Reliable Local Recording for Wyze Cam Floodlight with MicroSD
Reliable Local Recording Solutions for Wyze Cam Floodlight with Wyze MicroSD Card
When it comes to securing your home with Wyze Cam Floodlight models, having a reliable local recording solution is essential. The Wyze MicroSD Card is designed specifically to unlock continuous local recording and time lapse features for your Wyze cameras, including the Wyze Cam Floodlight series. This combination ensures you never miss a moment, even without cloud storage.
Wyze MicroSD Card: The Backbone of Local Recording
Unlock Continuous Local Recording and Timelapse
The Wyze MicroSD Card supports continuous local recording, allowing your Wyze Cam Floodlight to save footage directly to the card. This means you can review your video timeline anytime without relying on cloud services.
  • Available Sizes: 32GB, 128GB, and 256GB microSD cards
  • Features: Local recording, timeline controls, calendar view, continuous recording, and timelapse
  • Compatibility: Works seamlessly with all Wyze Cams including floodlight models
This memory card is an affordable and essential accessory to maximize your Wyze Cam Floodlight’s potential for local video storage.
Wyze Cam Floodlight v2: Bright, Smart, and Secure
Wyze Cam Floodlight v2 in action at driveway Alt text: Wyze Cam Floodlight v2 illuminating driveway with detected person
Key Features
  • Video Quality: Crisp 2K (2304 x 1296) resolution with Color Night Vision
  • Lighting: 2800 lumens from 2 dimmable LED panels, 5000K color temperature
  • Field of View: Wide 160° diagonal angle for broad coverage
  • Local Storage: Supports up to 256GB microSD card (ExFAT format)
  • Connectivity: 2.4 GHz Wi-Fi (802.11 b/g/n)
  • Smart Features: AI-powered light control, two-way audio, siren (105dB), and dusk-to-dawn automation
  • Durability: IP65 weather resistance for reliable outdoor use
  • Integration: Works with Alexa, Google Assistant, and IFTTT
The Wyze Cam Floodlight v2 is perfect for homeowners seeking a powerful floodlight camera with reliable local recording capabilities when paired with the Wyze MicroSD Card.
Wyze Cam Floodlight Pro: Enhanced Security with AI and 2.5K QHD Video
Wyze Cam Floodlight Pro with woman and dog Alt text: Woman with dog near Wyze Cam Floodlight Pro outdoor security camera
Advanced Specifications
  • Resolution: 2.5K QHD (2560 x 1440) with Color Night Vision
  • Field of View: Ultra-wide 180° diagonal, 170° horizontal, 95° vertical
  • Lighting: 3 dimmable LED panels delivering 3000 lumens at 5000K
  • AI-Powered Detection: Onboard AI computer vision detects people, vehicles, and more, triggering lights only for selected objects
  • Local Storage: Supports up to 256GB microSD card (exFAT, FAT32)
  • Connectivity: Dual-band Wi-Fi (2.4 & 5 GHz)
  • Audio: 105dB siren, two-way audio with built-in speaker and microphone
  • Weatherproof: IP65 rating for all-weather durability
  • Smart Home Integration: Alexa, Google Assistant, IFTTT compatibility
The Floodlight Pro is ideal for users who want a high-powered, intelligent floodlight camera with superior local recording and detection capabilities.
Wyze Cam Floodlight Pro + Plug-In Mount: Easy Installation with Plug-and-Play
For those who want the power of the Floodlight Pro but prefer a simpler installation without wiring a junction box, the Wyze Cam Floodlight Pro + Plug-In Mount bundle offers a convenient solution.
Highlights
  • Plug-In Convenience: Comes with a 20-foot power cord and plug-in mount for easy setup
  • Same Features as Floodlight Pro: 2.5K QHD video, 180° ultra-wide view, 3000 lumens lighting, AI detection, and local microSD recording support
  • Weather Resistance: IP65 rated for outdoor use
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT
This bundle is perfect for renters or anyone looking for a powerful floodlight camera with hassle-free installation and reliable local recording.
Why Choose Wyze MicroSD Card for Your Wyze Cam Floodlight?
"Local recording with Wyze MicroSD Card ensures your footage is always accessible, secure, and uninterrupted by internet outages or cloud subscription limits."
  • Supports continuous 24/7 recording and timelapse modes
  • Compatible with all Wyze Cam Floodlight models (v1, v2, Pro, and Pro + Plug-In)
  • Affordable storage upgrade to maximize your camera’s potential
  • Easy to format and manage via the Wyze app’s timeline and calendar views
Summary: Best Local Recording Setup for Wyze Cam Floodlight
ProductVideo ResolutionLighting LumensField of ViewLocal Storage SupportInstallation TypePrice (USD)
Wyze MicroSD CardN/AN/AN/AUp to 256GBN/A$8.99 - $29.99
Wyze Cam Floodlight v22K (2304x1296)2800160°Up to 256GBHardwired$89.98
Wyze Cam Floodlight Pro2.5K QHD3000180°Up to 256GBHardwired$149.98
Wyze Cam Floodlight Pro + Plug-In Mount2.5K QHD3000180°Up to 256GBPlug-in (no wiring)$169.96
Conclusion
For a reliable local recording solution with your Wyze Cam Floodlight, pairing the camera with a Wyze MicroSD Card is the best choice. Whether you opt for the Wyze Cam Floodlight v2, the advanced Floodlight Pro, or the convenient Floodlight Pro + Plug-In Mount, you can enjoy continuous, high-quality local video storage without worrying about cloud subscriptions or internet interruptions. Invest in the Wyze MicroSD Card to unlock the full potential of your Wyze Cam Floodlight and keep your home security footage safe and accessible at all times.
