Best Air Filters for VOCs & New Furniture in Your Home
Safe Air Filters for Homes with New Furniture and VOCs
When you bring new furniture into your home, it often releases volatile organic compounds (VOCs) and other harmful gases like formaldehyde. These pollutants can affect your indoor air quality and your family’s health. Choosing the right air filter designed to tackle VOCs and allergens is essential for a safe and fresh home environment. Wyze offers a range of connected air filters and purifiers tailored to combat these indoor air challenges effectively.
Wyze Air Filter: Customized Protection Against VOCs and Allergens
Tailored Filters for Your Home’s Unique Needs
The Wyze Air Filter lets you customize your air purification to target specific pollutants, including formaldehyde—a common VOC emitted by new furniture and building materials. Choose from three specialized filter types:
  • Allergen Filter (Standard): Captures dust, pet dander, and common allergens.
  • Formaldehyde Filter (Premium): Specifically designed to remove formaldehyde with a high CADR of 178 m³/h.
  • Wildfire Filter (Special Use): Ideal for smoke and wildfire-related particles.
Advanced Filtration Technology
  • HEPA Type: True HEPA 13 and HEPA 12 filters ensure efficient particulate removal.
  • Activated Carbon Layer: Absorbs gases and odors, including VOCs.
  • TVOC Removal Efficiency: Up to 98.9% for formaldehyde filters.
  • Virus and Bacteria Efficiency: Removes 99% of airborne viruses and bacteria.
  • Service Life: Filters last between 4 to 12 months depending on type.
Compact and Lightweight Design
  • Dimensions: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
  • Weight: Ranges from 1.5 to 1.9 lbs depending on filter type
Customize your air like you customize your meals—hold the formaldehyde and breathe easy with Wyze Air Filters.
Man replacing air purifier filter in home Alt text: Man replacing air purifier filter in a modern home setting
Wyze Air Purifier: Smart, Quiet, and Powerful Air Cleaning
High-Performance Air Purification for Larger Spaces
The Wyze Air Purifier is a connected home device designed to clear the air in rooms sized 450-550 ft², perfect for living rooms or bedrooms with new furniture emitting VOCs.
  • Pre-installed Filter Options: Allergen, Formaldehyde, or Wildfire filters.
  • Particulate Matter CADR: Up to 350 m³/h (206 CFM) for allergen filter.
  • Formaldehyde CADR: 317 m³/h (186 CFM) for premium formaldehyde filter.
  • Noise Levels: Whisper-quiet operation starting below 21 dBA.
  • Smart Features: Laser particle detection with 0.3-micron accuracy, real-time air quality alerts, and compatibility with Google Home and Alexa.
Sleek and Functional Design
  • Dimensions: 9.5" x 9.4" x 18.5" (243 mm x 240 mm x 472 mm)
  • Weight: Approximately 9 lbs depending on filter type
  • Operating Conditions: Works efficiently between 14°F to 104°F and humidity below 85%
A luxury air purifier without the luxury price tag, designed to protect your family from VOCs and allergens silently and smartly.
Lifestyle image of air purifier in cozy living room Alt text: Cozy living room with Wyze Air Purifier running in the background
Wyze Air Filter Subscription: Hassle-Free Replacement Filters
Keep Your Air Purifier Performing at Its Best
To maintain optimal air quality, regular filter replacement is crucial. Wyze offers a convenient subscription service for replacement filters matching your purifier’s needs:
  • Filter Types Available: Allergen, Formaldehyde, Wildfire
  • Filter Composition: Pre-filter + True HEPA + Activated Carbon (with MnO2 for formaldehyde)
  • Service Life: 4 to 12 months depending on filter type
Never worry about forgetting to replace your filter—subscribe and breathe fresh air continuously.
Why Choose Wyze for Your Home’s Air Quality?
  • Targeted VOC Removal: Specialized formaldehyde filters designed for new furniture emissions.
  • Smart Home Integration: Control and monitor air quality from your smartphone or voice assistant.
  • Quiet Operation: Maintain peace and comfort while your air purifier works.
  • Affordable and Effective: High-quality filtration without breaking the bank.
Enhance your home’s air quality today with Wyze’s customizable air filters and smart purifiers—perfect for homes with new furniture and VOC concerns.
