Low Cost Wyze Smart Security Packages for Indoor & Outdoor
Affordable Wyze Smart Security Packages for Indoor and Outdoor Use
Looking for a low cost, reliable smart security package that covers both indoor and outdoor areas? Wyze offers some of the best value-packed security bundles designed to keep your home safe around the clock without breaking the bank. Whether you want crystal-clear video surveillance indoors or rugged, weatherproof cameras outdoors, Wyze has you covered with advanced features and seamless smart home integration.
Wyze Cam v4 Home Security Bundle – Indoor Excellence
Crystal-Clear 2.5K QHD Video Resolution
The Wyze Cam v4 Home Security Bundle delivers stunning 2.5K Quad HD video, providing sharp, detailed footage that captures every important moment inside your home. This is the clearest Wyze Cam ever, ensuring you never miss a thing.
Enhanced Color Night Vision
Unlike traditional night vision, Wyze Cam v4 uses enhanced color night vision technology to reveal vibrant colors even in low-light conditions. This means you get superhero-like vision to monitor your home effectively at night.
Motion-Activated Spotlight & 24/7 Local Recording
Stay alerted with motion and sound detection that triggers a bright spotlight and sends instant notifications to your phone. Continuous 24/7 local recording is supported via included 128GB microSD cards, so you can review footage anytime.
Smart Home Compatibility & Wi-Fi 6 Support
Wyze Cam v4 works seamlessly with Alexa and Google Assistant, allowing voice control and smart automation. Plus, Wi-Fi 6 support ensures a stronger, more reliable connection for uninterrupted monitoring.
"Pound for pound, the clearest Wyze Cam ever."
Indoor Wyze Cam v4 in Playroom Wyze Cam v4 providing crystal-clear indoor security
Wyze Cam v4 Outdoor Bundle – Rugged Security for Any Weather
Designed for Outdoor Durability
The Wyze Cam v4 Outdoor Bundle includes a weatherproof camera paired with a Wyze Outdoor Power Adapter, making it perfect for rain, snow, or shine. Its IP65 rating ensures reliable performance in harsh conditions.
2.5K QHD Resolution with Color Night Vision
Capture vibrant, detailed footage day or night with the same advanced 2.5K Quad HD clarity and enhanced color night vision as the indoor version, but built tough for outdoor use.
Motion-Activated Spotlight & Smart Alerts
The outdoor camera features a motion-activated spotlight to deter intruders and sends real-time alerts to your phone. Customize motion detection zones to focus on critical areas and reduce false alarms.
Continuous Power & Local Recording
Being wired, the camera supports continuous power and 24/7 local recording with the included 128GB microSD card, so you never miss a moment outside your home.
"Ready for rain, snow, or shine."
Outdoor Wyze Cam v4 mounted on house exterior Wyze Cam v4 Outdoor Bundle securing your home exterior
Floodlight Security Bundle – Bright, Powerful Outdoor Protection
Super-Bright LEDs with Motion-Activated Voice Deterrence
Illuminate your yard with up to 3000 lumens of brightness from the Floodlight Pro, making it easy to spot any suspicious activity. The motion-activated voice deterrence feature warns off unwanted visitors effectively.
2K to 2.5K HD Resolution & Wide Field of View
Choose between Floodlight Pro (2.5K QHD) or Floodlight v2 (2K HD) models, both offering wide-angle views (up to 180° diagonal) to cover large outdoor areas with crisp video quality.
Color Night Vision & 24/7 Recording
See vibrant colors even at night with color night vision, and record continuously with support for microSD cards up to 256GB. The floodlight is dimmable and adjustable to suit your lighting needs.
Weather-Resistant & Smart Home Integration
Built with IP65 water resistance and a durable polycarbonate body, this floodlight withstands outdoor elements. It integrates with Alexa, Google Assistant, and IFTTT for smart control.
"Dominate the dark, spot bad guys."
Why Choose Wyze for Your Smart Security Needs?
  • Budget-Friendly Packages: Wyze offers some of the most affordable smart security bundles without compromising on quality or features.
  • Seamless Smart Home Integration: Compatible with Alexa and Google Assistant for voice commands and automation.
  • Advanced Night Vision: Enhanced color night vision technology provides superior low-light monitoring.
  • Continuous Local Recording: Included microSD cards enable 24/7 recording without monthly fees.
  • Reliable Wired Power: Wired cameras ensure uninterrupted power and recording.
  • Customizable Motion Detection: Set specific zones to reduce false alerts and focus on what matters.
Enhance Your Security Setup with Wyze Accessories
Wyze Security Yard Sign
Deter potential intruders before they approach with a stylish, durable Wyze Security Yard Sign. Made from tough aluminum with a highly visible reflective surface, it’s weatherproof and easy to install.
"Deter intruders in style."
Summary of Wyze Low Cost Smart Security Packages
ProductUse CaseKey FeaturesPrice (Approx.)
