Affordable Smart Porch Security Kit with HD Doorbell & Smart Lock
Affordable Smart Front Porch Security Kit Featuring HD Video Doorbell and Remote Smart Lock
Enhance your home’s safety and convenience with an affordable, all-in-one smart front porch security kit. Combining high-definition video surveillance with advanced keyless entry, this kit offers peace of mind and effortless control over your home’s access. Discover how the Wyze Lock Bolt and Wyze Video Doorbell work together to secure your front porch with smart technology designed for modern living.
Wyze Lock Bolt: The Ultimate Smart Lock for Your Front Door
Keyless Entry with Fingerprint Access
Say goodbye to fumbling for keys. The Wyze Lock Bolt replaces your traditional deadbolt with a sleek, solid metal smart lock featuring an ultra-fast fingerprint reader. Unlock your door in less than a second with just a touch of your finger or a tap in the Wyze app.
Luxurious Backlit Keypad and Anti-Peep Technology
The lock’s backlit keypad ensures easy code entry even at night. Plus, with anti-peep technology, you can enter extra random digits before or after your access code to keep your PIN secure from prying eyes.
Auto-Lock and Long Battery Life
Never worry about leaving your door unlocked. The Wyze Lock Bolt auto-locks after a set delay, configurable via the app. Powered by 4 AA batteries, it offers up to 12 months of battery life, with a USB-C port for emergency charging if needed.
Robust Security and Weatherproof Design
Crafted from solid metal, the Wyze Lock Bolt is fully pick-proof and weatherproof with an IPX5 rating, making it durable for outdoor use. It uses hardware encryption and two-factor authentication to keep your access data safe.
Easy Installation and App Control
Compatible with most exterior doors, installation takes about 20 minutes. The Wyze app lets you create and manage up to 20 access codes and 50 fingerprints, view lock/unlock history, and generate emergency one-time codes remotely.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt lifestyle front door Secure your front door with Wyze Lock Bolt
Wyze Video Doorbell: HD Video and Two-Way Audio for Front Porch Monitoring
Crisp 1080p HD Video with Night Vision
Keep an eye on your front porch day and night with the Wyze Video Doorbell’s 1080p HD camera. Infrared LEDs provide clear night vision, ensuring you never miss a visitor or package delivery.
Two-Way Audio with Noise Cancellation
Greet guests or deter unwanted visitors with built-in speaker and microphone featuring noise and echo cancellation. Communicate directly through your smartphone from anywhere.
Motion Detection and Smart Alerts
Receive instant notifications when motion is detected at your door. The Wyze app lets you view live video, recorded clips, and customize motion zones for precise monitoring.
Weather-Resistant and Easy to Install
Designed to withstand the elements with an IP65 rating, the doorbell is built for outdoor use. Installation is straightforward, compatible with standard doorbell wiring.
The Front Porch Security Bundle: Complete Smart Security Solution
Seamless Integration of Lock and Doorbell
The Front Porch Security Bundle pairs the Wyze Lock Bolt with the Wyze Video Doorbell and Chime, providing a comprehensive security system. Lock or unlock your door remotely, view your porch in HD, and receive alerts all from the Wyze app.
Voice Assistant Compatibility
Works with Alexa and Google Assistant for hands-free control, allowing you to check lock status or view your doorbell camera with simple voice commands.
Included Accessories for Easy Setup
The bundle comes with everything you need: Wyze Lock, Video Doorbell, Chime, mounting hardware, batteries, and quick start guides to get your smart porch security up and running quickly. Smart home front porch lifestyle Monitor your front porch anytime, anywhere
Why Choose This Affordable Smart Front Porch Security Kit?
  • Convenience: Keyless entry with fingerprint and app control eliminates the need for physical keys.
  • Enhanced Security: HD video doorbell with two-way audio and motion alerts keeps you connected to your front porch.
  • Durability: Weatherproof and pick-proof smart lock and doorbell designed for outdoor use.
  • Easy Installation: Quick setup with included hardware and intuitive app controls.
  • Smart Home Integration: Compatible with popular voice assistants for seamless automation.
Upgrade your home security affordably with this smart front porch kit that combines cutting-edge technology and user-friendly features to protect what matters most.
Product Summary
Product NameKey FeaturesPrice (Approx.)
