Wyze Robot Vacuum Replacement Parts with Extra Brushes and Filters
If you own a Wyze Robot Vacuum, keeping it in top shape is essential for maintaining a spotless home. Over time, parts like brushes and filters wear out and need replacement to ensure optimal cleaning performance. This guide highlights the best Wyze replacement parts kits and individual components, including extra brushes and HEPA filters, designed specifically for your Wyze Robot Vacuum.
Complete Replacement Parts Kit for Wyze Robot Vacuum
Wyze Robot Vacuum - Replacement Parts Kit
The ultimate maintenance solution for your Wyze Robot Vacuum is the
Replacement Parts Kit. This comprehensive kit includes everything you need to refresh your vacuum’s cleaning power:
- 4 Edge Brushes: These help sweep debris from corners and edges into the vacuum’s path.
- 2 Main Brushes: The primary brushes that pick up dirt and dust from floors.
- 4 HEPA Filters: High-efficiency particulate air filters that trap fine dust and allergens, improving air quality as you clean.
Priced affordably, this kit ensures your vacuum runs like new, extending its lifespan and maintaining peak cleaning efficiency.
Keep your Wyze Robot Vacuum performing at its best with this all-in-one kit designed for easy replacement and hassle-free maintenance.
Maintain a clean home effortlessly with Wyze Robot Vacuum replacement parts.
Individual Replacement Parts for Targeted Maintenance
If you only need specific parts, Wyze offers individual replacements to suit your needs:
Wyze Robot Vacuum - HEPA Filter
- Price: $4.99
- Designed to capture fine dust and allergens.
- Compatible exclusively with Wyze Robot Vacuum.
- Easy to replace for maintaining air quality and suction power.
Wyze Robot Vacuum - Edge Brush
- Price: $4.99
- Replacement edge brush to sweep dirt from corners.
- Essential for thorough cleaning along walls and edges.
Wyze Robot Vacuum - Power Adapter
- Price: $4.99
- Replacement power adapter to keep your vacuum charged and ready.
- Compatible with Wyze Robot Vacuum.
Wyze Robot Vacuum - Charging Station
- Price: $19.99
- Replacement charging dock to ensure your vacuum always has a home base.
- Compatible with Wyze Robot Vacuum for seamless recharging.
These individual parts allow you to replace only what you need, saving money and keeping your vacuum running smoothly.
Why Choose Wyze Replacement Parts?
- Perfect Compatibility: All parts are designed specifically for Wyze Robot Vacuum models, ensuring easy installation and reliable performance.
- Affordable Pricing: Replacement parts and kits are budget-friendly, making maintenance simple and cost-effective.
- Hassle-Free Returns: Enjoy 30-day hassle-free returns on all replacement parts.
- Extend Vacuum Life: Regularly replacing brushes and filters keeps your vacuum efficient and prolongs its lifespan.
Enhance Your Smart Home Cleaning Experience
Maintaining your Wyze Robot Vacuum with genuine replacement parts ensures consistent cleaning results and a healthier home environment. Whether you opt for the full replacement kit or individual parts like extra brushes and HEPA filters, Wyze makes it easy to keep your smart vacuum in top condition.
"A well-maintained vacuum is a happy vacuum — and a cleaner home is a happier home."
Related Smart Home Accessories
While focusing on vacuum replacement parts, consider complementing your smart home ecosystem with devices like the
Wyze Switch. This smart light switch integrates seamlessly with your Wyze Robot Vacuum and other Wyze devices, allowing you to control your home environment effortlessly.
Control your smart home devices, including your Wyze Robot Vacuum, with the Wyze Switch.
Summary of Wyze Robot Vacuum Replacement Parts
Product Name | Included Items / Features | Price | Stock Status |
Wyze Robot Vacuum - Replacement Parts Kit | 4 Edge Brushes, 2 Main Brushes, 4 HEPA Filters | $22.99 | Available |
Wyze Robot Vacuum - HEPA Filter | Single HEPA Filter | $4.99 | Available |
Wyze Robot Vacuum - Edge Brush | Single Edge Brush | $4.99 | Available |
Wyze Robot Vacuum - Power Adapter | Replacement Power Adapter | $4.99 | Available |
Wyze Robot Vacuum - Charging Station | Replacement Charging Dock | $19.99 | Available |
Keep your Wyze Robot Vacuum running at peak performance with genuine replacement parts, including extra brushes and filters. Regular maintenance ensures your smart vacuum continues to deliver a spotless, allergen-free home with minimal effort.
What replacement parts are available for the Wyze Robot Vacuum?
Wyze offers a variety of replacement parts for the Wyze Robot Vacuum, including a complete Replacement Parts Kit (with 4 edge brushes, 2 main brushes, and 4 HEPA filters), individual HEPA filters, edge brushes, power adapters, and charging stations. All parts are designed specifically for Wyze Robot Vacuum models.What is included in the Wyze Robot Vacuum Replacement Parts Kit?
The Wyze Robot Vacuum Replacement Parts Kit includes 4 edge brushes, 2 main brushes, and 4 HEPA filters. This comprehensive kit provides everything you need to maintain your vacuum’s cleaning performance and extend its lifespan.How often should I replace the brushes and filters on my Wyze Robot Vacuum?
It is recommended to regularly replace the brushes and HEPA filters on your Wyze Robot Vacuum to maintain optimal cleaning performance and air quality. The frequency depends on usage, but checking and replacing these parts every few months is a good practice.Are Wyze Robot Vacuum replacement parts compatible with all Wyze models?
Yes, all Wyze Robot Vacuum replacement parts are designed for perfect compatibility with Wyze Robot Vacuum models, ensuring easy installation and reliable performance.How much does the Wyze Robot Vacuum Replacement Parts Kit cost?
The Wyze Robot Vacuum Replacement Parts Kit is priced at $22.99 and includes 4 edge brushes, 2 main brushes, and 4 HEPA filters.Can I buy individual Wyze Robot Vacuum replacement parts?
Yes, you can purchase individual replacement parts for your Wyze Robot Vacuum, such as HEPA filters ($4.99), edge brushes ($4.99), power adapters ($4.99), and charging stations ($19.99).Why should I use genuine Wyze replacement parts for my robot vacuum?
Genuine Wyze replacement parts are specifically designed for Wyze Robot Vacuums, ensuring perfect fit, easy installation, and optimal performance. Using authentic parts helps maintain your vacuum’s efficiency and prolongs its lifespan.What are the benefits of replacing the HEPA filter in my Wyze Robot Vacuum?
Replacing the HEPA filter in your Wyze Robot Vacuum helps trap fine dust and allergens, improving air quality in your home and maintaining strong suction power for effective cleaning.Is there a return policy for Wyze Robot Vacuum replacement parts?
Yes, Wyze offers a 30-day hassle-free return policy on all replacement parts, allowing you to shop with confidence.How do I maintain my Wyze Robot Vacuum for optimal performance?
To keep your Wyze Robot Vacuum running at peak performance, regularly replace worn brushes and filters with genuine Wyze parts, clean the vacuum as recommended, and ensure the charging station and power adapter are functioning properly.Where can I buy Wyze Robot Vacuum replacement parts?
You can purchase Wyze Robot Vacuum replacement parts directly from the Wyze website, where you’ll find both complete kits and individual components available and in stock.
