Best Security Cameras for Home: Top Wyze Picks & Reviews
Best Security Cameras for Ultimate Home Protection
When it comes to securing your home or business, choosing the right security camera is crucial. Whether you need indoor monitoring, outdoor surveillance, or a versatile smart camera, Wyze offers a range of high-quality options designed to keep your property safe with advanced features and smart integrations. Explore the best Wyze security cameras that combine cutting-edge technology, ease of use, and affordability.
Wyze Cam v4: Crystal-Clear Security with Enhanced Night Vision
Experience unmatched clarity and security with the Wyze Cam v4, perfect for both indoor and outdoor use. This camera boasts a stunning 2.5K QHD resolution that captures every detail in vibrant color, even at night, thanks to its Enhanced Color Night Vision technology.
Key Features:
  • 2.5K QHD Video Resolution for sharp, detailed footage
  • Enhanced Color Night Vision powered by a CMOS Starlight Sensor
  • Motion-Activated Spotlight to deter intruders and illuminate dark areas
  • Wide Field of View: DFOV 115.8°, HFOV 98.5°, VFOV 53.1° covers more area
  • 24/7 Local Recording with Wi-Fi 6 support for faster, more reliable connectivity
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant
Available in multiple colors (Black, Clear, Grey, White) and pack options, the Wyze Cam v4 is a versatile choice for comprehensive home security.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Full Coverage
For those who want to monitor every corner, the Wyze Cam Pan v3 offers a dynamic 360° horizontal pan and 180° vertical tilt, ensuring no blind spots. This camera is designed for both indoor and outdoor use with IP65 weather resistance, making it durable against the elements.
Highlights:
  • 360° Pan & 180° Tilt for complete room or yard coverage
  • IP65 Weather Resistant for reliable outdoor performance (requires separate outdoor power adapter)
  • High-Quality Video with clear day and night vision
  • Available in Black and White with flexible pack sizes
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Stay protected in all weather with Wyze Cam Pan v3
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoors
Illuminate your property while keeping it secure with the Wyze Cam Floodlight v2. This powerful security camera combines a 2800-lumen LED floodlight with 2K video resolution and color night vision, providing clear visibility and deterrence against unwanted visitors.
Features:
  • 2800 Lumens LED Floodlight for bright, wide illumination
  • 2K Video with Color Night Vision and a 160° wide-angle view
  • AI-Powered Light Control and Ambient Light Mode for smart automation
  • Two-Way Talk to communicate with visitors or intruders
  • Dusk-to-Dawn Automation and IP65 weather resistance for hassle-free outdoor use
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration
<img src="https://www.wyze.com/cdn/shop/files/WyzeCamFloodlightv2Main-05_76f5ff71-b16d-4814-a365-7c14c1006cf5.jpg?v=1743789457&width=1946" alt="Wyze Cam Floodlight v2 illuminating driveway at night">
Brighten your driveway and secure your home with Wyze Cam Floodlight v2
Wyze Battery Cam Pro: Wire-Free, High-Resolution Security Anywhere
For flexible placement without worrying about wires, the Wyze Battery Cam Pro offers wire-free convenience with 2.5K HDR video quality. Its rechargeable battery packs and dual-band Wi-Fi support make it ideal for locations without easy access to power.
Why Choose Battery Cam Pro?
  • 2.5K HDR Video Resolution for crystal-clear images
  • Wire-Free Design with removable, rechargeable 6200mAh battery packs
  • Integrated Spotlight & Siren for active deterrence
  • Radar + PIR Motion Detection for precise alerts
  • IP65 Weatherproof for reliable outdoor use
  • Supports both 2.4GHz and 5GHz Wi-Fi networks
Wyze Cam OG: Affordable and Fast Live Streaming
The Wyze Cam OG is the next generation of Wyze’s popular camera line, offering quick live streaming and improved two-way audio. It features a built-in spotlight and is suitable for both indoor and outdoor use.
Key Specs:
  • 1080p Full HD Video with 120° field of view
  • 3X Faster Notifications to keep you instantly informed
  • Improved Two-Way Audio for clear communication
  • Built-In Spotlight for added security at night
Wyze Bulb Cam: Discreet Security with Smart Lighting
Combine security and lighting with the Wyze Bulb Cam, a 2-in-1 outdoor security camera and smart LED light bulb. It fits most standard fixtures and offers 2K HD video with color night vision.
Features:
  • 2K HD Video Resolution with color night vision
  • Instant Motion Alerts via the Wyze app
  • Easy Installation in standard light sockets
  • Local Video Storage with no subscription required
  • IP65 Rated for outdoor durability
<img src="https://www.wyze.com/cdn/shop/files/Wyze_Bulb_Cam_Shopify-07.jpg?v=1746478547&width=1500" alt="Wyze Bulb Cam installed in outdoor light fixture">
Discreetly protect your home with Wyze Bulb Cam
Conclusion
Choosing the best security camera depends on your specific needs—whether it’s wide coverage, night vision, wireless convenience, or integrated lighting. Wyze’s lineup offers reliable, feature-rich options for every scenario, ensuring your home stays safe and monitored around the clock.
