Affordable Cameras with Motion & Sound Detection and Cloud Storage
Looking for an affordable security camera that offers reliable motion and sound detection along with cloud storage? Wyze offers a range of smart cameras designed to keep your home safe without breaking the bank. Whether you want a wireless battery-powered cam, a discreet bulb camera, or a versatile pan-and-tilt model, Wyze has you covered with advanced features and easy cloud storage options.
Wyze Battery Cam Pro: Wireless Freedom with Pro-Grade Detection
Experience the ultimate in flexible home security with the
Wyze Battery Cam Pro. This wire-free camera delivers stunning 2.5K HDR video resolution and combines radar and PIR sensors for superior motion detection accuracy.
Key Features:
- 2.5K HDR Video: Crystal-clear footage day or night with color night vision.
- Radar + PIR Motion Detection: Dual sensors reduce false alarms and detect motion earlier.
- Integrated Spotlight & Siren: 150 lumens LED spotlight and siren to deter intruders.
- Wireless & Weatherproof: IP65 rating means it withstands rain, snow, and dust.
- Removable Rechargeable Batteries: Hot-swap batteries for continuous protection.
- Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks.
- Local & Cloud Storage: Supports microSD card for local recording; Cam Plus subscription offers unlimited cloud storage with smart notifications.
- Two-Way Audio: Built-in mic and speaker for real-time communication.
The Wyze Battery Cam Pro is perfect for those who want a no-hassle, wire-free security solution that can be placed anywhere around your home or property.
Weather-resistant Wyze Battery Cam Pro in snowy outdoor setting
Wyze Bulb Cam: Discreet 2-in-1 Security and Lighting
Transform any standard light fixture into a smart security camera with the
Wyze Bulb Cam. This innovative device combines a 2K HD camera with an 800-lumen dimmable LED bulb, providing both illumination and surveillance in one affordable package.
Highlights:
- 2K HD Video with Color Night Vision: See clear, colorful footage even in low light.
- Wide 160° Field of View: Covers more area than traditional cameras.
- Motion Detection & Instant Alerts: Receive notifications on your phone when motion is detected.
- Local Storage Support: Records continuously or on motion to a microSD card (up to 256GB) without subscription fees.
- Easy Installation: Simply screw into most outdoor light sockets—no wiring needed.
- Two-Way Audio: Talk to visitors or pets remotely.
- Smart Lighting Control: Adjust brightness, set schedules, and connect up to 5 accessory bulbs for full coverage.
- Works with Alexa, Google Assistant, and IFTTT: Seamless smart home integration.
Ideal for porch, garage, or backyard lighting and security, the Wyze Bulb Cam blends in naturally while keeping an eye on your property.
Wyze Bulb Cam installed in outdoor light fixture, providing security and lighting
Wyze Cam Pan v3: 360° Coverage with Smart Motion Tracking
For those who want full coverage and smart tracking, the
Wyze Cam Pan v3 offers a 360° horizontal and 180° vertical field of view with smooth pan and tilt capabilities.
Features at a Glance:
- 1080p Full HD Video: Clear, detailed footage with 20 fps daytime and 15 fps nighttime.
- 360° Pan & 180° Tilt: Covers every angle with remote control via the Wyze app.
- Motion Tracking: Automatically follows moving objects to keep them in frame.
- IP65 Weather Resistant: Suitable for indoor and outdoor use (requires outdoor power adapter).
- Two-Way Audio: Built-in mic and speaker with noise and echo cancellation.
- Local & Cloud Storage: Supports microSD cards up to 256GB; cloud storage available with subscription.
- Smart Home Compatible: Works with Alexa, Google Assistant, and IFTTT.
- Easy Setup: Quick Bluetooth setup and 2.4 GHz Wi-Fi connectivity.
The Wyze Cam Pan v3 is perfect for monitoring large areas like backyards, garages, or living rooms with its dynamic pan and tilt features.
Wyze Cam Pan v3 installed outdoors, capturing wide-angle views in snowy weather
Why Choose Wyze for Affordable Security Cameras?
Wyze cameras stand out for their combination of affordability, advanced features, and flexible storage options. With options for local microSD recording and affordable cloud subscriptions, you can customize your security setup to fit your needs and budget.
