Night Vision Smart Cameras for Pet Monitoring: Wyze Cam Pan v3 Series
Keeping an eye on your pets while you're away is easier and more reliable than ever with the Wyze Cam Pan v3 lineup. Designed for both indoor and outdoor use, these smart cameras offer advanced night vision, 360° coverage, and two-way audio, making them perfect for pet owners who want peace of mind anytime, day or night.
Wyze Cam Pan v3: Ultimate 360° Pet Surveillance
Key Features and Specifications
- 360° Horizontal & 180° Vertical Coverage: The Wyze Cam Pan v3 offers a full panoramic view with smooth pan and tilt capabilities, ensuring no corner is left unseen.
- 1080p Full HD Video: Crisp and clear video quality lets you monitor your pets in detail.
- Night Vision with 4 IR LEDs: Equipped with 850 nm infrared LEDs, the camera provides reliable black-and-white night vision, perfect for low-light or nighttime pet monitoring.
- Color Night Vision: Unlike many cameras, the Pan v3 supports color night vision, enhancing visibility and detail in dim environments.
- Two-Way Audio with Noise & Echo Cancellation: Communicate with your pets or family members through the built-in speaker and microphone.
- Weather Resistant (IP65 Rated): Suitable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately), making it versatile for monitoring pets inside or outside.
- Smart Alerts & Integration: Receive push notifications for motion detection and integrate seamlessly with Alexa, Google Assistant, and IFTTT.
- Storage Options: Supports up to 256 GB microSD cards for local storage and offers cloud storage options.
- Connectivity: Works on 2.4 GHz Wi-Fi networks with compatibility for Android 9.0+ and iOS 15.0+ devices.
Physical and Technical Details
- Dimensions: 124mm (H) x 60mm (W) x 63mm (D)
- Weight: 11.29 oz (320 g)
- CPU: 1.5 GHz processor for smooth operation
- Video Encoding: H.264 with 20 fps daytime and 15 fps nighttime video
- Digital Zoom: 8x zoom for close-up views
- Rotation Speed: Up to 110° per second for quick tracking
The Wyze Cam Pan v3 is a robust, weatherproof camera that adapts to your pet monitoring needs, whether indoors or outdoors.
Wyze Cam Pan v3 weather resistant outdoor camera
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Monitoring Experience
What’s Included?
- Wyze Cam Pan v3 (available in Black or White)
- 6' Micro USB Cable
- Power Adapter
- Mounting Kit
- Quick Start Guide
- 30-Day Cam Plus Subscription for advanced cloud storage and features
Additional Benefits
- Color Night Vision: Enhanced night vision with color imaging for better pet visibility at night.
- Push Notifications: Instant alerts on your phone when motion or sound is detected.
- Two-Way Audio: Talk to your pets to soothe or interact with them remotely.
- Easy Setup: Compatible with Android 9.0+ and iOS 15.0+ devices.
- IP65 Weather Resistance: Use indoors or outdoors with the appropriate power adapter.
This bundle is ideal for pet owners who want a comprehensive monitoring solution with extended cloud storage and premium features.
Two-Way Audio for Real-Time Pet Interaction
One of the standout features of the Wyze Cam Pan v3 series is the built-in two-way audio system. This allows you to hear your pets and talk back to them, providing comfort and interaction even when you’re not home.
Communicate with your pets anytime, anywhere
Why Choose Wyze Cam Pan v3 for Pet Monitoring?
- Comprehensive Coverage: Pan and tilt functionality ensures you can track your pet’s movement across the room or yard.
- Reliable Night Vision: Keep an eye on your pets even in complete darkness with IR LEDs and color night vision.
- Weatherproof Design: Use it outdoors without worry, perfect for monitoring pets in the yard or garage.
- Smart Home Integration: Works with Alexa and Google Assistant for voice control and automation.
- Affordable and Versatile: Offers premium features at a competitive price point, with options for bundles and accessories.
Accessories to Enhance Your Wyze Cam Pan v3 Experience
- Wyze Cam Pan v3 Skins by dBrand: Customize and protect your camera with stylish vinyl skins available in Green Camo or Triple Black.
- Wyze Cam Pan v3 USB Cable: Replacement or extra USB cable to ensure your camera stays powered.
- Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera through a lamp socket without needing an outlet, ideal for flexible placement.
Conclusion
For pet owners seeking a reliable, feature-rich night vision smart camera, the Wyze Cam Pan v3 and its bundle options provide an excellent solution. With 360° coverage, color night vision, two-way audio, and weather resistance, these cameras ensure you never miss a moment with your furry friends, whether you’re at work, traveling, or simply away from home.
What makes the Wyze Cam Pan v3 ideal for pet monitoring?
The Wyze Cam Pan v3 is designed for pet owners, offering 360° horizontal and 180° vertical coverage, advanced night vision (including color night vision), two-way audio for real-time interaction, and weather resistance for both indoor and outdoor use. These features ensure you can monitor and communicate with your pets anytime, day or night.Does the Wyze Cam Pan v3 have night vision for monitoring pets in the dark?
Yes, the Wyze Cam Pan v3 features advanced night vision with 4 infrared LEDs (850 nm) for clear black-and-white footage in low-light conditions, as well as color night vision for enhanced visibility and detail at night.Can I use the Wyze Cam Pan v3 outdoors to monitor my pets?
Absolutely. The Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). This allows you to monitor pets in your yard, garage, or other outdoor spaces.How does the two-way audio feature work on the Wyze Cam Pan v3?
The Wyze Cam Pan v3 includes built-in two-way audio with noise and echo cancellation. This allows you to listen to your pets and speak to them through the camera using the Wyze app, providing comfort and interaction even when you’re away from home.What storage options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports local storage with microSD cards up to 256 GB and offers cloud storage options. The Cam Plus bundle includes a 30-day subscription for advanced cloud storage and features.Is the Wyze Cam Pan v3 compatible with smart home systems?
Yes, the Wyze Cam Pan v3 integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What devices are compatible with the Wyze Cam Pan v3 app?
The Wyze Cam Pan v3 works with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The bundle includes a Wyze Cam Pan v3 (available in Black or White), a 6' Micro USB cable, power adapter, mounting kit, quick start guide, and a 30-day Cam Plus subscription for enhanced cloud storage and features.Are there accessories available for the Wyze Cam Pan v3?
Yes, accessories include Wyze Cam Pan v3 Skins by dBrand for customization and protection, replacement USB cables, and the Pan v3 + Lamp Socket v2 Bundle for flexible power options.How easy is it to set up the Wyze Cam Pan v3 for pet monitoring?
The Wyze Cam Pan v3 is designed for easy setup and is compatible with both Android and iOS devices. The included quick start guide and user-friendly app make installation and configuration straightforward.
