Best Stackable Security Camera Kits for Dual-Angle Coverage
Best Security Camera Kit with Stackable Mounting for Dual Angles
When it comes to securing your home or business, having versatile camera setups that cover multiple angles is essential. For those looking for a security camera kit with stackable mounting options to achieve dual-angle surveillance, Wyze offers an excellent range of products designed to meet these needs. Whether you want wireless flexibility, high-resolution video, or the ability to stack cameras for comprehensive coverage, Wyze has you covered.
Wyze Cam OG Stack Kit: The Ultimate Stackable Mounting Solution
Stack Two Cameras for Dual Angles
The Wyze Cam OG Stack Kit is specifically designed to power and mount two Wyze Cam OG or Wyze Cam OG Telephoto cameras stacked vertically. This kit includes a USB cable splitter, a power brick, and a stack mount, allowing you to run both cameras off a single power source while capturing different perspectives.
  • Stack Mount: Securely mounts two cameras on top of each other.
  • Power Efficiency: One power brick powers both cameras via USB splitter.
  • Compatibility: Works with Wyze Cam OG and Wyze Cam OG Telephoto.
  • Price: Affordable at $9.99, making it a cost-effective way to expand your surveillance angles.
This kit is perfect for users who want to monitor two different views from the same location, such as a front door and driveway or two sides of a room.
Wyze Cam OG and Wyze Cam OG Telephoto: Wired Cameras with Enhanced Features
Wyze Cam OG – Reliable 1080p Wired Camera
The Wyze Cam OG is a wired security camera offering 1080p full HD video with a 120° field of view. It features:
  • Quick Live Streaming: 50% faster than previous models.
  • Built-in Spotlight: 40 lumens for clear night vision.
  • Two-Way Audio: Enhanced microphone and speaker with noise cancellation.
  • Weather Resistance: IP65 rating for indoor/outdoor use.
  • Local Storage: Supports up to 256GB microSD card.
  • Custom Detection Zones: Tailor alerts to specific areas.
  • Dimensions: Compact 1.89" cube, easy to mount.
Wyze Cam OG Telephoto – Zoomed-In Detail with 3x Telephoto Lens
For more focused surveillance, the Wyze Cam OG Telephoto offers all the features of the OG model but adds a powerful 3x telephoto lens:
  • Telephoto Field of View: Narrower angles (27° diagonal) for zoomed-in views.
  • 1080p Video: Crisp and clear footage.
  • Night Vision: 4 IR LEDs for low-light conditions.
  • Mounting Flexibility: Stand, wall, or ceiling mount options.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT.
Together with the Stack Kit, these two cameras can be stacked to cover wide and zoomed-in views simultaneously, perfect for detailed monitoring.
Wyze Battery Cam Pro: Wireless Freedom with High-Resolution Video
For those who prefer wireless setups with flexible mounting, the Wyze Battery Cam Pro is an excellent choice:
  • 2.5K HDR Video Resolution: Superior image quality day and night.
  • Wire-Free Design: No hub or power outlet needed.
  • Integrated Spotlight & Siren: 150 lumens LED light and siren for deterrence.
  • Radar + PIR Motion Detection: Dual sensors for precise alerts.
  • Removable Rechargeable Batteries: Hot-swap batteries to avoid downtime.
  • Weatherproof: IP65 rating for all-weather use.
  • Dual-Band Wi-Fi: Supports 2.4 & 5 GHz networks.
  • Stackable Mounting: Compatible with Wyze Universal Mount (long stem) for ceiling or wall mounting, enabling flexible angles.
This camera is ideal for outdoor or indoor use where wiring is impractical, and the rechargeable battery packs ensure continuous protection. Wyze Battery Cam Pro in outdoor setting
Wyze Duo Cam Battery Doorbell: Dual Camera Views for Entryway Security
For comprehensive front-door security with dual angles, the Wyze Duo Cam Battery Doorbell offers two cameras in one device:
  • Dual Cameras: Front camera (2K resolution) and bottom camera (1080p) for people and package views.
