACompatible with Wyze Cam v2, v3, v3 Pro
Included Accessories6-foot micro USB to USB-A cableWyze Outdoor Power Adapter, 128GB microSD cardSpotlight x1, USB cable splitter x1Wall Plate x1, USB Extension Cable 5 ft x1, Adhesive Tape x1, Screw Set x1
Warranty1 Year1 Year1 YearN/A
Special FeaturesAI Auto-Zoom, Smoke & CO Alerts, Motion Detection ZonesSame as Wyze Cam v4IP65 rated, 5 LEDs, 130° beam angleMounting kit for cameras, longer cable
What are the best third-party accessories to weatherproof my Wyze Cam v4?The best third-party accessories to weatherproof your Wyze Cam v4 include the Wyze Cam v4 Skins by dBrand for added protection and style, and the Wyze Cam v4 Outdoor Bundle, which provides an outdoor power adapter and a 128GB MicroSD card for continuous recording and reliable outdoor performance.
Are Wyze Cam v4 Skins by dBrand effective for outdoor protection?Yes, Wyze Cam v4 Skins by dBrand are made from quality materials that shield your camera from scratches, minor impacts, and UV exposure. They are precision-cut for a perfect fit and are easy to apply and remove, making them an excellent choice for enhancing your camera’s durability and appearance outdoors.
What does the Wyze Cam v4 Outdoor Bundle include?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 with IP65 weather resistance, a Wyze Outdoor Power Adapter for reliable outdoor power, and a 128GB Wyze MicroSD Card for 24/7 local recording. This bundle ensures your camera remains powered and records continuously, even in harsh weather conditions.
How can I make my standard Wyze Cam v3 weatherproof for outdoor use?To weatherproof your standard Wyze Cam v3, you can use the Wyze Cam v3 Spotlight Kit, which adds an IP65-rated, motion-activated spotlight for improved visibility and weather resistance. Additionally, using a Wyze Cam Mounting Kit helps you securely install your camera in optimal locations to avoid direct exposure to the elements.
What are the benefits of the Wyze Cam v3 Spotlight Kit?The Wyze Cam v3 Spotlight Kit offers IP65 weather resistance, motion-activated lighting to deter intruders, and easy installation. It enhances nighttime security and allows your Wyze Cam v3 to function effectively outdoors without needing to replace the camera.
Which Wyze Cam models are compatible with the Wyze Cam Mounting Kit?The Wyze Cam Mounting Kit is compatible with Wyze Cam v2, v3, and v3 Pro models. It includes a wall plate, adhesive tape, a 5-foot USB extension cable, and screws for secure and flexible mounting options.
Why is weatherproofing my Wyze Cam important?Weatherproofing your Wyze Cam is important because it protects your camera from moisture, dust, temperature fluctuations, and physical impacts. Using weatherproof accessories extends your camera’s lifespan, maintains video quality, ensures continuous operation in all weather conditions, and enhances security with added lighting and mounting stability.
Do I need a subscription to record video with the Wyze Cam v4 Outdoor Bundle?No, you do not need a subscription to record video with the Wyze Cam v4 Outdoor Bundle. The included 128GB Wyze MicroSD Card allows for 24/7 local recording, so you can store footage without any additional fees.
How do I choose the right weatherproof accessory for my Wyze Cam model?To choose the right weatherproof accessory, first identify your Wyze Cam model. For Wyze Cam v4, consider dBrand Skins and the Outdoor Bundle. For Wyze Cam v3, the Spotlight Kit and Mounting Kit are recommended. Always check compatibility and select accessories that offer the protection and features you need for your specific outdoor setup.
What are the key features of the Wyze Cam v4 Outdoor Bundle?Can you tell me more about the Wyze Cam v3 Spotlight Kit?Are there any ongoing sales or discounts for Wyze accessories?
