Smart Robot Vacuum with Alexa & Wireless Setup | Wyze
Smart Home Robot Vacuum Compatible with Alexa and Wireless Setup
Looking for a smart home robot vacuum that seamlessly integrates with Alexa and offers easy wireless setup? Discover the Wyze Robot Vacuum, designed to keep your floors spotless while fitting perfectly into your smart home ecosystem. Paired with the Wyze Switch, you can control your cleaning and lighting effortlessly with voice commands and app automation.
Wyze Robot Vacuum – Intelligent Cleaning with Alexa Integration
The Wyze Robot Vacuum is your ideal smart cleaning companion, engineered to work smoothly with Alexa for hands-free control. Whether you're busy cooking, working, or relaxing, simply ask Alexa to start or stop cleaning without lifting a finger.
Key Features:
- Alexa Voice Control: Start, pause, or schedule cleaning sessions using Alexa voice commands.
- Wireless Setup: Connects easily to your home Wi-Fi network for quick installation and control via the Wyze app.
- Smart Navigation: Efficiently maps your home to clean every corner with precision.
- Maintenance Accessories: Keep your vacuum running like new with available replacement parts such as HEPA filters, edge brushes, and charging stations.
Maintenance and Accessories:
- Wyze Robot Vacuum - Replacement Parts Kit: Includes edge brushes, main brushes, and HEPA filters to maintain optimal performance.
- Wyze Robot Vacuum - HEPA Filter: Replace filters easily to ensure clean air circulation.
- Wyze Robot Vacuum - Charging Station: A reliable replacement charging dock to keep your vacuum powered.
- Wyze Robot Vacuum - Power Adapter: Spare power adapter for uninterrupted charging.
Experience a cleaner home with minimal effort, all controlled through Alexa or your smartphone.
Wyze Switch – Smart Light Control and More
Complement your Wyze Robot Vacuum with the Wyze Switch, a smart Wi-Fi light switch that transforms your home lighting and integrates with your Wyze ecosystem, including the robot vacuum.
Why Choose Wyze Switch?
- Multi-Device Control: Control lights, Wyze Cams, Wyze Lock, and even your Wyze Robot Vacuum with customizable multi-tap actions.
- Alexa Compatible: Use voice commands to control your lights and vacuum seamlessly.
- Smart Automations: Set timers, schedules, and vacation modes to automate your home lighting and security.
- Power Loss Recovery: Automatically reconnects to Wi-Fi and restores previous settings after power outages.
- Easy Installation: Upgrade any room with a simple switch replacement.
Custom Actions:
- Single-press to turn on lights.
- Double-press to lock doors.
- Triple-press to activate the robot vacuum.
- Press-and-hold for other smart home actions.
The Wyze Switch is the perfect hub to unify your smart home devices under one control system.
Why Choose Wyze for Your Smart Home?
Wyze offers a comprehensive smart home ecosystem that is affordable, reliable, and easy to use. The combination of the Wyze Robot Vacuum and Wyze Switch provides a powerful duo for automated cleaning and lighting control, all accessible via Alexa and the Wyze app.
- Seamless Integration: All Wyze devices work together to create a smarter, more connected home.
- Affordable Accessories: Keep your devices in top shape with replacement parts and accessories.
- User-Friendly App: Manage your devices remotely and create custom automations effortlessly.
Transform your home into a smart haven with Wyze’s innovative products designed for modern living.
Summary of Products for Your Smart Home Setup
- Wyze Robot Vacuum: Smart cleaning with Alexa voice control and wireless setup.
- Wyze Switch: Smart Wi-Fi light switch with multi-device control and Alexa compatibility.
- Wyze Robot Vacuum Replacement Parts: Maintenance kits, HEPA filters, charging stations, and power adapters to keep your vacuum running smoothly.
Feature | Wyze Robot Vacuum - Pad | Wyze Switch | Wyze Robot Vacuum - Replacement Parts Kit |
Type | Accessories | Connected Home | Replacement Parts |
Price | $4.99 | $14.99 (1 Pack), $41.98 (3 Pack) | $22.99 |
Description | Replacement pad for Wyze Robot Vacuum | Smart WiFi light switch to control lights and Wyze devices | Maintenance kit including Edge brush4, Main brush2, HEPA filter*4 |
Compatibility | Wyze Robot Vacuum | Works with Wyze devices (Cams, Lock, Robot Vacuum) | Wyze Robot Vacuum |
Collections | Smart Home Accessories, Shop All | Power & Lighting, Connected Home, Shop All | Smart Home Accessories, Replacement Parts, Shop All |
Return Policy | 30-day hassle-free returns | 30-day hassle-free returns | Not specified |
Key Features | Replacement part for vacuum pad | Multi-tap control, timers, schedules, vacation mode, power loss recovery | Full maintenance kit for Wyze Robot Vacuum |
What is the Wyze Robot Vacuum and how does it work with Alexa?
The Wyze Robot Vacuum is a smart home cleaning device that integrates seamlessly with Alexa. You can start, pause, or schedule cleaning sessions using Alexa voice commands, allowing for hands-free control of your vacuum.How do I set up the Wyze Robot Vacuum wirelessly?
The Wyze Robot Vacuum connects easily to your home Wi-Fi network. Simply follow the instructions in the Wyze app for a quick and hassle-free wireless setup, enabling you to control the vacuum from your smartphone.What smart navigation features does the Wyze Robot Vacuum offer?
The Wyze Robot Vacuum uses advanced smart navigation to efficiently map your home and clean every corner with precision, ensuring thorough and effective cleaning.What maintenance accessories are available for the Wyze Robot Vacuum?
Wyze offers a range of maintenance accessories for the Robot Vacuum, including replacement parts kits (edge brushes, main brushes, HEPA filters), HEPA filters, charging stations, and power adapters to keep your vacuum running optimally.What is the Wyze Switch and how does it enhance smart home control?
The Wyze Switch is a smart Wi-Fi light switch that allows you to control lights, Wyze Cams, Wyze Lock, and the Wyze Robot Vacuum with customizable multi-tap actions. It integrates with Alexa for voice control and supports smart automations like timers and schedules.Can I control both my Wyze Robot Vacuum and lights with Alexa using Wyze Switch?
Yes, the Wyze Switch is Alexa compatible, allowing you to control both your Wyze Robot Vacuum and home lighting with simple voice commands for seamless smart home automation.What custom actions can I set up with the Wyze Switch?
With the Wyze Switch, you can assign custom actions such as single-press to turn on lights, double-press to lock doors, triple-press to activate the robot vacuum, and press-and-hold for other smart home functions.What happens to the Wyze Switch after a power outage?
The Wyze Switch features power loss recovery, which means it automatically reconnects to Wi-Fi and restores your previous settings after a power outage, ensuring uninterrupted smart home control.Why should I choose Wyze for my smart home setup?
Wyze offers an affordable, reliable, and user-friendly smart home ecosystem. Their products, like the Wyze Robot Vacuum and Wyze Switch, provide seamless integration, easy app control, and a wide range of accessories for a connected and automated home.What replacement parts are available for the Wyze Robot Vacuum?
Wyze provides replacement parts such as maintenance kits (edge brushes, main brushes, HEPA filters), individual HEPA filters, charging stations, and power adapters to keep your Wyze Robot Vacuum in top condition.
Can you tell me more about the Wyze Switch and how it integrates with the Wyze Robot Vacuum?What are the key features of the Wyze Robot Vacuum that make it suitable for smart home use?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Robot Vacuum?