  • Wide Field of View: 132° horizontal front, 121° horizontal bottom.
  • Motion-Activated Voice Deterrence: Warn intruders with a 90 dB siren and voice alerts.
  • Two-Way Audio: Communicate with visitors or delivery personnel.
  • Wireless & Battery Powered: Easy installation without wiring.
  • Local and Cloud Storage: Supports microSD cards and cloud backup.
  • Weather Resistant: IP65 rating for outdoor durability.
This doorbell is perfect for monitoring your entryway with multiple angles, ensuring no detail is missed. Wyze Duo Cam Battery Doorbell lifestyle
Why Choose Wyze for Your Stackable Security Camera Kit?
"Wyze offers innovative, affordable, and flexible security solutions that adapt to your unique surveillance needs."
  • Stackable Mounting: The Wyze Cam OG Stack Kit enables dual-angle monitoring with a single power source.
  • Versatile Cameras: Choose from wired (Wyze Cam OG, Telephoto) or wireless (Battery Cam Pro) options.
  • High-Quality Video: From 1080p HD to 2.5K HDR, capture every detail.
  • Smart Features: Motion detection, two-way audio, spotlight, siren, and app control.
  • Weatherproof Designs: Reliable performance indoors and outdoors.
  • Expandable System: Add accessories like solar panels, mounts, and microSD cards for local recording.
Conclusion
For a security camera kit with stackable mounting for dual angles, the combination of the Wyze Cam OG Stack Kit with Wyze Cam OG and Wyze Cam OG Telephoto cameras offers a wired, power-efficient solution. If you prefer wireless flexibility, the Wyze Battery Cam Pro provides high-resolution video with versatile mounting options. For entryway monitoring with dual views, the Wyze Duo Cam Battery Doorbell is an advanced choice. Choose Wyze to build a customizable, reliable, and smart security system tailored to your surveillance needs.
Product Summary
Wyze Cam OG Stack Kit Wyze Cam OG Wyze Cam OG Telephoto Wyze Battery Cam Pro Wyze Duo Cam Battery Doorbell
Enhance your home security today with Wyze’s innovative stackable camera kits and enjoy peace of mind with comprehensive dual-angle coverage.
FeatureWyze Cam OG Stack KitWyze Cam OGWyze Battery Cam ProWyze Cam OG TelephotoWyze Duo Cam Battery Doorbell
TypeAccessoriesCameraCameraCameraCamera
Price$9.99$29.98 (1 Pack)$159.98 (1 Pack)$25.98 (1 Pack)$109.99 (Wyze Duo Cam Doorbell)
PurposePower & stack mount 2 Wyze Cam OG/TelephotoNext-gen wired camera with spotlightWire-free battery camera with spotlightWired camera with 3x telephoto lensBattery-powered video doorbell with dual cameras
Video ResolutionN/A1080p (1920 x 1080)2.5K (2560 x 1440)1080p (1920 x 1080)Front: 2K (2048 x 1536), Bottom: 1080p
Field of View (FOV)N/A120° (approx. 121.4° DFOV)134° DFOV27° DFOV (telephoto)Front: 132° H, 100° V; Bottom: 121° H, 60° V
Night VisionN/AColor Night VisionColor Night VisionIR LEDs (4x 850nm)IR Light (6x 850 nm)
SpotlightN/ABuilt-in 40 lumensIntegrated Spotlight (187 lumens)No spotlightNo spotlight
AudioN/ATwo-way audio with improved clarityTwo-way audio with MEMS micTwo-way audio with noise & echo cancellationTwo-way audio, siren 90 dB
Power SourceUSB Cable Splitter + Power BrickWired (5V/1A adapter)Rechargeable battery packs (6200mAh)Wired (5V/1A adapter)Battery or hardwired (10-24V AC)
Weather ResistanceN/AIP65 (Indoor/Outdoor)IP65IP65IP65
Wireless ConnectivityN/ANoYes (2.4 & 5 GHz WiFi)NoYes (2.4 & 5 GHz WiFi)
Local Storage SupportN/AmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
DimensionsN/ANot specified2.5 x 1.8 x 3.5 inches1.89 x 1.89 x 1.89 inches5.90 x 1.88 x 1.18 inches
WeightN/ANot specified0.94 lbs4.1 oz (116 g)0.92 lbs (416 g)
Special FeaturesStack mount for 2 cameras, single power source3x faster notifications, built-in spotlight, improved 2-way audioRadar + PIR motion detection, rechargeable battery, 6 months battery life3x telephoto lens, 8x digital zoomDual camera views, motion-activated voice deterrence, Wi-Fi chime included
WarrantyN/A1 YearNot specified1 Year1 Year
What is a security camera kit with stackable mounting for dual angles?A security camera kit with stackable mounting for dual angles allows you to mount two cameras vertically or in close proximity, enabling you to monitor two different views from the same location. Wyze offers the Wyze Cam OG Stack Kit, which is designed specifically for this purpose, providing comprehensive surveillance coverage.
