Home Monitoring Cameras with Motion Tracking and Local Storage
Protecting your home has never been easier or more intelligent. If you're searching for home monitoring cameras equipped with advanced motion tracking and reliable local storage, the
Ultimate Security Bundle (13-piece) from Wyze offers a complete solution. This bundle combines multiple smart cameras with motion tracking capabilities, local storage options, and a centralized system to keep your property safe inside and out.
Ultimate Security Bundle: All-in-One Smart Home Security
The
Ultimate Security Bundle is designed to cover every angle of your home security needs. It includes a variety of cameras and sensors that work seamlessly together to provide comprehensive monitoring with smart features like motion tracking and local storage.
Wyze Cam Pan v3 (2 units)
These pan-and-tilt cameras feature intelligent motion tracking that follows movement across the room, ensuring no activity goes unnoticed. With color night vision and two-way talk, you get clear, real-time video and communication capabilities. The cameras support local storage via microSD cards, allowing you to save footage directly without relying solely on cloud services.
Wyze Cam v4 (2 units)
These plug-in cameras are perfect for both indoor and outdoor use. They offer enhanced clarity, a built-in spotlight, and smart motion detection that triggers alerts only when necessary. Local storage is supported, giving you flexible options for video recording and playback.
Wyze Battery Cam Pro (2 units)
Wire-free and versatile, these battery-powered cameras are ideal for monitoring hard-to-reach or outdoor areas. They come with advanced AI detection to reduce false alarms and color night vision for clear images in low light. Local storage is available, ensuring your footage is safely stored even without continuous power.
Wyze Cam Duo Doorbell
This smart doorbell features dual cameras for full head-to-toe and front porch visibility. It includes two-way audio and smart alerts, so you can see and speak to visitors remotely. The doorbell supports local storage, allowing you to review footage without delay.
Wyze Sense Hub
Acting as the central brain of the system, the Wyze Sense Hub connects all cameras and sensors, sending instant alerts to your phone. It supports up to 100 sensors and has a robust communication range of 500 feet, ensuring reliable coverage throughout your property.
Motion Sensor & Entry Sensors
Included sensors detect motion and monitor doors or windows opening and closing. These sensors integrate with the cameras to trigger recording and alerts, helping you respond quickly to any unusual activity.
Whether you are home or away, this bundle keeps you connected and protected through the Wyze app, making smart, reliable home security simple and affordable.
Experience seamless outdoor monitoring with Wyze Cam v4.
Enhance Your Security with Wyze Sense Accessories
To complement your home monitoring cameras, Wyze offers a range of smart sensors and control devices that integrate perfectly with the Ultimate Security Bundle.
Wyze Sense Motion Sensor
- Detects motion within a 25-foot range and 120° field of view.
- Adjustable sensitivity settings to reduce false alarms.
- Easy installation with adhesive back or screws.
- Long battery life of up to 18 months.
- Requires Wyze Sense Hub for operation.
This sensor enhances your system’s ability to detect movement and trigger camera recording or alerts instantly.
Wyze Sense Entry Sensor
- Detects when doors or windows open or close.
- Works with Wyze Sense Hub and supports multiple sensors.
- Ideal for monitoring entry points and preventing unauthorized access.
Wyze Sense Hub
- Connects all Wyze Sense sensors and cameras.
- Supports up to 100 sensors with a 500-foot RF range.
- Features an 88db siren for audible alerts.
- Includes Ethernet, WiFi, and Bluetooth connectivity.
- Built-in rechargeable battery with 10-hour backup.
The hub is essential for managing your home monitoring system, ensuring all devices communicate effectively and alerts reach you promptly.
Secure your home entry with Wyze Lock Bolt and Keypad.
Why Choose Wyze for Home Monitoring?
- Advanced Motion Tracking: Pan-and-tilt cameras follow movement intelligently, reducing blind spots.
