Stackable Indoor & Outdoor Camera Pair for Full Home Coverage
Stackable Indoor Outdoor Camera Pair for Full Coverage Home Monitoring
When it comes to securing your home, having a versatile, stackable pair of indoor and outdoor cameras is essential for full coverage. Whether you want to monitor your front porch, backyard, or inside your living room, Wyze offers a range of smart cameras designed to work seamlessly together. From ultra-clear video quality to weather-resistant designs and smart features like motion tracking and color night vision, these cameras provide comprehensive home monitoring solutions.
Wyze Cam v4: The Ultimate Indoor/Outdoor Security Camera
Wyze Cam v4 is the clearest Wyze Cam ever made, perfect for stacking with other cameras to cover every angle of your home.
Key Features:
  • 2.5K Quad HD Resolution: Capture crystal-clear video with vibrant colors and sharp details.
  • Enhanced Color Night Vision: See more at night with hardware that reveals stunning details invisible to the naked eye.
  • IP65 Weather Resistance: Designed for both indoor and outdoor use, it withstands rain, snow, and dust.
  • Motion-Activated Spotlight & 99 dB Siren: Deter intruders with a bright spotlight and loud siren.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works with Alexa and Google Assistant for voice control.
  • Easy Setup & Magnetic Mount: Screw-free installation with a magnetic base.
Wyze Cam v4 is available in single, 2-pack, and 3-pack options, making it easy to stack multiple cameras for full home coverage. Wyze Cam v4 lifestyle Wyze Cam v4 providing seamless indoor and outdoor home monitoring
Wyze Cam Pan v3: Dynamic 360° Pan and 180° Tilt for Maximum Coverage
For areas requiring flexible viewing angles, the Wyze Cam Pan v3 is an excellent complement to the Wyze Cam v4.
Key Features:
  • 360° Pan & 180° Tilt: Covers every corner of a room or outdoor space with smooth, quiet motorized movement.
  • Automatic Motion Tracking: The camera detects and follows moving objects automatically.
  • IP65 Weatherproof: Suitable for outdoor use with the Wyze Outdoor Power Adapter.
  • Color Night Vision: See clear, colorful images even in low light.
  • Privacy Mode: Spin the camera downward to disable viewing when privacy is needed.
  • Two-Way Audio: Communicate through the camera with clear sound.
  • Custom Detection Zones: Focus alerts on specific areas of interest.
  • Local Storage Support: Save footage on microSD cards up to 256GB.
This camera is ideal for monitoring large spaces or areas where you want to actively track movement, making it a perfect partner for a fixed Wyze Cam v4. Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3 braving snowy weather for reliable outdoor security
Wyze Bulb Cam: Discreet Outdoor Security with Smart Lighting
For a unique combination of security and lighting, the Wyze Bulb Cam fits into any standard E26 light socket, providing both illumination and surveillance.
Key Features:
  • 2K HD Video with Color Night Vision: Clear video day and night with a wide 160° field of view.
  • IP65 Weather Resistant: Built to withstand outdoor conditions.
  • Smart LED Light Bulb: Up to 800 lumens brightness with 3000K warm light.
  • Motion-Activated Light & Alerts: Lights up and sends notifications when motion is detected.
  • Two-Way Audio & 95 dB Siren: Communicate and deter intruders effectively.
  • Local and Cloud Storage: Supports microSD cards up to 256GB and cloud storage options.
  • Easy Installation: Fits most outdoor fixtures without extra wiring.
The Wyze Bulb Cam is perfect for entryways, garages, or porches where you want to combine lighting and security in one device. Wyze Bulb Cam lifestyle Wyze Bulb Cam installed in an outdoor light fixture for smart home security
Additional Wyze Cameras to Enhance Your Monitoring Setup
Wyze Cam OG: Fast Live Streaming with Built-In Spotlight
  • 1080p HD video with 120° field of view
  • 3X faster notifications and improved two-way audio
  • Built-in 40-lumen spotlight and 90 dB siren
  • IP65 weather resistance for indoor/outdoor use
  • Supports microSD local storage up to 256GB
Wyze Cam OG Telephoto: Zoom In on Details
  • 3X telephoto lens for focused monitoring
  • 1080p HD video with 8X digital zoom
  • Same fast live streaming and two-way audio as Wyze Cam OG
  • Weather resistant with IP65 rating
  • Compatible with Alexa, Google Assistant, and IFTTT
Why Choose a Stackable Camera Pair for Home Monitoring?
