Low Voltage Smart Thermostat with C Wire Adapter Included
Looking for an efficient, easy-to-install low voltage smart thermostat that includes a C wire adapter? The Wyze Thermostat lineup offers a perfect blend of smart home convenience, energy savings, and user-friendly features designed to simplify your heating and cooling control. Whether you want a brand-new unit or a budget-friendly refurbished option, Wyze has you covered.
Wyze Thermostat: Smart Heating & Cooling Simplified
Key Features and Benefits
  • Smart Control Anywhere: Adjust your home's temperature from anywhere in the world using the Wyze app. Whether you're at work or on vacation, you can ensure your home is always comfortable.
  • Voice Assistant Compatibility: Works seamlessly with Alexa and Google Assistant, allowing hands-free temperature adjustments.
  • Comfort in Every Room: Pair with Wyze Room Sensors to eliminate hot and cold spots by monitoring multiple rooms and balancing your home's climate intelligently.
  • Motion-Sensing Comfort Mode: The thermostat prioritizes rooms with detected motion, saving energy by not heating or cooling unused spaces.
  • Always-On Display & Wireless Setup: Easy to read and install with a wireless setup process guided step-by-step through the Wyze app.
  • Simple Scheduling: Create daily schedules for weekdays and weekends to automate your home's temperature changes, saving energy and money.
  • Energy-Saving Tips: Receive personalized recommendations based on your usage history to optimize energy consumption.
  • DIY Installation: Designed for a quick 20-minute installation, even for those new to smart thermostats.
Technical Specs
  • Compatible with low voltage HVAC systems.
  • Supports up to 6 Wyze Room Sensors.
  • Magnetic table stand and wall mount included.
  • Intuitive dial control for easy manual adjustments.
"Arrive home to the perfect temperature every day, save energy, and keep your pets comfortable with Wyze Thermostat."
(Refurbished) Wyze Thermostat: Affordable Smart Control
If you're looking for the same smart thermostat experience at a lower price, the refurbished Wyze Thermostat offers all the features of the new model at a fraction of the cost. Fully tested and guaranteed to work like new, this option is perfect for budget-conscious buyers who want smart home convenience without compromise.
Highlights
  • Same smart heating and cooling features as the new Wyze Thermostat.
  • Voice assistant compatibility and app control.
  • Motion-sensing comfort and room sensor support.
  • Simple scheduling and energy-saving insights.
  • 20-minute DIY installation with app guidance.
"Get smart thermostat technology at a great price with the refurbished Wyze Thermostat."
Why Choose Wyze Thermostat with C Wire Adapter?
Many modern HVAC systems require a C wire (common wire) for continuous power to smart thermostats. Wyze Thermostat supports low voltage systems and includes the necessary wiring adapters to ensure compatibility and easy installation without additional parts.
  • No extra purchases needed: The included C wire adapter simplifies installation.
  • Energy-efficient operation: Continuous power ensures reliable Wi-Fi connectivity and smart features.
  • User-friendly setup: The Wyze app walks you through the wiring and installation process step-by-step.
Enhance Your Smart Home Experience
While the Wyze Thermostat is the centerpiece for smart climate control, consider complementing your setup with other Wyze smart home products for a fully integrated experience.
Lifestyle Image: Smart Home Comfort
Cozy living room with smart thermostat control Alt text: Cozy modern living room with smart home devices and thermostat control
Summary
The Wyze Thermostat and its refurbished counterpart provide an excellent solution for anyone seeking a low voltage smart thermostat with a C wire adapter included. With easy installation, smart scheduling, voice control, and energy-saving features, these thermostats bring comfort and convenience to your fingertips.
FeatureWyze Thermostat (Refurbished)Wyze Thermostat
Price$29.98 USD$79.98 USD
ConditionRefurbished, like new, fully testedNew
Return PolicyFinal sale, no returns30-day hassle-free returns
Smart Heating & CoolingYesYes
Remote Control via AppYesYes
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google Assistant
Wyze Room Sensor SupportYesYes
Motion-Sensing Comfort ModeYesYes
Always-on DisplayYesYes
Wireless SetupYesYes
Max Wyze Room Sensors SupportedUp to 6Up to 6
SchedulingSimple daily schedulingSimple daily scheduling
Energy Saving TipsYesYes
Installation20-minute DIY with app guidance20-minute DIY with app guidance
AvailabilitySold outSold out
What is included with the Wyze Low Voltage Smart Thermostat?The Wyze Low Voltage Smart Thermostat comes with a C wire adapter, a magnetic table stand, a wall mount, and step-by-step installation guidance through the Wyze app. This ensures compatibility with most low voltage HVAC systems and makes installation easy and convenient.
Is the Wyze Thermostat compatible with Alexa and Google Assistant?Yes, the Wyze Thermostat works seamlessly with both Alexa and Google Assistant, allowing you to control your home's temperature using simple voice commands for hands-free convenience.
Can I control the Wyze Thermostat remotely?Absolutely! You can adjust your home's temperature from anywhere in the world using the Wyze app. This remote access ensures your home is always comfortable, whether you're at work, on vacation, or just relaxing on the couch.
Does the Wyze Thermostat support room sensors?Yes, the Wyze Thermostat supports up to 6 Wyze Room Sensors. These sensors help eliminate hot and cold spots by monitoring multiple rooms and intelligently balancing your home's climate.
What is the benefit of the included C wire adapter?The included C wire adapter ensures that the Wyze Thermostat is compatible with most low voltage HVAC systems, even if your current setup lacks a C wire. This adapter provides continuous power for reliable Wi-Fi connectivity and smart features, eliminating the need for extra purchases.
How easy is it to install the Wyze Thermostat?The Wyze Thermostat is designed for quick and easy DIY installation, typically taking about 20 minutes. The Wyze app provides a step-by-step guide, making it accessible even for those new to smart thermostats.
What energy-saving features does the Wyze Thermostat offer?The Wyze Thermostat provides personalized energy-saving tips based on your usage history, motion-sensing comfort mode to avoid heating or cooling unused spaces, and simple scheduling to automate temperature changes and reduce energy consumption.
Is there a refurbished Wyze Thermostat available?Yes, Wyze offers a refurbished version of their smart thermostat. The refurbished Wyze Thermostat provides all the same features as the new model, is fully tested, and is available at a lower price for budget-conscious buyers.
Can I schedule temperature changes with the Wyze Thermostat?Yes, the Wyze Thermostat allows you to create daily schedules for weekdays and weekends, automating your home's temperature changes to save energy and enhance comfort.
What HVAC systems are compatible with the Wyze Thermostat?The Wyze Thermostat is compatible with most low voltage HVAC systems. The included C wire adapter ensures easy installation and compatibility with systems that may not have a dedicated C wire.
What are the key features of the Wyze Thermostat?How does the Wyze Thermostat work with voice assistants like Alexa and Google Assistant?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Thermostat?