Wyze Cam v4 Home Security BundleIndoor2.5K QHD, Color Night Vision, Spotlight, Wi-Fi 6$169.99
Wyze Cam v4 Outdoor BundleOutdoorWeatherproof, 2.5K QHD, Spotlight, Wired Power$69.99
Floodlight Security BundleOutdoor Lighting2K-2.5K HD, Super-Bright LEDs, Voice Deterrence$209.96
Wyze Security Yard SignAccessoryReflective, Durable, Weatherproof$16.99
Invest in a Wyze smart security package today to protect your home inside and out with affordable, feature-rich devices trusted by thousands. Enjoy peace of mind with crystal-clear video, smart alerts, and seamless integration — all at a low cost.
FeatureWyze Cam v4 Home Security BundleWyze Cam v4 Outdoor BundleFloodlight Security BundleWyze Security Yard Sign
Price$169.99$69.99$209.96$16.99 (Yard Sign), $22.98 (Yard Sign + Reflective Stickers)
Includes4x Wyze Cam v4, 4x Wyze MicroSD Card 128GB1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x Wyze MicroSD Card 128GBFloodlight Pro or Floodlight v2 (Black/White)Wyze yard sign, aluminum stake, installation kit
Camera Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)Floodlight Pro: 2.5K QHD (2560x1440) / Floodlight v2: 2K (2304x1296)N/A
Night VisionEnhanced Color Night VisionEnhanced Color Night Vision2K HD Resolution & Color Night VisionN/A
SpotlightMotion-activated spotlightMotion-activated spotlightSuper-Bright LEDs, Dimmable & adjustableN/A
Recording24/7 local recording (microSD included)24/7 local recording (microSD included)24/7 Recording with MicroSD CardN/A
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 2.4G b/g/nN/A
Smart Assistant CompatibilityAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTN/A
Motion & Sound DetectionYesYesYesN/A
Additional AlertsSmoke & CO AlertsSmoke & CO AlertsMotion-Activated Voice DeterrenceN/A
Weather ResistanceIP65IP65IP65Weatherproof & Fade-Resistant
Power SourceWired (continuous power)Wired (continuous power) + Outdoor Power AdapterHardwired 110-120V ACN/A
Field of ViewDFOV 115.8°, HFOV 98.5°, VFOV 53.1°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°Floodlight Pro: 180° Diagonal / Floodlight v2: 160°N/A
Warranty1 Year1 Year1 YearN/A
Bundle TypeIndoor Wired Cameras BundleOutdoor Wired Camera BundleFloodlight Camera BundleSecurity Yard Sign Accessory
What are the key features of Wyze Cam v4 Home Security Bundle for indoor use?The Wyze Cam v4 Home Security Bundle offers 2.5K Quad HD video resolution, enhanced color night vision, motion-activated spotlight, 24/7 local recording with a 128GB microSD card, smart home compatibility with Alexa and Google Assistant, and Wi-Fi 6 support for a reliable connection.
Is the Wyze Cam v4 Outdoor Bundle weatherproof?Yes, the Wyze Cam v4 Outdoor Bundle is designed for outdoor durability with an IP65 weatherproof rating, making it suitable for rain, snow, or shine. It also includes a Wyze Outdoor Power Adapter for continuous power.
Does Wyze offer continuous 24/7 local video recording?Yes, all Wyze security cameras support continuous 24/7 local recording using included microSD cards, so you can review footage anytime without monthly fees.
What is enhanced color night vision in Wyze security cameras?Enhanced color night vision is an advanced technology in Wyze cameras that allows you to see vibrant colors even in low-light conditions, providing clearer and more detailed nighttime footage compared to traditional black-and-white night vision.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras integrate seamlessly with Alexa and Google Assistant, allowing for voice control and smart home automation. Some models also support IFTTT for additional smart home integration.
What is included in the Wyze Floodlight Security Bundle?The Wyze Floodlight Security Bundle includes a super-bright floodlight (up to 3000 lumens), motion-activated voice deterrence, 2K or 2.5K HD video resolution, wide-angle field of view, color night vision, 24/7 recording support, and weather-resistant construction.
How does Wyze help reduce false motion alerts?Wyze cameras allow you to customize motion detection zones, so you can focus on critical areas and reduce false alarms from irrelevant movement.
What are the benefits of choosing a Wyze smart security package?Wyze smart security packages are budget-friendly, offer advanced features like color night vision and customizable motion detection, support continuous local recording without monthly fees, and integrate with popular smart home platforms.
What is the Wyze Security Yard Sign and how does it work?The Wyze Security Yard Sign is a durable, weatherproof aluminum sign with a highly visible reflective surface. It is designed to deter potential intruders by signaling that your property is protected by Wyze security devices.
Do Wyze security cameras require a subscription for video storage?No, Wyze security cameras support local video storage on included microSD cards, enabling 24/7 recording without the need for a monthly subscription.
What is the price range for Wyze smart security packages?Wyze smart security packages are affordably priced, with the Wyze Cam v4 Home Security Bundle at approximately $169.99, the Wyze Cam v4 Outdoor Bundle at $69.99, the Floodlight Security Bundle at $209.96, and the Wyze Security Yard Sign at $16.99.
What features does the Wyze Cam v4 Home Security Bundle offer for indoor use?Can you tell me more about the outdoor capabilities of the Wyze Cam v4 Outdoor Bundle?What is the warranty policy for Wyze products?
