Top Security Cameras with Spotlight, Siren & Motion Detection
Best Security Cameras with Integrated Spotlight, Siren, and Motion Detection
When it comes to securing your home or business, having a security camera that combines powerful motion detection with an integrated spotlight and siren is essential. These features not only capture clear video evidence but also deter intruders effectively by illuminating the area and sounding alarms. Below, we explore top Wyze security cameras designed to provide comprehensive protection with these advanced capabilities.
Wyze Battery Cam Pro: Wireless Freedom with Pro-Grade Security
Key Features
- 2.5K HDR Video Resolution: Capture crystal-clear footage with high dynamic range for balanced, vibrant images day or night.
- Integrated Spotlight & Siren: A bright 150-lumen LED spotlight activates on motion detection, paired with a loud siren to scare off intruders.
- Radar + PIR Motion Detection: Dual sensors provide earlier and more precise motion alerts, reducing false alarms.
- Wire-Free & Weatherproof: Completely wireless with removable rechargeable batteries and IP65 rating for all-weather durability.
- Flexible Power Options: Hot-swap battery packs or add a solar panel for continuous power without downtime.
- Connectivity: Supports both 2.4 GHz and 5 GHz Wi-Fi for reliable streaming and notifications.
- Local & Cloud Storage: Record locally to a microSD card or subscribe to Cam Plus for enhanced smart detections and cloud storage.
Why Choose Wyze Battery Cam Pro?
This camera is perfect for those who want a versatile, wire-free security solution that can be placed anywhere without the hassle of wiring or hubs. The integrated spotlight and siren provide active deterrence, while the advanced motion detection ensures you only get alerts that matter.
Wyze Cam v4: Wired Power with Enhanced Spotlight and Smart Features
Key Features
- 2.5K QHD Resolution: Ultra-clear video with a wide 115.8° diagonal field of view and enhanced color night vision.
- Motion-Activated Spotlight & Siren: Two white spotlight LEDs (72 lumens) illuminate the scene, combined with a built-in 99dB siren for immediate threat response.
- Advanced Sensor Technology: CMOS Starlight sensor and dual-band Wi-Fi 6 support for fast, reliable connectivity.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for flexible installation.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Local Storage & Cloud Options: Supports microSD cards up to 512GB and cloud storage subscriptions.
- Weather Resistant: IP65 rating ensures protection against rain, dust, and extreme temperatures.
Ideal Use Cases
Wyze Cam v4 is suited for users who prefer a wired camera with continuous power and advanced smart home compatibility. Its spotlight and siren features make it a strong deterrent, while the high-resolution video captures every detail.
Wyze Cam OG: The Next Generation with Built-In Spotlight and Siren
Key Features
- 1080p HD Video: Clear full HD video with a 120° field of view and CMOS-Starlight sensor.
- Built-In 40 Lumen Spotlight: Provides sufficient illumination to highlight activity and deter unwanted visitors.
- 90-Decibel User-Activated Siren: Loud siren to alert and scare off intruders.
- Faster Live Streaming & Notifications: 3X faster than previous models for real-time monitoring.
- Two-Way Audio: Enhanced microphone and speaker for clear communication.
- Weatherproof Design: IP65 rating for reliable outdoor use.
- Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
Why It Stands Out
Wyze Cam OG offers a balanced combination of affordability and essential security features, including a built-in spotlight and siren. It’s ideal for users looking for a straightforward wired camera with reliable performance.
Wyze Cam Spotlight Bundle: Add Motion-Activated Lighting to Your Wyze Cam v3
Key Features
- Motion-Activated Spotlight: Bright IP65-rated headlamp that activates on motion, illuminating the area instantly.
- Weather Resistant: Designed for outdoor use in all weather conditions.
- Custom Rules & Schedules: Automate the spotlight to turn on/off based on your preferences.
- Enhanced Security: Works seamlessly with Wyze Cam v3 to provide an extra layer of protection.
- Affordable Add-On: A cost-effective way to upgrade your existing Wyze Cam v3 with integrated lighting.
Perfect For
This bundle is ideal if you already own a Wyze Cam v3 and want to add a powerful spotlight that reacts to motion, enhancing visibility and security during nighttime or low-light conditions.
