Install Easy Wired Doorbell Camera with Motion Alerts and Live Streaming
Enhance your home security effortlessly with the latest wired doorbell cameras that offer crystal-clear video, instant motion alerts, and seamless live streaming. Whether you want to answer your door from anywhere or keep an eye on your porch with smart notifications, these Wyze products provide reliable, easy-to-install solutions tailored for your needs.
Wyze Video Doorbell v2: The Ultimate Wired Doorbell Camera
Crystal-Clear 2K Video and Head-to-Toe Coverage
Wyze Video Doorbell v2 delivers stunning 2K resolution video, capturing every detail on your porch with immaculate clarity. Its wide-angle lens ensures you see visitors from head to toe, so nothing goes unnoticed.
Local MicroSD Storage for 24/7 Recording
Unlike many doorbells that rely solely on cloud storage, this model features a built-in microSD card slot for continuous local recording. This means you can review footage anytime without worrying about subscription fees.
Easy Integration with Existing Chimes
Keep your traditional doorbell chime ringing! The included chime controller works with your home’s existing chime system, so upgrading to a smart doorbell won’t disrupt your familiar ding-dong sound.
Motion-Activated Voice Deterrence and Real-Time Alerts
Receive instant notifications on your phone when motion is detected. Plus, enable motion-activated voice deterrence to warn visitors they’re being recorded, helping to prevent unwanted activity.
Two-Way Audio and Pre-Roll Motion Recording
Communicate directly with visitors through the Wyze app using two-way talk. The wired power setup also enables 3-6 seconds of pre-roll recording, capturing the moments just before motion starts for a complete picture.
Weatherproof and Smart Home Compatible
Rated IP65 for weather resistance, this doorbell stands up to rain, snow, and harsh conditions. It also works seamlessly with Alexa and Google Home for voice commands and live feed viewing.
"Answer your door from anywhere with our clearest and most capable wired video doorbell yet."
Two-way audio lets you talk to visitors or pets from anywhere.
Wyze Bulb Cam: Easy Installation with Motion Alerts and Live Streaming
2-in-1 Outdoor Security Camera and Smart LED Bulb
Transform any standard light fixture into a powerful security camera with the Wyze Bulb Cam. It combines a bright, dimmable 800-lumen LED bulb with a 2K HD camera featuring color night vision.
Simple Twist-On Installation
No complicated wiring or mounting required—just screw it into your existing outdoor light socket. Adjust the camera angle manually to cover the perfect field of view.
Wide 160° Field of View and Motion Detection
Keep an eye on a broad area with the super-wide 160° viewing angle. Receive instant motion alerts on your smartphone, and customize detection zones to focus on important areas.
Local Storage and No Subscription Required
Record continuously to a microSD card (up to 256 GB) without any monthly fees. Review recorded events anytime through the Wyze app.
Smart Lighting Features and Siren
Control brightness and set schedules for your outdoor lighting. The built-in siren and flashing lights can deter intruders quickly.
Compatible with Alexa, Google Assistant, and IFTTT
Integrate with your smart home ecosystem for voice control and automation.
Easily install the Bulb Cam in your outdoor light fixture for instant security.
Wyze Cam v4: High-Resolution Wired Camera with Motion Alerts and Live Streaming
Stunning 2.5K QHD Video and Enhanced Color Night Vision
Wyze Cam v4 offers ultra-clear 2.5K resolution video with enhanced color night vision, so you get vivid, detailed footage day or night.
Motion-Activated Spotlight and Built-In Siren
The camera features a motion-activated spotlight to illuminate dark areas and a built-in siren to scare off unwanted visitors.
24/7 Local Recording and Wi-Fi 6 Support
Supports continuous local recording on microSD cards up to 512 GB. Wi-Fi 6 compatibility ensures faster, more reliable streaming and notifications.
Multiple Mounting Options and Weather Resistance
Mount it on walls, ceilings, or use the magnetic adhesive mount. Rated IP65, it withstands rain, snow, and extreme temperatures.
Two-Way Talk and Smart Home Integration
Communicate with visitors via two-way audio and control the camera with Alexa, Google Assistant, or IFTTT.
"Get unmatched security with crystal-clear video and smart alerts."
Why Choose Wyze for Your Wired Doorbell Camera Needs?
- Easy Installation: Whether it’s the wired Video Doorbell v2 or the twist-on Bulb Cam, setup is straightforward and user-friendly.
