Smart Security System: Wyze Cameras with Motion Alert Notifications
Smart Security System with Wyze Cameras and Integrated Motion Alert Notifications
Enhance your home security with Wyze’s cutting-edge smart cameras and integrated motion alert notifications. Whether you want to monitor your indoor spaces, outdoor areas, or large properties, Wyze offers a range of reliable, weather-resistant cameras with advanced features like two-way audio, motion-activated spotlights, and seamless app integration. Discover how Wyze cameras can provide you with peace of mind through real-time alerts and crystal-clear video streaming.
Wyze Cam OG: The Next Generation Smart Camera
Key Features
  • 1080p Full HD Video Resolution with CMOS-Starlight Sensor for clear day and night vision.
  • 120° Field of View captures wide areas indoors or outdoors.
  • 3X Faster Notifications ensure you get instant motion alerts.
  • Built-in 40 Lumen Spotlight and 90-decibel user-activated siren for active deterrence.
  • Upgraded Two-Way Audio with noise and echo cancellation for clear communication.
  • Supports up to 256 GB microSD local storage for continuous recording.
  • Weather Resistant IP65 Rating suitable for outdoor use in temperatures from -4°F to 131°F.
  • Custom Detection Zones to reduce false alerts and focus on important areas.
  • Compatible with Android 9.0+ and iOS 15.0+ devices.
The Wyze Cam OG is perfect for those who want a versatile, plug-in camera that works seamlessly indoors or outdoors with quick live streaming and reliable motion alerts.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Coverage
Wyze Cam Pan v3 in snowy outdoor setting Weather-resistant Wyze Cam Pan v3 providing full outdoor coverage
Highlights
  • 360° Horizontal and 180° Vertical View Range covers every angle of your property.
  • 1080p HD Video with 20 FPS Day / 15 FPS Night for smooth, clear footage.
  • Automatic Motion Tracking follows moving objects to keep them in frame.
  • Color Night Vision powered by 4 IR LEDs.
  • Two-Way Audio with noise and echo cancellation.
  • IP65 Weather Resistance for reliable outdoor use (requires Wyze Outdoor Power Adapter).
  • Supports up to 256 GB microSD local storage.
  • Integrates with Alexa, Google Assistant, and IFTTT for smart home automation.
  • Compatible with Android 9.0+ and iOS 15.0+.
Ideal for monitoring large areas like backyards or driveways, the Wyze Cam Pan v3 ensures you never miss a moment with its dynamic pan-tilt capabilities and instant motion alerts.
Wyze Cam v4: Advanced 2.5K QHD Resolution and Color Night Vision
Features at a Glance
  • 2.5K QHD (2560x1440) Video Resolution for ultra-clear images.
  • Enhanced Color Night Vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens).
  • 115.8° Diagonal Field of View captures broad scenes.
  • Built-in 99dB Waterproof Siren and two-way talk with noise cancellation.
  • Wi-Fi 6 Support for faster, more stable connections.
  • Local microSD Storage up to 512 GB plus cloud storage options.
  • IP65 Weather Resistance for indoor/outdoor versatility.
  • Compatible with Alexa, Google Assistant, and IFTTT.
Wyze Cam v4 is perfect for users seeking high-resolution video and enhanced night vision with smart alerts and voice assistant compatibility.
Wyze Bulb Cam: 2-in-1 Security Camera and Smart LED Light
Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam combines security and lighting in one smart device
Why Choose Wyze Bulb Cam?
  • 2K HD Video (2304 x 1296) with wide 160° field of view.
  • Color Night Vision and IR night vision for clear images day and night.
  • Motion-Activated Light and Instant Push Notifications keep you informed.
  • Up to 800 lumens brightness with 3000K warm light color temperature.
  • Standard E26 Socket fits most outdoor fixtures for easy installation.
  • Supports local microSD storage up to 256 GB and cloud storage.
  • 95 dB Siren and two-way audio for active security.
  • IP65 Weather Resistant for reliable outdoor use.
  • Compatible with Android 7.0+ and iOS 14.0+.
This innovative camera doubles as a smart light bulb, making it an excellent choice for porch or garage security with integrated motion alerts.
Essential Security Bundle: Comprehensive Home Protection
Bundle Includes:
  • Wyze Video Doorbell v2: Crisp 1080p HD video, two-way audio, and person detection.
  • Wyze Lock Bolt: Smart lock with fingerprint sensor and backlit keypad.
  • Wyze Cam Pan v3: 360° pan, 180° tilt, motion tracking, and color night vision.
  • Two Wyze Cam OG Cameras: Plug-in cameras with motion-activated spotlights and color night vision.
This all-in-one package offers a complete smart security system with integrated motion alert notifications, cloud and local recording, and voice assistant compatibility — perfect for safeguarding your entire home.
Why Choose Wyze Cameras for Your Smart Security System?
Wyze cameras combine affordability with advanced technology, offering fast live streaming, reliable motion detection, and instant alert notifications directly to your smartphone. Their IP65 weather resistance and versatile mounting options make them suitable for both indoor and outdoor use. Integration with Alexa, Google Assistant, and IFTTT allows you to customize your smart home security experience.
With Wyze’s smart security solutions, you get peace of mind knowing your home is protected 24/7 with real-time alerts and high-quality video monitoring.
