Smart Outdoor Doorbells with Pre-Roll Recording for Extra Security
Enhance your home security with smart outdoor doorbells that offer advanced pre-roll recording features. These devices capture crucial moments before motion is detected, giving you a complete picture of any activity at your doorstep. Below, we highlight the top Wyze products designed to provide exceptional outdoor security, combining high-quality video, smart lighting, and seamless integration for peace of mind.
Wyze Cam Floodlight Pro: Ultimate Outdoor Security with Smart Lighting
Key Features
- 2.5K QHD Video Quality: Crystal-clear 2560x1440 resolution with color night vision ensures you never miss a detail.
- 180° Wide-Angle Lens: Covers your entire yard or porch with a broad field of view (180° diagonal).
- Pre-Roll Recording: Captures video up to 3 seconds before motion is detected, providing context to events.
- AI-Powered Motion Detection: Detects people and vehicles specifically, reducing false alerts.
- 3,000 Lumens LED Floodlights: Bright, adjustable lighting that activates only when needed, enhancing visibility and security.
- Siren Alarm: 105dB siren to deter intruders effectively.
- Dual-Band WiFi Support: Connects via 2.4 GHz and 5 GHz networks for reliable streaming.
- Weatherproof IP65 Rating: Built to withstand harsh outdoor conditions from -4°F to 140°F (-20°C to 60°C).
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Why Choose Wyze Cam Floodlight Pro?
This device acts like a personal security guard with bright lights and intelligent alerts. Its pre-roll recording feature ensures you capture the full story, not just the aftermath. Perfect for front doors, backyards, and side entrances, it offers comprehensive protection with minimal setup.
Experience smart security lighting that responds to your home's needs.
Cam v4 + Lamp Socket v2 Bundle: Smart Doorbell Power and Lighting Solution
Key Features
- Convenient Power Supply: The Lamp Socket v2 powers the Wyze Cam v4 without needing an external outlet, simplifying installation.
- Motion-Activated Lights: Automatically turns on lights when motion is detected, enhancing visibility and security.
- Dusk to Dawn Scheduling: Lights operate automatically based on ambient light, saving energy.
- Linkability: Connect multiple devices without limits for expanded coverage.
- Compact and Durable: Made from polycarbonate and plastic, suitable for damp outdoor locations (not fully weatherproof).
- Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 cameras.
- Smartphone Compatibility: Works with Android 7.0+ and iOS 12.0+.
- Connectivity: Uses 2.4 GHz WiFi and Bluetooth for reliable communication.
Ideal Use Case
This bundle is perfect for users who want to upgrade their existing Wyze Cam v4 with smart lighting and hassle-free power options. The lamp socket eliminates the need for complex wiring, making it an excellent choice for porch or entryway installations.
Pan v3 + Lamp Socket v2 Bundle: Flexible Smart Camera with Power Convenience
Key Features
- Pan and Tilt Functionality: Offers 360° horizontal and 93° vertical rotation for full coverage.
- Lamp Socket Power: Powers the Pan v3 camera without an outlet, ideal for outdoor lighting fixtures.
- Smart Lighting Control: Enables motion-activated lighting to deter unwanted visitors.
- Compact Design: Small footprint (56.5mm x 56.5mm x 65mm) fits easily in most lamp sockets.
- Durability: Suitable for damp locations but not fully weatherproof.
- Compatibility: Supports multiple Wyze Cam models including Pan v3 and v4.
- Connectivity: 2.4 GHz WiFi and Bluetooth support.
- Smartphone Support: Compatible with Android 7.0+ and iOS 12.0+.
Why It Stands Out
The Pan v3 + Lamp Socket v2 bundle is a versatile solution for those who want a camera with flexible viewing angles combined with smart lighting and easy power options. It’s perfect for porches, garages, or any outdoor area where you want to monitor activity with a wide field of view.
Secure your home with smart lighting and wide-angle video coverage.
