Hardwired 1080p Smart Doorbells with Motion Detection & Audio
Hardwired 1080p Smart Doorbells with Motion Detection and Two-Way Audio
When it comes to securing your home entrance, a hardwired smart doorbell with crisp 1080p video, reliable motion detection alerts, and seamless two-way audio communication is essential. Whether you want to see who's at your door in real-time, speak to visitors remotely, or receive instant alerts on suspicious activity, the right doorbell can make all the difference. Below, we highlight the top Wyze products that perfectly match your needs for a hardwired 1080p smart doorbell featuring motion detection and two-way audio.
Wyze Video Doorbell v2: Wired 2K Clarity with Smart Features
Crystal-Clear Video and Local Storage
Wyze Video Doorbell v2 offers an impressive 2K video resolution, surpassing the standard 1080p for ultra-clear footage. This wired doorbell includes a local microSD card slot for continuous 24/7 recording, so you never miss a moment before or after the doorbell rings.
Motion Detection with Voice Deterrence
Receive real-time motion alerts directly to your phone. The doorbell also features motion-activated voice deterrence, which plays an automated warning to visitors detected on your porch, helping to prevent unwanted activity.
Two-Way Audio Communication
Easily talk to visitors from anywhere using the Wyze app. The two-way audio lets you answer your door remotely, whether you're at work or relaxing inside.
Easy Integration and Compatibility
  • Works with your existing home chime via the included chime controller
  • Compatible with Alexa and Google Home for voice commands and live feed viewing
  • IP65 weatherproof rating ensures durability in all weather conditions
Additional Features
  • Pre-roll motion recording captures 3-6 seconds before motion starts
  • Custom detection zones to reduce false alerts
  • Includes a 30° corner wedge kit for optimal viewing angles
Wyze Video Doorbell v2 is the perfect wired smart doorbell for those who want high-resolution video, reliable motion alerts, and two-way talk — all backed by local storage and smart home compatibility.
Wyze Video Doorbell lifestyle Experience smart home convenience with Wyze Video Doorbell v2 on your front porch.
The Front Porch Security Bundle: Complete Hardwired Doorbell & Lock Solution
All-in-One Front Porch Security
This bundle combines the Wyze Video Doorbell v2 with Wyze Lock Bolt Matte Black, giving you a comprehensive smart home entry system. View your front porch in crisp 1080p HD, talk to visitors with two-way audio, and remotely lock or unlock your door from the Wyze app.
Key Features
  • 1080p HD video doorbell with motion detection alerts
  • Two-way audio for real-time communication
  • Remote door lock control and lock history tracking
  • Integration with Wyze Lock Bolt for seamless access management
Why Choose the Bundle?
Get enhanced security and convenience by pairing your wired video doorbell with a smart lock. Control your front door from anywhere, receive alerts, and manage access all in one app.
This bundle is ideal for homeowners looking for a smart, hardwired doorbell with motion detection and two-way audio, plus the added security of a smart lock.
Wyze Video Doorbell Pro: Wired or Battery-Powered with Ultra-Wide View
Flexible Power Options and Installation
Wyze Video Doorbell Pro offers the convenience of hardwired or battery-powered installation, making it adaptable to various home setups. Installation is quick and easy, with screw or adhesive mounting options.
Superior Video and Detection
  • Crystal-clear HD video with a wider ultra-wide viewing angle
  • Smart detection alerts including person, package, vehicle, and pet detection (with Cam Plus subscription)
  • Motion-activated security light enhances night-time visibility
Two-Way Audio and Customizable Chimes
Communicate instantly with visitors using two-way audio and quick preset responses. Choose from 20 unique chime tunes with adjustable sound levels to suit your home environment.
Smart Home Integration
Works seamlessly with Alexa and Google Assistant. The included chime and Wyze Lock Bolt integration allow for a fully connected front door experience.
Wyze Video Doorbell Pro is perfect for those who want a versatile wired or wireless doorbell with advanced detection, two-way talk, and smart home compatibility.
Enhance Your Doorbell Setup with Wyze Video Doorbell v2 Wedge Kit
Perfect Viewing Angle Adjustment
The Wyze Video Doorbell v2 Wedge Kit is an essential accessory for homes with angled door frames or porches with stairs. It includes a 15° horizontal bracket and two 7.5° vertical brackets to eliminate blind spots and maximize coverage.
Weather-Resistant and Easy to Install
Made from durable plastic with weather resistance, this wedge kit ensures your doorbell stays secure and functional in all conditions. Installation is quick and straightforward.
Improve your wired doorbell’s field of view and security coverage with this simple, effective accessory.
Why Choose a Hardwired 1080p Smart Doorbell with Motion Detection and Two-Way Audio?
"A hardwired smart doorbell ensures continuous power without worrying about battery life, while 1080p or higher video resolution guarantees clear identification of visitors. Motion detection alerts keep you informed instantly, and two-way audio lets you communicate safely and conveniently from anywhere."
Wyze’s wired doorbells combine these features with smart home integration, local and cloud storage options, and weatherproof designs to provide reliable, high-quality home security.
Wyze Cam Floodlight v2 lifestyle Complement your doorbell with smart lighting and security for a safer home.
