Affordable Wireless Entry Sensors for Smart Indoor Security
When it comes to securing your home affordably and effectively, wireless entry sensors are a must-have. These devices alert you instantly when doors or windows are opened, providing peace of mind and enhancing your smart home security system. Below, we explore the best affordable wireless entry sensors and complementary smart security products designed for indoor use.
Wyze Sense Entry Sensor: Reliable and Budget-Friendly
Key Features
  • Wireless Entry Detection: Detects when doors or windows open or close, helping you monitor access points effortlessly.
  • Requires Wyze Sense Hub: Works seamlessly with Wyze Sense v2 or Wyze Home Monitoring systems.
  • Affordable 3-Pack: Priced at $41.98 for a pack of three sensors, making it an economical choice for multiple entry points.
  • Easy Integration: Perfect for expanding your existing Wyze smart home setup.
The Wyze Sense Entry Sensor is ideal for anyone looking to add affordable, reliable entry detection to their smart home security without breaking the bank.
Enhance Security with Wyze Sense Motion Sensor
Complementary Indoor Motion Detection
  • Motion Detection: Detects movement within a 25-foot range with a wide 120° field of view.
  • Adjustable Sensitivity: Customize detection sensitivity to reduce false alarms.
  • Long Battery Life: Up to 18 months on a single battery.
  • Simple Installation: Adhesive back or screws for secure mounting.
  • Compatibility: Requires Wyze Sense v2 or Wyze Home Monitoring hub.
Adding a motion sensor alongside entry sensors creates a layered security approach, alerting you to unexpected movement inside your home.
Wyze Cam v4: Crystal-Clear Indoor Surveillance
Advanced Indoor Camera Features
  • 2.5K QHD Resolution: Provides sharp, detailed video footage.
  • Enhanced Color Night Vision: See full-color video even in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • 24/7 Local Recording: Continuous recording with microSD card support.
  • Wi-Fi 6 Support: Faster, more reliable wireless connectivity.
  • Smart Assistant Integration: Compatible with Alexa and Google Assistant.
This camera pairs perfectly with entry sensors to visually verify alerts and monitor your indoor environment in real time. Wyze Cam v4 in Home Setting Indoor smart camera with two-way audio for interactive security
Whole Home Security Starter Kit: All-in-One Convenience
What’s Included
  • Wyze Cam v4: High-resolution indoor camera.
  • Wyze Video Doorbell v2: Monitor your front door with video and two-way audio.
  • Wyze Home Monitoring Starter Kit: Includes sensors and hub for comprehensive home security.
Benefits
  • Integrated System: Everything works together for seamless security management.
  • Affordable Bundle: Priced at $155.95, offering great value for a complete smart security setup.
  • Easy Setup: Designed for quick installation and user-friendly operation.
This starter kit is perfect if you want to combine entry sensors with cameras and doorbell monitoring for a robust indoor security solution.
Additional Wireless Camera Options for Indoor Security
Wyze Cam Pan v3
  • 360° Pan and 180° Tilt: Covers every corner of a room.
  • 1080p HD Video: Clear and smooth video quality.
  • IP65 Weather Resistant: Suitable for indoor and outdoor use.
  • Smart Tracking: Automatically follows motion for continuous monitoring.
Wyze Cam Pan v3 in Winter Outdoor Setting Versatile pan-tilt camera ideal for indoor and outdoor security
Wyze Battery Cam Pro
  • Wire-Free Operation: No hub required, fully wireless.
  • 2.5K HDR Video: High-quality video with wide 134° field of view.
  • Integrated Spotlight & Siren: Deters intruders with light and sound.
  • Long Battery Life: Up to 6 months per charge.
  • Weatherproof: IP65 rating for indoor/outdoor use.
This camera is a great addition if you want flexible placement without worrying about wiring or hubs.
Why Choose Wyze for Affordable Wireless Entry Sensors?
Wyze offers a range of smart security products that combine affordability, ease of use, and advanced technology. Their entry sensors and cameras integrate smoothly into a smart home ecosystem, providing real-time alerts, high-quality video, and smart assistant compatibility. Whether you want a simple entry sensor or a full home security kit, Wyze has options tailored to your needs.
Secure your home smartly and affordably with Wyze’s wireless entry sensors and complementary devices — peace of mind is just a sensor away.
Summary of Featured Products
Product NamePrice RangeKey FeatureWirelessIndoor Use
Wyze Sense Entry Sensor$41.98 (3-pack)Entry open/close detectionYesYes
Wyze Sense Motion Sensor$20.98 (1-pack)Motion detection with adjustable sensitivityYesYes
Wyze Cam v4From $35.982.5K QHD video, color night visionWiredYes
Whole Home Security Starter Kit$155.95Complete kit with camera & sensorsMixedYes
Wyze Cam Pan v3From $39.98360° pan/tilt, weather resistantWiredYes
Wyze Battery Cam ProFrom $89.98Wire-free, spotlight & sirenYesYes
Secure your indoor spaces with affordable, wireless entry sensors and smart cameras from Wyze — the perfect combination for modern, budget-conscious home security.
