Protect Wyze Camera Footage During Outages with MicroSD Cards
Protecting Valuable Footage on Wyze Cameras During Network Outages with Wyze MicroSD Card
When it comes to securing your home or business with Wyze cameras, one critical concern is ensuring your valuable footage is safely recorded even during network outages. Relying solely on cloud storage can leave gaps in your surveillance, but with the Wyze MicroSD Card, you can unlock continuous local recording that safeguards your videos regardless of internet connectivity.
Why Use Wyze MicroSD Card for Local Storage?
The Wyze MicroSD Card is designed specifically to complement Wyze cameras by enabling continuous recording and time-lapse features. This means your camera can store footage directly on the card, providing a reliable backup when your Wi-Fi is down or unstable.
  • Available Sizes: Choose from 32GB, 128GB, or 256GB microSD cards to fit your storage needs.
  • Seamless Integration: Works flawlessly with Wyze Cam models to ensure uninterrupted recording.
  • Affordable and Easy to Use: Starting at just $8.99, it’s a cost-effective way to enhance your camera’s capabilities.
Protect your footage locally and never miss a moment, even when your network fails.
Wyze Cam v4 and Wyze Cam v4 Outdoor Bundle: Advanced Cameras with Local Recording Support
Wyze Cam v4
The Wyze Cam v4 is a versatile indoor/outdoor camera that offers crystal-clear 2.5K QHD resolution and enhanced color night vision. Its compatibility with the Wyze MicroSD Card means you can enjoy 24/7 local recording, ensuring your footage is saved directly on the device.
  • Video Quality: 2.5K QHD resolution for sharp, detailed images.
  • Night Vision: Enhanced color night vision to capture clear footage in low light.
  • Field of View: Wide 115.8° diagonal field of view to cover more area.
  • Connectivity: Supports Wi-Fi 6 for faster, more reliable connections.
  • Smart Features: Works with Alexa and Google Assistant for voice control.
  • Local Storage: Supports continuous recording on Wyze MicroSD Cards.
For outdoor security, the Wyze Cam v4 Outdoor Bundle offers all the features of the standard v4 with added weatherproofing and a motion-activated spotlight to deter intruders.
  • Weatherproof Design: IP65 rating to withstand rain and dust.
  • Spotlight & Motion Detection: Integrated spotlight and radar + PIR motion sensors for enhanced security.
  • Local Recording: Supports 24/7 local recording with Wyze MicroSD Cards.
  • Wi-Fi 6 Support: Ensures stable connectivity even in busy networks.
  • Smart Home Integration: Compatible with Alexa and Google Assistant.
Wyze Cam v4 Outdoor Security
How Wyze MicroSD Card Enhances Your Camera’s Reliability
Using a Wyze MicroSD Card with your Wyze Cam v4 or Outdoor Bundle means your footage is stored locally on the card, providing several key benefits:
  • Network Independence: Footage is saved even if your internet goes down.
  • Continuous Recording: No gaps in video coverage during outages.
  • Easy Playback: Access recorded videos directly from the card via the Wyze app.
  • Time-Lapse Capability: Create time-lapse videos for quick event summaries.
This local storage solution is essential for anyone who wants peace of mind knowing their security footage is safe and accessible at all times.
Summary: Best Wyze Products for Reliable Footage Protection
ProductKey FeaturesPrice Range
Wyze MicroSD Card32GB, 128GB, 256GB sizes; continuous recording$8.99 - $29.99
Wyze Cam v42.5K QHD, color night vision, Wi-Fi 6, local recording$107.94 (varies)
Wyze Cam v4 Outdoor BundleWeatherproof, spotlight, motion detection, local recording$69.99
By pairing the Wyze MicroSD Card with the Wyze Cam v4 or its Outdoor Bundle, you ensure your valuable footage is protected no matter what happens to your network. Wyze Cam v4 Indoor Use
Invest in Wyze MicroSD Cards and Wyze Cam v4 cameras today to keep your home and memories safe, even during network interruptions.
Frequently Asked Questions
Can I use any microSD card with Wyze cameras?
While some microSD cards may work, the Wyze MicroSD Card is optimized for Wyze cameras to ensure reliable continuous recording and compatibility.
How much storage do I need?
For continuous recording, a 128GB or 256GB Wyze MicroSD Card is recommended to store several days of footage depending on your camera settings.
