Top Home Security Cameras with Smart Detection & Free SD Card
Best Home Security Cameras with Smart Detection and Free SD Card
Protect your home with the latest in smart security technology. Whether you want crystal-clear video, advanced motion detection, or convenient local storage with a free SD card, these Wyze cameras offer top-tier features to keep your property safe day and night. Explore the best options for wired, wireless, pan-tilt, and even bulb-style cameras that blend seamlessly into your home environment.
Wyze Cam v4: The Ultimate Wired Security Camera with Smart Detection
Experience unmatched home security with the Wyze Cam v4, the clearest Wyze Cam ever made. This wired camera delivers stunning 2.5K QHD resolution and enhanced color night vision, allowing you to see vibrant details even in low light.
Key Features:
  • 2.5K Quad HD Resolution: Capture every detail with crystal-clear video quality.
  • Enhanced Color Night Vision: See in full color at night, revealing details traditional night vision misses.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Supports continuous recording to a microSD card up to 256GB (free 32GB card included in bundles).
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Detection: Receive alerts for people, packages, vehicles, pets, and AI-based sound detection.
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT for smart home integration.
  • Weather Resistant: IP65 rating means it can be used indoors or outdoors with the proper power adapter.
Convenience & Setup:
  • Easy Bluetooth® setup with no QR codes.
  • Screw-free magnetic mount for quick installation.
  • Smoke and CO alarm alerts for added safety.
"Wyze Cam v4 gives your home superhero vision with its enhanced night vision and smart detection capabilities."
Wyze Cam v4 in use Two-way audio lets you communicate through your Wyze Cam v4, perfect for monitoring pets or talking to visitors.
Wyze Cam Pan v3: 360° Pan & Tilt with Weatherproof Durability
For those who want full coverage, the Wyze Cam Pan v3 offers a 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your home or yard.
Highlights:
  • 360° Pan & 180° Tilt: Complete room or yard coverage with smooth, quiet motion tracking.
  • IP65 Weather Resistance: Designed for outdoor use with the Wyze Outdoor Power Adapter.
  • Automatic Motion Tracking: The camera follows moving objects automatically, ensuring nothing escapes detection.
  • Color Night Vision: See clear, colorful images even in the dark.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
  • Two-Way Audio: Speak and listen through the camera via the Wyze app.
  • Local Storage: Supports microSD cards up to 256GB for continuous recording.
Smart Detection & Alerts:
  • Motion and sound detection with customizable detection zones.
  • Smoke and carbon monoxide alarm alerts.
  • Compatible with Alexa, Google Assistant, and IFTTT.
"Wyze Cam Pan v3 is your vigilant guardian, patrolling your property rain or shine."
Wyze Cam Pan v3 outdoor lifestyle Weather-resistant Wyze Cam Pan v3 keeps watch through snow and rain.
Wyze Battery Cam Pro: Wire-Free Security with Long Battery Life
If you prefer a wireless solution, the Wyze Battery Cam Pro offers powerful features without the hassle of wiring.
Features:
  • 2.5K HDR Video: High-resolution video with vivid colors and sharp details.
  • Wire-Free & No Hub Required: Easy installation anywhere with removable, rechargeable 6200mAh batteries lasting up to 6 months.
  • Integrated Spotlight & Siren: Motion-activated light and 100 dB siren for deterrence.
  • Radar + PIR Motion Detection: Advanced dual-sensor detection reduces false alerts.
  • IP65 Weatherproof: Built to withstand harsh outdoor conditions.
  • Local Storage: Supports microSD cards up to 256GB for continuous recording without subscription.
  • Two-Way Audio: Communicate through the built-in speaker and microphone.
  • Wi-Fi Support: Works on both 2.4 GHz and 5 GHz networks.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
"Wyze Battery Cam Pro combines freedom and power, delivering wire-free security with smart detection."
Wyze Bulb Cam: Discreet Outdoor Security with Smart Lighting
Protect your home with the innovative Wyze Bulb Cam, a 2-in-1 outdoor security camera and smart LED light bulb.
What Makes It Special:
  • 2K HD Video with Color Night Vision: Clear video day and night.
  • Fits Standard E26 Light Fixtures: Easy installation replacing your existing outdoor bulb.
  • Motion-Activated Light & Alerts: Lights up your porch and sends instant motion notifications.
  • Local Storage Support: Use microSD cards up to 256GB for local video storage without subscription.