FeatureWyze Cam OGWyze Cam Pan v3Essential Security BundleWyze Cam v4Wyze Bulb Cam
TypeWired Security CameraWired Pan & Tilt Security CameraBundle (Doorbell v2, Lock Bolt, Pan v3, 2× Cam OG)Wired Security CameraLighting Camera & Security Camera
Video Resolution1080p HD1080p HDIncludes Cam Pan v3 (1080p) and 2× Cam OG (1080p)2.5K QHD (2560x1440)2K (2304 x 1296)
Field of View120°360° pan, 180° tiltPan v3: 360° pan, 180° tilt; Cam OG: 120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°160° (diagonal 166°)
Night VisionColor Night VisionColor Night VisionColor Night Vision (Pan v3 & Cam OG)Enhanced Color Night VisionColor Night Vision + IR Night Vision
Weather ResistanceIP65 (Indoor/Outdoor)IP65 (Indoor/Outdoor with Outdoor Power Adapter)IP65 (Pan v3 & Cam OG)IP65 (Indoor/Outdoor)IP65 (Outdoor)
Two-Way AudioYesYesYes (Pan v3 & Cam OG)YesYes
Motion Detection & Notifications3x Faster NotificationsMotion & Sound Detection, Auto Motion TrackingCloud & Local Recording, Real-time Alerts, Motion-Activated Voice DeterrenceYes, with Motion Detection ZonesMotion Alerts
SpotlightBuilt-in 40-lumen SpotlightNoMotion-Activated Spotlight (Cam OG)Motion-Activated SpotlightMotion-Activated Light
Siren90 dB User-Activated Mini SirenNoIncluded in Cam OGBuilt-in Siren95 dB Siren at 4 in
Local Storage SupportmicroSD up to 256GBmicroSD supportIncluded (Cam OG & Pan v3 support microSD)microSD up to 512GBmicroSD up to 256GB (exFAT format)
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableSubscription plan availableAWS Cloud Storage
Audio QualityUpgraded 2-way audioTwo-way audioTwo-way audio (Pan v3 & Cam OG)Improved 2-way audioBuilt-in digital microphone
Power SourcePlug-in WiredPlug-in WiredPlug-in Wired (Pan v3 & Cam OG)WiredStandard E26 Socket (120V AC)
DimensionsNot specifiedNot specifiedNot specified2in x 2in x 2 3/8inNot specified
WeightNot specifiedNot specifiedNot specified0.49 lb (222 g)Not specified
Special FeaturesBuilt-in Spotlight, Mini Siren, 3x Faster Notifications360° Pan & 180° Tilt, Auto Motion Tracking, Privacy ModeIncludes Video Doorbell v2, Smart Lock Bolt, 2× Cam OG, Pan v3Wi-Fi 6, Alexa & Google Assistant Compatible2-in-1 LED Bulb & Security Camera, Up to 800 lm Brightness
Price (Single Pack)$29.98$39.98$199.99 (Bundle)$107.94$49.98
What are the key features of Wyze smart security cameras?Wyze smart security cameras offer advanced features such as high-definition video resolution, motion-activated spotlights, two-way audio with noise cancellation, instant motion alert notifications, weather-resistant IP65 ratings, and seamless app integration. They also support local microSD storage and cloud recording, making them ideal for both indoor and outdoor security.
How do Wyze cameras provide motion alert notifications?Wyze cameras use advanced motion detection technology to send instant push notifications to your smartphone whenever motion is detected. You can customize detection zones to focus on important areas and reduce false alerts, ensuring you are always informed about activity around your property.
What is the difference between Wyze Cam OG, Cam Pan v3, Cam v4, and Bulb Cam?Wyze Cam OG is a versatile plug-in camera with 1080p HD video, a built-in spotlight, and fast notifications. Wyze Cam Pan v3 offers 360° pan and 180° tilt for complete coverage and automatic motion tracking. Wyze Cam v4 features 2.5K QHD resolution, enhanced color night vision, and Wi-Fi 6 support. Wyze Bulb Cam combines a 2K HD security camera with a smart LED light, offering a wide 160° field of view and easy installation in standard E26 sockets.
Are Wyze cameras suitable for outdoor use?Yes, most Wyze cameras, including the Cam OG, Cam Pan v3, Cam v4, and Bulb Cam, are IP65 weather resistant, making them suitable for outdoor use in various weather conditions. They can operate in temperatures ranging from -4°F to 131°F, providing reliable security year-round.
Can Wyze cameras record video locally and to the cloud?Wyze cameras support local video recording via microSD cards (up to 256 GB or 512 GB depending on the model) for continuous or event-based recording. They also offer cloud storage options for added backup and remote access to recorded footage.
Do Wyze cameras work with smart home assistants?Yes, Wyze cameras are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT. This allows you to integrate your cameras into your smart home system for voice control and automation.
What is included in the Wyze Essential Security Bundle?The Wyze Essential Security Bundle includes a Wyze Video Doorbell v2, Wyze Lock Bolt smart lock, Wyze Cam Pan v3, and two Wyze Cam OG cameras. This comprehensive package provides complete home protection with features like HD video, motion tracking, person detection, and smart lock access.
How easy is it to install Wyze cameras and Bulb Cam?Wyze cameras are designed for easy installation, with versatile mounting options for both indoor and outdoor use. The Wyze Bulb Cam fits standard E26 sockets, making it simple to install in most outdoor light fixtures without additional wiring.
What makes Wyze cameras a good choice for home security?Wyze cameras combine affordability with advanced technology, offering high-quality video, reliable motion detection, instant alerts, and smart home integration. Their weather resistance and flexible installation options make them suitable for any home security setup, providing peace of mind with 24/7 monitoring.
Which devices are compatible with Wyze cameras?Wyze cameras are compatible with Android devices running version 7.0 or higher (9.0+ for some models) and iOS devices running version 14.0 or higher (15.0+ for some models). Always check the specific camera model for exact compatibility requirements.
What are the key features of the Wyze Cam OG?How does the motion tracking feature work on the Wyze Cam Pan v3?Do you have any deals, ongoing sales, discounts, or promotions for Wyze cameras?
