Refurbished Robot Vacuums Compatible with Alexa and Voice Assistants
Looking for a reliable refurbished robot vacuum that seamlessly integrates with Alexa and other voice assistants? Discover the Wyze Robot Vacuum ecosystem, designed to bring smart cleaning to your home with voice control convenience. Alongside the vacuum itself, Wyze offers a range of compatible accessories and replacement parts to keep your device running smoothly and smartly.
Wyze Robot Vacuum: Smart Cleaning with Voice Control
While the Wyze Robot Vacuum itself is not listed here, the ecosystem of replacement parts and accessories ensures your refurbished vacuum stays in top condition. The Wyze Robot Vacuum is known for its compatibility with Alexa and Google Assistant, allowing you to start, stop, or schedule cleaning sessions using simple voice commands.
Key Features of Wyze Robot Vacuum Accessories and Parts
Replacement Parts Kit
Keep your vacuum performing like new with the Wyze Robot Vacuum Replacement Parts Kit. It includes essential components such as 4 edge brushes, 2 main brushes, and 4 HEPA filters, ensuring thorough cleaning and optimal air filtration.
Price: $22.99
Stock: Available
HEPA Filter Replacement
Maintain clean air in your home by replacing your vacuum’s HEPA filter regularly. The Wyze Robot Vacuum HEPA Filter is designed specifically for this model, providing efficient dust and allergen capture.
Price: $4.99
Stock: Available
Vacuum Pad Accessory
Enhance your vacuum’s cleaning versatility with the Wyze Robot Vacuum Pad, perfect for mopping or gentle cleaning tasks.
Price: $4.99
Stock: Available
Charging Station Replacement
Ensure your vacuum is always ready to clean with the Wyze Robot Vacuum Charging Station replacement. Compatible with your Wyze Robot Vacuum, it guarantees efficient docking and charging.
Price: $19.99
Stock: Available
Power Adapter Replacement
Keep your vacuum powered with the Wyze Robot Vacuum Power Adapter, a reliable replacement part to avoid downtime.
Price: $4.99
Stock: Available
These parts and accessories come with a 30-day hassle-free return policy, making maintenance easy and worry-free.
Wyze Switch: Enhance Your Smart Home Control
While not a vacuum, the Wyze Switch is a smart WiFi light switch that integrates perfectly with your Wyze Robot Vacuum and other Wyze devices. It allows you to control your lights and robot vacuum with simple multi-tap actions or voice commands through Alexa and Google Assistant.
Why Choose Wyze Switch?
Voice Assistant Compatibility
Control your Wyze Robot Vacuum and other smart devices hands-free using Alexa or Google Assistant.
Customizable Multi-Tap Actions
Single-press to turn on lights, double-press to lock doors, triple-press to start the robot vacuum, and press-and-hold for other smart home automations.
Smart Control with Wyze Bulbs
Designed to work seamlessly with Wyze Bulbs, the switch maintains power to bulbs for uninterrupted automations.
Easy Installation & Reliable Connectivity
The Wyze Switch reconnects automatically after power loss and supports timers, schedules, and vacation mode for enhanced home security and convenience.
Control your smart home devices effortlessly with Wyze Switch and voice assistants like Alexa.
Why Choose Refurbished Wyze Robot Vacuum Accessories?
Refurbished products and accessories offer a cost-effective way to maintain and upgrade your smart home cleaning system without compromising on quality. Wyze’s commitment to smart home integration means your refurbished robot vacuum will work flawlessly with Alexa and other voice assistants, providing convenience and efficiency.
Summary of Available Products for Your Refurbished Robot Vacuum
Product Name | Type | Price | Stock |
Wyze Robot Vacuum - Replacement Kit | Replacement Parts | $22.99 | Available |
Wyze Robot Vacuum - HEPA Filter | Replacement Parts | $4.99 | Available |
Wyze Robot Vacuum - Pad | Accessories | $4.99 | Available |
Wyze Robot Vacuum - Charging Station | Replacement Parts | $19.99 | Available |
Wyze Robot Vacuum - Power Adapter | Replacement Parts | $4.99 | Available |
Wyze Switch | Connected Home | $14.99 | Available |
Upgrade your refurbished robot vacuum experience with Wyze’s smart accessories and enjoy seamless voice control with Alexa and other assistants. Keep your home clean, smart, and connected effortlessly.
Are refurbished Wyze Robot Vacuums compatible with Alexa and Google Assistant?
Yes, refurbished Wyze Robot Vacuums are fully compatible with Alexa and Google Assistant, allowing you to control cleaning sessions using simple voice commands for a seamless smart home experience.What replacement parts are available for Wyze Robot Vacuums?
Wyze offers a range of replacement parts for their robot vacuums, including a Replacement Parts Kit (with edge brushes, main brushes, and HEPA filters), individual HEPA filters, vacuum pads, charging stations, and power adapters. All parts are designed to keep your vacuum running efficiently.How do I maintain my refurbished Wyze Robot Vacuum for optimal performance?
To maintain optimal performance, regularly replace the HEPA filter, edge brushes, and main brushes using the Wyze Robot Vacuum Replacement Parts Kit. Also, ensure your charging station and power adapter are functioning properly for uninterrupted cleaning.What is included in the Wyze Robot Vacuum Replacement Parts Kit?
The Wyze Robot Vacuum Replacement Parts Kit includes 4 edge brushes, 2 main brushes, and 4 HEPA filters, providing all the essential components needed for thorough cleaning and air filtration.How often should I replace the HEPA filter in my Wyze Robot Vacuum?
It is recommended to replace the HEPA filter in your Wyze Robot Vacuum regularly to maintain efficient dust and allergen capture and ensure clean air in your home.What is the Wyze Switch and how does it work with Wyze Robot Vacuums?
The Wyze Switch is a smart WiFi light switch that integrates with Wyze Robot Vacuums and other Wyze devices. It allows you to control your vacuum and lights using customizable multi-tap actions or voice commands through Alexa and Google Assistant.Can I control my Wyze Robot Vacuum with voice commands using the Wyze Switch?
Yes, the Wyze Switch enables you to start your Wyze Robot Vacuum with a triple-press or other customizable actions, and also supports voice control through Alexa and Google Assistant.Are Wyze Robot Vacuum accessories and parts covered by a return policy?
Yes, all Wyze Robot Vacuum parts and accessories come with a 30-day hassle-free return policy, making maintenance easy and worry-free.Why should I choose refurbished Wyze Robot Vacuum accessories?
Refurbished Wyze Robot Vacuum accessories offer a cost-effective way to maintain and upgrade your smart home cleaning system without compromising on quality. They are fully compatible with Alexa and other voice assistants for convenient, efficient cleaning.What products are available for my refurbished Wyze Robot Vacuum?
Available products for your refurbished Wyze Robot Vacuum include the Replacement Parts Kit, HEPA Filter, Vacuum Pad, Charging Station, Power Adapter, and the Wyze Switch for enhanced smart home control.
