Best 1080p Surveillance Kits for Small Business Security
Small Business Surveillance Kit with 1080p Resolution Cameras
For small business owners looking to secure their premises with reliable, high-quality surveillance, choosing the right cameras is essential. This guide highlights top Wyze surveillance products that offer crisp 1080p (and higher) resolution, smart features, and versatile installation options to fit your business needs.
Wyze Cam v4: Advanced Wired Security Camera with 2.5K Resolution
Wyze Cam v4 is a powerhouse for small business surveillance, delivering crystal-clear 2.5K Quad HD video—well above the 1080p standard—ensuring every detail is captured with precision.
Key Features:
  • 2.5K QHD Resolution: Provides ultra-clear video, perfect for identifying faces and license plates.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, a major upgrade over traditional black-and-white night vision.
  • Motion-Activated Spotlight & Siren: Deter intruders with a built-in spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection for uninterrupted monitoring.
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for voice control.
  • Weather Resistant (IP65): Suitable for both indoor and outdoor use, making it flexible for various business environments.
  • Easy Setup & Magnetic Mount: Screw-free installation with a magnetic base for quick repositioning.
Wyze Cam v4 is ideal for small businesses needing high-resolution, dependable wired cameras that work day and night with smart features.
Wyze Cam Pan v3: 360° Pan and 180° Tilt with Weatherproof Design
For businesses requiring comprehensive coverage of larger areas, the Wyze Cam Pan v3 offers dynamic pan and tilt capabilities with full 360° horizontal and 180° vertical movement.
Highlights:
  • 1080p HD Video Quality: Crisp and clear video to monitor your business premises effectively.
  • IP65 Weather Resistance: Perfect for outdoor use when paired with the Wyze Outdoor Power Adapter.
  • Automatic Motion Tracking: The camera detects and follows movement automatically, ensuring nothing escapes its view.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
  • Two-Way Audio: Communicate directly through the camera using the Wyze app.
  • Custom Patrol Routes: Set up to 4 waypoints for the camera to patrol automatically.
  • Advanced Motion & Sound Detection: Receive instant alerts for motion or sound events, including smoke and CO alarms.
This camera is perfect for small businesses that want flexible, wide-area surveillance with smart tracking and weatherproof durability. Wyze Cam Pan v3 in snowy outdoor setting
The Front Porch Security Bundle: Smart 1080p Video Doorbell and Lock
Secure your business entry points with the Front Porch Security Bundle, combining a 1080p HD video doorbell and smart lock for comprehensive access management.
Bundle Features:
  • 1080p HD Video Doorbell: View your front porch with clear video and a wide 120° vertical by 88° horizontal field of view.
  • Two-Way Audio: Greet visitors or delivery personnel remotely with built-in speaker and microphone featuring noise and echo cancellation.
  • Remote Lock/Unlock: Control your door lock from anywhere and monitor lock history via the Wyze app.
  • Motion Event Alerts: Receive notifications for motion detected at your entryway.
  • IP65 Weather Resistance: Durable for outdoor installation in various weather conditions.
  • Works with Alexa and Google Assistant: Integrate with your smart office ecosystem.
This bundle is perfect for small businesses wanting to secure entrances with smart video and access control in one package.
Wyze Battery Cam Pro: Wire-Free, Weatherproof 2.5K HDR Camera
For businesses needing flexible placement without wiring constraints, the Wyze Battery Cam Pro offers wire-free convenience with high-resolution video.
Features:
  • 2.5K HDR Video Resolution: Superior image quality for detailed surveillance.
  • Wire-Free Operation: No hub required; powered by removable, rechargeable batteries.
  • Integrated Spotlight & Siren: Enhance nighttime security with a built-in spotlight and loud siren.
  • Radar + PIR Motion Detection: Advanced motion sensing for accurate alerts.
  • Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks.
  • IP65 Weatherproof: Ready for outdoor use in all weather conditions.
Ideal for small businesses that want easy-to-install, wireless cameras with premium video quality and smart detection. Wyze Cam Pan v3 two-way audio with pet
Why Choose Wyze Surveillance for Your Small Business?
Wyze cameras combine affordability with advanced features like high-resolution video, color night vision, weather resistance, and smart home integration. Whether you need wired or wireless solutions, panoramic coverage, or smart access control, Wyze offers versatile options tailored for small business security.
Summary of Small Business Surveillance Options
ProductResolutionKey FeaturesInstallationPrice Range
Wyze Cam v42.5K QHDColor Night Vision, Spotlight, SirenWired (Indoor/Outdoor)$35.98+
Wyze Cam Pan v31080p HD360° Pan/Tilt, Motion TrackingWired (Indoor/Outdoor)$39.98+
Front Porch Security Bundle1080p HDVideo Doorbell, Smart LockWired (Outdoor)$124.96+
Wyze Battery Cam Pro2.5K HDRWire-Free, Spotlight, Radar MotionWireless (Outdoor)$89.98+
Choose the right combination to cover entrances, indoor spaces, and outdoor areas with crystal-clear video and smart alerts.
