Heavy Duty 20ft Wyze Cam USB Extension Cable for Dusty Workshops
Heavy Duty 20ft USB Extension Cable for Wyze Cam in Dusty Workshops
When working in a dusty workshop, having a reliable and long extension cable for your Wyze Cam is essential to maintain clear surveillance without compromising on cable length or durability. The Wyze Cam USB Extension Cable - 20ft is designed to provide the perfect solution for extending your camera’s reach, especially in challenging environments like workshops where dust and distance can be an issue.
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach with Confidence
  • Length & Compatibility: This 20ft USB extension cable is compatible with a wide range of Wyze Cam models including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam models.
  • Durability: Built to withstand the rigors of workshop environments, this cable allows you to position your camera exactly where you need it without worrying about short cable lengths.
  • Ease of Use: Simply plug and play to extend your camera’s power and data connection, ensuring uninterrupted video streaming and power supply.
  • Affordable & Practical: At an affordable price point, this cable is a must-have accessory for anyone needing extra length in tough conditions.
Say goodbye to short cables and enjoy the freedom of a 20ft cable that keeps your Wyze Cam powered and connected even in dusty, cluttered workshop spaces.
Wyze Cam v4: The Ideal Camera for Workshop Surveillance
Pairing your extended cable with a robust camera like the Wyze Cam v4 ensures you get crystal-clear security footage in any environment.
Key Features of Wyze Cam v4
  • 2.5K QHD Resolution: Capture every detail with stunning clarity, perfect for monitoring intricate workshop activities.
  • Enhanced Color Night Vision: Even in low light or dusty conditions, the camera provides vibrant color video, making it easier to identify people and objects.
  • Weather Resistance (IP65): While primarily an indoor/outdoor camera, its weather resistance also helps it endure dusty and harsh workshop conditions.
  • Motion-Activated Spotlight & Siren: Alerts you instantly to any movement, with a built-in siren to deter intruders.
  • Wi-Fi 6 Support & Smart Home Integration: Seamlessly connects to your home network and works with Alexa, Google Assistant, and IFTTT for smart control.
  • Multiple Mounting Options: Flexible installation with stand, wall, ceiling, or magnetic mounts to fit your workshop layout.
  • Local & Cloud Storage: Supports microSD cards up to 512GB for continuous local recording, plus optional cloud storage.
Technical Specs at a Glance
FeatureSpecification
Video Resolution2.5K QHD (2560x1440)
Field of ViewDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
SensorCMOS Starlight Sensor
Night Vision4 IR LEDs + 2 white spotlight LEDs (72 lumens)
Audio99dB waterproof speaker, two-way talk
Power AdapterIndoor 5V/1A
Operating Temperature-4°F to 122°F (-20°C to 50°C)
Weight0.49 lb (222 g)
Wyze Cam v4 Outdoor Bundle: Complete Security Solution for Harsh Environments
For those who want an all-in-one package tailored for outdoor or workshop use, the Wyze Cam v4 Outdoor Bundle offers the camera plus essential accessories to maximize performance.
What’s Included?
  • Wyze Cam v4 with all the advanced features listed above
  • Wyze Outdoor Power Adapter designed for reliable power supply in outdoor or dusty workshop settings
  • Wyze MicroSD Card 128GB for extensive local video storage
Why Choose the Outdoor Bundle?
  • Enhanced Durability: The outdoor power adapter ensures stable power delivery even in dusty or damp workshop conditions.
  • 24/7 Local Recording: Never miss a moment with continuous recording capability.
  • Smart Alerts: Motion and sound detection with customizable zones to focus on critical areas in your workshop.
  • Wide Dynamic Range: Captures clear images even in challenging lighting conditions common in workshops.
This bundle is perfect for those who want a hassle-free, ready-to-go security setup that can handle the demands of a dusty workshop environment.
Summary: Best Setup for Dusty Workshop Surveillance
For a heavy-duty 20ft extension solution tailored to Wyze Cam users in dusty workshops, the Wyze Cam USB Extension Cable - 20ft is the essential accessory to extend your camera’s reach without sacrificing power or connectivity. Pair it with the Wyze Cam v4 for crystal-clear, reliable video surveillance, or opt for the Wyze Cam v4 Outdoor Bundle for a complete, ruggedized security system.