  • IP65 Weather Resistant: Durable for outdoor use.
  • Two-Way Audio & 95 dB Siren: Communicate and deter intruders.
  • Smart Controls: Schedule lighting, set motion-activated light, and use Wyze Automations.
Compatible with Alexa and Google Assistant.
"Wyze Bulb Cam blends security and lighting, keeping your home safe and well-lit."
Wyze Bulb Cam installed Wyze Bulb Cam fits seamlessly into your outdoor light fixtures for discreet security.
Wyze Video Doorbell v2: Clear 2K Video and Local Storage at Your Doorstep
Answer your door from anywhere with the Wyze Video Doorbell v2, offering sharp 2K video and essential smart features.
Features:
  • 2K Video Resolution: Crisp, detailed video of visitors and packages.
  • Local microSD Storage: Save footage locally without monthly fees.
  • Two-Way Audio: Talk to visitors in real-time.
  • Motion-Activated Voice Deterrence: Scare off unwanted guests with a custom voice message.
  • Real-Time Alerts: Instant notifications on your phone.
  • Easy Installation: Wired connection for continuous power.
  • Smart Home Compatible: Works with Alexa and Google Assistant.
"Wyze Video Doorbell v2 keeps you connected and in control, right at your doorstep."
Why Choose Wyze Cameras for Your Home Security?
Wyze offers a comprehensive lineup of smart security cameras that combine high-resolution video, advanced AI-powered detection, and flexible local storage options including free or affordable microSD cards. Whether you want wired reliability, wireless freedom, or innovative form factors like the Bulb Cam or Video Doorbell, Wyze has you covered with affordable, feature-rich solutions.
Protect your home smarter, safer, and simpler with Wyze.
Summary of Featured Products
Product NameResolutionSmart DetectionStorage TypeWeather ResistancePrice Range
Wyze Cam v42.5K QHDYesmicroSD (up to 256GB)IP65$35.98+
Wyze Cam Pan v32.5KYesmicroSD (up to 256GB)IP65$39.98+
Wyze Battery Cam Pro2.5K HDRYesmicroSD (up to 256GB)IP65$89.98+
Wyze Bulb Cam2K HDYesmicroSD (up to 256GB)IP65$49.98
Wyze Video Doorbell v22KYesmicroSD (local)Wired (outdoor use)$44.98
Secure your home with Wyze’s smart detection cameras and enjoy the convenience of free or affordable microSD card storage for continuous local recording. Choose the perfect camera to fit your lifestyle and keep your loved ones safe.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Bulb CamWyze Video Doorbell v2
TypeWired CameraWired Camera (Pan & Tilt)Battery Camera (Wireless)Lighting Camera (Bulb + Camera)Wired Video Doorbell
Video Resolution2.5K QHD (2560x1440)1080p (1920x1080)2.5K HDR (2560x1440)2K (2304x1296)2K (2048x1536)
Field of View (DFOV/HFOV/VFOV)115.8° / 98.5° / 53.1°120° FOV134° / 108° / 56°166° diagonal / 160° total166.8° diagonal / 135° horizontal / 103° vertical
Pan & TiltNo360° pan / 180° tiltNoNoNo
Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens), Color Night Vision4 IR LEDs (850 nm)2 IR LEDs (850 nm) + 2 White LEDs (187 lumens), Color Night Vision4 IR LEDs (850 nm), Color Night Vision6 x 940nm IR lights
Audio99dB waterproof speaker, 2-way talk, built-in siren, noise & echo cancellationBuilt-in speaker & mic, 2-way audio, noise & echo cancellationTwo-way audio with built-in speaker & micBuilt-in digital mic, 2-way audioECM microphone, 8Ω 1W speaker, 2-way audio
StoragemicroSD up to 512 GB (local), Cloud (subscription)microSD up to 256 GB (local)microSD up to 256 GB (local)microSD up to 256 GB (local), CloudmicroSD up to 256 GB (local), Cloud (subscription)
ConnectivityWi-Fi 2.4 GHz & Wi-Fi 6, Bluetooth 5.2Wi-Fi 2.4 GHz (no 5 GHz), Bluetooth N/AWi-Fi 2.4 & 5 GHz, Bluetooth BLE 5.1Wi-Fi 2.4 GHz, Bluetooth 4.2 BLEWi-Fi 2.4 GHz, Bluetooth N/A
Power SourceWired (Indoor 5V/1A adapter)Wired (5V/2000mA adapter)Removable rechargeable battery (6200mAh)120V AC (standard E26 socket)Wired (16V-24V AC)
Weather ResistanceIP65IP65IP65IP65IP65
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)124mm x 60mm x 63mm2.5 x 1.8 x 3.5 inchesNot specified4.3in x 1.7in x 0.9in (110 x 44 x 24 mm)
Weight0.49 lb (222 g)11.29 oz (320 g)0.94 lbNot specifiedNot specified
Mounting OptionsStand, Wall, Ceiling, Magnetic wall mount (adhesive)Screw 1/4"-20 mount1/4" - 20 standard mount, wall mount includedStandard bulb socket (E26)Wall mount (included)