FeatureWyze Sense Entry SensorWhole Home Security Starter KitWyze Sense Motion SensorWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam Pro
TypeHome MonitoringSecurity BundleHome MonitoringCameraCameraCamera
Price$41.98 (3 Pack)$155.95$20.98 (1 Pack)$35.98 - $107.94 (varies by pack/color)$39.98 - $114.94 (varies by pack/color)$89.98 - $219.98 (varies by pack/color)
Main FunctionDetects open/closeIncludes Wyze Cam v4, Video Doorbell v2, Home MonitoringDetects motion2.5K QHD video, color night vision, spotlight1080p, 360° pan, 180° tilt, color night vision2.5K HDR video, wire-free, spotlight, siren
Requires HubYes, Wyze Sense HubNo (includes monitoring kit)Yes, Wyze Sense HubNoNoNo
Video ResolutionN/AWyze Cam v4: 2.5K QHDN/A2.5K QHD (2560x1440)1080p (1920x1080)2.5K (2560x1440)
Field of ViewN/AWyze Cam v4: DFOV 115.8°120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°120°134° DFOV, 108° HFOV, 56° VFOV
Night VisionN/AYesN/A4 IR LEDs + 2 white spotlight LEDs4 IR LEDs (850 nm)2 IR LEDs + 2 White LEDs
Motion DetectionNoYesYesYesYesRadar + PIR Motion Detection
AudioNoYes (via included devices)No2-way audio, built-in speaker & mic2-way audio, built-in speaker & mic2-way audio, built-in speaker & mic
Power SourceBattery (not specified)Wired devices includedBattery (not specified)Wired (5V/1A adapter)Wired (5V/2000mA adapter)Rechargeable battery packs
Weather ResistanceNoNoNoIP65IP65IP65
InstallationRequires Wyze Sense HubN/AAdhesive or screwsStand, wall, ceiling, magnetic mountScrew mountWall mount included
Battery LifeNot specifiedN/AUp to 18 monthsN/AN/AUp to 6 months
CompatibilityWyze Sense v2, Wyze Home MonitoringWyze ecosystemWyze Sense v2, Wyze Home MonitoringAndroid 9.0+, iOS 15.0+, Alexa, Google AssistantAndroid 9.0+, iOS 15.0+, Alexa, Google AssistantAndroid 9.0+, iOS 15.0+, Alexa, Google Assistant
StorageN/AN/AN/AmicroSD up to 512 GB, cloud subscription optionmicroSD up to 256 GBmicroSD up to 256 GB
DimensionsNot specifiedN/ANot specified2in x 2in x 2 3/8in124mm x 60mm x 63mm2.5 x 1.8 x 3.5 inches
WeightNot specifiedN/ANot specified0.49 lb (222 g)11.29 oz (320 g)0.94 lbs
WarrantyNot specifiedNot specifiedNot specified1 Year1 YearNot specified
What are wireless entry sensors and how do they improve indoor home security?Wireless entry sensors are devices that detect when doors or windows are opened or closed. They instantly alert you to any unauthorized access, providing peace of mind and enhancing your smart home security system. These sensors are easy to install and integrate seamlessly with other smart security products for comprehensive indoor protection.
What makes the Wyze Sense Entry Sensor a good choice for affordable home security?The Wyze Sense Entry Sensor is a reliable and budget-friendly option for monitoring doors and windows. It comes in a 3-pack for $41.98, making it economical for multiple entry points. The sensor requires a Wyze Sense Hub and integrates easily with Wyze smart home systems, offering effective entry detection without breaking the bank.
Do Wyze entry sensors require a hub to function?Yes, Wyze entry sensors require the Wyze Sense v2 Hub or the Wyze Home Monitoring system to operate. This ensures seamless integration with your existing Wyze smart home setup and allows for real-time alerts and monitoring.
How can I enhance my indoor security with Wyze motion sensors?Wyze Sense Motion Sensors detect movement within a 25-foot range and have a wide 120° field of view. They feature adjustable sensitivity to reduce false alarms and offer up to 18 months of battery life. Adding motion sensors alongside entry sensors creates a layered security approach, alerting you to unexpected movement inside your home.
What are the key features of the Wyze Cam v4 for indoor surveillance?The Wyze Cam v4 offers 2.5K QHD resolution for sharp video, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with microSD support, Wi-Fi 6 connectivity, and compatibility with Alexa and Google Assistant. It pairs perfectly with entry sensors to visually verify alerts and monitor your indoor environment in real time.
What is included in the Wyze Whole Home Security Starter Kit?The Wyze Whole Home Security Starter Kit includes a Wyze Cam v4 indoor camera, Wyze Video Doorbell v2, and the Wyze Home Monitoring Starter Kit with sensors and a hub. This all-in-one bundle provides integrated security management for your home at an affordable price of $155.95.
Are there wireless camera options for flexible indoor security with Wyze?Yes, Wyze offers several wireless camera options for indoor security. The Wyze Cam Pan v3 features 360° pan and 180° tilt, 1080p HD video, and is weather resistant for indoor or outdoor use. The Wyze Battery Cam Pro is fully wire-free, offers 2.5K HDR video, an integrated spotlight and siren, and up to 6 months of battery life per charge.
How do Wyze security products integrate with smart home systems?Wyze security products, including entry sensors and cameras, integrate smoothly into smart home ecosystems. They provide real-time alerts, high-quality video, and are compatible with smart assistants like Alexa and Google Assistant, making it easy to manage your home security from anywhere.
What is the price range for Wyze wireless entry sensors and cameras?Wyze wireless entry sensors are available in a 3-pack for $41.98. Motion sensors are priced at $20.98 each. Indoor cameras like the Wyze Cam v4 start from $35.98, while the Wyze Cam Pan v3 starts from $39.98. The Wyze Battery Cam Pro starts from $89.98, and the Whole Home Security Starter Kit is priced at $155.95.
Why should I choose Wyze for affordable wireless entry sensors and smart home security?Wyze offers a range of affordable, easy-to-use, and technologically advanced smart security products. Their wireless entry sensors and cameras provide real-time alerts, high-quality video, and seamless integration with smart home systems, making them ideal for budget-conscious homeowners seeking reliable indoor security solutions.
What are the key features of the Wyze Sense Entry Sensor?How does the Wyze Sense Entry Sensor integrate with other Wyze products?Are there any ongoing promotions or discounts available for Wyze products?
