How to Add Local Storage to a Wyze Cam for 24/7 Footage with Wyze MicroSD Card
If you're looking to enable continuous 24/7 recording on your Wyze Cam, adding local storage via a microSD card is the perfect solution. Wyze offers a dedicated
Wyze MicroSD Card designed to unlock continuous recording and time lapse features for your Wyze cameras, including the popular
Wyze Cam v4. This guide will walk you through the benefits, setup, and usage of local storage to ensure you never miss a moment.
Wyze MicroSD Card: The Key to Continuous Local Recording
Unlock Continuous Recording and Time Lapses
The
Wyze MicroSD Card is specially optimized for Wyze cameras, allowing you to record video footage locally without relying solely on cloud storage. This means you can have uninterrupted 24/7 footage saved directly on the card, accessible anytime.
- Available Sizes: 32GB, 128GB, and 256GB microSD cards
Features:
- Continuous local recording
- Event-based recording
- Time lapse video creation
- Timeline controls and calendar view for easy navigation
Why Choose Wyze MicroSD Card?
Using the official Wyze MicroSD card ensures compatibility and reliability with your Wyze Cam. Larger capacity cards like 128GB or 256GB allow for longer recording periods before overwriting old footage, making them ideal for 24/7 surveillance.
"The larger the card capacity, the longer you can record continuously without interruption."
Wyze Cam v4: Advanced Security with Local Storage Support
Crystal Clear 2.5K QHD Video Quality
The
Wyze Cam v4 offers stunning 2.5K QHD resolution (2560x1440), providing crystal-clear video footage day and night. With its CMOS Starlight Sensor and color night vision, you get detailed images even in low light.
Local Storage Compatibility
- Supports microSD cards up to 512GB (Wyze recommends using a microSD card for local storage)
- Enables continuous recording or event-only recording modes
- Easily manage recordings via the Wyze app with timeline and calendar views
Robust Features for Home Security
- 115.8° diagonal field of view for wide coverage
- Weather-resistant IP65 rating for indoor/outdoor use
- Two-way talk and built-in siren for interactive security
- Compatible with Alexa, Google Assistant, and IFTTT integrations
Easy Setup for Local Storage
1.
Insert the microSD card into the slot on the Wyze Cam v4.
2.
Format the card via the Wyze app: Go to Settings > Advanced Settings > Manage MicroSD Card > Format.
3.
Enable local recording: In the app, toggle on "Record to MicroSD Card" and select continuous or event-based recording.
4.
View recordings anytime from the live stream playback or Events tab.
Experience peace of mind with continuous local recording on Wyze Cam v4.
Step-by-Step Guide to Enable 24/7 Local Storage on Your Wyze Cam
Step 1: Choose Your MicroSD Card Size
Select a Wyze MicroSD Card size that fits your recording needs:
- 32GB: Suitable for shorter recording periods or event-only recording.
- 128GB: Ideal for several days of continuous footage.
- 256GB: Best for extended 24/7 recording without frequent overwrites.
Step 2: Insert and Format the MicroSD Card
- Power off your Wyze Cam.
- Insert the microSD card into the designated slot (location varies by model).
- Power on the camera.
- Open the Wyze app, access your camera’s live stream, and format the card to prepare it for recording.
Step 3: Enable Local Recording
- In the Wyze app, navigate to Settings > Advanced Settings.
- Toggle on "Record to MicroSD Card."
- Choose between Continuous Recording for 24/7 footage or Events Only to save space and battery life.
Step 4: Access Your Footage
- Use the View Playback button on the live stream to scroll through recorded footage.
- Use the calendar view to select specific dates.
- Footage is saved in MP4 format and can be viewed on your computer by ejecting the microSD card.
Note: When the microSD card is full, the camera will automatically overwrite the oldest footage, ensuring continuous recording without manual intervention.
Benefits of Using Local Storage with Wyze Cam
- No Monthly Fees: Local storage is free and does not require a subscription.
- Offline Recording: Your camera records even if Wi-Fi is temporarily lost.
- Privacy: Footage is stored locally, giving you full control over your data.
- Easy Playback: Quickly find and review footage using timeline and calendar features in the Wyze app.
Summary
Adding a
Wyze MicroSD Card to your
Wyze Cam v4 is the best way to enable 24/7 local storage for continuous video recording. With easy setup, high compatibility, and no subscription fees, you can enjoy peace of mind knowing your home is monitored around the clock.
How do I enable 24/7 continuous recording on my Wyze Cam?
To enable 24/7 continuous recording on your Wyze Cam, insert a Wyze MicroSD Card into your camera, format it using the Wyze app (Settings > Advanced Settings > Manage MicroSD Card > Format), and toggle on 'Record to MicroSD Card.' Then, select 'Continuous Recording' to capture footage around the clock.What sizes of Wyze MicroSD Cards are available for local storage?
Wyze MicroSD Cards are available in 32GB, 128GB, and 256GB sizes. The larger the card, the longer you can record continuously before older footage is overwritten.Is the Wyze Cam v4 compatible with microSD cards for local storage?
Yes, the Wyze Cam v4 supports microSD cards up to 512GB for local storage. Wyze recommends using their official microSD cards for optimal compatibility and performance.How do I set up a microSD card for local recording on my Wyze Cam v4?
To set up a microSD card on your Wyze Cam v4, power off the camera, insert the microSD card into the slot, power the camera back on, and use the Wyze app to format the card. Then, enable local recording in the app's Advanced Settings.What are the benefits of using a Wyze MicroSD Card for local storage?
Using a Wyze MicroSD Card for local storage offers several benefits: no monthly fees, offline recording even if Wi-Fi is lost, enhanced privacy with footage stored locally, and easy playback using the Wyze app's timeline and calendar features.How can I view and manage my locally stored footage on Wyze Cam?
You can view and manage your locally stored footage by using the 'View Playback' button in the Wyze app's live stream. The app provides timeline and calendar views for easy navigation. You can also remove the microSD card and view MP4 files on your computer.What happens when the microSD card is full on my Wyze Cam?
When the microSD card is full, your Wyze Cam will automatically overwrite the oldest footage, ensuring continuous recording without manual intervention.Can I use event-only recording with a Wyze MicroSD Card?
Yes, you can choose between continuous recording and event-only recording modes in the Wyze app. Event-only recording saves space by only recording when motion or sound is detected.Does using local storage on Wyze Cam require a subscription?
No, using local storage with a Wyze MicroSD Card does not require any monthly subscription or fees.Why should I choose the official Wyze MicroSD Card for my Wyze Cam?
The official Wyze MicroSD Card is optimized for Wyze cameras, ensuring maximum compatibility, reliability, and performance for continuous and event-based recording.