Motion DetectionYesYesRadar + PIR Motion DetectionYesYes
SpotlightMotion-activated spotlight (2 white LEDs)NoIntegrated SpotlightNoNo
SirenBuilt-in siren (99dB)NoBuilt-in siren (100 dB)95 dB sirenNo
Digital Zoom8x8xNot specifiedYesDigital Zoom
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Operating Temperature-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
Warranty1 Year1 YearNot specified1 Year1 Year
Price Range (approx.)$35.98 - $107.94$39.98 - $114.94$89.98 - $219.98$49.98$44.98
What are the best Wyze home security cameras with smart detection and free SD card?The best Wyze home security cameras with smart detection and free SD card options include the Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Video Doorbell v2. These cameras offer advanced features like AI-powered motion detection, high-resolution video, and local storage with microSD cards (some bundles include a free 32GB card).
Does Wyze Cam v4 support local storage and come with a free SD card?Yes, the Wyze Cam v4 supports local storage with microSD cards up to 256GB and includes a free 32GB microSD card in select bundles, allowing for 24/7 continuous recording without a subscription.
What smart detection features do Wyze security cameras offer?Wyze security cameras offer advanced smart detection features, including AI-powered alerts for people, packages, vehicles, pets, and sound detection. Some models also provide smoke and carbon monoxide alarm alerts for added safety.
Are Wyze security cameras weather resistant for outdoor use?Yes, many Wyze security cameras such as the Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, and Wyze Bulb Cam are IP65 weather resistant, making them suitable for both indoor and outdoor use.
Can Wyze cameras be integrated with smart home systems?Wyze cameras are compatible with popular smart home platforms, including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
What is the video resolution of Wyze security cameras?Wyze security cameras offer high-resolution video, with models like the Wyze Cam v4 and Wyze Battery Cam Pro providing 2.5K QHD or HDR video, and the Wyze Bulb Cam and Video Doorbell v2 offering 2K HD video for clear and detailed footage.
How does the Wyze Cam Pan v3 provide full coverage?The Wyze Cam Pan v3 features 360° horizontal pan and 180° vertical tilt, along with automatic motion tracking, ensuring complete room or yard coverage and that no movement goes undetected.
Is there a wireless Wyze security camera option?Yes, the Wyze Battery Cam Pro is a wire-free security camera with removable, rechargeable batteries that last up to 6 months. It does not require a hub and supports both 2.4 GHz and 5 GHz Wi-Fi networks.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a 2-in-1 outdoor security camera and smart LED light bulb that fits standard E26 light fixtures. It provides 2K HD video with color night vision, motion-activated lighting, two-way audio, and local microSD card storage.
Does the Wyze Video Doorbell v2 offer local storage?Yes, the Wyze Video Doorbell v2 supports local microSD card storage, allowing you to save video footage without monthly subscription fees.
Do Wyze cameras require a subscription for video storage?No, Wyze cameras support local storage via microSD cards (up to 256GB), enabling continuous recording without the need for a subscription. Some models also include a free SD card in the bundle.
How easy is it to install Wyze security cameras?Wyze security cameras are designed for easy installation, with features like Bluetooth setup, screw-free magnetic mounts, and compatibility with standard light fixtures for the Bulb Cam. The Wyze Battery Cam Pro is completely wire-free for flexible placement.
What is the price range for Wyze smart security cameras?Wyze smart security cameras are affordably priced, with models ranging from $35.98 for the Wyze Cam v4 to $89.98 for the Wyze Battery Cam Pro. The Wyze Bulb Cam and Video Doorbell v2 are priced at $49.98 and $44.98, respectively.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam Pan v3 and its capabilities?Do you have any deals, ongoing sales, discounts, or promotions?
