Discover the Wyze Cordless Vacuum S: Powerful Cleaning with Extra Filter Included
If you're searching for a
cordless vacuum with an extra filter included in the box, the
Wyze Cordless Vacuum S stands out as an exceptional choice. Designed for effortless, deep cleaning, this vacuum combines industrial-level suction power with smart features and convenience, making it perfect for busy homes, especially those with pets.
Wyze Cordless Vacuum S: Unmatched Cleaning Power and Lightweight Design
Industrial-Grade Suction with Dual Motors
The Wyze Cordless Vacuum S boasts an impressive
20,000 Pa suction power, powered by not one but
two high-efficiency motors—one in the main body and another in the brush head. This dual-motor system ensures thorough cleaning on all surfaces, from hardwood floors to carpets, capturing even the finest dust and pet hair.
Ultra-Lightweight and Ergonomic
Weighing just
2.8 pounds, this vacuum is as light as a fluffy corgi puppy, making it easy to maneuver around furniture and up stairs without fatigue. Its ergonomic design ensures comfortable handling during extended cleaning sessions.
Versatile Cleaning Speeds with LED Display
Choose from
three suction modes to match your cleaning needs:
- Eco Mode: 6,000 Pa for light dust and delicate surfaces
- Medium Mode: 9,000 Pa for everyday cleaning
- Turbo Mode: 20,000 Pa for deep cleaning and stubborn debris
A crystal-clear LED display lets you monitor the current speed and battery life at a glance.
Long-Lasting, Interchangeable Battery
The vacuum includes a
40-minute fade-free lithium-ion battery, allowing you to finish your cleaning without interruptions. Plus, an
extra battery pack is available to extend your runtime even further, ensuring you never run out of power mid-task.
Lightweight and pet-friendly cleaning with Wyze Cordless Vacuum S
Advanced Filtration System: Extra Filter Included for Cleaner Air
3-Stage Filtration for Maximum Dust Capture
The Wyze Cordless Vacuum S features a
3-stage filtration system that traps 95% of particles as small as 0.3 microns:
1.
Vacuum cyclone separates large and small debris
2.
Metal screen filters out hair and dirt clumps
3.
High-efficiency HEPA filter captures fine dust and allergens
Easy Maintenance with Washable Filters
The vacuum comes with an
extra HEPA filter included in the box, so you can swap filters regularly to maintain peak performance. Both the dust cup and filters are washable and reusable, making upkeep simple and cost-effective.
Built-In Filter Brush
A built-in rotating filter brush helps knock dust off the filter into the dust cup, keeping the filter clean and efficient without extra effort.
What’s in the Box?
- Wyze Cordless Vacuum S with dual motors
- 40-minute interchangeable lithium-ion battery
- Extra HEPA filter for replacement
- Charger and cleaning accessories
For those who want even more cleaning time, the
Wyze Cordless Vacuum S - Battery Pack is available separately, designed specifically to fit and extend your vacuum’s runtime.
Effortless cleaning on hardwood floors with Wyze Cordless Vacuum S
Why Choose Wyze Cordless Vacuum S?
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
This vacuum is engineered to deliver
powerful, cordless freedom with smart features that make cleaning easier and more effective. Whether you have pets, kids, or just want a reliable vacuum that can handle every surface, the Wyze Cordless Vacuum S is your go-to solution.
Additional Accessories for Your Wyze Vacuum
- Wyze Cordless Vacuum S - Battery Pack: Extend your cleaning sessions with an extra battery designed specifically for the vacuum.
- Wyze Cordless Vacuum S - Charger: Replacement charger to keep your vacuum powered up and ready.
Summary of Key Features
Feature | Specification |
Suction Power | Up to 20,000 Pa |
Motors | Dual motors (main + brush head) |
Weight | 2.8 pounds |
Battery Life | 40 minutes fade-free, interchangeable |
Filtration | 3-stage HEPA filtration system |
Extra Filter Included | Yes |
Cleaning Speeds | Eco, Medium, Turbo |
LED Display | Yes |
Washable Dust Cup & Filters | Yes |
Invest in the
Wyze Cordless Vacuum S today for a powerful, lightweight, and hygienic cleaning experience with the convenience of an extra filter included right out of the box.
What makes the Wyze Cordless Vacuum S a powerful cordless vacuum?
The Wyze Cordless Vacuum S features industrial-grade suction power of up to 20,000 Pa, thanks to its dual high-efficiency motors—one in the main body and another in the brush head. This ensures deep and thorough cleaning on all surfaces, including hardwood floors and carpets.Does the Wyze Cordless Vacuum S come with an extra filter?
Yes, the Wyze Cordless Vacuum S includes an extra HEPA filter in the box. This allows you to swap filters regularly for optimal performance and cleaner air.What type of filtration system does the Wyze Cordless Vacuum S use?
The vacuum uses a 3-stage filtration system: a vacuum cyclone for separating debris, a metal screen for filtering hair and dirt clumps, and a high-efficiency HEPA filter that captures 95% of particles as small as 0.3 microns.Are the filters and dust cup on the Wyze Cordless Vacuum S washable?
Yes, both the dust cup and filters are washable and reusable, making maintenance easy and cost-effective.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a 40-minute fade-free lithium-ion battery, allowing for extended cleaning sessions without interruption.Is the battery on the Wyze Cordless Vacuum S interchangeable?
Yes, the vacuum features an interchangeable battery. You can purchase an extra battery pack separately to extend your cleaning time even further.How much does the Wyze Cordless Vacuum S weigh?
The vacuum is ultra-lightweight, weighing just 2.8 pounds, making it easy to maneuver around your home and up stairs.What cleaning modes are available on the Wyze Cordless Vacuum S?
There are three suction modes: Eco Mode (6,000 Pa) for light cleaning, Medium Mode (9,000 Pa) for everyday cleaning, and Turbo Mode (20,000 Pa) for deep cleaning and stubborn debris.Does the Wyze Cordless Vacuum S have an LED display?
Yes, it features a crystal-clear LED display that shows the current suction mode and battery life at a glance.Is the Wyze Cordless Vacuum S suitable for homes with pets?
Absolutely. Its powerful suction and advanced filtration system make it ideal for picking up pet hair and dander, ensuring a cleaner home environment.What accessories are included with the Wyze Cordless Vacuum S?
The box includes the Wyze Cordless Vacuum S with dual motors, a 40-minute interchangeable lithium-ion battery, an extra HEPA filter, a charger, and cleaning accessories.Are additional accessories available for the Wyze Cordless Vacuum S?
Yes, you can purchase a Wyze Cordless Vacuum S Battery Pack for extended runtime and a replacement charger to keep your vacuum powered up.How does the built-in filter brush work on the Wyze Cordless Vacuum S?
The built-in rotating filter brush helps knock dust off the filter into the dust cup, keeping the filter clean and maintaining efficient performance without extra effort.