FeatureWyze Air FilterWyze Air PurifierWyze Air Filter Subscription
TypeConnected Home AccessoryConnected Home DeviceHardware Subscription
PurposeReplacement/custom filters for air purifierAir purifier device with pre-installed filterReplacement filters for Wyze Air Purifier
VariantsAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use) pre-installedAllergen Filter, Formaldehyde Filter, Wildfire Filter
Price Range$37.99 - $63.99$169.99 - $194.99$37.99 - $63.99
Filter CompositionPre-filter + True HEPA 13 + Activated Carbon (Allergen)
Pre-filter + True HEPA 12 + MnO2 + Activated Carbon (Formaldehyde)
Pre-filter + True HEPA 12 + Activated Carbon (Wildfire)
Same as Wyze Air FilterSame as Wyze Air Filter
CADR (Particulate Matter)362 m³/h (Allergen)
317 m³/h (Formaldehyde)
342 m³/h (Wildfire)
350 CADR (overall device)Same as Wyze Air Filter
TVOC Removal Efficiency92.7% (Allergen)
98.9% (Formaldehyde)
97.1% (Wildfire)
Not specifiedSame as Wyze Air Filter
Service Life (Filter Life)6–12 months (Allergen)
5–12 months (Formaldehyde)
4–12 months (Wildfire)
Recommended filter replacement every 6 monthsSame as Wyze Air Filter
Dimensions8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)Not specifiedSame as Wyze Air Filter
Weight1.5 lb (Allergen)
1.7 lb (Formaldehyde)
1.9 lb (Wildfire)
FeaturesFilters customized to specific needs (allergens, formaldehyde, wildfire smoke)350 CADR, whisper-quiet (21 dB), smart controls, AQ alerts, laser particle detection, compatible with Alexa & Google HomeReplacement filters for continuous use
AvailabilityCurrently sold out or unavailableLow stock (43 left)Available
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
Why are air filters important for homes with new furniture and VOCs?New furniture often releases volatile organic compounds (VOCs) like formaldehyde, which can negatively impact indoor air quality and your family's health. Using air filters specifically designed to remove VOCs and allergens helps create a safer and fresher home environment.
What types of Wyze air filters are available for VOC and allergen removal?Wyze offers three specialized air filter types: the Allergen Filter (Standard) for dust and pet dander, the Formaldehyde Filter (Premium) for removing formaldehyde and VOCs, and the Wildfire Filter (Special Use) for smoke and wildfire-related particles.
How effective are Wyze air filters at removing formaldehyde and VOCs?Wyze Formaldehyde Filters offer up to 98.9% removal efficiency for total volatile organic compounds (TVOCs), including formaldehyde, making them highly effective for homes with new furniture or building materials.
What filtration technology do Wyze air filters use?Wyze air filters use a combination of True HEPA 13 or HEPA 12 filters for particulate removal, an activated carbon layer to absorb gases and odors (including VOCs), and, in the case of the formaldehyde filter, manganese dioxide (MnO2) for enhanced VOC removal.
How long do Wyze air filters last before needing replacement?Wyze air filters have a service life of 4 to 12 months, depending on the filter type and usage conditions. Regular replacement ensures optimal air purification performance.
What room size can the Wyze Air Purifier effectively clean?The Wyze Air Purifier is designed for rooms sized between 450 and 550 square feet, making it ideal for living rooms, bedrooms, or other large spaces with new furniture emitting VOCs.
Are Wyze air purifiers quiet during operation?Yes, Wyze air purifiers operate at whisper-quiet noise levels starting below 21 dBA, ensuring they clean your air without disturbing your home environment.
What smart features do Wyze air purifiers offer?Wyze air purifiers feature laser particle detection with 0.3-micron accuracy, real-time air quality alerts, and compatibility with Google Home and Alexa for convenient smart home integration.
How does the Wyze Air Filter Subscription work?The Wyze Air Filter Subscription is a hassle-free service that delivers replacement filters to your door at regular intervals, ensuring you never forget to replace your filter and always maintain optimal air quality.
Why should I choose Wyze air filters and purifiers for my home?Wyze offers targeted VOC removal with specialized formaldehyde filters, smart home integration, quiet operation, and affordable pricing, making them an effective and convenient choice for improving indoor air quality—especially in homes with new furniture.
What types of filters are available for the Wyze Air Filter?How does the formaldehyde filter work in the Wyze Air Filter?Do you have any deals, ongoing sales, discounts, or promotions?
