Top Indoor Outdoor WiFi Cameras Compatible with Stack Kits
Best Indoor Outdoor WiFi Cameras with Stack Kit Compatibility
Looking for versatile indoor and outdoor WiFi cameras that offer seamless integration with stack kits? Whether you want crystal-clear security footage, weather-resistant durability, or smart home compatibility, Wyze offers a range of cameras and accessories designed to meet your needs. Explore the top Wyze cameras and accessories that provide reliable performance, easy installation, and smart features for comprehensive home security.
Wyze Cam v4 – Advanced Indoor/Outdoor Security Camera
Experience unmatched security with the Wyze Cam v4, a powerful indoor/outdoor camera designed for high-quality surveillance.
Key Features:
  • 2.5K QHD Resolution: Crystal-clear video quality (2560x1440) ensures you never miss a detail.
  • Enhanced Color Night Vision: See vibrant colors even in low light conditions.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected for added security.
  • Weather Resistant: Rated IP65, suitable for outdoor use in rain or shine.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Local and Cloud Storage: Supports microSD cards up to 512GB and optional cloud plans.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible placement.
This camera is perfect for those who want a high-resolution, weatherproof camera that works indoors or outdoors with smart home compatibility. Wyze Cam Pan v3 Outdoor Lifestyle Wyze Cam v4 and Pan v3 are designed for all-weather outdoor use.
Wyze Cam Pan v3 – 360° Pan & Tilt Indoor/Outdoor Camera
The Wyze Cam Pan v3 offers dynamic coverage with its 360° horizontal and 180° vertical rotation, making it ideal for monitoring large areas both inside and outside your home.
Highlights:
  • Full 360° Pan and 180° Tilt: Covers every angle with smooth, fast rotation up to 110° per second.
  • 1080p Full HD Video: Clear and detailed video streaming.
  • IP65 Weather Resistance: Durable for outdoor environments.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Motion Tracking & Alerts: Automatically follows movement and sends push notifications.
  • Smart Home Compatible: Works with Alexa, Google Assistant, and IFTTT.
  • Storage Support: Up to 256GB microSD card for local recording.
  • Requires Outdoor Power Adapter for Outdoor Use: Ensures safe and reliable power supply.
This camera is perfect for users who want flexible, panoramic coverage with smart features and weatherproof design.
Wyze Battery Cam Pro – Wire-Free, Weatherproof Security
For those who prefer a wire-free solution, the Wyze Battery Cam Pro offers powerful features without the hassle of cables.
Features:
  • 2.5K HDR Video: High-resolution video with HDR for balanced lighting.
  • Wireless & No Hub Required: Connects directly to WiFi (2.4 & 5 GHz).
  • Integrated Spotlight & Siren: Enhances security with bright light and loud siren.
  • Radar + PIR Motion Detection: Advanced motion sensing for accurate alerts.
  • Removable Rechargeable Battery: Up to 6 months of battery life on a single charge.
  • IP65 Weatherproof: Built to withstand outdoor conditions.
  • Two-Way Audio: Communicate through the built-in speaker and microphone.
  • Supports Up to 256GB microSD Storage: Local video storage option.
Ideal for flexible placement anywhere around your property without worrying about power outlets.
Essential Accessories for Outdoor Use and Stack Kit Compatibility
Wyze Outdoor Power Adapter
To ensure your Wyze cameras perform optimally outdoors, the Wyze Outdoor Power Adapter is a must-have accessory.
  • IP67 Weather Resistant: Ready for rain, snow, or shine.
  • Compatible Models: Required for Wyze Cam v3 Pro, Pan v3, and Battery Cam Pro (with USB-C adapter).
  • Cable Length: 12.5 ft cable for flexible installation.
  • Includes: Wire clips, screws, weatherproof L-shaped Micro USB adapter.
  • Note: Not compatible with OG Stack Kit.
This adapter guarantees safe and reliable power for your outdoor cameras, extending their usability in harsh weather.
