Refurbished Noise Cancelling Bluetooth Headphones with 20 Hour Battery
Discover the perfect blend of premium sound quality, advanced noise cancellation, and long-lasting battery life with refurbished noise cancelling Bluetooth headphones. Whether you're commuting, working from home, or simply enjoying your favorite music, these headphones deliver an immersive audio experience while keeping distractions at bay.
Wyze Noise-Cancelling Headphones: Premium Sound Meets Affordability
Experience a symphony playing just for you with the
Wyze Noise-Cancelling Headphones, a top choice for refurbished noise cancelling Bluetooth headphones featuring an impressive 20-hour battery life.
Alt text: Person wearing Wyze noise cancelling headphones on a train platform, enjoying music during commute
Key Features and Specifications
- Hybrid Active Noise Cancellation (ANC): 40 dB noise reduction using 4 microphones and an ultra-fast processor to mute outside distractions.
- Transparency Mode: Amplify outside sounds with a simple touch, perfect for quick conversations or hearing your surroundings without removing headphones.
- Comfort Fit: 20mm memory foam and oblong earpads wrapped in protein leather provide fatigue-free comfort for all-day wear.
- Wireless Bluetooth 5.0: Seamlessly connect up to two devices simultaneously with a 33 ft range.
- 20-Hour Battery Life: Enjoy up to 20 hours of continuous music or calls on a single charge. Plus, a quick 10-minute charge gives you 4 extra hours.
- Voice-Isolating Microphones: Dedicated mics ensure your voice is crystal clear even in noisy environments.
- Customizable Sound: Use the Wyze app to adjust EQ settings for bass, mids, and highs to tailor your listening experience.
- Touch Controls & Voice Assistant: Intuitive touchpad controls for music, calls, and activating Alexa or your device’s native assistant.
Variants and Pricing
- Black or White colors available.
- Options with or without a travel case.
- Prices range from $89.99 to $99.99 depending on the variant.
"Few headsets cancel noise better than these Wyze Headphones, which are also one of the most comfortable headsets I’ve worn." – TechHive
Alt text: Person relaxing at home wearing Wyze noise cancelling headphones, enjoying music
Why Choose Refurbished Wyze Headphones?
Refurbished Wyze Noise-Cancelling Headphones offer the same high-quality audio and features as new models but at a more affordable price point. They undergo rigorous testing to ensure performance and reliability, making them a smart choice for budget-conscious audiophiles who want premium sound and noise cancellation.
Why Battery Life Matters in Noise Cancelling Headphones
Long battery life is essential for uninterrupted listening, especially when using active noise cancellation, which can drain power quickly. The Wyze Noise-Cancelling Headphones stand out with their 20-hour battery life, allowing you to enjoy your music, podcasts, or calls all day without frequent recharging.
Quick Charge Convenience
In a hurry? Just 10 minutes of charging provides 4 hours of playback, so you can get back to your audio experience fast.
Summary
If you're searching for
refurbished noise cancelling Bluetooth headphones with 20-hour battery life, the Wyze Noise-Cancelling Headphones are an excellent choice. They combine advanced hybrid ANC technology, comfortable design, and smart features like customizable EQ and voice assistant integration — all backed by a trusted brand.
Product Highlights
Conclusion
Upgrade your audio experience with refurbished Wyze Noise-Cancelling Headphones. Enjoy crystal-clear sound, powerful noise cancellation, and a full day of wireless freedom with a 20-hour battery. Perfect for work, travel, or relaxation, these headphones deliver premium quality without the premium price.
Note: This page focuses exclusively on refurbished noise cancelling Bluetooth headphones with 20-hour battery life. Other products such as smart scales or vacuum cleaners are not relevant to this query and thus not included.
What are refurbished noise cancelling Bluetooth headphones?
Refurbished noise cancelling Bluetooth headphones are pre-owned devices that have been professionally restored to like-new condition. They undergo rigorous testing to ensure they deliver the same high-quality audio, noise cancellation, and reliability as new models, but at a more affordable price.What is the battery life of Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones offer an impressive 20-hour battery life on a single charge, allowing you to enjoy uninterrupted music, calls, or podcasts all day long.How effective is the noise cancellation on Wyze Noise-Cancelling Headphones?
The Wyze Noise-Cancelling Headphones feature hybrid active noise cancellation (ANC) with 40 dB noise reduction, using 4 microphones and an ultra-fast processor to effectively mute outside distractions for an immersive listening experience.Do Wyze Noise-Cancelling Headphones support quick charging?
Yes, Wyze Noise-Cancelling Headphones support quick charging. A 10-minute charge provides up to 4 hours of playback, so you can get back to your audio experience quickly.Can I connect Wyze Noise-Cancelling Headphones to multiple devices?
Yes, these headphones use Bluetooth 5.0 technology and can seamlessly connect to up to two devices simultaneously within a 33 ft range.Are the Wyze Noise-Cancelling Headphones comfortable for long-term use?
Absolutely. The headphones feature 20mm memory foam and oblong earpads wrapped in protein leather, providing a fatigue-free, comfortable fit for all-day wear.What customization options are available for sound on Wyze Noise-Cancelling Headphones?
You can use the Wyze app to adjust EQ settings for bass, mids, and highs, allowing you to tailor your listening experience to your preferences.What colors and variants are available for refurbished Wyze Noise-Cancelling Headphones?
Refurbished Wyze Noise-Cancelling Headphones are available in black or white, with options to include or exclude a travel case. Prices range from $89.99 to $99.99 depending on the variant.Why should I choose refurbished Wyze Noise-Cancelling Headphones?
Refurbished Wyze Noise-Cancelling Headphones offer the same premium sound quality, advanced noise cancellation, and smart features as new models, but at a lower price. They are thoroughly tested for performance and reliability, making them a smart choice for budget-conscious audiophiles.Do Wyze Noise-Cancelling Headphones have voice assistant integration?
Yes, these headphones feature intuitive touchpad controls that allow you to activate Alexa or your device’s native voice assistant for hands-free convenience.
