Best Motion Sensor with 120° Field of View for Home Security
Looking to enhance your home security with a reliable motion sensor that covers a wide area? Discover the Wyze Sense Motion Sensor, designed specifically for home monitoring with a generous 120° field of view. This guide will walk you through its standout features, installation options, and why it’s the perfect fit for your smart home security needs.
Why Choose a 120° Motion Sensor for Home Security?
A motion sensor with a 120-degree field of view ensures broad coverage, minimizing blind spots and maximizing the area monitored. This is ideal for entryways, hallways, living rooms, and other high-traffic areas in your home.
"A wide field of view means fewer sensors are needed to cover your space, making installation simpler and more cost-effective."
Wyze Sense Motion Sensor: Wide Coverage, Smart Security
*Wyze Sense Motion Sensor offers discreet, effective security for any room.*
Key Features
- 120° Field of View: Detects motion across a wide area, perfect for monitoring large rooms or entryways.
- 25 ft Detection Range: Senses movement up to 25 feet away, ensuring early alerts for any activity.
- Adjustable Sensitivity: Customize detection levels to suit your environment and reduce false alarms.
- Long Battery Life: Up to 18 months of operation on a single battery, minimizing maintenance.
- Flexible Installation: Mount easily with adhesive backing or screws for added security.
- Smart Home Integration: Compatible with Wyze Sense v2 and Wyze Home Monitoring systems.
- Supports Up to 100 Sensors per Hub: Scale your security system as your needs grow.
Effortless Installation & Seamless Integration
*Easy to install in any room for instant peace of mind.*
- Adhesive Backing: Stick the sensor to walls, doors, or ceilings in seconds—no tools required.
- Screw Mount Option: For high-traffic or vibration-prone areas, use screws for extra stability.
- Indoor Use: Designed for reliable performance in any indoor environment.
Smart Security for Every Home
*Discreet design blends into your home while providing powerful protection.*
- Expandable System: Add up to 100 sensors to a single Wyze Sense Hub for comprehensive coverage.
- Real-Time Alerts: Receive instant notifications on your phone when motion is detected.
- Perfect for Families, Apartments, and Small Businesses: Protect what matters most with a sensor that adapts to your lifestyle.
Technical Specifications at a Glance
Feature | Details |
Field of View | 120° |
Detection Range | 25 ft |
Sensitivity | Adjustable |
Battery Life | Up to 18 months |
Installation | Adhesive or screws |
Indoor Use | Yes |
Compatibility | Wyze Sense v2, Home Monitoring |
Max Sensors per Hub | 100 |
Conclusion
The Wyze Sense Motion Sensor is the ideal choice for anyone seeking a motion sensor with a 120-degree field of view for home security. With its wide coverage, easy installation, and smart integration, you can enjoy peace of mind knowing your home is protected—day and night.
"Upgrade your home security with a motion sensor that’s smart, reliable, and built for real life."
Ready to secure your home with wide-angle motion detection? The Wyze Sense Motion Sensor is your go-to solution for modern, effective home security.
What is the field of view of the Wyze Sense Motion Sensor?
The Wyze Sense Motion Sensor features a wide 120° field of view, allowing it to monitor large areas and minimize blind spots in your home.How far can the Wyze Sense Motion Sensor detect motion?
The Wyze Sense Motion Sensor has a detection range of up to 25 feet, ensuring early alerts for any movement within its coverage area.Is the Wyze Sense Motion Sensor easy to install?
Yes, the Wyze Sense Motion Sensor offers effortless installation with adhesive backing for tool-free setup or screws for added stability in high-traffic areas.Can I adjust the sensitivity of the Wyze Sense Motion Sensor?
Yes, the Wyze Sense Motion Sensor features adjustable sensitivity settings, allowing you to customize detection levels and reduce false alarms.How long does the battery last in the Wyze Sense Motion Sensor?
The Wyze Sense Motion Sensor provides up to 18 months of battery life on a single battery, minimizing maintenance and ensuring reliable operation.Is the Wyze Sense Motion Sensor compatible with smart home systems?
The Wyze Sense Motion Sensor is compatible with Wyze Sense v2 and Wyze Home Monitoring systems, making it easy to integrate into your smart home setup.How many Wyze Sense Motion Sensors can I connect to one hub?
You can connect up to 100 Wyze Sense Motion Sensors to a single Wyze Sense Hub, allowing for scalable and comprehensive home security coverage.Where can I install the Wyze Sense Motion Sensor?
The Wyze Sense Motion Sensor is designed for indoor use and can be installed in entryways, hallways, living rooms, or any area where you need reliable motion detection.Will I receive alerts when motion is detected?
Yes, the Wyze Sense Motion Sensor sends real-time notifications to your phone whenever motion is detected, keeping you informed and secure.Is the Wyze Sense Motion Sensor suitable for apartments and small businesses?
Absolutely. The Wyze Sense Motion Sensor is perfect for families, apartments, and small businesses, offering flexible installation and scalable security solutions.