Combining Wyze Cam v4 with Wyze Cam Pan v3 or Wyze Bulb Cam creates a layered security system that covers every angle of your home, indoors and outdoors. Stackable packs and versatile mounting options allow you to customize your setup for maximum coverage and peace of mind.
  • Full Coverage: Fixed cameras like Wyze Cam v4 provide constant monitoring, while Pan v3 offers dynamic tracking.
  • Indoor & Outdoor Use: All cameras are IP65 rated, ensuring durability in all weather conditions.
  • Smart Features: Motion tracking, color night vision, two-way audio, and smart assistant integration.
  • Flexible Storage: Local microSD recording with optional cloud storage plans.
  • Easy Installation: Magnetic mounts, standard bulb sockets, and wireless setup simplify deployment.
Conclusion
For full coverage home monitoring, the Wyze Cam v4 paired with the Wyze Cam Pan v3 or Wyze Bulb Cam offers a powerful, stackable solution. Whether you want fixed high-resolution views, dynamic pan-and-tilt tracking, or discreet lighting-integrated surveillance, Wyze cameras deliver reliable, smart security for every corner of your home.
Product Tags Summary
  • Wyze Cam v4:
  • Wyze Cam Pan v3:
  • Wyze Bulb Cam:
  • Wyze Cam OG:
  • Wyze Cam OG Telephoto:
  • Wyze Cam v4 Home Security Bundle:
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Bulb CamWyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p)2K (2304x1296)1080p (1920x1080)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt160° (FOV), 166° diagonal120°27° (D), 23.6° (H), 13.6° (V)115.8° (D) x 98.5° (H) x 53.1° (V)
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)Color Night Vision + IR Night Vision4 IR LEDs (850nm)4 IR LEDs (850nm)Color Night Vision + 4 IR LEDs + 2 white spotlight LEDs (72 lumens)
AudioEnhanced Two-Way TalkTwo-Way AudioBuilt-in digital microphone, Two-Way AudioBuilt-in Speaker & Microphone; Noise & Echo CancellationBuilt-in Speaker & Microphone; Noise & Echo CancellationImproved 2-way audio
Siren99 dBNot specified95 dB at 4 in90 dB user-activated sirenNot specifiedNot specified
SpotlightMotion-activated spotlightNoNoBuilt-in spotlight (40 lumens)NoMotion-activated spotlight
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD 128GB included
Wi-FiWi-Fi 6 supportNot specified (likely 2.4 GHz)2.4 GHz (b/g/n)2.4 GHz (b/g/n)2.4 GHz (b/g/n)Wi-Fi 6 support
PowerWired (micro USB)Wired (micro USB)120V AC (bulb socket)Wired (5V/1A adapter)Wired (5V/1A adapter)Wired (5V/1A adapter)
Mounting OptionsStand, Wall, Ceiling, MagneticWall mount, StandStandard E26 bulb socketStand, Wall, CeilingStand, Wall, CeilingStand, Wall, Ceiling, Magnetic
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specifiedAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Special FeaturesAuto-zoom with AI, Motion-activated spotlight, Smoke & CO alerts360° pan & 180° tilt, Motion tracking, Privacy mode2-in-1 camera & smart LED bulb, Motion-activated light, Up to 800 lm brightnessFaster live streaming, 3X faster notifications3X telephoto lensBundle includes 128GB microSD card, Enhanced 2-way audio
Price (Single Pack)$35.98$39.98$49.98$29.98$25.98$169.99
What is a stackable indoor outdoor camera pair for home monitoring?A stackable indoor outdoor camera pair refers to using two or more compatible security cameras, such as the Wyze Cam v4 and Wyze Cam Pan v3, together to achieve full coverage of your home. These cameras are designed to work seamlessly indoors and outdoors, providing comprehensive monitoring and enhanced security.
