Portable Handheld Vacuum with True HEPA Filter for Allergies
If you suffer from allergies and need a reliable, portable handheld vacuum that effectively traps allergens, the Wyze Handheld Vacuum is an excellent choice. Designed with a True HEPA allergen filtration system, this vacuum ensures that dust, pet dander, and other microscopic particles are captured, helping you breathe cleaner air while keeping your home spotless.
Wyze Handheld Vacuum: Compact, Powerful, Allergy-Friendly
The Wyze Handheld Vacuum is a compact yet powerful cordless vacuum designed for spot cleaning anywhere—from your car to your home. It features:
  • True HEPA allergen filtration that traps 99.97% of particles as small as 0.3 microns, ideal for allergy sufferers.
  • Powerful suction: 9,000 PA in default mode and up to 16,800 PA in max power mode, delivering double the suction of many handheld vacuums.
  • Lightweight and portable: Weighing only 1.23 lbs (19.8 oz) and under 3 inches thick, it’s easy to carry and maneuver.
  • Quiet operation: At 73.8 dB(A), it’s 20% quieter than most handheld vacuums.
  • Long battery life: Up to 30 minutes in default mode and 10 minutes in max power mode, with a quick 3-hour Type-C charging.
  • Full accessory kit: Includes crevice tool, brush tool, extension hose, flat nozzle, and storage bag for versatile cleaning.
This vacuum is perfect for allergy sufferers who want a portable, effective cleaning tool that doesn’t stir up dust or allergens. Lifestyle image of vacuuming with pet nearby Keep your home allergen-free with Wyze Handheld Vacuum
Wyze Handheld Vacuum Filter: Maintain Peak Performance
To keep your Wyze Handheld Vacuum working at its best and maintaining its HEPA filtration efficiency, regular filter replacement is essential. The Wyze Handheld Vacuum Filter is designed exclusively for this vacuum and comes in convenient 1-pack or 3-pack options.
  • Ensures continued allergen capture and suction power.
  • Easy to replace and maintain.
  • Affordable and readily available.
Wyze Cordless Vacuum S: For More Power and Longer Cleaning Sessions
If you need a more robust cordless vacuum with advanced filtration for allergy control, consider the Wyze Cordless Vacuum S. It offers:
  • 20,000 Pa suction power in Turbo Mode and 100 AW power rating for deep cleaning.
  • 3-stage filtration system including HEPA filter to trap allergens and fine dust.
  • Lightweight design: 2.8 lbs main unit, easy to handle.
  • Longer runtime: Up to 40 minutes in ECO mode.
  • LED screen and 6 daylight-bright LED lights in the brush head for better visibility.
  • Comes with multiple attachments like crevice tool, floor brush, and HEPA filter housing.
This vacuum is ideal for allergy sufferers who want a cordless vacuum with professional-grade suction and filtration for whole-home cleaning. Wyze Cordless Vacuum lifestyle cleaning Powerful cordless vacuum for allergy relief
Enhance Your Allergy Defense with Wyze Air Purifier and Filters
While handheld vacuums with HEPA filters help reduce allergens on surfaces, improving your indoor air quality is equally important. The Wyze Air Purifier paired with its customizable Allergen Filter offers:
  • True HEPA 13 filtration capturing 99% of airborne allergens, viruses, and bacteria.
  • Activated carbon layer to reduce odors and harmful gases.
  • High CADR (Clean Air Delivery Rate): 350 m³/h for allergen filter, suitable for rooms up to 550 sq. ft.
  • Whisper-quiet operation: As low as 21 dBA.
  • Smart controls and air quality alerts via app integration with Alexa and Google Home.
  • Filter options include Allergen, Formaldehyde, and Wildfire filters for tailored air purification.
This purifier complements your handheld vacuum by continuously cleaning the air you breathe, making it a must-have for allergy-prone households. Man replacing air purifier filter Maintain fresh air with Wyze Air Purifier filter replacement
Summary
For allergy sufferers seeking a portable handheld vacuum with True HEPA filtration, the Wyze Handheld Vacuum stands out with its powerful suction, lightweight design, and comprehensive accessory kit. Keep it performing at its best with the dedicated Wyze Handheld Vacuum Filters. For more intensive cleaning needs, the Wyze Cordless Vacuum S offers superior suction and a multi-stage HEPA filtration system, perfect for whole-home allergen control. To complement your cleaning routine, the Wyze Air Purifier with customizable HEPA filters ensures the air in your home stays clean and allergen-free. Together, these Wyze products provide a comprehensive solution to allergy management through effective surface and air cleaning.
