Extend Your Wyze Cam Power with the 20ft USB Extension Cable
If you're looking to stretch your Wyze Cam power source to an outer window facing your driveway, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This cable provides the freedom to position your Wyze Cam exactly where you need it without worrying about short cable lengths.
Why Choose the Wyze Cam USB Extension Cable - 20ft?
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Length: A generous 20-foot length allows you to power your camera from a distant outlet or indoor power source.
- Flexibility: Ideal for mounting your camera on outer windows or farther away from power outlets, especially useful for driveway monitoring.
- Affordable: Priced at just $7.99, it’s a cost-effective solution to extend your camera’s reach.
Say goodbye to the frustration of limited cable length and enjoy flexible placement options for your Wyze Cam.
Enhance Your Outdoor Security Setup with Wyze Cam v4 and Accessories
For driveway-facing outdoor surveillance, the
Wyze Cam v4 combined with the USB extension cable offers a powerful and flexible security solution.
Wyze Cam v4: Advanced Features for Outdoor Monitoring
- Crystal Clear 2.5K QHD Video: Capture every detail with high-resolution video.
- Enhanced Color Night Vision: See vibrant colors even in low light conditions.
- Weather Resistant: Rated IP65, perfect for outdoor use in various weather conditions.
- Wide Field of View: 115.8° diagonal field of view covers a broad area.
- Multiple Mounting Options: Stand, wall mount, ceiling mount, or magnetic wall mount for versatile installation.
- Smart Features: Two-way audio, built-in siren, noise and echo cancellation, and Alexa/Google Assistant compatibility.
- Power: Comes with a 6-foot flat micro USB cable; extend power easily with the 20ft USB extension cable.
Using the 20ft USB extension cable with the Wyze Cam v4 allows you to place the camera on an outer window or farther from power outlets, ensuring optimal driveway coverage without compromising on power.
Power Your Wyze Cam Anywhere with the Cam v4 + Lamp Socket v2 Bundle
If you want to power your Wyze Cam v4 without relying on a nearby outlet, consider the
Cam v4 + Lamp Socket v2 Bundle. This innovative solution lets you power your camera directly from an existing lamp socket.
Key Benefits of the Cam v4 + Lamp Socket v2 Bundle
- No Outlet Needed: Powers Wyze Cam v4 and other compatible Wyze cameras through a standard E26 lamp socket.
- Motion-Activated Lights: Adds smart lighting that activates on motion detection.
- Dusk to Dawn Scheduling: Automatically controls lighting based on time of day.
- Compact and Easy to Install: Fits most lamp sockets and is suitable for damp locations.
Compatible with Wyze Cam v3, v4, OG, and Pan v3.
This bundle is ideal for outdoor setups where power outlets are scarce, and you want to combine lighting and camera power in one solution.
Summary: Perfect Setup for Driveway Surveillance
- Use the Wyze Cam USB Extension Cable - 20ft to extend your camera’s power cable to an outer window facing your driveway.
- Pair it with the Wyze Cam v4 for high-resolution, weatherproof outdoor monitoring with advanced night vision.
- For even more convenience, the Cam v4 + Lamp Socket v2 Bundle offers a unique way to power your camera without an outlet, adding smart lighting features.
These products together provide a flexible, reliable, and smart security solution for monitoring your driveway and outdoor spaces.
Keep your driveway safe with extended power options for Wyze Cam.
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the power source for your Wyze Cam, allowing you to position your camera farther from power outlets, such as on an outer window facing your driveway. This provides greater flexibility in camera placement for optimal security coverage.Which Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.How long is the Wyze Cam USB Extension Cable and what are its benefits?
The Wyze Cam USB Extension Cable is 20 feet long, allowing you to power your camera from a distant outlet or indoor power source. This extended length is ideal for mounting your camera in locations that are farther from available power, such as outer windows or garages.Is the Wyze Cam USB Extension Cable affordable?
Yes, the Wyze Cam USB Extension Cable - 20ft is priced at just $7.99, making it a cost-effective solution for extending your camera’s reach.What are the key features of the Wyze Cam v4 for outdoor monitoring?
The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, IP65 weather resistance, a wide 115.8° field of view, multiple mounting options, two-way audio, a built-in siren, noise and echo cancellation, and compatibility with Alexa and Google Assistant.Can I use the Wyze Cam v4 outdoors?
Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use in various weather conditions.How can I power my Wyze Cam v4 if there is no nearby outlet?
You can use the Cam v4 + Lamp Socket v2 Bundle to power your Wyze Cam v4 directly from a standard E26 lamp socket, eliminating the need for a nearby power outlet.What are the benefits of the Cam v4 + Lamp Socket v2 Bundle?
The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 through a lamp socket, adds motion-activated smart lighting, supports dusk to dawn scheduling, and is easy to install in most lamp sockets, even in damp locations.Which Wyze Cam models are compatible with the Lamp Socket v2?
The Lamp Socket v2 is compatible with Wyze Cam v3, v4, OG, and Pan v3.What is the best setup for driveway surveillance with Wyze Cam products?
For optimal driveway surveillance, use the Wyze Cam USB Extension Cable - 20ft to extend your camera’s power, pair it with the Wyze Cam v4 for high-resolution, weatherproof monitoring, and consider the Cam v4 + Lamp Socket v2 Bundle for powering your camera without an outlet while adding smart lighting features.
