Recessed Smart Bulbs with Sun Match & Custom Lighting Scenes
Recessed Smart Bulbs with Sun Match and Custom Lighting Scenes
Transform your home lighting with advanced recessed smart bulbs that offer sun-matching technology and customizable lighting scenes. Whether you want to mimic natural daylight or create the perfect ambiance for any occasion, these smart bulbs provide versatile, energy-efficient solutions that integrate seamlessly with your smart home ecosystem.
Wyze Bulb Color BR30 – Perfect for Recessed Lighting Fixtures
The Wyze Bulb Color BR30 is designed specifically for recessed lighting fixtures, making it an ideal choice for those seeking smart, color-changing bulbs with extensive customization options.
  • Dimmable & Color-Changing: Choose from 16 million ultra-accurate colors and adjust brightness to set the perfect mood.
  • Sun Match & Wide Color Temperature Range: Offers a color temperature range from 1800K to 6500K, allowing you to replicate natural sunlight or cozy warm light.
  • High Brightness: Lumens range from 30 to 950, providing ample light for any room.
  • Smart Features: Includes voice control compatibility with Alexa and Google Assistant, sleep routines, vacation mode, and music mode for dynamic lighting effects.
  • Long Life & Reliable: Rated for 25,000 hours of use with a high color rendering index (90+), ensuring vibrant and true-to-life colors.
  • Easy Integration: Connects via 2.4GHz WiFi and Bluetooth, controllable through the Wyze app for custom lighting scenes and schedules.
Light up your recessed fixtures with a smart bulb that adapts to your lifestyle and enhances your home’s ambiance effortlessly.
Cozy living room with recessed smart lighting Create natural daylight ambiance with recessed smart bulbs
Wyze Bulb White – Simple, Bright, and Dimmable
For those who prefer classic white lighting with smart controls, the Wyze Bulb White offers a bright, dimmable solution that fits standard fixtures.
  • Brightness & Color Temperature: Adjustable from 2700K (warm white) to 6500K (cool daylight) with brightness up to 800 lumens.
  • Energy Efficient: Consumes only 9.5 watts while delivering excellent illumination.
  • Smart Control: Compatible with Alexa, Google Assistant, and IFTTT for voice and app control.
  • Durable & Safe: Suitable for damp locations and rated for 25,000 hours of life.
  • Wide Beam Angle: 230° beam angle for broad, even lighting coverage.
  • Easy Setup: Works on 2.4GHz WiFi and Bluetooth, controllable via the Wyze app for scheduling and automation.
Perfect for recessed fixtures where you want reliable, bright white light with smart convenience.
Warm bedroom lighting with Wyze Bulb White Smart white lighting for cozy, customizable spaces
Wyze Switch – Upgrade Your Existing Lights to Smart Control
If you want to convert your existing recessed lighting into smart lighting without changing bulbs, the Wyze Switch is the perfect companion.
  • Smart Control Anywhere: Turn your normal lights into smart lights controllable from anywhere via the Wyze app.
  • Multi-Tap Actions: Customize single, double, and triple taps to control other Wyze devices like cameras, locks, or robot vacuums.
  • Automation & Scheduling: Create lighting automations, timers, and schedules to fit your daily routine.
  • Vacation Mode: Simulate occupancy by turning lights on/off randomly to enhance home security.
  • Power Loss Recovery: Automatically restores settings after power outages.
  • Seamless Integration: Works within the Wyze ecosystem and supports voice commands through Alexa and Google Assistant.
Easily transform your recessed lighting setup into a smart system without replacing bulbs.
Modern kitchen with Wyze Switch smart lighting Smart switch control for seamless lighting automation
Why Choose Wyze for Your Recessed Smart Lighting?
Wyze offers a comprehensive smart lighting solution that combines advanced technology, ease of use, and affordability. Whether you want the full color spectrum with the Wyze Bulb Color BR30, the simplicity of the Wyze Bulb White, or the flexibility of the Wyze Switch, you can create custom lighting scenes that match natural sunlight or your personal style.
  • Custom Lighting Scenes: Tailor your lighting to your mood, time of day, or activity.
  • Sun Match Technology: Mimic natural daylight to improve comfort and productivity.
  • Voice & App Control: Manage your lights hands-free or remotely from your smartphone.
  • Energy Efficient & Long-Lasting: Save on energy bills with smart scheduling and bulbs rated for 25,000 hours.
  • Integrated Ecosystem: Combine with other Wyze smart devices for a fully automated home.
Elevate your home lighting experience with Wyze’s recessed smart bulbs and switches designed for modern living.
Summary of Recessed Smart Bulb Options
ProductColor OptionsLumensColor Temp RangeSmart FeaturesIdeal For
Wyze Bulb Color BR3016 million colors30 - 9501800K - 6500KVoice control, custom scenes, music modeRecessed fixtures, mood lighting
Wyze Bulb WhiteWhite only30 - 8002700K - 6500KVoice control, dimmable, schedulingGeneral recessed lighting
Wyze SwitchN/A (switch control)N/AN/AMulti-tap, automation, vacation modeUpgrade existing lights
Enhance your home with recessed smart bulbs that offer sun match and custom lighting scenes. Choose Wyze for smart, reliable, and beautifully controllable lighting solutions.