Wyze Lock BoltFingerprint unlock, backlit keypad, auto-lock, weatherproof, 12-month battery life$79.98
Wyze Video Doorbell1080p HD video, two-way audio, night vision, motion detection, weather-resistantIncluded in bundle
Front Porch Security BundleWyze Lock Bolt + Wyze Video Doorbell + Chime, app control, voice assistant compatibleFrom $124.96
FeatureWyze Lock BoltThe Front Porch Security Bundle
Product TypeBluetooth Smart LockSecurity Bundle (Lock + Video Doorbell + Chime)
Included DevicesWyze Lock BoltWyze Lock or Wyze Lock Bolt + Wyze Video Doorbell + Chime
Lock Style OptionsMatte Black, Satin NickelWyze Lock Bolt Matte Black or Wyze Lock variants
Price$79.98$123.99 - $173.97 (varies by variant)
Key Features- Ultra-fast fingerprint reader- Wyze Lock Bolt features (fingerprint, backlit keypad, auto-lock)
- Backlit keypad with anti-peep technology- Wyze Video Doorbell (1080p HD, two-way audio)
- Auto-lock timer- Wyze Chime for doorbell sound
- Fully pick-proof and weatherproof (IPX5)- Remote lock/unlock via app and doorbell viewer
- Up to 12 months battery life- View lock history in Wyze app
- Local Bluetooth connection only
Installation TimeAbout 20 minutesIncludes Wyze Lock Bolt installation + Video Doorbell setup
App Features- Lock/unlock history- Lock/unlock door from Wyze app and Video Doorbell viewer
- Store up to 20 access codes and 50 fingerprints
- Emergency one-time codes
Security Features- Hardware encryptionIncludes Wyze Lock Bolt security features
- Two-factor authentication
CompatibilityReplaces existing deadboltWyze Lock Bolt compatible with most exterior doors
Weather ResistanceIPX5Wyze Lock Bolt IPX5; Video Doorbell weather resistant
Battery4x AA batteries (up to 12 months)Same for Wyze Lock Bolt
ConnectivityBluetooth 5.0 (16 ft range)Bluetooth for lock; Wi-Fi for Video Doorbell
Auto-lock FeatureYesYes
Fingerprint SensorYesYes (if Wyze Lock Bolt included)
KeypadBacklit, anti-peep technologyIncluded with Wyze Lock Bolt
Video Doorbell ResolutionN/A1080p HD (Wyze Video Doorbell)
Two-way AudioN/AYes (Wyze Video Doorbell)
Remote AccessVia Bluetooth app onlyVia Wyze app (lock and doorbell)
Emergency Access CodesYesYes (via Wyze Lock Bolt)
Return Policy30-day hassle-free returns30-day hassle-free returns
What is included in the Wyze Smart Front Porch Security Kit?The Wyze Smart Front Porch Security Kit includes the Wyze Lock Bolt, Wyze Video Doorbell, Chime, mounting hardware, batteries, and quick start guides. This all-in-one bundle provides keyless entry, HD video monitoring, and seamless app control for enhanced front porch security.
How does the Wyze Lock Bolt provide keyless entry?The Wyze Lock Bolt offers keyless entry through an ultra-fast fingerprint reader and a backlit keypad. You can unlock your door in less than a second using your fingerprint or by entering a code in the Wyze app, eliminating the need for traditional keys.
Is the Wyze Lock Bolt secure and weatherproof?Yes, the Wyze Lock Bolt is crafted from solid metal, making it pick-proof and weatherproof with an IPX5 rating. It also features hardware encryption and two-factor authentication to keep your access data safe, ensuring robust security for outdoor use.
How long does the Wyze Lock Bolt battery last and what happens if it runs out?The Wyze Lock Bolt is powered by 4 AA batteries, offering up to 12 months of battery life. In case the batteries run out, there is a USB-C port for emergency charging, so you can always access your home.
Can I control the Wyze Lock Bolt and Video Doorbell remotely?Yes, both the Wyze Lock Bolt and Wyze Video Doorbell can be controlled remotely through the Wyze app. You can lock or unlock your door, view live video, receive motion alerts, and manage access codes from anywhere.
What video quality does the Wyze Video Doorbell offer?The Wyze Video Doorbell provides crisp 1080p HD video with infrared night vision, ensuring clear footage of your front porch both day and night.
Does the Wyze Video Doorbell have two-way audio?Yes, the Wyze Video Doorbell features built-in two-way audio with noise and echo cancellation, allowing you to communicate with visitors or deter unwanted guests directly from your smartphone.
Is the Wyze Video Doorbell weather-resistant?Yes, the Wyze Video Doorbell is designed for outdoor use with an IP65 weather-resistant rating, making it durable and reliable in various weather conditions.
How easy is it to install the Wyze Lock Bolt and Video Doorbell?Both the Wyze Lock Bolt and Video Doorbell are designed for easy installation. The lock is compatible with most exterior doors and can be installed in about 20 minutes, while the doorbell works with standard doorbell wiring. All necessary hardware and guides are included.
Can I integrate the Wyze Front Porch Security Kit with voice assistants?Yes, the Wyze Front Porch Security Kit is compatible with Alexa and Google Assistant, allowing you to check lock status or view your doorbell camera using simple voice commands for hands-free control.
How many fingerprints and access codes can I store with the Wyze Lock Bolt?The Wyze Lock Bolt allows you to store up to 50 fingerprints and 20 access codes, making it easy to manage access for family members, guests, or service providers.
What is anti-peep technology on the Wyze Lock Bolt?Anti-peep technology allows you to enter random digits before or after your actual access code on the backlit keypad, preventing others from guessing your PIN by watching your entry sequence.
What are the main benefits of the Wyze Smart Front Porch Security Kit?The main benefits include keyless entry with fingerprint and app control, HD video monitoring with two-way audio, weatherproof and pick-proof design, easy installation, and smart home integration with popular voice assistants—all at an affordable price.
How does the Wyze Lock Bolt's fingerprint access work?Can the Wyze Video Doorbell be installed without existing doorbell wiring?Do you have any deals, ongoing sales, discounts, or promotions for the smart front porch security kit?
