Hardwired Battery Doorbells: Continuous Recording & Pre-Roll
Hardwired Battery Doorbells for Continuous Recording with Extra Pre-Roll Video
When it comes to securing your home entrance with continuous video recording and advanced pre-roll video features, choosing the right hardwired battery doorbell is essential. These smart devices combine wired power reliability with battery backup, ensuring uninterrupted surveillance and detailed video capture. Below, we explore two top Wyze video doorbells that perfectly fit this need: the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell.
Wyze Video Doorbell v2: Wired Power with Crisp 2K Video
Superior Video Quality and Continuous Recording
The Wyze Video Doorbell v2 offers an impressive 2K (2048 x 1536) resolution powered by a CMOS Starlight Sensor, delivering crystal-clear video day and night. With a wide 166.8° diagonal field of view, it captures every detail at your doorstep. The doorbell supports local microSD storage up to 256GB, enabling continuous recording and easy access to pre-roll video clips that capture moments just before motion is detected.
Hardwired for Reliable Power
Designed to operate on 16V-24V AC power, this doorbell ensures continuous operation without worrying about battery life. The hardwired setup guarantees your doorbell stays powered even during extended use, making it ideal for users who want uninterrupted video coverage.
Smart Features for Enhanced Security
  • Two-way audio with an ECM microphone and 8Ω 1W speaker for clear communication
  • Motion-activated voice deterrence to warn unwanted visitors
  • Real-time alerts sent directly to your smartphone
  • IP65 weather resistance for reliable outdoor use in various climates
  • Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration
Included Accessories for Easy Installation
The package includes everything needed for a smooth setup: Wyze Video Doorbell v2, Chime Controller, wall plate, wedge for angled mounting, wire caps, extension wires, screws, wall anchors, and a quick start guide. Wyze Video Doorbell v2 Lifestyle Experience smart home security with Wyze Video Doorbell v2
Wyze Duo Cam Battery Doorbell: Dual Cameras with Hardwired Power Option
Dual Camera Views for Comprehensive Coverage
The Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered doorbell, featuring two cameras: a front-facing 2K camera and a bottom-facing 1080p camera. This dual setup allows you to monitor both visitors and packages simultaneously, reducing blind spots and enhancing security.
Flexible Power Options: Battery or Hardwired
While primarily battery-powered with a 6200 mAh lithium-ion battery, the Duo Cam Doorbell can also be hardwired (10-24V AC) for continuous power and 24/7 local recording. This hybrid power approach ensures you never miss a moment, even if the battery runs low.
Advanced Video and Audio Capabilities
  • Front camera: 2K resolution at 20 FPS (day) and 15 FPS (night)
  • Bottom camera: 1080p resolution with wide horizontal and vertical fields of view
  • 8x digital zoom for detailed close-ups
  • Two-way talk with a sensitive microphone and 90 dB siren for deterrence
  • Motion-activated voice warnings: "Hi, you’re currently being recorded."
  • 6x 850 nm IR lights for clear night vision
Smart Storage and Cloud Integration
Supports up to 256GB microSD card for local storage and AWS Cloud storage for secure backup. Real-time AI detections and alerts notify you of people, packages, and other activities.
Weatherproof and Durable
IP65-rated for weather resistance, the Duo Cam Doorbell withstands harsh outdoor conditions, ensuring reliable performance year-round.
What’s in the Box?
Includes the Wyze Duo Cam Doorbell, Wi-Fi Chime, back plate, corner kit, USB-C charging cable, wire nuts, extension wires, screws, expansion tubes, adhesive tape, doorbell detaching pin, removable battery pack, and quick start guide. Wyze Duo Cam Doorbell Lifestyle Wyze Duo Cam Doorbell offers dual-camera security with flexible power
Why Choose a Hardwired Battery Doorbell with Pre-Roll Video?
Hardwired battery doorbells combine the best of both worlds: the reliability of wired power with the backup and flexibility of battery operation. This ensures continuous recording without interruptions, even during power outages or battery charging cycles. Pre-roll video captures crucial seconds before motion triggers recording, giving you a fuller picture of events at your doorstep.
Both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell support local microSD storage for continuous recording and pre-roll video, making them excellent choices for homeowners seeking dependable, high-quality video doorbells with smart features.
Summary of Key Features
FeatureWyze Video Doorbell v2Wyze Duo Cam Battery Doorbell
Video Resolution2K (2048 x 1536)Front: 2K, Bottom: 1080p
PowerHardwired (16V-24V AC)Battery + Hardwired (10-24V AC)
Continuous RecordingYes, via microSD (up to 256GB)Yes, 24/7 local recording with microSD
Field of View166.8° diagonalFront: 132° horizontal, Bottom: 121°
Night Vision6x 940nm IR lights6x 850nm IR lights
Two-Way AudioYesYes
Motion-Activated Voice WarningYesYes
Weather ResistanceIP65IP65
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Invest in a Wyze hardwired battery doorbell today to enjoy continuous, high-resolution video recording with extra pre-roll video, ensuring your home stays secure and you never miss a moment.
