Cheap Cameras with Local & Cloud Storage | Affordable Security
Affordable Cameras with Local and Cloud Storage Options
Looking for cheap cameras that offer both local and cloud storage? Whether you want to secure your home, monitor your pets, or keep an eye on your front door, Wyze offers a range of budget-friendly cameras packed with features. These cameras provide reliable local storage via microSD cards and optional cloud storage subscriptions for added convenience and security.
Wyze Bulb Cam: 2-in-1 Outdoor Security and Smart Lighting
Transform any outdoor light fixture into a smart security camera with the Wyze Bulb Cam. This innovative device combines a bright, dimmable 800-lumen LED bulb with a 2K HD security camera featuring color night vision.
Key Features:
  • 2K HD Video with Color Night Vision: Capture clear, vibrant footage day and night.
  • Local Storage: Supports continuous 24/7 recording to a microSD card up to 256GB—no subscription required.
  • Smart Lighting Control: Adjust brightness, set schedules, and connect up to 5 accessory bulbs for full outdoor lighting coverage.
  • Motion Detection & Alerts: Receive instant notifications on your phone when motion is detected.
  • Two-Way Audio & Siren: Communicate remotely and deter intruders with a built-in siren and flashing lights.
  • Easy Installation: Fits most standard light fixtures with a simple twist installation.
The Wyze Bulb Cam is perfect for those who want to combine outdoor lighting with security without extra wiring or complicated setups.
Wyze Bulb Cam in outdoor light fixture Wyze Bulb Cam installed in outdoor light fixture
Wyze Cam v4: High-Resolution Wired Camera with Wi-Fi 6
For unmatched clarity and smart home integration, the Wyze Cam v4 offers 2.5K QHD resolution and enhanced color night vision, making it one of the clearest cameras in its price range.
Highlights:
  • 2.5K Quad HD Video: Crystal-clear footage with wide dynamic range (WDR) for vibrant colors.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription.
  • Wi-Fi 6 Support: Stronger, more reliable connection for smooth streaming.
  • Motion-Activated Spotlight & Siren: Illuminate and deter intruders automatically.
  • Weather Resistant (IP65): Suitable for indoor and outdoor use.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Easy Setup: Bluetooth-enabled setup and magnetic mount for hassle-free installation.
Wyze Cam v4 is ideal for users who want premium video quality and robust smart features at an affordable price.
Wyze Cam Floodlight v2 lifestyle Enjoy clear 2K video and wide-angle coverage with Wyze Cam Floodlight v2
Wyze Cam Floodlight v2: Bright Security with 2K Video and AI Lighting
If you want powerful illumination combined with security, the Wyze Cam Floodlight v2 delivers 2800 lumens of LED brightness alongside 2K video with color night vision.
Features:
  • 2800 Lumens LED Floodlight: Brightly light up your driveway or backyard.
  • 2K Video with Color Night Vision: See every detail clearly, even in the dark.
  • 160° Wide-Angle View: Covers a broad area for maximum security.
  • 24/7 Local Recording: Supports microSD cards for continuous recording.
  • AI-Powered Light Control: Automatically adjusts lighting based on motion and ambient light.
  • Two-Way Talk & Siren: Communicate and scare off unwanted visitors.
  • Dusk-to-Dawn Automation: Lights turn on/off automatically based on time of day.
  • IP65 Weather Resistance: Built to withstand outdoor elements.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This camera is perfect for those who want a bright, smart floodlight combined with reliable security monitoring.
Wyze Video Doorbell v2: Clear 2K Video with Local Storage
Secure your front door with the Wyze Video Doorbell v2, offering 2K video resolution and local microSD storage to capture every visitor in detail.
Benefits:
  • 2K HD Video: Crisp, detailed video of your doorstep.
  • Local Storage: Save footage directly to a microSD card—no monthly fees.
  • Two-Way Audio: Speak to visitors or delivery personnel from anywhere.
  • Motion-Activated Voice Deterrence: Automatically warns unwanted guests.
  • Real-Time Alerts: Instant notifications on your smartphone.