FeatureWyze Handheld VacuumWyze Cordless Vacuum SWyze Handheld Vacuum FilterWyze Air Purifier
TypeHandheld Cordless VacuumCordless Stick VacuumReplacement FilterAir Purifier
Price$39.99 (Sold out)$139.99$9.99 (3 Pack), $13.99 (1 Pack)$169.99 - $194.99 (depending on filter)
Weight1.23 lbs2.8 lbsN/A8.75 - 9.32 lbs (depending on filter)
DimensionsUnder 3" thickNot specifiedN/A9.5" x 9.4" x 18.5"
Suction Power16.8 kPaUp to 20,000 PaN/AN/A
Battery LifeUp to 30 minutesUp to 40 minutesN/AN/A
ChargingUSB-CNot specified (interchangeable lithium-ion)N/AAC 120V/60 Hz
FiltrationTrue HEPA (95% allergen trapping)3-stage HEPA (95% particles <0.3 µm)Replacement for Wyze Handheld Vacuum HEPAPremium HEPA filters (Allergen, Formaldehyde, Wildfire)
Noise Level20% quieter than most handheld vacuumsNot specifiedN/A21 dBA (whisper-quiet)
Accessories IncludedFull accessory kit (4 tools: Extension Hose, Brush Tool, Flat Nozzle, Crevice Tool)Multiple attachments including crevice and brush toolsN/AN/A
Special FeaturesLightweight, compact, turbo/eco modesTwo motors, LED display, 3 suction speeds, LED lights on brush headN/ASmart controls, AQ alerts, laser particle detection
CompatibilityN/AN/AOnly for Wyze Handheld VacuumCompatible with Google Home, Alexa
Return Policy30-day hassle-free returns30-day hassle-free returnsN/AN/A
What makes the Wyze Handheld Vacuum suitable for allergy sufferers?The Wyze Handheld Vacuum features a True HEPA allergen filtration system that traps 99.97% of particles as small as 0.3 microns, including dust, pet dander, and other allergens. This ensures cleaner air and reduces allergy triggers while you clean.
How powerful is the Wyze Handheld Vacuum's suction?The Wyze Handheld Vacuum delivers 9,000 PA of suction in default mode and up to 16,800 PA in max power mode, offering double the suction of many other handheld vacuums for effective spot cleaning.
Is the Wyze Handheld Vacuum easy to carry and use?Yes, the Wyze Handheld Vacuum is lightweight at only 1.23 lbs (19.8 oz) and under 3 inches thick, making it highly portable and easy to maneuver for cleaning your home, car, or other spaces.
How quiet is the Wyze Handheld Vacuum during operation?The Wyze Handheld Vacuum operates at 73.8 dB(A), which is 20% quieter than most handheld vacuums, making it ideal for use around pets and sensitive individuals.
What is the battery life and charging time for the Wyze Handheld Vacuum?The Wyze Handheld Vacuum offers up to 30 minutes of cleaning in default mode and 10 minutes in max power mode. It recharges quickly in just 3 hours using a Type-C charger.
What accessories are included with the Wyze Handheld Vacuum?The Wyze Handheld Vacuum comes with a full accessory kit, including a crevice tool, brush tool, extension hose, flat nozzle, and a storage bag for versatile cleaning tasks.
How do I maintain the Wyze Handheld Vacuum's HEPA filtration performance?To maintain peak HEPA filtration and suction power, regularly replace the Wyze Handheld Vacuum Filter. Replacement filters are easy to install and available in 1-pack or 3-pack options.
What are the benefits of the Wyze Cordless Vacuum S for allergy control?The Wyze Cordless Vacuum S offers 20,000 Pa suction power in Turbo Mode, a 3-stage filtration system with HEPA filter, lightweight design, up to 40 minutes of runtime, and multiple attachments, making it ideal for deep cleaning and whole-home allergen control.
How does the Wyze Air Purifier help with allergies?The Wyze Air Purifier uses a True HEPA 13 filter to capture 99% of airborne allergens, viruses, and bacteria. It also features an activated carbon layer to reduce odors and harmful gases, high CADR for large rooms, and smart controls for continuous air quality management.
Can I customize the Wyze Air Purifier for specific air quality needs?Yes, the Wyze Air Purifier offers customizable filter options, including Allergen, Formaldehyde, and Wildfire filters, allowing you to tailor air purification to your specific needs.
How do Wyze products work together for comprehensive allergy management?Wyze products like the Handheld Vacuum, Cordless Vacuum S, and Air Purifier combine powerful HEPA filtration for both surfaces and air, providing a complete solution for reducing allergens and improving indoor air quality in your home.
What are the benefits of using a True HEPA filter in the Wyze Handheld Vacuum?How often should I replace the filter for the Wyze Handheld Vacuum?Do you have any ongoing sales or discounts for the Wyze Handheld Vacuum?