Wyze Bulb Cam: 2-in-1 Outdoor Security Camera and Smart LED Light
Key Features
- 2K HD Video with Color Night Vision: Capture detailed video with vibrant colors even at night.
- Integrated Smart LED Bulb: Up to 800 lumens brightness with motion-activated lighting.
- 95 dB Siren: Loud siren to deter intruders effectively.
- Easy Installation: Fits standard E26 light sockets, making it simple to replace existing outdoor bulbs.
- Local Storage Support: Compatible with microSD cards up to 256GB for continuous recording.
- Weatherproof: IP65 rating ensures durability in outdoor environments.
- Two-Way Audio: Built-in microphone and speaker for communication.
Why Choose Wyze Bulb Cam?
This innovative 2-in-1 device combines a security camera with a smart light bulb, making it perfect for users who want to secure their porch, garage, or outdoor fixtures without additional wiring or devices.
Conclusion
For comprehensive home security with integrated spotlight, siren, and motion detection, Wyze offers a range of cameras tailored to different needs:
- Wyze Battery Cam Pro for wireless, flexible placement with powerful deterrents.
- Wyze Cam v4 for wired, high-resolution video with smart home integration.
- Wyze Cam OG for a reliable, budget-friendly wired camera with spotlight and siren.
- Wyze Cam Spotlight Bundle to enhance your Wyze Cam v3 with motion-activated lighting.
- Wyze Bulb Cam for a unique 2-in-1 camera and smart light bulb solution.
Choose the model that best fits your security needs and enjoy peace of mind with Wyze’s advanced technology.
Wyze Cam Pan v3 - Weather Resistant Outdoor Security
Wyze Bulb Cam - Outdoor Security with Smart Lighting
Communicate Easily with Two-Way Audio
Feature | Wyze Battery Cam Pro | Wyze Cam v4 | Wyze Cam OG | Wyze Bulb Cam |
Video Resolution | 2.5K HDR (2560x1440) | 2.5K QHD (2560x1440) | 1080p (1920x1080) | 2K (2304x1296) |
Field of View | Not explicitly stated | 115.9° (D) x 98.5° (H) x 53.1° (V) | 120° | 160° (diagonal 166°, horizontal 144°, vertical 82.5°) |
Night Vision | Color Night Vision, Integrated Spotlight | Enhanced Color Night Vision, Spotlight | IR Night Vision (4 IR LEDs 850nm), Built-in Spotlight (40 lumens) | Color Night Vision, IR Night Vision (4x 850nm IR LEDs) |
Power Source | Battery (Removable, Rechargeable), Solar Panel option | Wired (Power adapter included) | Wired (Power adapter included) | Wired (Standard E26 socket, 120V AC) |
Weather Resistance | IP65 | IP65 | IP65 | IP65 |
Connectivity | 2.4 & 5 GHz Wi-Fi | Wi-Fi 6, Bluetooth 5.2 | 2.4 GHz Wi-Fi (802.11 b/g/n) | 2.4 GHz Wi-Fi (802.11 b/g/n), Bluetooth 4.2/ BLE |
Motion Detection | Radar + PIR Motion Detection, Custom Zones | Motion & Sound Detection, Custom Zones | Motion Detection, Custom Zones | Motion Detection |
Audio | Two-Way Audio (Mic & Speaker), Siren | Enhanced Two-Way Talk, 99 dB Siren | Two-Way Audio (Upgraded Mic & Speaker), 90 dB Siren | Two-Way Audio, 95 dB Siren |
Local Storage | MicroSD card support (up to 256GB) | MicroSD card support (up to 256GB, 512GB in hidden variant) | MicroSD card support (up to 256GB) | MicroSD card support (up to 256GB) |
Cloud Storage | Optional Cam Plus subscription | Optional Cam Plus subscription | Optional Cam Plus subscription | Cloud storage via AWS |
Spotlight | Integrated 150 lumens LED | Motion-activated Spotlight (99 dB Siren) | Built-in Spotlight (40 lumens) | Smart LED bulb (up to 800 lumens) with motion-activated light |
Dimensions | Not specified | 2in x 2in x 2 3/8in (approx. 50.8 x 50.8 x 60.3 mm) | 1.89 in x 1.89 in x 1.89 in (48 x 48 x 48 mm) | Standard bulb size (fits E26 socket) |
Weight | Not specified | 0.49 lb (222 g) | 4.1 oz (116 g) | Not specified |
Setup | Wireless, No Hub, Bluetooth setup | Wired, Bluetooth setup | Wired | Screw-in bulb, Bluetooth setup |
Additional Features | Removable battery packs, Solar panel option, Radar + PIR sensors | Wi-Fi 6 support, Smoke & CO alerts, AI Auto-Zoom, Alexa/Google/IFTTT | Faster live streaming, 3x faster notifications, 3x telephoto lens (OG Telephoto variant) | 2-in-1 camera and smart LED bulb, supports linking up to 5 bulbs |
Price (1 Pack) | $89.98 | $35.98 | $29.98 | $49.98 |
What are the best Wyze security cameras with integrated spotlight, siren, and motion detection?