  • Wired Installation: Reliable power and continuous recording.
Ideal for homeowners wanting a budget-friendly video doorbell with local storage and smart features.
Wyze Cam Pan v3: 360° Coverage with Pan and Tilt
For comprehensive indoor or outdoor monitoring, the Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt with IP65 weather resistance.
Features:
  • 360° Pan & 180° Tilt: Covers every angle in a room or outdoor space.
  • 1080p HD Video: Clear video with color night vision.
  • Supports up to 256GB microSD: Continuous local recording without subscription.
  • Two-Way Audio: Communicate through the camera.
  • Weather Resistant: Suitable for outdoor use with optional power adapter.
  • Smart Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
Perfect for users who want flexible camera positioning and full coverage at an affordable price.
Wyze Cam OG: Budget-Friendly Camera with Essential Features
The Wyze Cam OG is a great entry-level camera offering 1080p video, 120° field of view, and local storage support.
Highlights:
  • 1080p Full HD Video: Clear and reliable footage.
  • Local microSD Storage: Supports up to 256GB cards.
  • Two-Way Audio: Talk and listen remotely.
  • Built-in Spotlight: Enhances night vision and security.
  • Indoor/Outdoor Use: Versatile placement options.
  • Fast Notifications: Quick alerts to your phone.
A solid choice for those seeking a no-frills, affordable security camera with local storage.
Why Choose Cameras with Local and Cloud Storage?
Cameras with local storage allow you to save video footage directly on a microSD card, eliminating monthly fees and subscription dependencies. Cloud storage adds an extra layer of security by backing up your videos remotely, accessible anytime from your smartphone or computer. Wyze cameras offer both options, giving you flexibility and peace of mind.
Conclusion
Wyze offers a variety of cheap cameras with both local and cloud storage options to fit every security need and budget. From the innovative Wyze Bulb Cam that doubles as a smart light to the powerful Wyze Cam Floodlight v2, you can protect your home day and night with crystal-clear video, smart alerts, and easy installation. Choose the camera that best fits your lifestyle and enjoy affordable, reliable home security with Wyze.
Wyze Bulb Cam motion detection at night Wyze Bulb Cam detects motion and records in color at night
FeatureWyze Bulb CamWyze Cam v4Wyze Cam Floodlight v2Wyze Video Doorbell v2Wyze Cam Pan v3Wyze Cam OG
TypeOutdoor Security Camera + LED BulbWired Security CameraWired Floodlight CameraWired Video DoorbellIndoor/Outdoor Pan & Tilt CameraIndoor/Outdoor Security Camera
Video Resolution2K HD (2304 x 1296)2.5K QHD (2560 x 1440)2K (2304 x 1296)2K (2048 x 1536)1080p (1920 x 1080)1080p (1920 x 1080)
Field of View160° Wide115.9° (D) x 98.5° (H) x 53.1° (V)160° Diagonal166.8° Diagonal360° horizontal, 180° vertical120°
Night VisionColor Night VisionEnhanced Color Night VisionColor Night VisionIR Night VisionIR Night Vision (4 IR LEDs)IR Night Vision (4 IR LEDs)
AudioTwo-Way AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way AudioTwo-Way Audio with Noise & Echo CancellationTwo-Way Audio with Noise & Echo Cancellation
SpotlightNoMotion-Activated Spotlight2800 Lumens LED PanelsNoNoBuilt-in Spotlight (40 Lumens)
SirenBuilt-in Siren99 dB Siren105 dB SirenMotion-Activated Voice DeterrenceNo90 dB User-Activated Siren
Local StorageMicroSD up to 256 GB (no subscription)MicroSD up to 256 GB (no subscription)MicroSD up to 256 GB (no subscription)MicroSD up to 256 GB (no subscription)MicroSD up to 256 GB (no subscription)MicroSD up to 256 GB (no subscription)
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Weather ResistanceOutdoor Rated (fits most fixtures)IP65IP65IP65IP65IP65
PowerPowered by light fixture (LED bulb)WiredHardwiredWired (16V-24V AC)Wired (via power adapter)Wired
ConnectivityWi-Fi 2.4 GHzWi-Fi 6 (requires Wi-Fi 6 router)Wi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
DimensionsFits most light fixturesNot specified9.5" x 7.7" x 7.0"4.3" x 1.7" x 0.9"124mm x 60mm x 63mm1.89" x 1.89" x 1.89"
