Smart Outdoor Power Adapter Compatible with Wyze Cams
When it comes to powering your Wyze outdoor cameras, having the right power adapter is essential for reliable, weatherproof performance. The
Wyze Outdoor Power Adapter is specifically designed to meet the voltage and connectivity needs of Wyze outdoor cameras, including the Wyze Cam v3 Pro, Pan v3, and Battery Cam Pro. This adapter ensures your cameras stay powered rain or shine, providing continuous security and monitoring.
Wyze Outdoor Power Adapter: Built for All Weather Conditions
Weather-Resistant and Durable
The Wyze Outdoor Power Adapter boasts an
IP67 weather-resistant rating, making it ready for rain, snow, or shine. Whether you live in a rainy climate or experience heavy snowfall, this adapter protects your Wyze cameras from the elements, ensuring uninterrupted power supply outdoors.
Compatibility and Voltage Details
- Works with Wyze Cam v4, OG series, Cam Pan v3, and Cam v3 Pro (when paired with the L-shaped Micro USB Adapter).
- Required for Wyze Battery Cam Pro when used with the USB-C adapter.
- Power output: 5V/2000mA, suitable for Wyze cameras’ voltage needs.
- Input voltage supports 110-240V (AC/DC), making it versatile for various power sources.
⚠️ Note: The Outdoor Power Adapter will NOT work with the OG Stack Kit.
Convenient Variants
- Outdoor Adapter + L-shaped Adapter + USB-C Adapter bundle for $19.99.
- L-shaped Micro USB Adapter sold separately for $5.99.
- Some bundles may be out of stock, but the main adapter remains available.
Wyze Cam Pan v3: The Perfect Outdoor Camera Companion
360° Pan and 180° Tilt with IP65 Weather Resistance
The
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring a
360° horizontal pan and
180° vertical tilt. Its
IP65 rating ensures it withstands outdoor conditions, but for safe outdoor use, pairing it with the Wyze Outdoor Power Adapter is essential.
Key Specifications
- Video resolution: 1080p Full HD with H.264 encoding.
- Night vision: 4 IR LEDs (850 nm) for clear images in the dark.
- Field of view: 120° FOV with 8x digital zoom.
- Built-in speaker and microphone enable 2-way audio with noise and echo cancellation.
- Connectivity: 2.4 GHz Wi-Fi (no 5 GHz support).
- Power adapter output: 5V/2000mA, matching the Wyze Outdoor Power Adapter.
Easy Installation and Smart Features
- Mounts easily with a 1/4" - 20 screw mount.
- Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
- Supports up to 256 GB microSD card for local storage.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For those looking to get started quickly, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the camera, power adapter, and mounting kit in one package. This bundle ensures you have everything needed for seamless outdoor security setup.
- Includes 1x Wyze Cam Pan v3, 1x 6' micro USB cable, 1x power adapter, and mounting kit.
- Comes with a 30-day trial of Cam Plus for enhanced cloud storage and intelligent alerts.
- Same IP65 weather resistance and 1080p video quality as the standalone camera.
Lifestyle and Usage
Experience reliable outdoor security with Wyze Cam Pan v3 powered by the Wyze Outdoor Power Adapter, ready for all weather conditions.
The Wyze Outdoor Power Adapter combined with the Wyze Cam Pan v3 creates a robust outdoor security solution. Whether monitoring your home, garden, or driveway, this setup ensures your camera stays powered and protected from the elements.
Why Choose Wyze Outdoor Power Adapter for Your Wyze Cameras?
- Perfect Voltage Match: Designed to deliver the exact 5V/2000mA power output required by Wyze outdoor cameras.
- Weatherproof Design: IP67 rating means it can handle harsh outdoor environments without fail.
- Versatile Compatibility: Supports multiple Wyze camera models with the appropriate adapters.
- Affordable and Reliable: Priced reasonably with options for bundles and individual adapters.
Summary
For anyone searching for a
smart outdoor power adapter compatible with Wyze cams, the
Wyze Outdoor Power Adapter is the ideal choice. It meets the voltage needs of Wyze outdoor cameras like the Cam v3 Pro and Pan v3, ensuring continuous operation regardless of weather. Pair it with the Wyze Cam Pan v3 or the convenient Pan v3 bundle to enjoy seamless, weather-resistant outdoor security.
What is the Wyze Outdoor Power Adapter and what cameras is it compatible with?
The Wyze Outdoor Power Adapter is a weather-resistant power supply designed specifically for Wyze outdoor cameras. It is compatible with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (when used with the L-shaped Micro USB Adapter), and is required for Wyze Battery Cam Pro when used with the USB-C adapter. It is not compatible with the OG Stack Kit.Is the Wyze Outdoor Power Adapter weatherproof?
Yes, the Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it suitable for use in rain, snow, or shine. It is built to protect your Wyze cameras from harsh outdoor elements and ensure uninterrupted power supply.What is the power output and input voltage of the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter provides a power output of 5V/2000mA, which matches the voltage requirements of Wyze outdoor cameras. It supports an input voltage of 110-240V (AC/DC), making it versatile for various power sources.Can I use the Wyze Outdoor Power Adapter with the Wyze Cam Pan v3?
Yes, the Wyze Outdoor Power Adapter is recommended for the Wyze Cam Pan v3 to ensure safe and reliable outdoor use. The adapter provides the necessary power and weather resistance for continuous operation.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes one Wyze Cam Pan v3, a 6-foot micro USB cable, a power adapter, a mounting kit, and a 30-day trial of Cam Plus for enhanced cloud storage and intelligent alerts.What are the key features of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 features 360° horizontal pan, 180° vertical tilt, IP65 weather resistance, 1080p Full HD video resolution, night vision with 4 IR LEDs, 120° field of view, 8x digital zoom, 2-way audio with noise and echo cancellation, and compatibility with Alexa, Google Assistant, and IFTTT.Are there different variants or bundles available for the Wyze Outdoor Power Adapter?
Yes, the Wyze Outdoor Power Adapter is available as a bundle with an L-shaped Adapter and USB-C Adapter for $19.99. The L-shaped Micro USB Adapter can also be purchased separately for $5.99. Availability may vary depending on stock.Why should I choose the Wyze Outdoor Power Adapter for my Wyze cameras?
The Wyze Outdoor Power Adapter is designed to deliver the exact voltage required by Wyze outdoor cameras, features a weatherproof IP67 rating, supports multiple camera models with the right adapters, and is affordably priced with bundle options for added convenience.Does the Wyze Cam Pan v3 support local storage?
Yes, the Wyze Cam Pan v3 supports local storage with a microSD card of up to 256 GB capacity, allowing you to record and store footage directly on the device.Is the Wyze Cam Pan v3 compatible with smart home systems?
Yes, the Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, making it easy to integrate into your smart home setup.
