Weatherproof Wyze Outdoor Power Adapter for Heavy Rain Protection
Protected Outdoor Power Adapter for Wyze Devices Under Heavy Rainfall
When it comes to securing your outdoor Wyze devices, having a reliable and weather-resistant power adapter is essential. Whether you’re facing heavy rainfall, snow, or intense sun, the Wyze Outdoor Power Adapter ensures your cameras stay powered safely and continuously. This page highlights the best Wyze products designed for outdoor use, focusing on their durability, compatibility, and performance under harsh weather conditions.
Wyze Outdoor Power Adapter: Ultimate Weather Protection
Designed for All Weather Conditions
The Wyze Outdoor Power Adapter is built to withstand the elements with an IP67 weather-resistant rating, making it perfect for use in heavy rain, snow, or shine. This means it is dust-tight and can handle immersion in water up to 1 meter deep for 30 minutes, ensuring your Wyze cameras remain powered no matter the weather.
Compatibility and Versatility
  • Works seamlessly with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, and Battery Cam Pro (with the appropriate adapters).
  • For Wyze Cam v3 Pro and Pan v3, pairing with the L-shaped MicroUSB Adapter is required.
  • Battery Cam Pro users will need the USB-C adapter alongside the power adapter.
  • Note: Not compatible with the OG Stack Kit.
Easy Installation and Reliable Power
  • Comes in multiple variants including bundles with L-shaped and USB-C adapters.
  • Provides a steady 5V/2A output to keep your cameras running smoothly.
  • 6-foot power cable length for flexible placement.
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter is your go-to solution for powering Wyze outdoor cameras safely and reliably.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 powered by Wyze Outdoor Power Adapter, weatherproof and ready for snow.
Wyze Cam Pan v3: 360° Outdoor Surveillance with Weather Resistance
Full Outdoor Protection with IP65 Rating
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera featuring a 360° horizontal pan and 180° vertical tilt. Its IP65 weather resistance rating means it can handle rain and dust, making it ideal for outdoor security when paired with the Wyze Outdoor Power Adapter.
Key Features
  • 1080p Full HD video with smooth pan and tilt for complete coverage.
  • Night vision with 4 IR LEDs for clear images in the dark.
  • Two-way audio with built-in microphone and speaker for real-time communication.
  • Noise and echo cancellation for crystal-clear sound.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
  • Operating temperature range from -4°F to 122°F (-20°C to 50°C).
Why Pair with Wyze Outdoor Power Adapter?
The Pan v3 requires the Wyze Outdoor Power Adapter (sold separately) for safe and reliable outdoor use, ensuring your camera stays powered through heavy rain and adverse weather.
Wyze Cam v4: High-Resolution Outdoor Security with Enhanced Night Vision
Superior Video Quality and Weather Resistance
The Wyze Cam v4 offers 2.5K QHD resolution for crystal-clear video, making it one of the most advanced outdoor cameras in the Wyze lineup. It features Enhanced Color Night Vision and a motion-activated spotlight to keep your property safe day and night.
Outdoor-Ready Design
  • IP65 weather resistance rating protects against rain and dust.
  • Supports 24/7 local recording and Wi-Fi 6 for faster, more reliable connectivity.
  • Compatible with Alexa and Google Assistant for voice control.
  • Includes a 6-foot flat micro USB cable and multiple mounting options (stand, wall, ceiling, magnetic).
Powering Wyze Cam v4 Outdoors
Use the Wyze Outdoor Power Adapter to ensure your Cam v4 remains powered safely outdoors, even during heavy rainfall or snow.
Why Choose Wyze Outdoor Power Solutions?
  • IP67-rated power adapter ensures your outdoor Wyze cameras stay powered in wet conditions.
  • Compatible with multiple Wyze camera models, including the latest Cam v4 and Pan v3.
  • Easy to install with bundled adapters for different camera models.
  • Designed to work seamlessly with Wyze’s smart home ecosystem.
Protect your investment and keep your outdoor Wyze devices running smoothly with the Wyze Outdoor Power Adapter — the trusted choice for weatherproof power.
Additional Outdoor Power Option: Wyze Plug Outdoor
While the Wyze Outdoor Power Adapter is designed specifically for Wyze cameras, the Wyze Plug Outdoor is a smart plug solution for powering other outdoor devices like garden lights, holiday inflatables, or pond pumps. It features:
  • IP64 weather resistance for protection against rain and dust.
  • Two independently controlled outlets.
  • Energy monitoring and scheduling via the Wyze app.
  • Long-range Wi-Fi connectivity up to 300 feet in open space.
  • Voice control compatibility with Alexa and Google Assistant.
Though not a direct power source for Wyze cameras, the Wyze Plug Outdoor complements your outdoor smart setup by powering additional devices safely in all weather.