Additional Benefits:
- Smart Notifications: Receive alerts for people, packages, vehicles, and even birds (Wyze Battery Cam Pro).
- Easy App Control: Manage all your cameras from the Wyze app with live view, playback, and settings.
- Expandable Ecosystem: Add accessories like solar panels, charging docks, and mounts to enhance your system.
- Reliable Weather Resistance: Most models are IP65 rated, ensuring durability in harsh outdoor conditions.
Summary of Affordable Wyze Cameras with Motion & Sound Detection and Cloud Storage
Product | Video Resolution | Motion Detection | Cloud Storage Option | Price Range | Power Type |
Wyze Battery Cam Pro | 2.5K HDR | Radar + PIR dual sensors | Cam Plus subscription | $89.98+ | Battery (wireless) |
Wyze Bulb Cam | 2K HD | Motion alerts | Cam Plus subscription | $49.98 | Wired (light socket) |
Wyze Cam Pan v3 | 1080p Full HD | Motion tracking | Cam Plus subscription | $39.98 | Wired (power adapter) |
Protect your home smartly and affordably with Wyze cameras that combine motion and sound detection with flexible cloud storage. Choose the model that fits your lifestyle and enjoy peace of mind with advanced security technology.
What affordable security cameras does Wyze offer with motion and sound detection?
Wyze offers several affordable security cameras with motion and sound detection, including the Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Cam Pan v3. Each model features advanced detection capabilities and flexible storage options to help keep your home secure.Does Wyze offer security cameras with cloud storage?
Yes, Wyze cameras support cloud storage through the Cam Plus subscription, which provides unlimited cloud storage and smart notifications. Most models also support local storage via microSD cards for added flexibility.What are the key features of the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features 2.5K HDR video, radar and PIR dual motion detection sensors, integrated spotlight and siren, wireless and weatherproof design (IP65), removable rechargeable batteries, dual-band Wi-Fi support, local and cloud storage, and two-way audio.How does the Wyze Bulb Cam work as both a security camera and a light?
The Wyze Bulb Cam combines a 2K HD security camera with an 800-lumen dimmable LED bulb. It installs easily into most standard light sockets, providing both illumination and surveillance. It features motion detection, instant alerts, two-way audio, and smart lighting control.Can Wyze cameras be used outdoors?
Yes, many Wyze cameras, such as the Wyze Battery Cam Pro and Wyze Cam Pan v3, are IP65 weather resistant and suitable for outdoor use. The Wyze Bulb Cam is also designed for outdoor light fixtures.What storage options are available for Wyze security cameras?
Wyze cameras offer both local and cloud storage options. You can use a microSD card (up to 256GB) for local recording, or subscribe to Cam Plus for unlimited cloud storage and smart notifications.Are Wyze cameras compatible with smart home systems?
Yes, Wyze cameras work with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.What is the video resolution of Wyze security cameras?
Wyze security cameras offer various video resolutions: Wyze Battery Cam Pro provides 2.5K HDR video, Wyze Bulb Cam offers 2K HD video, and Wyze Cam Pan v3 delivers 1080p Full HD video.How does motion detection work on Wyze cameras?
Wyze cameras use advanced motion detection technologies. The Wyze Battery Cam Pro uses radar and PIR dual sensors for accurate detection, the Wyze Bulb Cam provides motion alerts, and the Wyze Cam Pan v3 features smart motion tracking to follow moving objects.Do Wyze cameras support two-way audio?
Yes, all featured Wyze cameras include built-in microphones and speakers, allowing for real-time two-way audio communication with visitors or pets.How easy is it to install Wyze security cameras?
Wyze cameras are designed for easy installation. The Wyze Battery Cam Pro is wire-free and weatherproof, the Wyze Bulb Cam simply screws into a standard light socket, and the Wyze Cam Pan v3 offers quick Bluetooth setup and remote pan/tilt control via the Wyze app.What is the price range for Wyze security cameras?
Wyze security cameras are affordably priced: Wyze Battery Cam Pro starts at $89.98, Wyze Bulb Cam at $49.98, and Wyze Cam Pan v3 at $39.98.
