Home Monitoring Sensors for Door Openings with Wyze Hub
When it comes to securing your home and monitoring door openings efficiently, Wyze offers a comprehensive range of smart sensors designed to work seamlessly with the Wyze Sense Hub. Whether you want to detect when doors or windows open or close, or integrate these sensors into a broader home monitoring system, Wyze provides reliable, easy-to-install solutions that keep you informed and in control.
Wyze Sense Entry Sensor: Precise Door and Window Monitoring
The
Wyze Sense Entry Sensor is specifically designed to detect when doors or windows open and close, making it an essential component for home security and automation.
- Compatibility: Works exclusively with the Wyze Sense Hub and Wyze Sense v2 or Wyze Home Monitoring systems.
- Functionality: Sends instant alerts when doors or windows are opened or left open.
- Pack Options: Available in convenient 3-packs for multiple entry points.
- Installation: Wireless and easy to install with adhesive backing.
- Note: This sensor does not function as a standalone device and requires the Wyze Sense Hub.
This sensor is perfect for anyone looking to monitor entry points in real-time and enhance their home security setup.
Lifestyle image showing easy installation of Wyze entry sensors on doors and windows.
Wyze Sense Hub: The Central Brain of Your Home Monitoring System
At the heart of Wyze’s home monitoring ecosystem is the
Wyze Sense Hub, the essential device that connects all your sensors and manages alerts.
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF communication.
- Range: Covers up to 500 feet (152 meters) to sensors, ensuring wide home coverage.
- Battery Backup: Built-in rechargeable battery with up to 10 hours of backup power.
- Siren: Loud 88db siren at 2 feet to deter intruders.
- Capacity: Supports up to 100 sensors, allowing for extensive home monitoring.
- Indoor Use: Designed for indoor environments with a sleek matte finish and compact size (4.5” x 4” x 1”).
The Wyze Sense Hub is indispensable for anyone wanting a centralized, reliable system that keeps all sensors connected and alerts you instantly.
Wyze Sense Entry Sensor v2: Enhanced Door Opening Detection
For users seeking the latest in entry sensor technology, the
Wyze Sense Entry Sensor v2 offers improved performance and compatibility.
- Compatibility: Designed for use with Wyze Sense Hub v2 and Wyze Home Monitoring.
- Pack Sizes: Available in 1, 2, or 3 packs to suit your home’s needs.
- Functionality: Detects open/close status of doors and windows with high accuracy.
- Wireless: Easy to install and maintain with wireless operation.
- Ideal For: Those upgrading from previous versions or expanding their Wyze home monitoring system.
This sensor is a great choice for users who want the newest generation of Wyze entry sensors with reliable performance.
Why Choose Wyze for Door Opening Monitoring?
Wyze’s home monitoring sensors are designed to provide peace of mind with smart, connected technology that integrates effortlessly into your home. The combination of the Wyze Sense Entry Sensors and the Wyze Sense Hub creates a powerful system that alerts you immediately when doors or windows are opened, helping you protect your home and loved ones.
With support for up to 100 sensors, long battery life, and easy installation, Wyze’s solutions are perfect for homeowners, renters, and even RV owners looking for dependable security.
Wyze app control interface showcasing seamless home monitoring and sensor management.
Summary of Key Features
Product | Key Features | Price Range (USD) |
Wyze Sense Entry Sensor | Door/window open detection, requires hub | $41.98 (3 Pack) |
Wyze Sense Hub | Central hub, supports 100 sensors, siren | $45.98 |
Wyze Sense Entry Sensor v2 | Improved detection, compatible with Hub v2 | $14.99 - $41.98 |
Conclusion
For anyone searching for a
home monitoring sensor for detecting door openings with Wyze Hub, the Wyze Sense Entry Sensors paired with the Wyze Sense Hub offer a robust, scalable, and user-friendly solution. Whether you are securing your home, office, or RV, these devices provide reliable alerts and easy integration into your smart home ecosystem.
Start protecting your entry points today with Wyze’s trusted home monitoring technology.
What is the Wyze Sense Entry Sensor and how does it work for door and window monitoring?
The Wyze Sense Entry Sensor is a smart device designed to detect when doors or windows are opened or closed. It sends instant alerts to your phone via the Wyze app, helping you monitor entry points in real-time. The sensor works exclusively with the Wyze Sense Hub or Wyze Home Monitoring systems and is easy to install with adhesive backing.Do Wyze Sense Entry Sensors require a hub to function?
Yes, Wyze Sense Entry Sensors require the Wyze Sense Hub or Wyze Home Monitoring system to operate. They do not function as standalone devices and must be connected to a compatible hub for monitoring and alerts.What is the Wyze Sense Hub and why is it important for home monitoring?
The Wyze Sense Hub is the central device that connects and manages all Wyze sensors in your home monitoring system. It supports up to 100 sensors, offers multiple connectivity options (Ethernet, WiFi, Bluetooth, RF), features a loud 88db siren, and includes a 10-hour battery backup. The hub ensures all sensors communicate efficiently and alerts you instantly to any activity.How many Wyze sensors can the Wyze Sense Hub support?
The Wyze Sense Hub can support up to 100 sensors, making it ideal for monitoring multiple doors, windows, and entry points throughout your home, office, or RV.What are the differences between Wyze Sense Entry Sensor and Wyze Sense Entry Sensor v2?
The Wyze Sense Entry Sensor v2 offers improved detection accuracy and is designed for use with the Wyze Sense Hub v2 and Wyze Home Monitoring. It is available in 1, 2, or 3 packs, making it suitable for various home sizes. The original Wyze Sense Entry Sensor is compatible with the Wyze Sense Hub and Wyze Sense v2 or Wyze Home Monitoring systems, and is available in 3-packs.Is the installation of Wyze Sense Entry Sensors wireless and easy?
Yes, Wyze Sense Entry Sensors are wireless and feature adhesive backing for quick and easy installation on doors and windows. No complex wiring or tools are required.Can Wyze home monitoring sensors be used in apartments, offices, or RVs?
Absolutely. Wyze home monitoring sensors are suitable for homeowners, renters, office spaces, and RV owners. Their wireless design and easy installation make them versatile for various environments.What is the range of the Wyze Sense Hub for connecting to sensors?
The Wyze Sense Hub has a range of up to 500 feet (152 meters) to connected sensors, ensuring wide coverage for most homes and properties.Does the Wyze Sense Hub have a battery backup in case of power outages?
Yes, the Wyze Sense Hub includes a built-in rechargeable battery that provides up to 10 hours of backup power, ensuring your home monitoring system remains active during power outages.How does Wyze help with real-time door opening alerts?
Wyze Sense Entry Sensors send instant notifications to your smartphone via the Wyze app whenever a door or window is opened or left open, allowing you to respond quickly to any potential security concerns.