- Motion Alerts: Stay informed with real-time notifications tailored to your preferences.
- Live Streaming: Watch live video anytime from your smartphone with minimal delay.
- Local and Cloud Storage Options: Choose local microSD storage for no monthly fees or subscribe for cloud storage with advanced AI detections.
- Smart Home Compatibility: Integrate with Alexa, Google Home, and IFTTT for a connected home experience.
- Weatherproof Durability: All cameras are rated IP65 or better, built to withstand outdoor conditions.
Conclusion
Installing an easy wired doorbell camera with motion alerts and live streaming has never been simpler. The Wyze Video Doorbell v2 stands out as the top choice for wired doorbell solutions, offering 2K video, local storage, and smart features. For versatile outdoor security, the Wyze Bulb Cam provides a unique all-in-one camera and lighting solution with effortless installation. Meanwhile, the Wyze Cam v4 delivers high-resolution video and advanced night vision for comprehensive home monitoring.
Choose the Wyze camera that fits your home security needs and enjoy peace of mind with smart, reliable technology.
What are the main features of the Wyze Video Doorbell v2 wired doorbell camera?
The Wyze Video Doorbell v2 offers crystal-clear 2K video resolution, head-to-toe coverage with a wide-angle lens, local microSD storage for 24/7 recording, easy integration with existing chimes, motion-activated voice deterrence, real-time motion alerts, two-way audio, pre-roll motion recording, weatherproof IP65 rating, and compatibility with Alexa and Google Home.How does the Wyze Video Doorbell v2 integrate with my existing doorbell chime?
The Wyze Video Doorbell v2 includes a chime controller that works with your home’s existing chime system, allowing you to upgrade to a smart doorbell without losing your traditional doorbell sound.Does the Wyze Video Doorbell v2 require a subscription for video storage?
No, the Wyze Video Doorbell v2 features a built-in microSD card slot for continuous local recording, so you can review footage anytime without worrying about monthly subscription fees. Cloud storage with advanced AI detections is also available as an option.What is the Wyze Bulb Cam and how is it installed?
The Wyze Bulb Cam is a 2-in-1 outdoor security camera and smart LED bulb. It installs easily by screwing into any standard outdoor light socket—no complicated wiring or mounting required. The camera angle can be manually adjusted for optimal coverage.What security features does the Wyze Bulb Cam offer?
The Wyze Bulb Cam provides 2K HD video with color night vision, a wide 160° field of view, instant motion alerts, customizable detection zones, local microSD storage, smart lighting controls, a built-in siren, flashing lights for deterrence, and compatibility with Alexa, Google Assistant, and IFTTT.Can I use Wyze cameras without a monthly subscription?
Yes, all featured Wyze cameras—including the Video Doorbell v2, Bulb Cam, and Cam v4—support local microSD card storage for continuous recording and event playback without any monthly fees. Cloud storage is optional for those who want advanced AI features.What makes the Wyze Cam v4 suitable for outdoor security?
The Wyze Cam v4 offers 2.5K QHD video, enhanced color night vision, a motion-activated spotlight, built-in siren, 24/7 local recording, Wi-Fi 6 support for fast streaming, multiple mounting options, IP65 weather resistance, two-way talk, and smart home integration.Are Wyze security cameras weatherproof?
Yes, all Wyze security cameras mentioned—including the Video Doorbell v2, Bulb Cam, and Cam v4—are rated IP65 or higher, making them weatherproof and suitable for outdoor use in rain, snow, and extreme temperatures.How do Wyze cameras provide motion alerts and live streaming?
Wyze cameras use advanced motion detection to send instant alerts to your smartphone. You can watch live video streams anytime through the Wyze app with minimal delay, ensuring you stay informed about activity around your home.Are Wyze cameras compatible with smart home systems?
Yes, Wyze cameras are compatible with Alexa, Google Home, and IFTTT, allowing for voice control, live feed viewing, and smart home automation.What are the storage options for Wyze security cameras?
Wyze security cameras offer both local storage via microSD cards (with capacities up to 512 GB depending on the model) and optional cloud storage for advanced AI detections and event history.Why should I choose Wyze for my wired doorbell camera needs?
Wyze offers easy installation, real-time motion alerts, live streaming, flexible storage options, smart home compatibility, and weatherproof durability, making it a reliable and user-friendly choice for home security.
