Smart Bulbs for Home Automation with App Control & Timer
Smart Bulbs for Home Automation with App Control and Timer
Enhance your home automation experience with Wyze’s range of smart bulbs designed for seamless app control, customizable lighting, and convenient timer features. Whether you want vibrant colors to set the mood or crisp white light for everyday use, these smart bulbs integrate effortlessly into your smart home ecosystem.
Wyze Bulb Color: Vibrant, Customizable Smart Lighting
Experience the ultimate in smart lighting with the Wyze Bulb Color, a powerful A19 bulb that offers:
  • 16 Million Colors: Choose from an extensive palette to create the perfect ambiance for any occasion.
  • Dimmable Brightness: Adjustable from 30 to 1100 lumens, allowing you to set the ideal light level.
  • Tunable White Light: Customize color temperature from warm 1800K to cool 6500K for versatile lighting moods.
  • High Color Rendering Index (90+): Ensures colors appear vivid and natural.
  • Long Life Expectancy: Up to 25,000 hours of reliable use.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for stable app control.
  • App Control & Timer: Easily schedule on/off times, set scenes, and control brightness or color from your smartphone.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice commands and automation.
  • Suitable for Damp Locations: Perfect for kitchens, bathrooms, and covered outdoor areas.
This bulb is perfect for living rooms, bedrooms, or any space where you want to add a splash of color or adjust lighting to your lifestyle. Wyze Bulb Color in Living Room Alt: Colorful smart bulb lighting up a cozy living room
Wyze Bulb Color BR30: Smart Recessed Lighting with Mood Control
For recessed lighting fixtures, the Wyze Bulb Color BR30 offers smart, color-changing illumination with these standout features:
  • Dimmable & Color-Changing: Select from 16 million colors and adjust brightness from 30 to 950 lumens.
  • Fits Standard Recessed Fixtures: BR30 shape fits most ceiling cans for easy upgrade.
  • Color Temperature Range: 1800K to 6500K tunable white light.
  • Smart Features: Control via Wyze app with scheduling, scenes, and timers.
  • Voice Control: Works with Alexa and Google Assistant.
  • Long Life: 25,000 hours of use.
  • Connectivity: 2.4GHz Wi-Fi and Bluetooth.
  • Not for Use with Dimmer Switches: Designed for smart app dimming only.
  • Suitable for Damp Locations: Great for bathrooms and kitchens.
Ideal for creating dynamic lighting scenes in hallways, kitchens, or living rooms with recessed lighting.
Wyze Bulb White: Simple, Bright, and Smart
If you prefer classic white lighting with smart features, the Wyze Bulb White is a perfect choice:
  • Dimmable White Light: Adjustable brightness from 30 to 800 lumens.
  • Color Temperature Options: Switch between warm 2700K and cool 6500K white light.
  • High Color Rendering Index (90+): For natural, clear lighting.
  • Easy App Control: Schedule timers, set sleep routines, and control brightness remotely.
  • Voice Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
  • Long Life Expectancy: 25,000 hours.
  • Suitable for Damp Locations: Use in bathrooms, kitchens, and covered outdoor spaces.
This bulb is ideal for everyday lighting needs with the convenience of smart control and automation. Wyze Bulb White in Bedroom Alt: Warm white smart bulb lighting a cozy bedroom
Why Choose Wyze Smart Bulbs for Your Home Automation?
“Wyze smart bulbs combine vibrant color options, easy app control, and reliable scheduling features to transform your home lighting experience.”
  • Seamless App Control: Manage all your bulbs from the Wyze app, set timers, create lighting schedules, and customize scenes to fit your daily routine.
  • Voice Assistant Integration: Use voice commands with Alexa or Google Assistant to turn lights on/off, change colors, or adjust brightness hands-free.
  • Energy Efficient & Long-Lasting: Save on energy bills with LED technology and enjoy years of use without frequent replacements.
  • Flexible Installation: Compatible with standard E26 sockets and recessed fixtures (BR30), suitable for most home lighting setups.
  • Perfect for Home Automation: Integrate with other Wyze smart devices for a connected, intelligent home environment.
Conclusion
For smart bulbs that offer app control, timer functionality, and vibrant lighting options, Wyze’s Bulb Color, Bulb Color BR30, and Bulb White provide versatile solutions tailored to your home automation needs. Whether you want to brighten your mornings, set the perfect mood for evenings, or automate your lighting schedule, these bulbs deliver convenience, style, and smart technology in one package.
