Wyze Cam Solar & Battery Solutions for Power Outage Protection
Reliable Charging Solutions for Wyze Cams in Power Outage Areas
When it comes to securing your home or property with Wyze cameras in areas prone to power outages, having a dependable charging solution is essential. Wyze offers a range of products designed to keep your cameras powered longer and ensure continuous surveillance without interruption. Below, we explore the best Wyze charging accessories and cameras tailored for reliable, wire-free operation.
Wyze Battery Cam Pro + Solar Panel: Ultimate Wire-Free Security
Key Features and Benefits
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with 2560 x 1440 resolution, ensuring you never miss a detail.
  • Integrated Spotlight & Siren: Deter intruders with a built-in spotlight and a loud 100 dB siren.
  • Radar + PIR Motion Detection: Advanced motion sensing for accurate alerts.
  • Removable, Rechargeable Battery Packs: Comes with a powerful 6200mAh battery that lasts up to 6 months on a single charge.
  • IP65 Weatherproof Rating: Built to withstand harsh weather conditions, perfect for outdoor use.
  • Dual-Band WiFi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Why It’s Ideal for Power Outage Areas
The Wyze Battery Cam Pro’s rechargeable battery packs provide long-lasting power without the need for constant wiring. When paired with the Wyze Battery Cam Solar Panel, it becomes a self-sustaining security system that harnesses solar energy to extend battery life indefinitely, even during extended power outages.
Wyze Battery Cam Solar Panel: Harness the Sun for Continuous Power
Product Highlights
  • Extend Battery Life: Designed specifically to work with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, this solar panel keeps your camera charged by converting sunlight into power.
  • Weather Resistant (IP65): Durable against rain, dust, and other outdoor elements.
  • Easy 360° Mount: Flexible mounting options let you position the panel for optimal sun exposure.
  • 13-foot Power Cable: Provides versatile installation options, allowing you to place the solar panel in the sunniest spot while your camera stays mounted securely.
  • Compact Dimensions: 173 mm x 120 mm x 17 mm, with a sleek white frame and black solar cells.
Benefits for Areas Prone to Power Outages
By running your Wyze Battery Cam Pro on solar power, you eliminate the worry of battery drain during outages. The solar panel ensures your camera remains operational day and night, providing peace of mind and uninterrupted security monitoring. Outdoor Security with Solar Power
Wyze Removable Battery Pack: Backup Power on Demand
Features at a Glance
  • 6200mAh Rechargeable Battery: Matches the capacity of the original battery pack, providing up to 6 months of power.
  • USB-C Charging Port: Convenient and fast charging with modern USB-C technology.
  • Compact and Lightweight: Measures 2.9 in x 1.6 in x 0.9 in and weighs just 3.9 oz, making it easy to swap batteries quickly.
  • Wide Operating Temperature Range: Performs reliably from -4°F to 122°F, suitable for various climates.
  • Perfect for Extended Use: Keep a spare battery on hand to swap out and maintain continuous camera operation during long power outages or travel.
Why It Complements Solar Charging
While the solar panel provides ongoing power, having a removable battery pack ensures you can quickly replace depleted batteries without downtime. This combination is perfect for remote or off-grid locations where power reliability is a concern.
Conclusion: The Best Power Solutions for Wyze Cams in Outage-Prone Areas
For those living in regions with frequent power interruptions, the Wyze Battery Cam Pro combined with the Wyze Battery Cam Solar Panel and an extra Wyze Removable Battery Pack offers a comprehensive, reliable charging solution. This setup guarantees your security cameras stay powered, weatherproof, and ready to protect your home 24/7 without the hassle of wiring or frequent battery changes.
"Harness solar energy and backup batteries to keep your Wyze cams running no matter the power situation."