Product Highlights Summary
  • Wyze Cam v4: Crystal-clear 2.5K video, enhanced night vision, motion spotlight
  • Wyze Cam Pan v3: 360° pan, 180° tilt, weather resistant
  • Wyze Cam Floodlight v2: Powerful floodlight, 2K color night vision, AI light control
  • Wyze Battery Cam Pro: Wire-free 2.5K HDR, rechargeable battery, spotlight & siren
  • Wyze Cam OG: Fast live streaming, 1080p HD, built-in spotlight
  • Wyze Bulb Cam: 2-in-1 bulb and camera, 2K HD, easy installation
Secure your home with Wyze’s best security cameras and enjoy peace of mind with smart, reliable surveillance.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Battery Cam ProWyze Cam OGWyze Bulb Cam
TypeWired CameraWired Camera (Pan & Tilt)Wired Lighting CameraBattery CameraWired CameraLighting Camera
Video Resolution2.5K QHD (2560 x 1440)2.5K (2560 x 1440)2K (2304 x 1296)2.5K HDR (2560 x 1440)1080p (1920 x 1080)2K (2304 x 1296)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt160° diagonal134° (DFOV), 108° (HFOV), 56° (VFOV)120°160° diagonal (166° diagonal, 144° horizontal, 82.5° vertical)
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)Color Night Vision2 IR LEDs + 2 White LEDs (Color)4 IR LEDs (B&W)Color Night Vision + IR Night Vision
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way AudioTwo-Way AudioBuilt-in Speaker & Microphone; Noise & Echo CancellationTwo-Way Audio
SirenYes (integrated)Yes105 dB100 dB SPL90 dB user-activated95 dB at 4 in
SpotlightMotion-activated spotlightNoYes (2 dimmable LED panels)Integrated SpotlightBuilt-in Spotlight (40 Lumens)Integrated Smart LED Light Bulb
Power SourceWiredWiredHardwiredRemovable, Rechargeable BatteryWired120V AC (standard E26 socket)
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local StorageMicroSD up to 256 GBMicroSD up to 256 GBMicroSD up to 256 GBMicroSD up to 256 GBMicroSD up to 256 GBMicroSD up to 256 GB
ConnectivityWi-Fi 6 (requires Wi-Fi 6 router)Wi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTT
DimensionsNot specifiedNot specified9.5" x 7.7" x 7.0" (24.13 x 19.56 x 17.78 cm)2.5" x 1.8" x 3.5"1.89" x 1.89" x 1.89" (48 mm)Not specified
WeightNot specifiedNot specified2.76 lbs (1.25 kg)0.94 lbs4.1 oz (116 g)Not specified
MountingMagnetic mountMagnetic mountWall or Ceiling mount1/4" - 20 standard mountWired mountStandard E26 socket
Special FeaturesAuto-zoom with AI, Motion-activated spotlight, Smoke & CO alerts360° pan & 180° tilt, Motion tracking, Privacy Mode2800 Lumens LEDs, Ambient Light Mode, AI-Powered Light Control, Dusk-to-dawn automationRadar + PIR Motion Detection, Removable battery, Up to 6 months battery lifeFaster live streaming, 3X faster notifications, Built-in spotlight2-in-1 camera and smart LED bulb, Motion-activated light, Schedule & Automations
Price (1 Pack)$35.98$39.98$89.98$159.98$29.98$49.98
What are the best Wyze security cameras for home protection?Wyze offers a range of top-rated security cameras for home protection, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, Wyze Cam OG, and Wyze Bulb Cam. Each model is designed to meet different security needs, from indoor and outdoor monitoring to wire-free installation and integrated lighting.
What features does the Wyze Cam v4 offer for home security?The Wyze Cam v4 provides 2.5K QHD video resolution, enhanced color night vision with a CMOS Starlight Sensor, a motion-activated spotlight, wide field of view, 24/7 local recording, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant. It is suitable for both indoor and outdoor use.
How does the Wyze Cam Pan v3 provide full coverage?The Wyze Cam Pan v3 features a 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of a room or outdoor area. It is IP65 weather resistant, making it ideal for both indoor and outdoor surveillance.
What makes the Wyze Cam Floodlight v2 effective for outdoor security?The Wyze Cam Floodlight v2 combines a powerful 2800-lumen LED floodlight with 2K video resolution and color night vision. It also features AI-powered light control, two-way talk, dusk-to-dawn automation, and is IP65 weather resistant for reliable outdoor use.
Is there a wire-free Wyze security camera option?Yes, the Wyze Battery Cam Pro is a wire-free security camera that offers 2.5K HDR video, removable and rechargeable battery packs, integrated spotlight and siren, radar and PIR motion detection, and IP65 weatherproofing. It supports both 2.4GHz and 5GHz Wi-Fi networks.
What are the benefits of the Wyze Cam OG for home monitoring?The Wyze Cam OG offers 1080p Full HD video, a 120° field of view, 3X faster notifications, improved two-way audio, and a built-in spotlight. It is suitable for both indoor and outdoor use and provides fast, reliable live streaming.
How does the Wyze Bulb Cam combine security and lighting?The Wyze Bulb Cam is a 2-in-1 device that functions as both a security camera and a smart LED light bulb. It offers 2K HD video with color night vision, instant motion alerts, easy installation in standard light sockets, local video storage without a subscription, and is IP65 rated for outdoor durability.
Are Wyze security cameras compatible with smart home systems?Yes, many Wyze security cameras, including the Wyze Cam v4 and Wyze Cam Floodlight v2, are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home setup.
Which Wyze camera is best for outdoor use?Several Wyze cameras are designed for outdoor use, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, and Wyze Bulb Cam. These models feature weather resistance (IP65 rating) and advanced night vision for reliable outdoor surveillance.
Do Wyze security cameras offer local video storage?Yes, many Wyze cameras, such as the Wyze Cam v4 and Wyze Bulb Cam, support local video storage, allowing you to record footage without a subscription.
What are the key features of the Wyze Cam v4?How does the Enhanced Color Night Vision work on the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions?