How does the Wyze Cam OG Stack Kit work?The Wyze Cam OG Stack Kit enables you to stack two Wyze Cam OG or Wyze Cam OG Telephoto cameras vertically. It includes a stack mount, USB cable splitter, and a power brick, allowing both cameras to be powered from a single source while capturing different angles for enhanced security.
Which Wyze cameras are compatible with the Stack Kit?The Wyze Cam OG Stack Kit is compatible with the Wyze Cam OG and Wyze Cam OG Telephoto models. These cameras can be stacked together to provide both wide and zoomed-in surveillance views.
What are the main features of the Wyze Cam OG?The Wyze Cam OG is a wired security camera offering 1080p full HD video, a 120° field of view, quick live streaming, built-in 40-lumen spotlight, two-way audio with noise cancellation, IP65 weather resistance, support for up to 256GB microSD card, and customizable detection zones.
What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?While both cameras share core features like 1080p video, weather resistance, and two-way audio, the Wyze Cam OG Telephoto includes a 3x telephoto lens for a narrower, zoomed-in 27° field of view, making it ideal for focused surveillance of specific areas.
Can I use Wyze cameras outdoors?Yes, Wyze cameras such as the Wyze Cam OG, Wyze Cam OG Telephoto, Wyze Battery Cam Pro, and Wyze Duo Cam Battery Doorbell are all IP65 weather resistant, making them suitable for both indoor and outdoor use.
Is there a wireless security camera option with stackable mounting?Yes, the Wyze Battery Cam Pro is a wireless security camera that supports stackable mounting using the Wyze Universal Mount (long stem). It offers 2.5K HDR video, wire-free installation, integrated spotlight and siren, and is ideal for flexible indoor or outdoor placement.
What are the benefits of the Wyze Duo Cam Battery Doorbell for entryway security?The Wyze Duo Cam Battery Doorbell features dual cameras—one for people and one for packages—offering 2K and 1080p resolution, wide fields of view, motion-activated voice deterrence, two-way audio, wireless battery-powered installation, and both local and cloud storage options.
How do Wyze cameras store video footage?Wyze cameras support both local and cloud storage. Most models, including the Wyze Cam OG and Wyze Duo Cam Battery Doorbell, allow you to use a microSD card for local recording, and also offer cloud backup for added security.
What smart home integrations are available with Wyze security cameras?Wyze security cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, allowing you to integrate your cameras into your existing smart home ecosystem for enhanced convenience and control.
Why should I choose Wyze for my stackable security camera kit?Wyze offers innovative, affordable, and flexible security solutions with stackable mounting options, high-quality video, smart features like motion detection and two-way audio, weatherproof designs, and an expandable system to meet your unique surveillance needs.
Can you tell me more about the features of the Wyze Cam OG?How does the Wyze Duo Cam Battery Doorbell compare to the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze security camera kits?