Will footage be saved if my Wi-Fi disconnects?
Yes, with a Wyze MicroSD Card installed, your camera will save footage locally even if your network is down.
Protect your home and valuable footage with the perfect combination of Wyze cameras and Wyze MicroSD Cards — the smart choice for uninterrupted security. Wyze Cam v4 Family Security
FeatureWyze MicroSD CardWyze Cam v4 Outdoor BundleWyze Cam v4
Product TypeAccessory (Memory Card)Camera BundleCamera
DescriptionUnlock continuous recording and time lapses for Wyze CamsWyze Cam v4 with Outdoor Power Adapter and 128GB MicroSD CardWyze Cam v4 standalone camera
Storage Options32GB microSDHC, 128GB microSDXC, 256GB microSDXCIncludes 128GB MicroSD CardSupports microSD card up to 512GB (sold separately)
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$69.99$35.98 (1 pack)
Video ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Continuous Local RecordingYesYesYes
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
Motion-Activated SpotlightN/AYesYes
Weather ResistanceN/AIP65IP65
CompatibilityCompatible with Wyze Cams with microSD slotWyze Cam v4Wyze Cam v4
Included AccessoriesMemory Card onlyWyze Cam v4, Outdoor Power Adapter, 128GB MicroSD CardWyze Cam v4, Quick Start Guide, Wall Mount, Power Adapter, USB Cable
Mounting OptionsN/ASame as Wyze Cam v4Stand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
PowerN/AWired (requires power adapter)Wired (requires power adapter)
Additional FeaturesUnlocks time lapse and continuous recording24/7 local recording, Wi-Fi 6, Alexa & Google Assistant compatible24/7 local recording, Wi-Fi 6, Alexa & Google Assistant compatible
WarrantyNot specified1 Year1 Year
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
How does the Wyze MicroSD Card protect my footage during network outages?The Wyze MicroSD Card enables your Wyze camera to record and store footage locally, ensuring that your videos are saved even if your internet connection goes down. This provides continuous surveillance coverage without relying solely on cloud storage.
What sizes are available for the Wyze MicroSD Card?The Wyze MicroSD Card is available in 32GB, 128GB, and 256GB sizes, allowing you to choose the storage capacity that best fits your recording needs.
Is the Wyze MicroSD Card compatible with all Wyze cameras?The Wyze MicroSD Card is designed to work seamlessly with Wyze Cam models, including the Wyze Cam v4 and Wyze Cam v4 Outdoor Bundle, ensuring reliable continuous recording and easy playback.
Can I use any microSD card with Wyze cameras?While some third-party microSD cards may work, the Wyze MicroSD Card is specifically optimized for Wyze cameras to ensure maximum compatibility and reliable continuous recording.
How much storage do I need for continuous recording on my Wyze camera?For continuous recording, it is recommended to use a 128GB or 256GB Wyze MicroSD Card. The exact number of days of footage stored will depend on your camera settings and resolution.
Will my Wyze camera save footage if my Wi-Fi disconnects?Yes, with a Wyze MicroSD Card installed, your Wyze camera will continue to record and save footage locally even if your Wi-Fi or internet connection is lost.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, a wide 115.8° field of view, Wi-Fi 6 support, smart home integration with Alexa and Google Assistant, and continuous local recording with a Wyze MicroSD Card.
What makes the Wyze Cam v4 Outdoor Bundle suitable for outdoor security?The Wyze Cam v4 Outdoor Bundle features weatherproofing with an IP65 rating, a motion-activated spotlight, radar and PIR motion sensors, Wi-Fi 6 support, and 24/7 local recording with a Wyze MicroSD Card, making it ideal for outdoor surveillance.
How can I access and playback footage stored on the Wyze MicroSD Card?You can easily access and playback recorded videos directly from the Wyze MicroSD Card using the Wyze app, allowing you to review footage anytime.
Does the Wyze MicroSD Card support time-lapse recording?Yes, the Wyze MicroSD Card enables time-lapse recording on compatible Wyze cameras, allowing you to create quick event summaries and monitor changes over time.
How does the Wyze MicroSD Card enhance the reliability of my Wyze camera?What are the available sizes for the Wyze MicroSD Card?Can I access recorded videos directly from the Wyze MicroSD Card using the Wyze app?