Why Pre-Roll Recording Matters for Outdoor Doorbells
Pre-roll recording captures video footage seconds before motion triggers the camera. This feature is crucial for outdoor doorbells because it provides context to events, such as identifying a person approaching your door or a package delivery before the motion alert is sent. It enhances security by reducing blind spots and ensuring you have a complete timeline of activity.
Wyze’s smart cameras, especially the Floodlight Pro, incorporate this technology to give you an edge in home security.
Conclusion
For those seeking a smart outdoor doorbell with pre-roll recording and enhanced security features, Wyze offers a range of products tailored to your needs:
- Wyze Cam Floodlight Pro for powerful lighting and detailed video.
- Cam v4 + Lamp Socket v2 Bundle for easy power and smart lighting integration.
- Pan v3 + Lamp Socket v2 Bundle for flexible camera angles and convenient power.
Each product combines smart technology, weather resistance, and seamless app control to keep your home safe and monitored at all times.
What is pre-roll recording in smart outdoor doorbells and why is it important?
Pre-roll recording is a feature in smart outdoor doorbells that captures video footage a few seconds before motion is detected. This provides important context to events, such as seeing someone approach your door or a package being delivered before the motion alert is triggered. It enhances security by reducing blind spots and ensuring you have a complete timeline of activity at your doorstep.Which Wyze products offer pre-roll recording for outdoor security?
The Wyze Cam Floodlight Pro is a top Wyze product that offers pre-roll recording for outdoor security. This feature allows you to capture up to 3 seconds of video before motion is detected, ensuring you never miss crucial moments.What are the key features of the Wyze Cam Floodlight Pro?
The Wyze Cam Floodlight Pro features 2.5K QHD video quality with color night vision, a 180° wide-angle lens, pre-roll recording, AI-powered motion detection for people and vehicles, 3,000 lumens LED floodlights, a 105dB siren alarm, dual-band WiFi support, weatherproof IP65 rating, and smart home integration with Alexa, Google Assistant, and IFTTT.How does the Wyze Cam Floodlight Pro enhance outdoor security?
The Wyze Cam Floodlight Pro enhances outdoor security by combining high-resolution video, wide-angle coverage, bright motion-activated floodlights, AI-powered motion detection, a loud siren alarm, and pre-roll recording. These features work together to deter intruders, provide clear footage, and ensure you are alerted to any activity around your home.What is included in the Cam v4 + Lamp Socket v2 Bundle?
The Cam v4 + Lamp Socket v2 Bundle includes a Wyze Cam v4 and a Lamp Socket v2. The lamp socket powers the camera without the need for an external outlet and provides motion-activated lighting, dusk to dawn scheduling, and the ability to link multiple devices for expanded coverage.Is the Cam v4 + Lamp Socket v2 Bundle weatherproof?
The Cam v4 + Lamp Socket v2 Bundle is suitable for damp outdoor locations but is not fully weatherproof. It is designed for use in covered areas like porches or entryways.What are the benefits of the Pan v3 + Lamp Socket v2 Bundle?
The Pan v3 + Lamp Socket v2 Bundle offers 360° horizontal and 93° vertical rotation for full coverage, motion-activated lighting, convenient power through the lamp socket, and a compact design. It is ideal for monitoring porches, garages, or any outdoor area where flexible camera angles and easy installation are needed.Are Wyze smart outdoor doorbells compatible with smart home systems?
Yes, Wyze smart outdoor doorbells, such as the Wyze Cam Floodlight Pro, are compatible with popular smart home systems including Alexa, Google Assistant, and IFTTT, allowing for voice control and automation.What connectivity options do Wyze outdoor security cameras support?
Wyze outdoor security cameras support 2.4 GHz WiFi, and some models like the Wyze Cam Floodlight Pro also support 5 GHz WiFi for reliable streaming. Bluetooth is also available for setup and communication in certain bundles.Can I control Wyze outdoor security cameras from my smartphone?
Yes, Wyze outdoor security cameras can be controlled and monitored from your smartphone. They are compatible with Android 7.0+ and iOS 12.0+ devices, allowing you to receive alerts, view live footage, and manage settings through the Wyze app.