Power SourceWired (AC 16-24 V)Battery-powered (Removable Battery Pack) or Wired
Video Resolution2K (2048 x 1536)Top Camera: 2K; Bottom Camera: 1080p
CamerasSingle cameraDual cameras (people and package views)
Local StoragemicroSD card slot (up to 256GB)microSD card supported (sold separately)
Continuous Local RecordingYes, 24/7 with microSDYes, 24/7 with microSD and hardwired power
Two-Way AudioYesYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect subscription)Yes (requires Cam Plus or Cam Protect subscription)
Field of View (FOV)135° horizontal x 103° verticalTop: 132° x 100°; Bottom: 121° x 60°
Night VisionColor Night Vision with Starlight SensorColor Night Vision with Starlight Sensor
Chime CompatibilityWorks with existing mechanical chime via included Chime ControllerIncludes Wyze Wi-Fi Chime; compatible with Wyze Chime Controller
InstallationScrew mounting, requires existing wiringAdhesive or screw mounting; wire or battery power
Smart Assistant IntegrationAlexa, Google Home, IFTTTAlexa, Google Assistant, IFTTT
AI Features (with Cam Plus)Person, Package, Vehicle DetectionPerson, Package, Vehicle, Facial, Pet Detection
Pre-roll Motion Recording3-6 secondsNot specified
Price (Regular)$44.98$89.98 (doorbell only) / $109.99 (with extra battery)
Included AccessoriesChime Controller, Wedge (30°), Installation KitWyze Wi-Fi Chime, Removable Battery Pack
What are the benefits of a hardwired battery doorbell with continuous recording?A hardwired battery doorbell combines the reliability of wired power with the backup of a battery, ensuring uninterrupted surveillance even during power outages or battery charging. Continuous recording with local microSD storage means you never miss important moments, and pre-roll video captures crucial seconds before motion is detected for enhanced security.
Does the Wyze Video Doorbell v2 support continuous video recording?Yes, the Wyze Video Doorbell v2 supports continuous video recording when a microSD card (up to 256GB) is installed. This allows for 24/7 local video storage and easy access to pre-roll video clips that capture moments just before motion is detected.
What is pre-roll video and how does it work on Wyze doorbells?Pre-roll video is a feature that records a few seconds before motion is detected, giving you a fuller picture of events at your doorstep. Both the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell offer pre-roll video, ensuring you see what happened just before an alert is triggered.
Can the Wyze Duo Cam Battery Doorbell be hardwired for continuous power?Yes, the Wyze Duo Cam Battery Doorbell can be powered by its built-in 6200 mAh battery or hardwired (10-24V AC) for continuous power. When hardwired, it supports 24/7 local recording to a microSD card, ensuring you never miss a moment.
What video quality do the Wyze Video Doorbell v2 and Duo Cam Battery Doorbell offer?The Wyze Video Doorbell v2 provides 2K (2048 x 1536) resolution with a wide 166.8° field of view. The Wyze Duo Cam Battery Doorbell features a front-facing 2K camera and a bottom-facing 1080p camera, allowing you to monitor both visitors and packages in high detail.
Are Wyze hardwired battery doorbells weatherproof?Yes, both the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell are IP65-rated for weather resistance, making them suitable for reliable outdoor use in various climates.
What smart home integrations are available with Wyze doorbells?Both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.
What storage options are available for Wyze doorbells?Wyze doorbells support local storage via microSD cards up to 256GB for continuous and pre-roll recording. The Wyze Duo Cam Battery Doorbell also offers AWS Cloud storage for secure video backup.
What is included in the box with Wyze Video Doorbell v2?The Wyze Video Doorbell v2 package includes the doorbell unit, Chime Controller, wall plate, wedge for angled mounting, wire caps, extension wires, screws, wall anchors, and a quick start guide for easy installation.
What comes with the Wyze Duo Cam Battery Doorbell?The Wyze Duo Cam Battery Doorbell package includes the doorbell, Wi-Fi Chime, back plate, corner kit, USB-C charging cable, wire nuts, extension wires, screws, expansion tubes, adhesive tape, doorbell detaching pin, removable battery pack, and a quick start guide.
What are the key features of the Wyze Video Doorbell v2?Can you explain the installation process for the Wyze Video Doorbell v2?Are there any ongoing promotions or discounts for the Wyze Video Doorbell?