FeatureWyze Cam v4Wyze Cam Pan v3The Front Porch Security BundleWyze Battery Cam Pro
TypeWired Security CameraWired Pan & Tilt Security CameraSmart Home Front Porch Security BundleWire-Free Battery Security Camera
Video Resolution2.5K QHD (2560 x 1440)Not specified (Comparable to $150 competitor)Wyze Video Doorbell: 1080p HD (2048 x 1536)2.5K HDR (2560 x 1440)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)360° Pan, 180° Tilt120° Vertical x 88° Horizontal (Doorbell camera)134° (DFOV), 108° (HFOV), 56° (VFOV)
Night VisionEnhanced Color Night VisionColor Night Vision with Starlight SensorIR Night Light (4 x 940nm LEDs)2 IR LEDs (850 nm), 2 White LEDs (5500K)
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way Audio (Doorbell & Chime)Two-Way Audio with built-in speaker & mic
SpotlightMotion-activated SpotlightNo spotlightNo spotlightIntegrated Spotlight
Siren99 dB SirenNo sirenNo siren100 dB Siren
Weather ResistanceIP65IP65Doorbell: IP65 Weather-resistantIP65
Power SourceWiredWiredDoorbell: 16V-24V ACRemovable, Rechargeable Battery Packs
WirelessNoNoNoYes (2.4 & 5 GHz WiFi)
Local Storage SupportMicroSD up to 256GBMicroSD up to 256GBNot specifiedMicroSD up to 256GB
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Motion DetectionYes, with zonesYes, with motion tracking & zonesYes (Doorbell motion events)Radar + PIR Motion Detection
Additional FeaturesWi-Fi 6 support, AI Auto-Zoom with Smart Focus, Smoke & CO alertsPan Scan™ Patrol, Privacy Mode, Smoke & CO alertsRemote lock/unlock, lock history, chime with multiple soundsUp to 6 months battery life, BLE 5.1, 2-way audio, IP65
Price (Single Pack)$35.98$39.98From $123.99 (bundle with lock and doorbell)$159.98
MountingMagnetic mount, screw-freeMount with Wyze Outdoor Power Adapter for outdoor useIncluded accessories for doorbell and lockWall mount included
What is the best Wyze camera for small business surveillance?The Wyze Cam v4 is an excellent choice for small business surveillance, offering 2.5K Quad HD resolution, color night vision, motion-activated spotlight and siren, 24/7 local recording, and weather resistance for both indoor and outdoor use.
Do Wyze cameras support 1080p or higher video resolution?Yes, Wyze cameras such as the Wyze Cam v4 and Wyze Battery Cam Pro offer 2.5K (higher than 1080p) resolution, while the Wyze Cam Pan v3 and Front Porch Security Bundle provide crisp 1080p HD video quality.
Can Wyze cameras be used outdoors for business security?Yes, many Wyze cameras, including the Wyze Cam v4, Wyze Cam Pan v3 (with outdoor power adapter), and Wyze Battery Cam Pro, are IP65 weather resistant and suitable for outdoor installation in various weather conditions.
What features make Wyze Cam Pan v3 suitable for wide-area business surveillance?The Wyze Cam Pan v3 offers 360° pan and 180° tilt, automatic motion tracking, custom patrol routes, advanced motion and sound detection, two-way audio, and weatherproof design, making it ideal for monitoring large business areas.
How does the Wyze Front Porch Security Bundle enhance business entry security?The Front Porch Security Bundle combines a 1080p HD video doorbell with a smart lock, allowing you to view visitors, communicate via two-way audio, receive motion alerts, and remotely control and monitor your door lock through the Wyze app.
Are there wireless Wyze cameras available for small businesses?Yes, the Wyze Battery Cam Pro is a wire-free, weatherproof camera with 2.5K HDR video resolution, integrated spotlight and siren, radar and PIR motion detection, and dual-band Wi-Fi support, making it easy to install anywhere without wiring.
Do Wyze cameras require a subscription for 24/7 recording?No, Wyze Cam v4 supports continuous 24/7 local recording to a microSD card (up to 256GB) without any subscription fees.
Can Wyze cameras be integrated with smart assistants?Yes, Wyze cameras are compatible with Alexa and Google Assistant, allowing for voice control and integration with your smart office ecosystem.
What is the price range for Wyze small business surveillance cameras?Wyze surveillance cameras for small businesses range from $35.98 for the Wyze Cam v4 to $124.96 for the Front Porch Security Bundle, offering affordable options for various security needs.
What are the main benefits of choosing Wyze surveillance for small business security?Wyze surveillance cameras offer high-resolution video, advanced features like color night vision, weather resistance, smart home integration, and both wired and wireless options, all at an affordable price, making them ideal for small business security.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam Pan v3 and its capabilities?Do you have any ongoing sales or discounts for Wyze products?