Wyze Plug Outdoor
Power your outdoor devices smartly with the Wyze Plug Outdoor.
  • IP64 Weather Rating: Durable for outdoor use.
  • Dual Outlets: Control two devices independently.
  • App Control: Schedule, monitor energy usage, and control remotely.
  • Voice Control: Works with Alexa.
  • WiFi Range: Up to 300 feet for flexible placement.
  • Operating Temperature: -4°F to 120°F.
Perfect for powering garden lights, holiday decorations, or other outdoor electronics alongside your security setup.
Why Choose Wyze Indoor/Outdoor Cameras with Stack Kit Compatibility?
Wyze cameras combine high-quality video, smart home integration, and rugged weather resistance to provide comprehensive security solutions for any environment. Whether you want wired or wireless options, panoramic views, or battery-powered flexibility, Wyze has you covered.
With stack kit compatibility, these cameras and accessories integrate smoothly into your existing Wyze ecosystem, making setup and management easier than ever.
Summary of Featured Products
ProductKey FeaturesWeather ResistancePower SourceStack Kit Compatible
Wyze Cam v42.5K QHD, Color Night Vision, Wi-Fi 6IP65Wired (Micro USB)Yes
Wyze Cam Pan v3360° Pan/Tilt, 1080p, Two-Way AudioIP65Wired (Micro USB)Yes (with adapter)
Wyze Battery Cam Pro2.5K HDR, Wireless, Rechargeable BatteryIP65Battery PoweredYes (with adapter)
Wyze Outdoor Power AdapterIP67, Weatherproof power adapterIP67Wired (Power Adapter)Required for outdoor
Wyze Plug OutdoorSmart outdoor plug, 2 outlets, AlexaIP64Wired (Plug)Yes
Wyze Cam Floodlight v2 Lifestyle Smart outdoor lighting and security with Wyze Cam Floodlight v2.
Enhance your home security with Wyze’s reliable indoor/outdoor WiFi cameras and accessories designed for stack kit compatibility. Enjoy peace of mind with smart features, weatherproof durability, and seamless integration into your smart home ecosystem.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Outdoor Power AdapterWyze Plug Outdoor
TypeWired Security CameraWired Pan & Tilt Security CameraWire-Free Battery Security CameraPower AdapterOutdoor Smart Plug
Video Resolution2.5K QHD (2560x1440)Not specified (award-winning pan & tilt)2.5K HDR (2560x1440)N/AN/A
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt134° (DFOV), 108° (HFOV), 56° (VFOV)N/AN/A
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)Color Night Vision with Starlight Sensor2 IR LEDs (850 nm), 2 White LEDs (5500K)N/AN/A
AudioEnhanced Two-Way Talk, 99 dB SirenTwo-Way AudioTwo-Way Audio, 100 dB SirenN/AN/A
Motion DetectionYes, with motion detection zonesYes, with motion tracking and zonesRadar + PIR Motion DetectionN/AN/A
Power SourceWired (6-foot micro USB cable included)Wired (requires Outdoor Power Adapter for outdoor use)Removable, Rechargeable Battery PacksAC to 5V DC, Micro USB output120V AC, 2 Outlets
Weather ResistanceIP65IP65 (requires Outdoor Power Adapter for outdoor use)IP65IP67IP64
Wireless ConnectivityWi-Fi 6 (2.4 GHz & Wi-Fi 6)Wi-Fi (2.4 GHz)Wi-Fi 2.4 & 5 GHzN/A2.4 GHz Wi-Fi, Bluetooth V4.2
Local Storage SupportmicroSD card up to 512 GB (sold separately)microSD card supportmicroSD card up to 256 GBN/AN/A
Cloud StorageSubscription availableSubscription availableSubscription availableN/AN/A
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/AAlexa
Dimensions2in x 2in x 2 3/8in (0.49 lb)Not specified2.5 x 1.8 x 3.5 in (0.94 lb)78.7 mm x 62.5 mm x 29.4 mm (235 g)4.0" x 2.8" x 1.4" (7.2 oz)
Mounting OptionsStand, Wall, Ceiling, Magnetic MountWall mount1/4" - 20 standard, Wall mount includedWall plug with Micro USB connectorPlugs into standard outdoor outlet
Battery LifeN/A (wired)N/A (wired)Up to 6 monthsN/AN/A
Price (Single Pack)$35.98$39.98$159.98$14.99 - $19.99 (varies by style)$15.99
Additional FeaturesMotion-activated spotlight, Siren, AI Auto-Zoom, Smoke & CO alertsAutomatic motion tracking, Privacy Mode, Pan Scan™ PatrolIntegrated Spotlight & Siren, Radar + PIR detectionWeatherproof for outdoor useEnergy monitoring, Scheduling, App control
What are the best Wyze indoor and outdoor WiFi cameras with stack kit compatibility?The best Wyze indoor and outdoor WiFi cameras with stack kit compatibility include the Wyze Cam v4, Wyze Cam Pan v3, and Wyze Battery Cam Pro. These cameras offer high-resolution video, weather resistance, smart home integration, and seamless compatibility with Wyze stack kits for easy setup and management.
