How to Upgrade Home Security with Wyze Monitoring Starter Kit
Upgrading your home security has never been easier or more affordable than with the Wyze Monitoring Starter Kits. Whether you want a comprehensive all-in-one solution or a core set of monitoring essentials, Wyze offers smart, professional-grade security systems designed for easy DIY installation and seamless integration with your smart home.
Wyze’s home monitoring solutions combine advanced sensors, cameras, and professional monitoring services to protect your home 24/7. Let’s explore the best Wyze products to upgrade your home security effectively.
Whole Home Security Starter Kit: All-in-One Protection
What’s Included?
The
Whole Home Security Starter Kit is a complete package that combines video surveillance and home monitoring in one bundle. It includes:
- Wyze Cam v4: The clearest Wyze Cam ever made, available in Black, Grey, or White. It offers sharp video quality for indoor or outdoor use.
- Wyze Video Doorbell v2: Keep an eye on your front door with two-way audio and motion detection.
- Wyze Home Monitoring Starter Kit: Includes sensors and a hub to monitor doors, windows, and motion inside your home.
Key Features
- Color Options: Choose from Black, Grey, or White to match your home decor.
- Comprehensive Coverage: Video cameras combined with entry and motion sensors provide layered security.
- Easy Setup: No tools required for installation, making it perfect for renters and homeowners alike.
Upgrade your home security with a system that watches over your entire property, inside and out.
Wyze Cam v4 in action, securing your home with smart video surveillance.
Wyze Home Monitoring Core Starter Kit: Essential Security Made Simple
What’s Inside?
The
Wyze Home Monitoring Core Starter Kit is designed for those who want a focused, sensor-based security system with professional monitoring. It includes:
- Wyze Sense Hub: The central unit that connects all sensors and sends alerts.
- 2x Wyze Entry Sensors: Wireless sensors for doors and windows with 18-month battery life.
- 1x Wyze Motion Sensor: Detects movement up to 25 feet indoors.
- 1x Wyze Keypad: Arm and disarm your system easily with backlit keys and an emergency button.
Why Choose This Kit?
- Built-in Battery Backup: The hub has a 10-hour backup battery to keep your system running during power outages.
- Wireless and Flexible: Sensors and keypad are wireless, allowing flexible placement without messy wires.
- Professional Monitoring Included: Comes with 3 months of professional monitoring to ensure your home is protected around the clock.
- Range and Reliability: Sensors communicate up to 500 feet, covering large homes or properties.
Feel secure knowing your home is monitored 24/7 by real people ready to respond in emergencies.
Wyze sensors installed easily on doors and windows for reliable home monitoring.
Wyze Sense Keypad: Convenient Remote Control for Your Security System
Features and Benefits
The
Wyze Sense Keypad is an optional but highly recommended accessory that enhances your home security experience by allowing you to:
- Arm and Disarm Remotely: Control your Wyze Home Monitoring system from anywhere in your home.
- Emergency Button: Quickly send alerts to first responders in case of an emergency.
- Wireless and Compact: Easy to mount anywhere indoors with permanent adhesive.
- Supports Up to 100 Accessories: Expand your system with multiple sensors and devices.
The keypad adds convenience and peace of mind, making it simple to manage your security system without needing your phone.
Wyze Sense Keypad offers quick, easy control of your home security system.
Why Choose Wyze for Your Home Security Upgrade?
Professional Monitoring with No Contracts
Wyze partners with Noonlight to provide 24/7 professional monitoring by real US-based agents. In case of an alarm, they will contact you immediately and dispatch emergency services if needed. This service requires no long-term contracts and offers flexible monthly or annual plans.
Easy DIY Installation
Wyze systems are designed for simple setup without professional help or tools. The Wyze Sense Hub connects all sensors, and the intuitive Wyze app lets you arm/disarm, view camera feeds, and receive alerts in real time.
Expandable and Customizable
Start with a starter kit and add sensors like leak detectors, climate sensors, or additional cameras to tailor your system to your home’s unique needs.
Trusted by Thousands of Customers
“Excellent service, fast response time, exceptional monitoring quickness, very fast cost-efficient equipment.” — Bakersfield, CA
“I absolutely LOVE every product I own. Reasonably priced and reliable.” — Elgin, IL
Getting Started: Build Your Wyze Home Security System
1.
Choose Your Starter Kit: Pick between the Whole Home Security Starter Kit or the Core Starter Kit based on your needs.
2.
Add Optional Accessories: Enhance your system with the Wyze Sense Keypad and additional sensors.
3.
Select a Monitoring Plan: Choose monthly or annual professional monitoring for peace of mind.
4.
Install and Connect: Use the Wyze app to set up your devices and customize your security settings.
With Wyze, upgrading your home security is straightforward, affordable, and effective.
Upgrade your home security today with Wyze Monitoring Starter Kits — smart, reliable, and designed to protect what matters most.
Product Summary
Wyze Sense Keypad
What is included in the Wyze Whole Home Security Starter Kit?
The Wyze Whole Home Security Starter Kit includes the Wyze Cam v4 (available in Black, Grey, or White), Wyze Video Doorbell v2 with two-way audio and motion detection, and the Wyze Home Monitoring Starter Kit with sensors and a hub to monitor doors, windows, and motion inside your home.How does the Wyze Home Monitoring Core Starter Kit work?
The Wyze Home Monitoring Core Starter Kit is a sensor-based security system that includes a Wyze Sense Hub, two Wyze Entry Sensors for doors and windows, one Wyze Motion Sensor, and a Wyze Keypad. It offers wireless installation, a 10-hour backup battery, and comes with 3 months of professional monitoring for 24/7 protection.What are the benefits of using the Wyze Sense Keypad?
The Wyze Sense Keypad allows you to arm and disarm your Wyze Home Monitoring system remotely, features an emergency button for quick alerts to first responders, and supports up to 100 accessories. It is wireless, compact, and easy to mount anywhere indoors.Does Wyze offer professional home monitoring services?
Yes, Wyze partners with Noonlight to provide 24/7 professional monitoring by US-based agents. In case of an alarm, agents will contact you and dispatch emergency services if needed. There are no long-term contracts, and you can choose between flexible monthly or annual plans.Is Wyze home security easy to install?
Yes, Wyze home security systems are designed for easy DIY installation with no tools required. The Wyze Sense Hub connects all sensors, and the Wyze app guides you through setup, allowing you to arm/disarm your system, view camera feeds, and receive real-time alerts.Can I expand my Wyze home security system?
Absolutely. Wyze security systems are expandable and customizable. You can start with a starter kit and add additional sensors such as leak detectors, climate sensors, or more cameras to fit your home’s unique needs.What color options are available for Wyze Cam v4?
The Wyze Cam v4 is available in Black, Grey, or White, allowing you to choose the color that best matches your home decor.How reliable are Wyze home security sensors?
Wyze home security sensors are wireless, have a communication range of up to 500 feet, and feature long battery life (up to 18 months for entry sensors). The system also includes a 10-hour backup battery in the hub for added reliability during power outages.How do I get started with Wyze home security?
To get started, choose the Wyze Whole Home Security Starter Kit or the Core Starter Kit based on your needs, add optional accessories like the Wyze Sense Keypad, select a monthly or annual professional monitoring plan, and use the Wyze app to install and customize your system.Why should I choose Wyze for my home security upgrade?
Wyze offers affordable, professional-grade home security systems with easy DIY installation, 24/7 professional monitoring, and seamless smart home integration. Their systems are trusted by thousands of customers for reliability, flexibility, and cost-effectiveness.