Summary
For reliable, weatherproof power under heavy rainfall and harsh outdoor conditions, the Wyze Outdoor Power Adapter is the essential accessory for your Wyze outdoor cameras. Pair it with the Wyze Cam Pan v3 or Wyze Cam v4 for comprehensive outdoor security with peace of mind. Enhance your outdoor smart home setup with the Wyze Plug Outdoor for versatile power control of other outdoor electronics.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam v4
TypeAccessoryCameraCamera
Weather ResistanceIP67IP65IP65
Outdoor UseYes, designed for outdoor useYes, requires Wyze Outdoor Power Adapter (sold separately)Yes, requires Outdoor Power Adapter (sold separately)
CompatibilityWorks with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, Battery Cam Pro (with adapters)Indoor/Outdoor 360° pan and 180° tilt cameraIndoor/Outdoor camera
Power Adapter IncludedNo, sold separatelyNo, sold separatelyIncluded in some bundles, sold separately
Video ResolutionN/A1080p (1920 x 1080)2.5K QHD (2560 x 1440)
Field of ViewN/A120° FOVDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Pan/TiltN/A360° pan, 180° tiltFixed angle
Night VisionN/AColor Night Vision (Starlight Sensor)Enhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)
AudioN/A2-way audio, built-in speaker and microphone2-way audio, 99dB waterproof speaker
ConnectivityN/A802.11 b/g/n 2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6
StorageN/ASupports up to 256 GB microSD (ExFAT)Supports microSD up to 512 GB
DimensionsN/A124mm (H) x 60mm (W) x 63mm (D)2in x 2in x 2 3/8in
WeightN/A11.29 oz (320 g)0.49 lb (222 g)
Power Adapter Output5V/2000mA5V/2000mA (via adapter)5V/1A (Indoor adapter included)
Operating TemperatureN/A-20°C to 50°C (-4°F to 122°F)-20°C to 50°C (-4°F to 122°F)
Mounting OptionsN/AScrew 1/4" - 20Stand, wall mount, ceiling mount, magnetic mount
Additional FeaturesIP67 weather resistant, required for outdoor use with certain Wyze camerasAutomatic motion tracking, Privacy Mode, Pan Scan™ Patrol, Custom detection zonesMotion-activated spotlight, Wide Dynamic Range (WDR), Built-in siren
Price$14.99 - $19.99 (depending on variant)$39.98 (1 pack)$35.98 - $100 (varies by bundle and variant)
What is the Wyze Outdoor Power Adapter and why is it important for outdoor Wyze cameras?The Wyze Outdoor Power Adapter is a weather-resistant power solution designed to keep your Wyze cameras powered safely and continuously outdoors. With an IP67 rating, it protects against heavy rainfall, snow, and dust, ensuring your cameras remain operational in harsh weather conditions.
Which Wyze camera models are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, and Battery Cam Pro (with the appropriate adapters). Note that it is not compatible with the OG Stack Kit.
What weather resistance rating does the Wyze Outdoor Power Adapter have?The Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it dust-tight and capable of withstanding immersion in water up to 1 meter deep for 30 minutes. This ensures reliable performance in heavy rain, snow, and other challenging outdoor conditions.
Do I need any additional adapters to use the Wyze Outdoor Power Adapter with certain cameras?Yes, for Wyze Cam v3 Pro and Pan v3, you need the L-shaped MicroUSB Adapter. For Battery Cam Pro, a USB-C adapter is required. These adapters are available in bundles with the power adapter.
How long is the power cable included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 6-foot power cable, providing flexible placement options for your outdoor cameras.
Is the Wyze Outdoor Power Adapter easy to install?Yes, the Wyze Outdoor Power Adapter is designed for easy installation and comes in multiple variants, including bundles with necessary adapters for different camera models.
Why should I use the Wyze Outdoor Power Adapter with the Wyze Cam Pan v3?The Wyze Cam Pan v3 is an indoor/outdoor camera with IP65 weather resistance. For safe and reliable outdoor use, especially in heavy rain or snow, it requires the Wyze Outdoor Power Adapter to ensure continuous power supply.
How does the Wyze Cam v4 benefit from the Wyze Outdoor Power Adapter?The Wyze Cam v4 features 2.5K QHD resolution and IP65 weather resistance. Using the Wyze Outdoor Power Adapter ensures the camera remains powered safely outdoors, even during severe weather, for uninterrupted security coverage.
What is the difference between the Wyze Outdoor Power Adapter and Wyze Plug Outdoor?The Wyze Outdoor Power Adapter is specifically designed to power Wyze cameras outdoors with IP67 weather resistance. The Wyze Plug Outdoor is a smart plug with IP64 weather resistance, ideal for powering other outdoor devices like garden lights or pond pumps, and offers energy monitoring and scheduling via the Wyze app.
Can the Wyze Plug Outdoor be used to power Wyze cameras?No, the Wyze Plug Outdoor is not a direct power source for Wyze cameras. It is intended for other outdoor electronics, such as lights or pumps, and complements your outdoor smart home setup.
What are the key features of the Wyze Cam Pan v3 for outdoor use?The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, night vision, two-way audio, and IP65 weather resistance. It operates in temperatures from -4°F to 122°F and integrates with Alexa, Google Assistant, and IFTTT.
What are the main benefits of using Wyze Outdoor Power Solutions?Wyze Outdoor Power Solutions provide weatherproof, reliable power for your outdoor Wyze cameras, are compatible with multiple camera models, are easy to install, and integrate seamlessly with Wyze’s smart home ecosystem.
What are the key features of the Wyze Outdoor Power Adapter?How does the Wyze Outdoor Power Adapter ensure compatibility with different Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