Is the Wyze Cam v4 suitable for both indoor and outdoor use?Yes, the Wyze Cam v4 is designed for both indoor and outdoor use. It features IP65 weather resistance, making it durable in rain or shine, and offers flexible mounting options for various locations around your home.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, IP65 weather resistance, Wi-Fi 6 support, smart assistant integration (Alexa, Google Assistant, IFTTT), local and cloud storage options, and multiple mounting options.
Does the Wyze Cam Pan v3 work outdoors?Yes, the Wyze Cam Pan v3 is IP65 weather resistant and can be used outdoors. For outdoor installation, it requires the Wyze Outdoor Power Adapter to ensure safe and reliable power supply.
What makes the Wyze Cam Pan v3 ideal for large area monitoring?The Wyze Cam Pan v3 features 360° horizontal pan and 180° vertical tilt, allowing it to cover every angle with smooth, fast rotation. It also includes motion tracking, two-way audio, and smart home compatibility for comprehensive monitoring.
Is the Wyze Battery Cam Pro completely wireless?Yes, the Wyze Battery Cam Pro is a wire-free, battery-powered security camera. It connects directly to WiFi (2.4 & 5 GHz) and does not require a hub, offering flexible placement anywhere around your property.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro features a removable rechargeable battery that can last up to 6 months on a single charge, depending on usage and environmental conditions.
What is the Wyze Outdoor Power Adapter and why is it needed?The Wyze Outdoor Power Adapter is a weather-resistant (IP67) accessory designed to provide safe and reliable power to Wyze cameras used outdoors, such as the Wyze Cam v3 Pro, Pan v3, and Battery Cam Pro (with USB-C adapter). It includes a 12.5 ft cable and weatherproof connectors for flexible installation.
Are Wyze cameras compatible with smart home assistants?Yes, Wyze cameras such as the Cam v4, Cam Pan v3, and Battery Cam Pro are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.
What storage options are available for Wyze indoor/outdoor cameras?Wyze cameras support both local and cloud storage. Local storage is available via microSD cards (up to 512GB for Cam v4 and up to 256GB for Pan v3 and Battery Cam Pro). Optional cloud storage plans are also available for continuous recording and event history.
What is the Wyze Plug Outdoor and how can it be used?The Wyze Plug Outdoor is a smart outdoor plug with dual outlets, IP64 weather resistance, and app control. It allows you to schedule, monitor energy usage, and control outdoor devices remotely. It is ideal for powering garden lights, holiday decorations, or other outdoor electronics.
Why choose Wyze cameras with stack kit compatibility for home security?Wyze cameras with stack kit compatibility offer high-quality video, smart home integration, weatherproof durability, and easy installation. Stack kit compatibility ensures seamless integration with your existing Wyze ecosystem, making setup and management straightforward for comprehensive home security.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Battery Cam Pro and its capabilities?Are there any ongoing sales or discounts available for Wyze products?