- Local Storage Options: Save video footage directly on microSD cards for quick access and privacy.
- Comprehensive Coverage: Indoor, outdoor, wired, and wire-free cameras cover all areas.
- Smart Alerts: Receive instant notifications on your phone for motion, entry, or unusual activity.
- Expandable System: Add sensors and devices as needed, all managed through a single hub.
- Affordable and Reliable: High-end features at a budget-friendly price point.
Summary of Featured Products
Product Name | Key Features | Local Storage | Motion Tracking | Indoor/Outdoor |
Ultimate Security Bundle | 13-piece system with multiple cameras & sensors | Yes | Yes | Yes |
Wyze Sense Motion Sensor | 25 ft range, adjustable sensitivity | N/A | Yes | Indoor |
Wyze Sense Hub | Central hub, supports 100 sensors, siren | N/A | N/A | Indoor |
Wyze Sense Entry Sensor | Detects door/window open/close | N/A | N/A | Indoor |
Protect your home with the best in smart monitoring technology. The
Ultimate Security Bundle combined with Wyze Sense accessories offers a powerful, flexible, and easy-to-use system that keeps you connected and secure 24/7.
What is included in the Wyze Ultimate Security Bundle?
The Wyze Ultimate Security Bundle is a 13-piece home security system that includes 2 Wyze Cam Pan v3 cameras, 2 Wyze Cam v4 cameras, 2 Wyze Battery Cam Pro cameras, 1 Wyze Cam Duo Doorbell, 1 Wyze Sense Hub, motion sensors, and entry sensors. This bundle provides comprehensive indoor and outdoor monitoring with advanced features like motion tracking and local storage.Do Wyze home monitoring cameras support local storage?
Yes, Wyze home monitoring cameras such as the Wyze Cam Pan v3, Wyze Cam v4, Wyze Battery Cam Pro, and Wyze Cam Duo Doorbell all support local storage via microSD cards. This allows you to save and access video footage directly without relying solely on cloud services.How does motion tracking work on Wyze security cameras?
Wyze security cameras like the Wyze Cam Pan v3 feature intelligent motion tracking that automatically follows movement across the room. This ensures that any activity is captured and recorded, reducing blind spots and enhancing your home security.Can Wyze cameras be used both indoors and outdoors?
Yes, Wyze cameras such as the Wyze Cam v4 and Wyze Battery Cam Pro are designed for both indoor and outdoor use. They are weather-resistant and provide reliable monitoring in various environments.What is the Wyze Sense Hub and why is it important?
The Wyze Sense Hub acts as the central brain of your home security system. It connects all Wyze cameras and sensors, supports up to 100 sensors, and has a 500-foot communication range. The hub ensures seamless integration, instant alerts, and reliable coverage throughout your property.How do Wyze motion and entry sensors enhance home security?
Wyze motion sensors detect movement within a 25-foot range and a 120° field of view, while entry sensors monitor when doors or windows are opened or closed. These sensors integrate with your cameras to trigger recordings and send instant alerts, helping you respond quickly to any unusual activity.Is the Wyze home security system expandable?
Yes, the Wyze home security system is highly expandable. You can add more cameras, motion sensors, entry sensors, and other Wyze devices as needed, all managed through the Wyze Sense Hub and the Wyze app.How do I receive alerts from my Wyze home monitoring system?
You receive instant notifications on your smartphone through the Wyze app whenever motion is detected, a door or window is opened, or any unusual activity occurs. The system ensures you stay connected and informed whether you are home or away.What are the benefits of using Wyze home monitoring cameras with local storage?
Using Wyze cameras with local storage provides quick access to your video footage, enhances privacy by keeping recordings on-site, and ensures you can review footage even if your internet connection is interrupted.Are Wyze home security products affordable?
Yes, Wyze offers high-end features such as advanced motion tracking, local storage, and smart alerts at a budget-friendly price point, making reliable home security accessible to everyone.