WeightNot specifiedNot specified2.76 lbs (1.25 kg)Not specified11.29 oz (320 g)4.1 oz (116 g)
MountingFits standard light socketsWall or ceiling mountWall or ceiling mountDoorbell mountScrew mountSurface mount
Special FeaturesDimmable LED bulb, group light control, motion-activated lightsAuto-zoom with AI, Wi-Fi 6, smoke & CO alertsAmbient Light Mode, AI-Powered Light Control, Dimmable LEDsMotion-activated voice deterrence, digital zoom360° pan, 180° tilt, 8x digital zoomFaster live streaming, upgraded 2-way audio
Price (Single Unit)$49.98$35.98$89.98$44.98$39.98$29.98
What are the best affordable security cameras with both local and cloud storage options?Wyze offers a range of budget-friendly security cameras that support both local storage via microSD cards and optional cloud storage subscriptions. These cameras provide reliable video recording and flexible storage solutions to fit your needs and budget.
How does local storage work on Wyze cameras?Wyze cameras support local storage by allowing you to insert a microSD card (up to 256GB) into the camera. This enables continuous 24/7 recording or event-based recording without the need for a monthly subscription.
Do Wyze cameras require a subscription for video storage?No, Wyze cameras do not require a subscription for local storage. You can record and store footage directly to a microSD card. However, Wyze also offers optional cloud storage subscriptions for added convenience and remote backup.
What is the Wyze Bulb Cam and what features does it offer?The Wyze Bulb Cam is a 2-in-1 device that combines an 800-lumen smart LED bulb with a 2K HD security camera featuring color night vision. It supports local microSD storage, motion detection, two-way audio, a built-in siren, and easy installation in most standard light fixtures.
Which Wyze camera offers the highest video resolution?The Wyze Cam v4 offers 2.5K Quad HD resolution, providing crystal-clear footage with wide dynamic range and enhanced color night vision for superior image quality.
Are Wyze cameras suitable for outdoor use?Yes, several Wyze cameras, including the Wyze Bulb Cam, Wyze Cam v4, Wyze Cam Floodlight v2, and Wyze Cam Pan v3, are IP65 weather resistant and designed for both indoor and outdoor use.
What smart home integrations are available with Wyze cameras?Wyze cameras are compatible with popular smart home platforms such as Amazon Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
What is the Wyze Cam Floodlight v2 and what makes it unique?The Wyze Cam Floodlight v2 combines a powerful 2800-lumen LED floodlight with a 2K security camera featuring color night vision, AI-powered light control, two-way talk, a siren, and dusk-to-dawn automation for comprehensive outdoor security.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 supports local storage by saving footage directly to a microSD card, allowing you to capture and review video without monthly fees.
Which Wyze camera is best for 360° coverage?The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, providing full-room or outdoor area coverage with 1080p HD video and color night vision.
What is the most budget-friendly Wyze camera with essential features?The Wyze Cam OG is an entry-level, affordable camera offering 1080p HD video, a 120° field of view, local microSD storage, two-way audio, and a built-in spotlight for enhanced night vision.
Why choose a security camera with both local and cloud storage?Cameras with both local and cloud storage provide flexibility and peace of mind. Local storage allows you to save footage without monthly fees, while cloud storage offers remote backup and access to your videos from anywhere.
How easy is it to install Wyze cameras?Wyze cameras are designed for easy installation, with features like Bluetooth-enabled setup, magnetic mounts, and compatibility with standard light fixtures for quick and hassle-free setup.
What are the key features of the Wyze Bulb Cam?Can you tell me more about the local storage options for Wyze cameras?Are there any ongoing sales or discounts for Wyze cameras?