Summary of Recommended Hardwired Smart Doorbells
Product NameVideo ResolutionPower TypeMotion DetectionTwo-Way AudioSpecial Features
Wyze Video Doorbell v22K (2304x1296)HardwiredYesYesLocal microSD storage, voice deterrence
The Front Porch Security Bundle1080p HDHardwiredYesYesIncludes Wyze Lock for remote door control
Wyze Video Doorbell ProHD (1080p)Hardwired/BatteryYesYesUltra-wide view, motion-activated light
Conclusion
For a reliable, feature-rich hardwired smart doorbell with 1080p or better video, motion detection alerts, and two-way audio, Wyze offers excellent options tailored to your home security needs. Whether you want standalone doorbells or a full front porch security bundle, these products provide peace of mind and smart home convenience.
FeatureWyze Video Doorbell v2Wyze Video Doorbell ProThe Front Porch Security BundleWyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellWired or Wireless Video DoorbellBundle: Wyze Video Doorbell + Wyze LockAccessory for Doorbell v2
Video Resolution2K (2048 x 1536)HD (exact resolution not specified)1080p HDN/A
Field of View135° horizontal, 103° vertical, 166.8° diagonalUltra-wide, head-to-toe view120° vertical x 88° horizontalN/A
Local StoragemicroSD slot for 24/7 local recordingCloud storage with Cam Plus subscriptionNot specifiedN/A
Cloud Storage14-day free, Cam Plus subscription available14-day free, Cam Plus subscription availableNot specifiedN/A
Two-Way AudioYesYesYesN/A
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Not specifiedNot specifiedN/A
Night VisionColor Night Vision with Starlight sensorColor Night VisionIR Night LightN/A
Weather ResistanceIP65Not specifiedIP65Weather resistant
Power SourceWired (16V-24V AC)Wired or Battery-poweredWired (16V-24V AC)N/A
Chime CompatibilityWorks with existing chime via included controllerIncludes dual-band Wi-Fi Extender chimeIncludes Wyze ChimeN/A
InstallationWired, requires wiringWired or wireless, install in 30 secondsWiredQuick installation
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantN/A
Additional FeaturesPre-roll motion recording (3-6 sec), AI detections with Cam Plus, 30° corner kit includedMotion-activated security light, quick responses, unlock Wyze Lock Bolt integrationLock/unlock door remotely, view lock historyAdjusts viewing angle for Doorbell v2
Included ItemsDoorbell + Chime ControllerDoorbell Pro + Chime (sold out)Wyze Lock, Wyze Lock Gateway, Wyze Video Doorbell, Wyze Chime, mounting accessories1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, screws, guide
Price$44.98$99.98 (sold out)From $123.99 to $173.97 depending on variant$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)
Warranty1 YearNot specifiedNot specified1 Year
What are the benefits of a hardwired 1080p smart doorbell with motion detection and two-way audio?A hardwired 1080p smart doorbell provides continuous power, eliminating battery concerns, and delivers clear video for easy visitor identification. Motion detection alerts keep you instantly informed of activity at your door, while two-way audio allows you to communicate with visitors remotely and safely. These features enhance home security and convenience.
Which Wyze doorbell models offer hardwired installation and 1080p or higher video resolution?Wyze offers several hardwired doorbell options: Wyze Video Doorbell v2 (2K resolution), The Front Porch Security Bundle (includes a 1080p HD doorbell), and Wyze Video Doorbell Pro (HD 1080p, with both hardwired and battery-powered options). All models feature motion detection and two-way audio.
Does the Wyze Video Doorbell v2 support local video storage?Yes, the Wyze Video Doorbell v2 includes a local microSD card slot for continuous 24/7 recording, ensuring you never miss important footage before or after the doorbell rings.
How does motion detection work on Wyze smart doorbells?Wyze smart doorbells use advanced motion sensors to detect activity at your front door. You receive real-time alerts on your phone, and features like custom detection zones and pre-roll recording help reduce false alerts and capture important moments.
Can I talk to visitors remotely using Wyze doorbells?Yes, all featured Wyze doorbells offer two-way audio, allowing you to speak with visitors in real-time through the Wyze app, no matter where you are.
Are Wyze doorbells compatible with smart home systems?Wyze doorbells are compatible with Alexa and Google Home, enabling voice commands and live video feed viewing for seamless smart home integration.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes the Wyze Video Doorbell v2 and the Wyze Lock Bolt Matte Black. This combination provides 1080p HD video, motion detection, two-way audio, and remote door lock control for comprehensive front porch security.
Can I adjust the viewing angle of my Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 Wedge Kit allows you to adjust the viewing angle with a 15° horizontal bracket and two 7.5° vertical brackets, helping eliminate blind spots and maximize coverage.
Is the Wyze Video Doorbell Pro suitable for both wired and wireless installation?Yes, the Wyze Video Doorbell Pro offers flexible installation options, supporting both hardwired and battery-powered setups to fit various home requirements.
What special features do Wyze doorbells offer for enhanced security?Wyze doorbells offer features such as motion-activated voice deterrence, pre-roll motion recording, customizable detection zones, ultra-wide viewing angles, motion-activated security lights, and integration with Wyze Lock Bolt for remote access management.
Are Wyze doorbells weatherproof?Yes, Wyze doorbells, including the Video Doorbell v2, have an IP65 weatherproof rating, ensuring reliable performance in all weather conditions.
What are the key features of the Wyze Video Doorbell v2?Can the Wyze Video Doorbell v2 be integrated with smart home systems like Alexa or Google Home?Are there any ongoing sales or discounts for the Wyze Video Doorbell v2?