FeatureWyze Bulb Color BR30Wyze Bulb WhiteWyze Switch
TypeConnected Home - Smart Color Bulb (BR30)Connected Home - Smart White BulbConnected Home - Smart Switch
Shape/BaseBR30 shape, E26 baseStandard bulb, E26 baseN/A (Switch)
Color Options16 million colorsWhite light (2700K - 6500K tunable)N/A
Brightness (Lumens)30 - 950 lm800 lmN/A
DimmableYes (Not for use with dimmer switches)YesControls dimmable lights
Color Temperature ControlYes (full color + white temperature control)Yes (2700K - 6500K)Controls connected lights
CRI Rating90+90+N/A
ConnectivityWiFi 2.4 GHz, BluetoothBluetooth (no hub required)WiFi via Wyze app
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Special FeaturesSun Match, Custom Scenes, Notifications, Music Mode (with Light Strip)Sun Match, Sleep Routines, Vacation ModeMulti-tap custom actions, automations, vacation mode, power loss recovery
Power SourceStandard light socketStandard light socketWired switch replaces normal switch
Compatible FixturesRecessed/can lighting with BR30 socketStandard E26 socketsControls normal lights
Packs & Pricing2-Pack $27.98, 4-Pack $49.982-Pack $23.99, 4-Pack $39.99, 6-Pack $59.991-Pack $14.99, 3-Pack $41.98
Notable LimitationsNot for use with dimmer switchesNone specifiedRequires installation, replaces existing switch
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What are recessed smart bulbs with sun match and custom lighting scenes?Recessed smart bulbs with sun match and custom lighting scenes are advanced lighting solutions designed for recessed fixtures. They allow you to mimic natural daylight, adjust color temperature, and create personalized lighting scenes for any occasion. These bulbs are energy-efficient, integrate with smart home systems, and can be controlled via voice or app.
What makes the Wyze Bulb Color BR30 ideal for recessed lighting?The Wyze Bulb Color BR30 is specifically designed for recessed lighting fixtures. It offers 16 million color options, a wide color temperature range from 1800K to 6500K, high brightness (30 to 950 lumens), and advanced smart features like voice control, custom scenes, and music mode. Its easy integration with WiFi and Bluetooth makes it perfect for creating dynamic and customizable lighting in any room.
How does Sun Match technology work in Wyze smart bulbs?Sun Match technology in Wyze smart bulbs automatically adjusts the color temperature of your lighting to mimic natural sunlight throughout the day. This helps improve comfort, productivity, and overall well-being by providing lighting that aligns with your natural circadian rhythm.
Can I control Wyze smart bulbs with voice assistants?Yes, Wyze smart bulbs are compatible with popular voice assistants like Amazon Alexa and Google Assistant. You can control your lights hands-free by using simple voice commands to turn them on or off, adjust brightness, or change colors.
What is the difference between Wyze Bulb Color BR30 and Wyze Bulb White?The Wyze Bulb Color BR30 offers 16 million color options, a wider color temperature range (1800K-6500K), and advanced features like music mode and custom scenes, making it ideal for mood lighting in recessed fixtures. The Wyze Bulb White provides adjustable white light (2700K-6500K), up to 800 lumens brightness, and is perfect for those who prefer classic white lighting with smart controls.
How energy efficient are Wyze smart bulbs?Wyze smart bulbs are highly energy efficient. For example, the Wyze Bulb White consumes only 9.5 watts while delivering up to 800 lumens of brightness. Both the Bulb Color BR30 and Bulb White are rated for 25,000 hours of use, helping you save on energy bills and reduce the need for frequent replacements.
What is the Wyze Switch and how does it work with recessed lighting?The Wyze Switch is a smart light switch that allows you to upgrade your existing recessed lighting to smart control without changing the bulbs. It enables remote control, automation, scheduling, and multi-tap actions to control other Wyze devices. The switch integrates seamlessly with the Wyze ecosystem and supports voice commands via Alexa and Google Assistant.
Can I automate and schedule my Wyze smart lighting?Yes, Wyze smart bulbs and switches support automation and scheduling through the Wyze app. You can set routines, timers, and custom lighting scenes to match your daily activities, ensuring your lights are always set to your preferred settings.
Are Wyze smart bulbs suitable for damp locations?Yes, the Wyze Bulb White is suitable for damp locations, making it a reliable choice for areas like bathrooms or kitchens where moisture may be present.
How do I set up Wyze smart bulbs and switches?Wyze smart bulbs and switches are easy to set up. They connect via 2.4GHz WiFi and Bluetooth and are controlled through the Wyze app. Simply follow the in-app instructions to add your devices, customize settings, and integrate them with your smart home ecosystem.
What are the benefits of using Wyze smart lighting for recessed fixtures?Wyze smart lighting offers customizable lighting scenes, sun match technology, voice and app control, energy efficiency, and long-lasting performance. With options for both color and white lighting, as well as smart switches, Wyze provides a flexible and affordable solution for enhancing your home’s ambiance and convenience.
Can you tell me more about the smart features of the Wyze Bulb Color BR30?How does the sun match technology work in the recessed smart bulbs?Do you have any deals, ongoing sales, discounts, or promotions for the recessed smart bulbs?