FeatureWyze MicroSD CardWyze Cam Floodlight v2Wyze Cam Floodlight ProWyze Cam Floodlight Pro + Plug-In Mount
TypeAccessory (Memory Card)CameraCameraCamera Bundle (Floodlight Pro + Plug-In Mount)
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$89.98$149.98$169.96
Video ResolutionN/A2K HD2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Field of ViewN/A160° wide-angle180° wide-angle180° wide-angle
LightingN/A2 floodlight heads, 2800 lumens3 dimmable light panels, 3000 lumens total3 dimmable light panels, 3000 lumens total
Night VisionN/AColor Night VisionColor Night VisionColor Night Vision
Local RecordingYes, supports up to 256GB microSD24/7 local recording with microSD card up to 256GB24/7 local recording with microSD card up to 256GB24/7 local recording with microSD card up to 256GB
Storage SupportmicroSDHC/microSDXC (32GB, 128GB, 256GB)microSD card up to 256GBmicroSD card up to 256GBmicroSD card up to 256GB
Power SupplyN/AHardwired 110-120V ACHardwired 110-120V ACHardwired 110-120V AC
Plug-In Mount IncludedNoNoNoYes
Plug-In Mount PriceN/AN/AN/AIncluded
Motion DetectionN/AAdvanced motion detection, 270° PIR sensorAI computer vision, 270° PIR sensorAI computer vision, 270° PIR sensor
SirenN/A105 dB105 dB105 dB
Two-Way AudioN/AYesYesYes
Weather ResistanceN/AIP65IP65IP65
ConnectivityN/A2.4 GHz WiFi2.4 & 5 GHz dual-band WiFi2.4 & 5 GHz dual-band WiFi
AI FeaturesN/APerson, Pets, Vehicle, Package detection (with Cam Plus)Person, Pets, Vehicle, Package detection (with Cam Plus)Person, Pets, Vehicle, Package detection (with Cam Plus)
Ambient Light ModeN/AYesYesYes
InstallationN/ADIY, no junction box neededHardwired, professional or DIYDIY with plug-in mount, no junction box needed
DimensionsN/ANot specified10.2" x 9.1" x 7.8" (25.91 cm x 23.11 cm x 19.81 cm)Same as Floodlight Pro
WeightN/ANot specified2.9 lbs (1.32 kg)Same as Floodlight Pro
WarrantyNot specified1 Year1 Year1 Year
What is the best local recording solution for Wyze Cam Floodlight?The best local recording solution for Wyze Cam Floodlight is using a Wyze MicroSD Card. It enables continuous local recording and timelapse features, ensuring your footage is always accessible without relying on cloud storage.
Which Wyze Cam Floodlight models support local microSD card recording?All Wyze Cam Floodlight models, including Wyze Cam Floodlight v2, Floodlight Pro, and Floodlight Pro + Plug-In Mount, support local microSD card recording with up to 256GB capacity.
What sizes of Wyze MicroSD Card are available for Wyze Cam Floodlight?Wyze MicroSD Cards are available in 32GB, 128GB, and 256GB sizes, providing flexible storage options for your Wyze Cam Floodlight.
What are the benefits of using a Wyze MicroSD Card with my Wyze Cam Floodlight?Using a Wyze MicroSD Card with your Wyze Cam Floodlight allows for continuous 24/7 local recording, timelapse features, easy timeline and calendar review, and uninterrupted access to your footage even during internet outages or without a cloud subscription.
Is the Wyze MicroSD Card compatible with all Wyze cameras?Yes, the Wyze MicroSD Card is compatible with all Wyze cameras, including all Wyze Cam Floodlight models.
What video resolution does the Wyze Cam Floodlight v2 offer?The Wyze Cam Floodlight v2 offers crisp 2K (2304 x 1296) video resolution with Color Night Vision for clear footage day and night.
What are the key features of the Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro features 2.5K QHD video resolution, ultra-wide 180° field of view, 3000 lumens of lighting, onboard AI detection for people and vehicles, dual-band Wi-Fi, and support for up to 256GB microSD card for local recording.
Can I install the Wyze Cam Floodlight Pro without wiring?Yes, the Wyze Cam Floodlight Pro + Plug-In Mount bundle allows for easy plug-and-play installation with a 20-foot power cord, making it ideal for renters or those who prefer not to hardwire.
How much local video storage can I use with Wyze Cam Floodlight models?Wyze Cam Floodlight models support up to 256GB microSD cards (exFAT or FAT32 format), allowing for extensive local video storage.
Do Wyze Cam Floodlight models work with smart home assistants?Yes, all Wyze Cam Floodlight models are compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
What makes the Wyze MicroSD Card a good choice for local recording?The Wyze MicroSD Card is affordable, easy to manage via the Wyze app, supports continuous and timelapse recording, and is specifically designed for reliable performance with Wyze cameras.
Are Wyze Cam Floodlight cameras weather resistant?Yes, all Wyze Cam Floodlight models have an IP65 weather resistance rating, making them suitable for reliable outdoor use in various weather conditions.
What are the available sizes for the Wyze MicroSD Card?Can the Wyze MicroSD Card be used with all Wyze Cam models?What is the warranty policy for the Wyze MicroSD Card?
