Smart Home Monitoring Kit with Keypad Sensor Integration and Built-in Siren
Enhance your home security with a comprehensive smart home monitoring kit that combines advanced sensor integration, keypad control, and a powerful built-in siren. Whether you want to monitor your entire home or start with essential security features, these kits and components offer seamless connectivity, remote control, and reliable alerts to keep your home safe and secure.
Whole Home Security Enhanced Kit: Complete Protection with Cameras and Floodlights
The
Whole Home Security Enhanced Kit is designed for those who want robust, all-around protection. This kit includes the latest Wyze Cam v4 and Wyze Cam Floodlight v2, providing both indoor and outdoor surveillance with bright floodlights to deter intruders.
- Wyze Cam v4: Crisp 1080p HD video with color night vision, motion detection, and two-way audio.
- Wyze Cam Floodlight v2: Powerful floodlight with motion-activated lighting and siren integration.
- Multiple color variants available to match your home’s aesthetic.
- Priced at $256.91, this kit offers a premium security solution with easy app control.
This kit is perfect for homeowners looking for a comprehensive system that covers all angles with smart cameras and lighting.
Wyze Sense Hub: The Brain of Your Smart Security System with Built-in Siren
At the heart of your smart home monitoring setup is the
Wyze Sense Hub, which connects all your sensors and devices, ensuring smooth communication and instant alerts.
- Built-in 88dB siren to alert you and deter intruders.
- Supports up to 100 sensors, including motion, door/window, and climate sensors.
- Connectivity options include Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF.
- Compact design with a rechargeable battery backup lasting up to 10 hours.
- Indoor use with operating temperature range from 32°F to 104°F.
The Wyze Sense Hub is essential for integrating keypad sensors and other monitoring devices, making it the command center of your smart home security.
Wyze Sense Keypad: Convenient Arm/Disarm and Emergency Control
For seamless keypad sensor integration, the
Wyze Sense Keypad offers easy control over your home security system.
- Arm and disarm your system remotely with a simple keypad interface.
- Includes an emergency button to send alerts to first responders quickly.
- Requires the Wyze Sense Hub for full functionality.
- Indoor use with permanent adhesive mounting.
- Supports up to 100 accessories, allowing for scalable security setups.
The keypad adds a layer of convenience and safety, enabling quick system control without needing your phone.
Additional Sensors to Enhance Your Monitoring System
To complement your smart home monitoring kit, consider adding these sensors for comprehensive coverage:
Wyze Sense Motion Sensor
- Detects motion within a 25 ft range and 120° field of view.
- Adjustable sensitivity settings.
- Battery life up to 18 months.
- Requires Wyze Sense Hub.
Wyze Sense Climate Sensor
- Monitors temperature and humidity in any room.
- 500 ft wireless range.
- Sleek, unobtrusive design with adhesive or screw mounting.
These sensors integrate seamlessly with the Wyze Sense Hub and keypad, providing real-time alerts and environmental monitoring to keep your home safe and comfortable.
Why Choose This Smart Home Monitoring Kit?
Combining the Whole Home Security Enhanced Kit, Wyze Sense Hub, and Wyze Sense Keypad gives you a powerful, integrated security system with:
- Easy keypad sensor integration for quick arming/disarming.
- A loud built-in siren to deter intruders.
- Scalable sensor support for motion, climate, and more.
- Remote monitoring and control via the Wyze app.
- Reliable connectivity and battery backup for uninterrupted protection.
Invest in a smart home monitoring kit that offers peace of mind, convenience, and advanced security features tailored to your needs.
What is included in the Whole Home Security Enhanced Kit?
The Whole Home Security Enhanced Kit includes the Wyze Cam v4 for crisp 1080p HD indoor video, the Wyze Cam Floodlight v2 for outdoor surveillance with motion-activated lighting and siren integration, and multiple color variants to match your home’s aesthetic. This kit provides comprehensive protection with both cameras and floodlights.How does the Wyze Sense Hub improve my smart home security system?
The Wyze Sense Hub acts as the central command center for your smart home security system. It connects up to 100 sensors and devices, features a built-in 88dB siren to deter intruders, and offers multiple connectivity options including Ethernet, WiFi, Bluetooth, and RF. The hub also has a rechargeable battery backup lasting up to 10 hours for uninterrupted protection.What are the benefits of integrating a keypad sensor with my home security system?
Integrating a keypad sensor, such as the Wyze Sense Keypad, allows you to easily arm and disarm your security system without needing your phone. It also features an emergency button for quick alerts to first responders and supports up to 100 accessories for scalable security setups.Can I control my smart home monitoring kit remotely?
Yes, you can control your smart home monitoring kit remotely using the Wyze app. This allows you to monitor your home, receive real-time alerts, and manage your security system from anywhere.What types of sensors can I add to the Wyze Sense Hub?
You can add a variety of sensors to the Wyze Sense Hub, including motion sensors that detect movement within a 25 ft range and 120° field of view, and climate sensors that monitor temperature and humidity. These sensors provide real-time alerts and environmental monitoring for comprehensive home protection.Is the Wyze Sense Hub suitable for large homes?
Yes, the Wyze Sense Hub supports up to 100 sensors and has a wireless range of up to 500 ft for climate sensors, making it suitable for large homes and scalable security setups.Does the Wyze Sense Hub work during power outages?
The Wyze Sense Hub features a rechargeable battery backup that lasts up to 10 hours, ensuring your home security system remains operational during power outages.What is the price of the Whole Home Security Enhanced Kit?
The Whole Home Security Enhanced Kit is priced at $256.91 and offers a premium security solution with easy app control, cameras, and floodlights for complete home protection.How does the built-in siren help protect my home?
The built-in 88dB siren in the Wyze Sense Hub and Wyze Cam Floodlight v2 provides a loud alert to deter intruders and notify you of potential security breaches, enhancing your home’s safety.What are the installation requirements for the Wyze Sense Keypad?
The Wyze Sense Keypad is designed for indoor use and can be mounted using permanent adhesive. It requires the Wyze Sense Hub for full functionality and supports up to 100 accessories for flexible security configurations.