Wyze Battery Cam Pro in Action
Product Summary
Product NameKey FeatureIdeal Use Case
Wyze Battery Cam ProLong battery life, 2.5K HDR videoPrimary security camera
Wyze Battery Cam Solar PanelSolar-powered charging, weatherproofContinuous power in outdoor setups
Wyze Removable Battery PackSpare rechargeable batteryQuick battery swaps, backup power
Secure Outdoor Home
Product Tags Recap
By choosing these Wyze products, you ensure your security system remains operational and reliable, even in the most challenging power outage scenarios. Invest in smart, sustainable power solutions today for uninterrupted peace of mind.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam Pro + Solar PanelWyze Removable Battery Pack
Product TypeAccessoryCamera Bundle (Camera + Solar Panel)Accessory
Compatible DevicesWyze Cam Outdoor v1/v2, Wyze Battery Cam ProWyze Battery Cam ProWyze Battery Cam Pro, Wyze Duo Cam Doorbell
Video ResolutionN/A2.5K HDRN/A
Power SourceSolar Panel (extends battery life)Battery Cam Pro with Solar Panel for continuous power6200mAh rechargeable battery
Battery LifeExtends battery life of compatible camerasUp to 6 months (Battery Cam Pro)Up to 6 months on one charge
Weather ResistanceIP65 (weatherproof and dustproof)IP65Operating temp: -4°F to 122°F, humidity <90%
Mounting360° freestyle mount, mountable anywhereFlexible mounting optionsN/A
Cable Length13-foot weatherproof power cableIncluded with Solar PanelN/A
Included ItemsSolar Panel or USB-C Adapter Cable (variants)Wyze Battery Cam Pro + Solar PanelRechargeable battery pack
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)$109.98 (Camera + Solar Panel bundle)$22.99
Charging TimeN/AApproximately 9 hours (battery charging)Approximately 9 hours at 77°F
WirelessN/AYesN/A
Additional FeaturesWeather resistant, mountable anywhereIntegrated spotlight & siren, radar + PIR motion detectionUSB-C charging port, lithium-ion battery
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What is the best Wyze camera solution for areas with frequent power outages?The Wyze Battery Cam Pro, especially when paired with the Wyze Battery Cam Solar Panel and a Wyze Removable Battery Pack, is the best solution for areas prone to power outages. This setup ensures continuous, wire-free operation and reliable security monitoring even during extended outages.
How does the Wyze Battery Cam Pro stay powered during a power outage?The Wyze Battery Cam Pro features a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge. When combined with the Wyze Battery Cam Solar Panel, the camera can be continuously charged using solar energy, ensuring uninterrupted operation during power outages.
Can I use a solar panel to charge my Wyze camera?Yes, the Wyze Battery Cam Solar Panel is designed to work with the Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro. It converts sunlight into power, keeping your camera charged and operational even when the main power is out.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel has an IP65 weather-resistant rating, making it durable against rain, dust, and other outdoor elements. It is ideal for outdoor installations in various climates.
How long does the Wyze Removable Battery Pack last?The Wyze Removable Battery Pack has a 6200mAh capacity, providing up to 6 months of power for your Wyze Battery Cam Pro, depending on usage and environmental conditions.
What are the benefits of using a removable battery pack with my Wyze camera?Using a removable battery pack allows you to quickly swap out depleted batteries, ensuring your Wyze camera remains operational without downtime. This is especially useful during long power outages or when solar charging is not available.
Can the Wyze Battery Cam Pro connect to both 2.4 GHz and 5 GHz WiFi networks?Yes, the Wyze Battery Cam Pro supports dual-band WiFi, allowing it to connect seamlessly to both 2.4 GHz and 5 GHz networks for flexible installation and reliable connectivity.
Is the Wyze Battery Cam Pro suitable for outdoor use?Absolutely. The Wyze Battery Cam Pro is IP65 weatherproof, making it ideal for outdoor security in various weather conditions.
Does the Wyze Battery Cam Pro support smart home integration?Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What is included with the Wyze Battery Cam Pro?The Wyze Battery Cam Pro comes with a removable, rechargeable 6200mAh battery pack, integrated spotlight and siren, advanced motion detection, and support for dual-band WiFi. The solar panel and additional battery packs are sold separately.
What are the key features of the Wyze Battery Cam Pro?How does the Wyze Battery Cam Solar Panel work with the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
