Professional Level Home Security Kit for Renters Without Expensive Contracts
Renting a home doesn't mean you have to compromise on security. For renters seeking a professional-grade home security system without the burden of costly contracts, the Wyze Sense product line offers an affordable, flexible, and easy-to-install solution. These devices work seamlessly together to provide comprehensive monitoring, alerting you instantly to any unusual activity or hazards in your home.
Core Components of Your Home Security Kit
Wyze Sense Hub: The Central Brain of Your Security System
The Wyze Sense Hub acts as the command center for your entire security setup. It connects all your sensors and devices, sending real-time alerts directly to your smartphone.
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication.
- Range: Covers up to 500 feet to sensors, ideal for apartments or multi-room setups.
- Battery Backup: Built-in rechargeable battery with up to 10 hours of backup power.
- Siren: Loud 88db siren at 2 feet to deter intruders.
- Compact Design: Matte white finish measuring 4.5” x 4” x 1” fits discreetly in any room.
- Included Accessories: Power adapter, Ethernet cable, window decals, and quick start guide.
This hub is essential for integrating all Wyze Sense sensors and managing your home security remotely without any monthly fees.
Essential Sensors for Complete Home Protection
Wyze Sense Keypad: Arm and Disarm with Ease
The Wyze Sense Keypad allows you to arm or disarm your security system remotely or on-site, providing convenient control without needing your phone.
- Functionality: Arm/disarm system, emergency button for quick alerts.
- Indoor Use: Designed for indoor installation with permanent adhesive mounting.
- Compatibility: Requires Wyze Sense Hub and Wyze Home Monitoring.
- Accessory Capacity: Supports up to 100 accessories, perfect for expanding your system.
This keypad is perfect for renters who want quick, contract-free control over their home security.
Wyze Sense Motion Sensor: Detect Movement Instantly
Keep an eye on any unexpected movement inside your home with the Wyze Sense Motion Sensor.
- Detection Range: Up to 25 feet with a 120° field of view.
- Adjustable Sensitivity: Customize detection levels to reduce false alarms.
- Installation: Easy adhesive back or optional screws for secure mounting.
- Battery Life: Long-lasting battery up to 18 months.
- Compatibility: Works with Wyze Sense Hub and Wyze Home Monitoring.
Wyze Sense Entry Sensor: Monitor Doors and Windows
Know immediately when doors or windows are opened or closed with the Wyze Sense Entry Sensor.
- Detection: Alerts you to any opening or closing events.
- Pack Size: Available in convenient 3-packs for multiple entry points.
- Installation: Simple adhesive mounting.
Wyze Sense Leak Sensor & Probe: Protect Against Water Damage
Water leaks can cause costly damage. The Wyze Sense Leak Sensor & Probe notifies you instantly if leaks are detected.
- Sensor Range: Up to 500 feet from the hub.
- Operating Conditions: Works indoors between 32°F to 104°F.
- Installation: Place near potential leak sources like sinks or water heaters.
Why Choose Wyze Sense for Renters?
"Wyze Sense offers a professional-grade security system that is easy to install, contract-free, and budget-friendly—ideal for renters who want peace of mind without long-term commitments."
- No Expensive Contracts: Own your system outright with no monthly fees.
- Easy Installation: Adhesive mounts and wireless connectivity mean no drilling or wiring.
- Expandable: Add up to 100 sensors and accessories to customize your security.
- Remote Control: Manage your system from anywhere using the Wyze app.
- Discreet Design: Sleek, compact devices blend seamlessly into your home environment.
Summary of Your Professional Home Security Kit
Product | Key Features | Price (USD) |
Wyze Sense Hub | Central controller, 500 ft range, siren | $45.98 |
Wyze Sense Keypad | Arm/disarm, emergency button | $27.98 |
Wyze Sense Motion Sensor | 25 ft detection, adjustable sensitivity | $20.98 |
Wyze Sense Entry Sensor | Detects open/close, 3-pack | $41.98 |
Wyze Sense Leak Sensor | Leak detection, probe included | $13.98 - $55.98 |
Equip your rental home with this professional-level security kit from Wyze Sense and enjoy smart, contract-free protection tailored to your needs.
What makes the Wyze Sense Home Security Kit ideal for renters?
The Wyze Sense Home Security Kit is perfect for renters because it offers professional-grade security without expensive contracts or monthly fees. Its easy, adhesive-based installation requires no drilling or wiring, making it simple to set up and remove when moving. The system is also fully expandable and can be managed remotely via the Wyze app.Do I need to sign a contract to use Wyze Sense home security products?
No, Wyze Sense home security products are contract-free. You own your system outright and are not required to pay any monthly fees or sign long-term agreements.What components are included in the Wyze Sense Home Security Kit?
The core components of the Wyze Sense Home Security Kit include the Wyze Sense Hub (central controller), Wyze Sense Keypad (for arming/disarming), Wyze Sense Motion Sensor (detects movement), Wyze Sense Entry Sensor (monitors doors and windows), and Wyze Sense Leak Sensor & Probe (detects water leaks).How does the Wyze Sense Hub work?
The Wyze Sense Hub acts as the command center for your security system, connecting all sensors and devices. It supports Ethernet, WiFi, Bluetooth, and RF communication, covers up to 500 feet, and features a built-in siren and battery backup. It sends real-time alerts to your smartphone and allows remote management via the Wyze app.Can I install Wyze Sense security devices without professional help?
Yes, Wyze Sense security devices are designed for easy DIY installation. Most components use adhesive mounts, so no drilling or wiring is required. The system is renter-friendly and can be set up in minutes.Is the Wyze Sense system expandable?
Yes, the Wyze Sense system is highly expandable. You can add up to 100 sensors and accessories, allowing you to customize your home security setup to fit your needs.How do I control and monitor my Wyze Sense security system?
You can control and monitor your Wyze Sense security system remotely using the Wyze app on your smartphone. The app provides real-time alerts, system status, and allows you to arm or disarm your system from anywhere.What is the range of the Wyze Sense Hub and sensors?
The Wyze Sense Hub covers up to 500 feet to connected sensors, making it suitable for apartments and multi-room homes. Individual sensors, such as the motion and leak sensors, also operate within this range.How does the Wyze Sense Entry Sensor work?
The Wyze Sense Entry Sensor monitors doors and windows, sending instant alerts to your phone whenever they are opened or closed. It is easy to install with adhesive backing and comes in convenient 3-packs for multiple entry points.What is the battery life of Wyze Sense sensors?
Wyze Sense sensors are designed for long-lasting performance. For example, the motion sensor has a battery life of up to 18 months, reducing the need for frequent replacements.Does the Wyze Sense system include a siren?
Yes, the Wyze Sense Hub features a built-in 88db siren to help deter intruders and alert you to emergencies.Can Wyze Sense detect water leaks?
Yes, the Wyze Sense Leak Sensor & Probe detects water leaks and notifies you instantly if a leak is detected, helping you prevent costly water damage. It can be placed near sinks, water heaters, or other potential leak sources.Are Wyze Sense devices discreet and suitable for any home decor?
Yes, Wyze Sense devices feature a sleek, compact, and matte white design that blends seamlessly into any home environment, making them both functional and unobtrusive.
