Pet-Friendly Security with Wyze Battery Cam Pro
When it comes to keeping your home safe while ensuring your pets roam freely, the
Wyze Battery Cam Pro stands out as a top choice. This smart camera is designed to alert you instantly when your dog enters off-limits areas, making it perfect for pet owners who want to maintain boundaries without constant supervision.
Advanced Motion Detection with Radar + PIR Sensors
The Wyze Battery Cam Pro features a sophisticated combination of radar and PIR (Passive Infrared) motion detection. This dual-sensor system accurately detects movement, including your furry friends, and sends real-time alerts to your phone. This means you can be notified immediately if your dog wanders into restricted zones, helping you intervene quickly.
Crisp 2.5K HDR Video Quality
Capture every detail with stunning 2560 x 1440 (2.5K) HDR video resolution. Whether it’s day or night, the camera’s CMOS-Starlight sensor combined with 2 IR LEDs and 2 white LEDs ensures clear, color night vision. This allows you to monitor your pet’s activity with sharp, vibrant footage, even in low-light conditions.
Wire-Free and Weatherproof Design
The Wyze Battery Cam Pro is completely wire-free, powered by removable and rechargeable 6200mAh battery packs that last up to 6 months on a single charge. Its IP65 weatherproof rating means it can withstand rain, snow, and dust, making it ideal for both indoor and outdoor use around your home or yard.
Smart Features and Integrations
- Two-way audio lets you communicate with your pet remotely.
- A built-in 100 dB siren can deter unwanted visitors or alert your pet.
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
- Supports both 2.4 GHz and 5 GHz WiFi for reliable connectivity.
Dimensions and Mounting
Compact and lightweight (0.94 lbs), the camera measures 2.5 x 1.8 x 3.5 inches and comes with a standard 1/4” - 20 mount and wall mount included for flexible installation anywhere around your home.
Extend Your Camera’s Runtime with Wyze Battery Cam Solar Panel
For pet owners who want continuous monitoring without worrying about battery life, the
Wyze Battery Cam Solar Panel is the perfect accessory. This solar panel attaches easily to your Wyze Battery Cam Pro, providing a sustainable power source that keeps your camera running longer.
Key Features of the Solar Panel
- IP65 weather resistance ensures durability in all weather conditions.
- Easy 360° mount allows flexible placement to capture optimal sunlight.
- Comes with a 13-foot power cable for convenient installation.
- Compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2.
By harnessing solar power, you reduce the need for frequent battery changes, ensuring your pet-friendly camera stays active and alert at all times.
Why Choose Wyze Battery Cam Pro for Pet Monitoring?
"Keep your pets safe and your home secure with smart, pet-friendly technology."
The Wyze Battery Cam Pro is more than just a security camera—it’s a smart companion that helps you maintain boundaries for your pets while giving you peace of mind. Its advanced motion detection, high-resolution video, and weatherproof design make it ideal for monitoring dogs in off-limits areas, whether indoors or outdoors.
Additional Benefits
- Supports local storage up to 256 GB microSD cards for extensive video recording.
- Rechargeable battery packs are easy to swap and charge.
- Compatible with both Android (9.0+) and iOS (15.0+) devices for easy app control.
Summary
Product | Highlights |
Wyze Battery Cam Pro | 2.5K HDR, Radar + PIR, Wire-free, IP65 |
Wyze Battery Cam Solar Panel | Solar-powered, Weatherproof, 13-ft cable |
With the Wyze Battery Cam Pro and its solar panel accessory, you get a reliable, pet-friendly camera system that alerts you when your dog enters restricted areas, ensuring your pets stay safe and your home secure.
What makes the Wyze Battery Cam Pro pet-friendly?
The Wyze Battery Cam Pro is designed with advanced motion detection that can alert you instantly when your dog enters off-limits areas. Its real-time notifications help pet owners maintain boundaries without constant supervision, making it ideal for pet monitoring.How does the Wyze Battery Cam Pro detect pet movement?
The Wyze Battery Cam Pro uses a combination of radar and PIR (Passive Infrared) sensors to accurately detect movement, including your pets. This dual-sensor system ensures you receive immediate alerts if your dog or other pets enter restricted zones.What video quality does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro provides crisp 2.5K HDR video resolution (2560 x 1440), ensuring you capture every detail of your pet’s activity. Its CMOS-Starlight sensor and night vision capabilities deliver clear, color footage even in low-light conditions.Is the Wyze Battery Cam Pro suitable for outdoor use?
Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it resistant to rain, snow, and dust. Its wire-free design and durable build make it perfect for both indoor and outdoor pet monitoring.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro is powered by removable and rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental conditions.Can I extend the battery life of my Wyze Battery Cam Pro?
Yes, you can extend the camera’s runtime by using the Wyze Battery Cam Solar Panel. This accessory provides a sustainable power source, reducing the need for frequent battery changes and ensuring continuous monitoring.What are the features of the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is IP65 weather-resistant, comes with a 13-foot power cable for flexible installation, and features a 360° mount for optimal sunlight capture. It is compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2.Does the Wyze Battery Cam Pro support two-way audio?
Yes, the Wyze Battery Cam Pro includes two-way audio, allowing you to communicate with your pet remotely through the camera.Is the Wyze Battery Cam Pro compatible with smart home systems?
The Wyze Battery Cam Pro works with Alexa, Google Assistant, and IFTTT, making it easy to integrate into your existing smart home setup.What WiFi networks does the Wyze Battery Cam Pro support?
The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi networks, ensuring reliable and flexible connectivity.Can I store video footage locally on the Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB, allowing for extensive video recording and playback.What devices are compatible with the Wyze app for camera control?
The Wyze app is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher, making it easy to control your camera from your smartphone.What are the dimensions and mounting options for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro measures 2.5 x 1.8 x 3.5 inches and weighs 0.94 lbs. It comes with a standard 1/4” - 20 mount and a wall mount for flexible installation anywhere around your home.