Workshop Security Setup Secure your workshop with extended reach and crystal-clear video. Wyze Cam v4 in Use Wyze Cam v4 delivering vibrant color night vision in challenging environments. Outdoor Security Bundle Complete outdoor security bundle ideal for dusty and harsh workshop conditions.
Enhance your workshop security today with the right combination of Wyze Cam products and accessories designed for durability, extended reach, and superior video quality.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Wyze Cam v4 Outdoor Bundle
TypeAccessoryCameraBundle (Camera + Accessories)
Price$7.99$35.98 (1 Pack)$69.99
Cable Length20 ft USB extension6-Foot Flat micro USB to USB-A cable included6-Foot Flat micro USB to USB-A cable included
Compatible CamerasWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoN/AN/A
ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Local RecordingN/A24/7 local recording (microSD card required)24/7 local recording (microSD card included, 128GB)
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
Compatibility with Smart AssistantsN/AAlexa, Google AssistantAlexa, Google Assistant
Motion DetectionN/AYesYes
Sound DetectionN/AYesYes
Motion Detection ZonesN/AYesYes
Smoke & CO AlertsN/AYesYes
Dynamic Range (WDR)N/AYesYes
Weather ResistanceN/AIP65IP65
Power SourceN/AWiredWired
Outdoor CompatibilityN/AYes (with outdoor power adapter sold separately)Yes
Included Items1 x 20ft USB Extension CableWyze Cam v4, Quick Start Guide, Wall Mount Plate, Tape, Screw Kit, Indoor USB Power Adapter, 6-ft USB cableWyze Cam v4, Wyze Outdoor Power Adapter, 128GB MicroSD Card
Warranty30-day hassle-free returns1 Year1 Year
Is the 20ft USB extension cable compatible with all Wyze Cam models?Yes, the 20ft USB extension cable is compatible with a wide range of Wyze Cam models, including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam models.
How durable is the Wyze Cam 20ft USB extension cable for workshop use?The Wyze Cam 20ft USB extension cable is built to withstand the rigors of dusty and harsh workshop environments, ensuring reliable power and data connection even in challenging conditions.
Can I use the Wyze Cam v4 for surveillance in a dusty workshop?Absolutely. The Wyze Cam v4 is designed with weather resistance (IP65), enhanced color night vision, and a robust build, making it ideal for clear and reliable surveillance in dusty workshop environments.
What are the key features of the Wyze Cam v4 for workshop security?The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, weather resistance (IP65), motion-activated spotlight and siren, Wi-Fi 6 support, smart home integration, multiple mounting options, and both local and cloud storage.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter for reliable power in tough environments, and a Wyze MicroSD Card 128GB for extensive local video storage.
Why should I choose the Wyze Cam v4 Outdoor Bundle for my workshop?The Wyze Cam v4 Outdoor Bundle is perfect for workshops because it offers enhanced durability, stable power delivery, 24/7 local recording, smart alerts with customizable zones, and wide dynamic range for clear images in challenging lighting.
How easy is it to install the Wyze Cam 20ft USB extension cable?Installation is simple and user-friendly. Just plug and play to extend your Wyze Cam’s power and data connection, ensuring uninterrupted video streaming and power supply.
Does the Wyze Cam v4 support local and cloud video storage?Yes, the Wyze Cam v4 supports microSD cards up to 512GB for continuous local recording and also offers optional cloud storage for added security.
What mounting options are available for the Wyze Cam v4 in a workshop?The Wyze Cam v4 offers flexible installation options, including stand, wall, ceiling, or magnetic mounts, allowing you to position the camera wherever you need in your workshop.
Is the Wyze Cam 20ft USB extension cable affordable?Yes, the Wyze Cam 20ft USB extension cable is offered at an affordable price point, making it a practical accessory for anyone needing extra cable length in tough workshop conditions.
What are the key features of the Wyze Cam v4 that make it suitable for workshop use?Can the Wyze Cam USB Extension Cable be used with all Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions available?