Wyze Cam Floodlight v2 Lifestyle Alt: Person controlling smart home lighting with phone app
FeatureWyze Bulb ColorWyze Bulb Color BR30Wyze Bulb White
TypeSmart LightingConnected HomeConnected Home
ShapeA19BR30A19
Base TypeE26E26E26
Lumen Output30 lm (dim) - 1100 lm (bright)30 lm (dim) - 950 lm (bright)30 lm - 800 lm
Wattage Equivalent75W75W9.5W
Color Options16 million colors16 million colorsWhite light only
Color Temperature RangeTunable white (1800K - 6500K approx.)Tunable white (1800K - 6500K approx.)2700K - 6500K
CRI Rating90+90+90+
DimmableYes (but "takes offense" humorously)Yes (not for use with dimmer switches)Yes
White Light Temperature ControlYesYesYes
Custom PresetsYesYesNo
Brilliant NotificationsYesYesNo
Sleep RoutinesYesYesNo
Music ModeYes (when grouped with Light Strip)Yes (when grouped with Light Strip)No
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYesNo
GroupingYesYesNo
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Compatible AppWyze appWyze appWyze app
Pack Variants & Price2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)2 Pack ($27.98), 4 Pack ($49.98)2 Pack ($23.99), 4 Pack ($39.99), 6 Pack ($59.99)
Special NotesBrightest smart bulb (1100 lm max)Fits recessed lighting fixtures, not for dimmer switchesBrighter than average white bulb, dimmable
Life ExpectancyNot specifiedNot specified25,000 hours
What are the main features of Wyze smart bulbs for home automation?Wyze smart bulbs offer seamless app control, customizable lighting with millions of colors, dimmable brightness, timer and scheduling features, voice assistant integration, and energy-efficient LED technology. They are suitable for various home environments, including damp locations like kitchens and bathrooms.
How do I control Wyze smart bulbs?You can control Wyze smart bulbs using the Wyze app on your smartphone, which allows you to adjust brightness, change colors, set timers, create lighting schedules, and customize scenes. The bulbs also support voice control through Alexa, Google Assistant, and IFTTT.
What is the difference between Wyze Bulb Color, Bulb Color BR30, and Bulb White?Wyze Bulb Color is an A19 bulb offering 16 million colors, tunable white light, and high brightness (up to 1100 lumens). Wyze Bulb Color BR30 is designed for recessed fixtures, also with 16 million colors and tunable white light, but fits standard ceiling cans. Wyze Bulb White provides classic white lighting with adjustable brightness and color temperature, ideal for everyday use.
Are Wyze smart bulbs compatible with voice assistants?Yes, Wyze smart bulbs are compatible with Amazon Alexa, Google Assistant, and IFTTT, allowing you to control your lights with simple voice commands.
Can I use Wyze smart bulbs in damp locations?Yes, all Wyze smart bulbs are suitable for damp locations such as kitchens, bathrooms, and covered outdoor areas, making them versatile for various home settings.
Do Wyze smart bulbs require a hub for operation?No, Wyze smart bulbs connect directly to your 2.4GHz Wi-Fi network and Bluetooth, so no additional hub is required for operation.
How long do Wyze smart bulbs last?Wyze smart bulbs have a long life expectancy of up to 25,000 hours, providing years of reliable use without frequent replacements.
Can I schedule Wyze smart bulbs to turn on or off automatically?Yes, you can easily schedule Wyze smart bulbs to turn on or off at specific times using the Wyze app’s timer and scheduling features.
Are Wyze smart bulbs energy efficient?Yes, Wyze smart bulbs use LED technology, which is energy efficient and helps reduce your electricity bills while providing bright, customizable lighting.
Can Wyze Bulb Color BR30 be used with dimmer switches?No, Wyze Bulb Color BR30 is not designed for use with traditional dimmer switches. Dimming should be controlled through the Wyze app or compatible voice assistants.
What sockets are Wyze smart bulbs compatible with?Wyze Bulb Color and Bulb White are compatible with standard E26 sockets, while Wyze Bulb Color BR30 is designed to fit most standard recessed lighting fixtures.
Can you tell me more about the features of the Wyze Bulb Color?How do I control the brightness and color of the Wyze smart bulbs using the app?Do you have any ongoing sales or discounts for smart bulbs?
