Full Room Coverage with Wyze Cam Pan v3
When it comes to securing your home or office with a camera that offers
full room coverage, the
Wyze Cam Pan v3 stands out as a top choice. Designed for both indoor and outdoor use, this camera features a
360-degree horizontal pan and
180-degree vertical tilt, ensuring no blind spots in your surveillance area. Whether you want to monitor your living room, backyard, or office space, the Wyze Cam Pan v3 delivers comprehensive coverage with smooth, fast rotation up to 110° per second.
Experience seamless control over your camera’s view with tilt and pan capabilities that let you scan every corner of the room effortlessly.
Key Features of Wyze Cam Pan v3
- 360° Horizontal Pan & 180° Vertical Tilt: Complete panoramic coverage to monitor every angle.
- 1080p Full HD Video: Crisp and clear video quality with H.264 encoding.
- Night Vision: Equipped with 4 IR LEDs (850 nm) for clear night monitoring.
- Weather Resistant (IP65 Rated): Durable polycarbonate body designed for outdoor use (with optional outdoor power adapter).
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for real-time communication.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for smart home automation.
- Storage Options: Supports up to 256 GB microSD card for local storage.
- Connectivity: Works on 2.4 GHz Wi-Fi networks (802.11 b/g/n).
Specifications at a Glance
Specification | Details |
Dimensions | 124mm (H) x 60mm (W) x 63mm (D) |
Weight | 11.29 oz (320 g) |
CPU | 1.5 GHz |
Image Sensor | 1/2.9" CMOS |
Field of View | 120° FOV |
Video FPS | Day: 20 fps, Night: 15 fps |
Digital Zoom | 8x |
Power Cable Length | 6" (1.8 m) |
Operating Temperature | -20°C to 50°C (-4°F to 122°F) |
Certifications | FCC, IC, UL, TSCA, IP65 |
Wyze Cam Pan v3 providing weather-resistant outdoor security in snowy conditions
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For users looking to enhance their security experience, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera with added value. This bundle includes a 30-day trial of Cam Plus, Wyze’s subscription service that unlocks advanced features such as person detection, package detection, and longer event video storage.
Why Choose the Bundle?
- All features of the Wyze Cam Pan v3 camera.
- Color Night Vision: See more details in low light with color night vision technology.
- Included accessories: power adapter, micro USB cable, mounting kit, and quick start guide.
- Push notifications for instant alerts on your phone.
- Compatible with Android 9.0+ and iOS 15.0+ devices.
This bundle is perfect for those who want to maximize their home security with smart alerts and enhanced video analytics.
Advanced Communication with Two-Way Audio
The Wyze Cam Pan v3 supports
two-way audio with built-in microphone and speaker, allowing you to listen and speak through the camera remotely. This feature is ideal for interacting with pets, family members, or even deterring intruders.
Communicate clearly with two-way audio on Wyze Cam Pan v3
Additional Accessories for Wyze Cam Pan v3
To customize and maintain your Wyze Cam Pan v3, consider these accessories:
- Wyze Cam Pan v3 Skins by dBrand: Stylish vinyl skins in Green Camo or Triple Black to protect your camera from scratches and personalize its look.
- Wyze Cam Pan v3 USB Cable: Replacement USB cable to keep your camera powered without interruption.
- Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera through a lamp socket without needing a dedicated outlet, perfect for flexible installation options.
Why Wyze Cam Pan v3 is the Best Choice for Full Room Coverage
The Wyze Cam Pan v3 combines
advanced pan-tilt technology,
weather resistance, and
smart home compatibility to deliver a versatile security solution. Its ability to cover 360° horizontally and 180° vertically ensures you never miss a moment, while features like two-way audio and night vision enhance its usability day and night.
Protect your home or business with a camera designed for comprehensive coverage and smart control.
What is the Wyze Cam Pan v3 and what makes it ideal for full room coverage?
The Wyze Cam Pan v3 is a security camera designed for both indoor and outdoor use, featuring a 360-degree horizontal pan and 180-degree vertical tilt. This allows it to provide complete panoramic coverage, ensuring there are no blind spots in your home or office surveillance.Can the Wyze Cam Pan v3 be used outdoors?
Yes, the Wyze Cam Pan v3 is weather resistant with an IP65 rating, making it suitable for outdoor use when paired with the optional outdoor power adapter. Its durable polycarbonate body is designed to withstand various weather conditions.What video quality does the Wyze Cam Pan v3 offer?
The Wyze Cam Pan v3 delivers crisp and clear 1080p Full HD video with H.264 encoding, ensuring high-quality footage for your security needs.Does the Wyze Cam Pan v3 have night vision?
Yes, the Wyze Cam Pan v3 is equipped with 4 IR LEDs (850 nm) for clear night vision, allowing you to monitor your property even in complete darkness. The Cam Plus bundle also offers color night vision for enhanced detail in low-light conditions.What smart home integrations are available with the Wyze Cam Pan v3?
The Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, making it easy to integrate with your existing smart home setup for automated control and monitoring.What storage options does the Wyze Cam Pan v3 support?
The Wyze Cam Pan v3 supports local storage with a microSD card of up to 256 GB, allowing you to record and store video footage directly on the device.How does the two-way audio feature work on the Wyze Cam Pan v3?
The Wyze Cam Pan v3 includes a built-in speaker and microphone with noise and echo cancellation, enabling real-time two-way communication. You can listen and speak through the camera remotely, making it ideal for interacting with family, pets, or deterring intruders.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera, a 30-day trial of Cam Plus (which unlocks advanced features like person and package detection, longer event video storage, and color night vision), a power adapter, micro USB cable, mounting kit, and a quick start guide.What are the key specifications of the Wyze Cam Pan v3?
Key specifications include: 124mm (H) x 60mm (W) x 63mm (D) dimensions, 11.29 oz (320 g) weight, 1.5 GHz CPU, 1/2.9" CMOS image sensor, 120° field of view, 20 fps (day) and 15 fps (night) video, 8x digital zoom, 6' (1.8 m) power cable, and an operating temperature range of -20°C to 50°C (-4°F to 122°F).What accessories are available for the Wyze Cam Pan v3?
Available accessories include Wyze Cam Pan v3 Skins by dBrand (in Green Camo or Triple Black), a replacement USB cable, and the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera through a lamp socket for flexible installation.Is the Wyze Cam Pan v3 compatible with both Android and iOS devices?
Yes, the Wyze Cam Pan v3 is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher, allowing you to control and monitor your camera from your smartphone.How fast can the Wyze Cam Pan v3 rotate?
The Wyze Cam Pan v3 can rotate up to 110° per second, providing smooth and fast pan and tilt capabilities for comprehensive room scanning.