Wyze offers several top security cameras with integrated spotlight, siren, and motion detection, including the Wyze Battery Cam Pro, Wyze Cam v4, Wyze Cam OG, Wyze Cam Spotlight Bundle (for Wyze Cam v3), and Wyze Bulb Cam. Each model provides unique features to enhance home or business security.How does the Wyze Battery Cam Pro enhance home security?
The Wyze Battery Cam Pro features 2.5K HDR video resolution, a 150-lumen integrated spotlight, a loud siren, and advanced radar plus PIR motion detection. It is wire-free, weatherproof (IP65), and offers flexible power options, including rechargeable batteries and solar panel compatibility. This makes it ideal for versatile, wireless security anywhere on your property.What are the key features of the Wyze Cam v4?
Wyze Cam v4 offers 2.5K QHD resolution, a wide 115.8° field of view, enhanced color night vision, motion-activated dual spotlights (72 lumens), a 99dB siren, and advanced sensor technology. It supports dual-band Wi-Fi 6, multiple mounting options, smart home integration (Alexa, Google Assistant, IFTTT), and both local and cloud storage. It is also weather resistant with an IP65 rating.Is the Wyze Cam OG a good budget-friendly security camera?
Yes, the Wyze Cam OG is an affordable wired security camera that includes a 1080p HD video, a built-in 40-lumen spotlight, a 90-decibel siren, two-way audio, custom detection zones, and weatherproof design (IP65). It is ideal for users seeking essential security features at a budget-friendly price.How can I add a spotlight to my existing Wyze Cam v3?
You can enhance your Wyze Cam v3 with the Wyze Cam Spotlight Bundle. This add-on provides a motion-activated, weather-resistant spotlight that illuminates the area when motion is detected. It is an affordable way to upgrade your existing camera for better nighttime security.What makes the Wyze Bulb Cam unique among security cameras?
The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED bulb (up to 800 lumens). It features color night vision, a 95dB siren, two-way audio, easy installation in standard E26 sockets, local storage support, and weatherproofing (IP65). It is perfect for securing porches, garages, or outdoor fixtures without extra wiring.Are Wyze security cameras weatherproof for outdoor use?
Yes, most Wyze security cameras with integrated spotlight and siren, including the Wyze Battery Cam Pro, Wyze Cam v4, Wyze Cam OG, Wyze Cam Spotlight Bundle, and Wyze Bulb Cam, are IP65 weatherproof. This ensures reliable performance in rain, dust, and extreme temperatures.Do Wyze security cameras support local and cloud storage?
Wyze security cameras support both local storage via microSD cards and cloud storage through Cam Plus subscriptions. This allows users to choose between continuous local recording and enhanced smart detections with cloud backup.Can Wyze security cameras be integrated with smart home systems?
Yes, Wyze Cam v4 and other compatible models can be integrated with smart home systems such as Amazon Alexa, Google Assistant, and IFTTT. This enables voice control, automation, and seamless smart home connectivity.What are the benefits of having a security camera with an integrated spotlight and siren?
Security cameras with integrated spotlight and siren provide active deterrence by illuminating intruders and sounding alarms, in addition to capturing clear video evidence. This combination helps prevent break-ins and enhances overall property security.
What are the key features of the Wyze Battery Cam Pro?How does the motion detection work in the Wyze security cameras?Do you have any ongoing sales or discounts for the Wyze security cameras?