What are the key features of the Wyze Cam v4 for home security?The Wyze Cam v4 offers 2.5K Quad HD resolution, enhanced color night vision, IP65 weather resistance for indoor and outdoor use, a motion-activated spotlight, a 99 dB siren, 24/7 local recording to microSD card, Wi-Fi 6 support, compatibility with Alexa and Google Assistant, and easy magnetic mount installation.
Can Wyze Cam v4 be used both indoors and outdoors?Yes, the Wyze Cam v4 is IP65 weather resistant, making it suitable for both indoor and outdoor use. It is designed to withstand rain, snow, and dust, ensuring reliable performance in various environments.
How does the Wyze Cam Pan v3 enhance home monitoring coverage?The Wyze Cam Pan v3 features 360° pan and 180° tilt capabilities, automatic motion tracking, color night vision, two-way audio, privacy mode, custom detection zones, and IP65 weatherproofing. This makes it ideal for monitoring large spaces and tracking movement, complementing fixed cameras like the Wyze Cam v4.
What is the benefit of pairing Wyze Cam v4 with Wyze Cam Pan v3 or Wyze Bulb Cam?Pairing Wyze Cam v4 with Wyze Cam Pan v3 or Wyze Bulb Cam creates a layered security system that covers every angle of your home. The fixed Wyze Cam v4 provides constant high-resolution monitoring, while the Pan v3 offers dynamic tracking, and the Bulb Cam adds discreet surveillance with integrated lighting.
Does Wyze Cam v4 support local storage without a subscription?Yes, Wyze Cam v4 supports 24/7 local recording to a microSD card (up to 256GB) without requiring a subscription. This allows you to store footage locally and access it anytime.
What makes the Wyze Bulb Cam unique for outdoor security?The Wyze Bulb Cam combines a 2K HD security camera with a smart LED light bulb, fitting into any standard E26 light socket. It offers color night vision, motion-activated lighting and alerts, two-way audio, a 95 dB siren, and both local and cloud storage options, making it ideal for entryways, garages, or porches.
Are Wyze cameras easy to install?Yes, Wyze cameras are designed for easy installation. The Wyze Cam v4 features a magnetic mount for screw-free setup, the Wyze Bulb Cam fits standard light sockets, and the Wyze Cam Pan v3 can be installed with the Wyze Outdoor Power Adapter for outdoor use.
Do Wyze cameras work with smart home assistants?Yes, Wyze cameras such as the Cam v4, Cam Pan v3, and Cam OG series are compatible with Alexa and Google Assistant, allowing for convenient voice control and integration with your smart home ecosystem.
What storage options are available for Wyze security cameras?Wyze security cameras support local storage via microSD cards up to 256GB for continuous or event-based recording. Additionally, cloud storage options are available for those who prefer offsite backup and remote access to footage.
Are Wyze cameras weather resistant for outdoor use?Yes, Wyze cameras such as the Cam v4, Cam Pan v3, Cam OG, and Bulb Cam are all rated IP65 weather resistant, making them suitable for outdoor installation and reliable operation in various weather conditions.
What is the advantage of using a Wyze Cam OG Telephoto in my security setup?The Wyze Cam OG Telephoto features a 3X telephoto lens and 8X digital zoom, allowing you to focus on specific areas or details. It offers 1080p HD video, fast live streaming, two-way audio, and IP65 weather resistance, making it ideal for monitoring driveways, gates, or distant areas.
Can I customize detection zones with Wyze cameras?Yes, Wyze cameras like the Cam Pan v3 allow you to set custom detection zones, so you receive alerts only for activity in specific areas of interest, reducing false notifications and enhancing security.
What are the key features of the Wyze Cam v4?How does the Wyze Cam Pan v3 complement the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions available?
